  4. neu installierter ioBroker über Browser nicht erreichbar
browserjs controller update
62 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
    @C3PO
    Als loxberry
    groups
    C3PO
    @Thomas-Braun
    loxberry@loxberry:~ $ groups
    loxberry tty dialout sudo audio www-data gpio
    • C C3PO
      @Thomas-Braun
      @C3PO Dann klemmen die den user noch irgendwo anders ab.
      Soll mir jetzt auch egal sein...
      iobroker status
      C 1 Antwort Letzte Antwort
        iobroker status
        C3PO
        @Thomas-Braun
         iobroker status
        Socket.io Server detected. Please update to js-controller 2.0 or higher!
        No iobroker host is running.
        Objects type: file
        States  type: file
        • C C3PO
          @Thomas-Braun
           iobroker status
          Objects type: file
          States  type: file
          @C3PO
          Keine Ahnung wie die 'Kollegen' von LoxBerry da im System rumfuhrwerken.
          Sieht auf jedenfalls für mich äußerst schräg aus.
          In /opt/iobroker
          npm install iobroker.js-controller
            @C3PO
            In /opt/iobroker
            C3PO
            @Thomas-Braun
            root@loxberry:/opt/iobroker# npm install iobroker.js-controller
            > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.4
            > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + iobroker.js-controller@2.2.9
            updated 1 package in 32.054s
            3 packages are looking for funding
              run `npm fund` for details
            • C C3PO
              @Thomas-Braun
              NPM version: 6.14.4
              @C3PO Stop mal den LoxBerry Server Kram auf der Kiste.
              Als root
              netstat -tulpen | grep -v 127.0.0.1
                Als root
                C3PO
                schrieb am zuletzt editiert von C3PO
                @Thomas-Braun
                root@loxberry:/# netstat -tulpen | grep -v 127.0.0.1
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18602      1081/java
                tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      0          14524      718/mosquitto
                tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16342      1174/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17422      736/sshd
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          14530      718/mosquitto
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          17692      835/smbd
                tcp        1      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      0          14527      718/mosquitto
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          17693      835/smbd
                tcp6       0      0 :::81                   :::*                    LISTEN      0          14553      824/apache2
                tcp6       0      0 :::6066                 :::*                    LISTEN      0          14559      824/apache2
                tcp6       0      0 :::8883                 :::*                    LISTEN      0          14525      718/mosquitto
                tcp6       0      0 :::53                   :::*                    LISTEN      0          16344      1174/dnsmasq
                tcp6       0      0 :::22                   :::*                    LISTEN      0          17424      736/sshd
                tcp6       0      0 :::1883                 :::*                    LISTEN      0          14531      718/mosquitto
                tcp6       0      0 :::445                  :::*                    LISTEN      0          17690      835/smbd
                tcp6       0      0 :::139                  :::*                    LISTEN      0          17691      835/smbd
                udp        0      0 0.0.0.0:50000           0.0.0.0:*                           0          17971      1081/java
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          17976      1081/java
                udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16341      1174/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13093      526/dhclient
                udp        0      0 0.0.0.0:11884           0.0.0.0:*                           1001       17871      1074/perl
                udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          15597      712/nmbd
                udp        0      0 192.168.1.57:137        0.0.0.0:*                           0          15596      712/nmbd
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15586      712/nmbd
                udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          15599      712/nmbd
                udp        0      0 192.168.1.57:138        0.0.0.0:*                           0          15598      712/nmbd
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15587      712/nmbd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          19641      1081/java
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13472      167/avahi-daemon: r
                udp        0      0 0.0.0.0:56045           0.0.0.0:*                           108        13474      167/avahi-daemon: r
                udp6       0      0 :::42310                :::*                                108        13475      167/avahi-daemon: r
                udp6       0      0 :::53                   :::*                                0          16343      1174/dnsmasq
                udp6       0      0 :::5353                 :::*                                108        13473      167/avahi-daemon: r
                Ich glaub ein zweiter raspberry für ioBroker wäre einfacher
                • C C3PO
                  @Thomas-Braun
                  @C3PO sagte in neu installierter ioBroker über Browser nicht erreichbar:
                  Der Port 9001 ist bei dir schon von mosquitto blockiert. Da läuft beim iobroker das:
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16990      704/iobroker.js-con
                  Thomas BraunT C 2 Antworten Letzte Antwort
                    @Thomas-Braun
                      C3PO
                      @Thomas-Braun
                      kann man das beim ioBroker über die console ändern?
                      • C C3PO
                        @Thomas-Braun
                        @C3PO Da laufen die db vom broker drauf. Ich vermute, da schauen ziemlich viele Adapter nach. Ob und wie man die Ports umbiegen kann weiß ich nicht. Kann vielleicht @apollon77 was zu sagen. Da sind meine Kenntnisse am Ende.
                        C apollon77A 2 Antworten Letzte Antwort
                          C3PO
                          @Thomas-Braun
                          ok, dann nochmal vielen Dank für dein Mühen.
                          Thomas BraunT harrymH 2 Antworten Letzte Antwort
                          • C C3PO
                            @Thomas-Braun
                            @C3PO
                            Du kannst den mosquitto auch mal stoppen
                            service mosquitto stop
                            oder
                            systemctl stop mosquitto.service
                            Dann
                            iobroker restart
                            Mich würde aber doch noch interessieren, wo der sudo kastriert wurde:
                            ls -la /usr/bin/sudo
                            • C C3PO
                              @Thomas-Braun
                              harrymH Offline
                              harrymH Offline
                              harrym
                              schrieb am zuletzt editiert von harrym
                              @C3PO ind der config vom mosquitto kannst du einen beliebigen port vergeben .....
                              https://mosquitto.org/man/mosquitto-conf-5.html
                              ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                @Thomas-Braun iobroker setup custom ... da kann der port angegeben werden
                                  @C3PO
                                  oder
                                  Dann
                                  iobroker restart
                                  C3PO
                                  @Thomas-Braun
                                  sieht so aus:
                                  loxberry@loxberry:~ $ ls -la /usr/bin/sudo
                                  -rwsr-xr-x 1 root root 147560 Feb  2 08:41 /usr/bin/sudo
                                  • apollon77A apollon77
                                    C3PO
                                    @apollon77
                                    Es war der Port :-)
                                    hab jetzt 9001 zu 9101 und 9000 zu 9100 gemacht.
                                    Sind die ports in Adaptern hart kodiert?
                                    auf den iobroker komm ich jetzt :-)
                                    Vielen Dank.
                                    • C C3PO
                                      @apollon77
                                      Es war der Port :-)
                                      Vielen Dank.
                                      @C3PO alle Adapter nutzen diese zentrale konfig. Sollte also tun
