js-controller 3.0/3.1 jetzt im Latest!
Ich habe es jetzt nochmal aus dem Verzeichnis /opt/iobroker heraus versucht. So sieht's aus:
pi@raspberrypi4:/opt/iobroker $ cd /opt/iobroker pi@raspberrypi4:/opt/iobroker $ iobroker stop pi@raspberrypi4:/opt/iobroker $ iobroker upgrade self Update js-controller from @2.2.9 to @3.1.4 NPM version: 6.14.4 npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call) Package pangocairo was not found in the pkg-config search path. Perhaps you should add the directory containing `pangocairo.pc' to the PKG_CONFIG_PATH environment variable No package 'pangocairo' found gyp: Call to 'pkg-config pangocairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1 gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16) gyp ERR! stack at ChildProcess.emit (events.js:198:13) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12) gyp ERR! System Linux 4.19.97-v7l+ gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64" gyp ERR! cwd /opt/iobroker/node_modules/canvas gyp ERR! node -v v10.20.1 gyp ERR! node-gyp -v v5.1.0 gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1) node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29) node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13) node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16) node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5) node-pre-gyp ERR! System Linux 4.19.97-v7l+ node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas node-pre-gyp ERR! node -v v10.20.1 node-pre-gyp ERR! node-pre-gyp -v v0.11.0 node-pre-gyp ERR! not ok npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the canvas@2.6.1 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-05-16T14_56_08_759Z-debug.log Starting node restart.js pi@raspberrypi4:/opt/iobroker $ iobroker start pi@raspberrypi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.4 > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram > node-gyp rebuild make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o In file included from ../src/unix_dgram.cc:5: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ In file included from ../../nan/nan.h:54, from ../src/unix_dgram.cc:5: ../src/unix_dgram.cc: At global scope: /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~ In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/unix_dgram.cc:5: /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’: /home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78: required from here /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’: ../../nan/nan_object_wrap.h:65:61: required from here /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] SOLINK_MODULE(target) Release/obj.target/unix_dgram.node COPY Release/unix_dgram.node make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional > node rebuild.js > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage > node-gyp rebuild make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten CXX(target) Release/obj.target/diskusage/src/main.o In file included from ../src/main.cpp:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ In file included from ../../nan/nan.h:54, from ../src/main.cpp:3: ../src/main.cpp: At global scope: /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(diskusage, Init) ^~~~~~~~~~~ In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/main.cpp:3: /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’: /home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78: required from here /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’: ../../nan/nan_object_wrap.h:65:61: required from here /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o SOLINK_MODULE(target) Release/obj.target/diskusage.node COPY Release/diskusage.node make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object 0_userdata.0.example_state created The following notifications happened during sync: - Ignoring Directory "bshb.admin" because officially not created as meta object. Please remove directory! - Ignoring Directory "fritzdect.admin" because officially not created as meta object. Please remove directory! - Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory! > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2 > node scripts/postinstall Greenlock and ACME.js v3 are on the way! Watch for updates at https://indiegogo.com/at/greenlock npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + iobroker.js-controller@2.2.9 added 126 packages from 148 contributors and removed 1 package in 54.635s 41 packages are looking for funding run `npm fund` for details pi@raspberrypi4:/opt/iobroker $ iobroker startAber danach bin ich wieder auf Version 2.2.9.
@Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
ls -la ~
pi@raspberrypi4:~ $ ls -la ~ insgesamt 96948 drwxr-xr-x 20 pi pi 4096 Mai 16 15:56 . drwxr-xr-x 4 root root 4096 Mär 20 10:28 .. -rw------- 1 pi pi 4696 Mai 16 17:02 .bash_history -rw-r--r-- 1 pi pi 220 Feb 13 16:55 .bash_logout -rw-r--r-- 1 pi pi 3633 Mai 16 13:27 .bashrc drwxr-xr-x 8 pi pi 4096 Mär 20 10:29 .cache drwx------ 9 pi pi 4096 Mai 1 09:20 .config drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Desktop drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Documents drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Downloads drwx------ 3 pi pi 4096 Feb 13 17:16 .gnupg -rw-r--r-- 1 pi pi 35583874 Mär 20 15:21 grafana_6.7.1_armhf.deb -rw-r--r-- 1 pi pi 63480656 Feb 7 08:29 influxdb_1.7.10_amd64.deb -rw-r--r-- 1 pi pi 169 Mär 22 16:01 .influx_history drwxr-xr-x 2 pi pi 4096 Mär 20 10:30 .iobroker drwxr-xr-x 3 pi pi 4096 Feb 13 17:03 .local drwxr-xr-x 2 pi pi 4096 Feb 13 17:03 MagPi drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Music drwxr-xr-x 144 pi pi 4096 Mai 9 10:13 node_modules drwxr-xr-x 5 pi pi 4096 Mai 9 10:13 .npm -rw------- 1 pi pi 36 Mär 20 10:28 .npmrc -rw-r--r-- 1 pi pi 45978 Mai 9 10:13 package-lock.json drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Pictures drwx------ 3 pi pi 4096 Mär 18 20:52 .pki -rw-r--r-- 1 pi pi 807 Feb 13 16:55 .profile drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Public drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Templates drwxr-xr-t 2 pi pi 4096 Mär 18 18:22 thinclient_drives drwxr-xr-x 2 pi pi 4096 Mär 18 18:22 Videos -rw------- 1 pi pi 172 Mai 9 09:49 .Xauthority -rw-r--r-- 1 pi pi 15717 Mai 1 10:54 .xorgxrdp.10.log -rw-r--r-- 1 pi pi 15531 Mai 1 10:30 .xorgxrdp.10.log.old -rw------- 1 pi pi 2499 Mai 1 11:46 .xsession-errors -rw------- 1 pi pi 2499 Mai 1 11:07 .xsession-errors.old@Svenson6 Ach du je... Wo anfangen...
sudo apt update sudo apt dist-upgrade sudo apt install libpango1.0-dev build-essential -
pi@raspberrypi4:~ $ sudo apt update OK:1 http://archive.raspberrypi.org/debian buster InRelease Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] OK:3 https://repos.influxdata.com/debian buster InRelease OK:4 https://deb.nodesource.com/node_10.x buster InRelease Es wurden 15,0 kB in 1 s geholt (10,9 kB/s). Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. pi@raspberrypi4:~ $ sudo apt dist-upgrade Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Fertig Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: libmicrodns0 Verwenden Sie »sudo apt autoremove«, um es zu entfernen. Die folgenden NEUEN Pakete werden installiert: libfl2 Die folgenden Pakete werden aktualisiert (Upgrade): binutils binutils-arm-linux-gnueabihf binutils-common libbinutils 4 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 1.871 kB von 4.350 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 143 kB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf binutils-arm-linux-gnueabihf armhf 2.31.1-16+rpi2 [1.814 kB] Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf binutils armhf 2.31.1-16+rpi2 [57,0 kB] Es wurden 1.871 kB in 1 s geholt (2.897 kB/s). Changelogs werden gelesen... Fertig (Lese Datenbank ... 105461 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../binutils-arm-linux-gnueabihf_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils-arm-linux-gnueabihf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../libbinutils_2.31.1-16+rpi2_armhf.deb ... Entpacken von libbinutils:armhf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../binutils_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../binutils-common_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils-common:armhf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vormals nicht ausgewähltes Paket libfl2:armhf wird gewählt. Vorbereitung zum Entpacken von .../libfl2_2.6.4-6.2_armhf.deb ... Entpacken von libfl2:armhf (2.6.4-6.2) ... binutils-common:armhf (2.31.1-16+rpi2) wird eingerichtet ... libfl2:armhf (2.6.4-6.2) wird eingerichtet ... libbinutils:armhf (2.31.1-16+rpi2) wird eingerichtet ... binutils-arm-linux-gnueabihf (2.31.1-16+rpi2) wird eingerichtet ... binutils (2.31.1-16+rpi2) wird eingerichtet ... Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ... Trigger für man-db (2.8.5-2) werden verarbeitet ... pi@raspberrypi4:~ $ sudo apt install libpango1.0-dev build-essential Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig build-essential ist schon die neueste Version (12.6). Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: libmicrodns0 Verwenden Sie »sudo apt autoremove«, um es zu entfernen. Die folgenden zusätzlichen Pakete werden installiert: gir1.2-harfbuzz-0.0 icu-devtools libfribidi-dev libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libicu-dev libxft-dev pango1.0-tools Vorgeschlagene Pakete: libgraphite2-utils icu-doc imagemagick libpango1.0-doc Die folgenden NEUEN Pakete werden installiert: gir1.2-harfbuzz-0.0 icu-devtools libfribidi-dev libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libicu-dev libpango1.0-dev libxft-dev pango1.0-tools 0 aktualisiert, 10 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 9.197 kB von 12,3 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 47,1 MB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf icu-devtools armhf 63.1-6+deb10u1 [163 kB] Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libicu-dev armhf 63.1-6+deb10u1 [8.841 kB] Holen:3 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf pango1.0-tools armhf 1.42.4-8~deb10u1 [53,5 kB] Holen:4 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libpango1.0-dev armhf 1.42.4-8~deb10u1 [139 kB] Es wurden 9.197 kB in 1 s geholt (8.135 kB/s). Vormals nicht ausgewähltes Paket libharfbuzz-gobject0:armhf wird gewählt. (Lese Datenbank ... 105469 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../0-libharfbuzz-gobject0_2.3.1-1_armhf.deb ... Entpacken von libharfbuzz-gobject0:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket gir1.2-harfbuzz-0.0:armhf wird gewählt. Vorbereitung zum Entpacken von .../1-gir1.2-harfbuzz-0.0_2.3.1-1_armhf.deb ... Entpacken von gir1.2-harfbuzz-0.0:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket icu-devtools wird gewählt. Vorbereitung zum Entpacken von .../2-icu-devtools_63.1-6+deb10u1_armhf.deb ... Entpacken von icu-devtools (63.1-6+deb10u1) ... Vormals nicht ausgewähltes Paket libfribidi-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../3-libfribidi-dev_1.0.5-3.1+deb10u1_armhf.deb ... Entpacken von libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ... Vormals nicht ausgewähltes Paket libgraphite2-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../4-libgraphite2-dev_1.3.13-7_armhf.deb ... Entpacken von libgraphite2-dev:armhf (1.3.13-7) ... Vormals nicht ausgewähltes Paket libicu-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../5-libicu-dev_63.1-6+deb10u1_armhf.deb ... Entpacken von libicu-dev:armhf (63.1-6+deb10u1) ... Vormals nicht ausgewähltes Paket libharfbuzz-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../6-libharfbuzz-dev_2.3.1-1_armhf.deb ... Entpacken von libharfbuzz-dev:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket libxft-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../7-libxft-dev_2.3.2-2_armhf.deb ... Entpacken von libxft-dev:armhf (2.3.2-2) ... Vormals nicht ausgewähltes Paket pango1.0-tools wird gewählt. Vorbereitung zum Entpacken von .../8-pango1.0-tools_1.42.4-8~deb10u1_armhf.deb ... Entpacken von pango1.0-tools (1.42.4-8~deb10u1) ... Vormals nicht ausgewähltes Paket libpango1.0-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../9-libpango1.0-dev_1.42.4-8~deb10u1_armhf.deb ... Entpacken von libpango1.0-dev:armhf (1.42.4-8~deb10u1) ... libfribidi-dev:armhf (1.0.5-3.1+deb10u1) wird eingerichtet ... pango1.0-tools (1.42.4-8~deb10u1) wird eingerichtet ... libharfbuzz-gobject0:armhf (2.3.1-1) wird eingerichtet ... gir1.2-harfbuzz-0.0:armhf (2.3.1-1) wird eingerichtet ... libgraphite2-dev:armhf (1.3.13-7) wird eingerichtet ... icu-devtools (63.1-6+deb10u1) wird eingerichtet ... libicu-dev:armhf (63.1-6+deb10u1) wird eingerichtet ... libxft-dev:armhf (2.3.2-2) wird eingerichtet ... libharfbuzz-dev:armhf (2.3.1-1) wird eingerichtet ... libpango1.0-dev:armhf (1.42.4-8~deb10u1) wird eingerichtet ... Trigger für man-db (2.8.5-2) werden verarbeitet ... Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ... pi@raspberrypi4:~ $ -
pi@raspberrypi4:~ $ sudo apt update OK:1 http://archive.raspberrypi.org/debian buster InRelease Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] OK:3 https://repos.influxdata.com/debian buster InRelease OK:4 https://deb.nodesource.com/node_10.x buster InRelease Es wurden 15,0 kB in 1 s geholt (10,9 kB/s). Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. pi@raspberrypi4:~ $ sudo apt dist-upgrade Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Fertig Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: libmicrodns0 Verwenden Sie »sudo apt autoremove«, um es zu entfernen. Die folgenden NEUEN Pakete werden installiert: libfl2 Die folgenden Pakete werden aktualisiert (Upgrade): binutils binutils-arm-linux-gnueabihf binutils-common libbinutils 4 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 1.871 kB von 4.350 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 143 kB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf binutils-arm-linux-gnueabihf armhf 2.31.1-16+rpi2 [1.814 kB] Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf binutils armhf 2.31.1-16+rpi2 [57,0 kB] Es wurden 1.871 kB in 1 s geholt (2.897 kB/s). Changelogs werden gelesen... Fertig (Lese Datenbank ... 105461 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../binutils-arm-linux-gnueabihf_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils-arm-linux-gnueabihf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../libbinutils_2.31.1-16+rpi2_armhf.deb ... Entpacken von libbinutils:armhf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../binutils_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vorbereitung zum Entpacken von .../binutils-common_2.31.1-16+rpi2_armhf.deb ... Entpacken von binutils-common:armhf (2.31.1-16+rpi2) über (2.31.1-16+rpi1) ... Vormals nicht ausgewähltes Paket libfl2:armhf wird gewählt. Vorbereitung zum Entpacken von .../libfl2_2.6.4-6.2_armhf.deb ... Entpacken von libfl2:armhf (2.6.4-6.2) ... binutils-common:armhf (2.31.1-16+rpi2) wird eingerichtet ... libfl2:armhf (2.6.4-6.2) wird eingerichtet ... libbinutils:armhf (2.31.1-16+rpi2) wird eingerichtet ... binutils-arm-linux-gnueabihf (2.31.1-16+rpi2) wird eingerichtet ... binutils (2.31.1-16+rpi2) wird eingerichtet ... Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ... Trigger für man-db (2.8.5-2) werden verarbeitet ... pi@raspberrypi4:~ $ sudo apt install libpango1.0-dev build-essential Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig build-essential ist schon die neueste Version (12.6). Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: libmicrodns0 Verwenden Sie »sudo apt autoremove«, um es zu entfernen. Die folgenden zusätzlichen Pakete werden installiert: gir1.2-harfbuzz-0.0 icu-devtools libfribidi-dev libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libicu-dev libxft-dev pango1.0-tools Vorgeschlagene Pakete: libgraphite2-utils icu-doc imagemagick libpango1.0-doc Die folgenden NEUEN Pakete werden installiert: gir1.2-harfbuzz-0.0 icu-devtools libfribidi-dev libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libicu-dev libpango1.0-dev libxft-dev pango1.0-tools 0 aktualisiert, 10 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 9.197 kB von 12,3 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 47,1 MB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf icu-devtools armhf 63.1-6+deb10u1 [163 kB] Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libicu-dev armhf 63.1-6+deb10u1 [8.841 kB] Holen:3 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf pango1.0-tools armhf 1.42.4-8~deb10u1 [53,5 kB] Holen:4 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf libpango1.0-dev armhf 1.42.4-8~deb10u1 [139 kB] Es wurden 9.197 kB in 1 s geholt (8.135 kB/s). Vormals nicht ausgewähltes Paket libharfbuzz-gobject0:armhf wird gewählt. (Lese Datenbank ... 105469 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../0-libharfbuzz-gobject0_2.3.1-1_armhf.deb ... Entpacken von libharfbuzz-gobject0:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket gir1.2-harfbuzz-0.0:armhf wird gewählt. Vorbereitung zum Entpacken von .../1-gir1.2-harfbuzz-0.0_2.3.1-1_armhf.deb ... Entpacken von gir1.2-harfbuzz-0.0:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket icu-devtools wird gewählt. Vorbereitung zum Entpacken von .../2-icu-devtools_63.1-6+deb10u1_armhf.deb ... Entpacken von icu-devtools (63.1-6+deb10u1) ... Vormals nicht ausgewähltes Paket libfribidi-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../3-libfribidi-dev_1.0.5-3.1+deb10u1_armhf.deb ... Entpacken von libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ... Vormals nicht ausgewähltes Paket libgraphite2-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../4-libgraphite2-dev_1.3.13-7_armhf.deb ... Entpacken von libgraphite2-dev:armhf (1.3.13-7) ... Vormals nicht ausgewähltes Paket libicu-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../5-libicu-dev_63.1-6+deb10u1_armhf.deb ... Entpacken von libicu-dev:armhf (63.1-6+deb10u1) ... Vormals nicht ausgewähltes Paket libharfbuzz-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../6-libharfbuzz-dev_2.3.1-1_armhf.deb ... Entpacken von libharfbuzz-dev:armhf (2.3.1-1) ... Vormals nicht ausgewähltes Paket libxft-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../7-libxft-dev_2.3.2-2_armhf.deb ... Entpacken von libxft-dev:armhf (2.3.2-2) ... Vormals nicht ausgewähltes Paket pango1.0-tools wird gewählt. Vorbereitung zum Entpacken von .../8-pango1.0-tools_1.42.4-8~deb10u1_armhf.deb ... Entpacken von pango1.0-tools (1.42.4-8~deb10u1) ... Vormals nicht ausgewähltes Paket libpango1.0-dev:armhf wird gewählt. Vorbereitung zum Entpacken von .../9-libpango1.0-dev_1.42.4-8~deb10u1_armhf.deb ... Entpacken von libpango1.0-dev:armhf (1.42.4-8~deb10u1) ... libfribidi-dev:armhf (1.0.5-3.1+deb10u1) wird eingerichtet ... pango1.0-tools (1.42.4-8~deb10u1) wird eingerichtet ... libharfbuzz-gobject0:armhf (2.3.1-1) wird eingerichtet ... gir1.2-harfbuzz-0.0:armhf (2.3.1-1) wird eingerichtet ... libgraphite2-dev:armhf (1.3.13-7) wird eingerichtet ... icu-devtools (63.1-6+deb10u1) wird eingerichtet ... libicu-dev:armhf (63.1-6+deb10u1) wird eingerichtet ... libxft-dev:armhf (2.3.2-2) wird eingerichtet ... libharfbuzz-dev:armhf (2.3.1-1) wird eingerichtet ... libpango1.0-dev:armhf (1.42.4-8~deb10u1) wird eingerichtet ... Trigger für man-db (2.8.5-2) werden verarbeitet ... Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ... pi@raspberrypi4:~ $@Svenson6 Am besten mal rebooten. Da waren die binutils dabei, das ist sehr systemnah.
@Svenson6 Vielleicht auch besser in einem eigenen Thread weitermachen. Das hat mit dem Thema hier nichts zu tun.
@Svenson6 Du hast ja einiges durcheinander!
Ich würde an deiner Stelle von neu Anfangen! Raspi komplett neu installieren. Und dann alles richtig von Anfang an machen! Sonst würde ich sagen wirst du immer wieder Probleme haben.Das hatte ich auch schon befürchtet, aaaber! Das hier von @Thomas-Braun scheint's echt gebracht zu haben:
sudo apt update sudo apt dist-upgrade sudo apt install libpango1.0-dev build-essentialDer Laden läuft wieder. js-controller ist auf Version 3.1.4, und die Updates für die Adapter können auch wieder installiert werden. Ich bin begeistert und bedanke mich mit einer Verbeugung für die Hilfe - Ihr seid super!
Noch ein schönes Wochenende wünscht
Sven -
Sven -
@Thomas-Braun Alles klar, habe ich gemacht, lief auch erfolgreich durch. Vielen Dank nochmal!
@apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
@Steff Also controller wieder auf 3.1.4? :-)
Habe nun die 3.1.4 draufgebügelt, läuft jetzt einwandfrei. Mirroring geht auch wieder.
Danke nochmals!
@apollon77
Ja, gerne.
In das Verzeichnis : /opt/iobroker/iobroker-data/files/ wechseln.
Hier die Verzeichnisse anlegen, die im Logfile mit einer warn-Meldung aufgelistet sind.
Bei mir war das :
mkdir admin.0 mkdir web.0 und mkdir 0_userdata.0Beim nächsten Backup über backitup tauchen diese Fehlermeldungen dann nicht mehr auf.
@karlo-enzo sagte in js-controller 3.0/3.1 jetzt im Latest!:
@apollon77
Ergänzung: Da ich den Enigma2-Adapter laufen habe musste ich obiges zusätzlich mit dem Verzeichnis enigma2.0 machen.
Gruß Steffen
@apollon77
Gruß Steffen
@Steff
bei mir wird admin.1 an gemeckert, wobei ich gar keine Instanz admin.1 habe. Die hatte ich mal vor langer zeit angelegt und wieder gelöscht.
Wo bekommt IOBroker die Info her und warum wird das beanstandet?host.Beelink 2020-05-17 10:34:43.848 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=iqontrol.meta: Not exists host.Beelink 2020-05-17 10:34:43.848 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=enigma2.0: Not exists host.Beelink 2020-05-17 10:34:43.844 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=admin.1: Not exists -
@Steff
@Steff
Ja nur wo soll das liegen und warum meckert er dann auch noch das an iqontrol.meta? Das ist nun das einzige meta Verzeichnis unter /opt/iobroker/iobroker-data/files das ich jetzt manuell angelegt habe. Jetzt sind keine Meldungen mehr im Log, wobei ich das ganze nicht wirklich verstehe. -
@Jan1,
hmm, und unter Objekte --> Expertenmodus ist kein Meta-Objekt Namens admin.1 auffindbar? -
@Steff
nein, nichts dabei. Wobei es eh nur Warnungen sind und die jetzt mit den angelegten Verzeichnissen auch weg sind. Verstehen würde ich es trotzdem gerne. -
@Jan1,
sehr komisch.
Bin da jetzt aber auch raus, bei mir war glücklicherweise nach dem Anlegen der Verzeichnisse das Log wieder sauber. -
@Steff
Wo bekommt IOBroker die Info her und warum wird das beanstandet?host.Beelink 2020-05-17 10:34:43.848 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=iqontrol.meta: Not exists host.Beelink 2020-05-17 10:34:43.848 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=enigma2.0: Not exists host.Beelink 2020-05-17 10:34:43.844 warn Objects 127.0.0.1:59028 Error from InMemDB: Error: ERROR readDir id=admin.1: Not exists@Jan1 Damit die .1 Instanz Warnungen nicht mehr kommen musst du die meta Objekte in der Objektansicht in ioBroker löschen. Also nichts im Dateisystem anlegen oder löschen.
In der Objektansicht auf Expertenmodus schalten und in der linken Spalte einfach mal admin.1 eingeben, dann filtert er genau auf das. Gleiches für iqontrol.1.
Bei den Adaptern wo die Instanz existiert legt man wiederum wie hier schon geschrieben das Verzeichnis im Dateisystem an.
