  4. neu installierter ioBroker über Browser nicht erreichbar
browserjs controller update
62 Beiträge 4 Kommentatoren 8.9k Aufrufe 4 Beobachtet
  • C C3PO
    @Thomas-Braun
    root@loxberry:~# usermod -aG sudo loxberry
    root@loxberry:~# exit
    logout
    loxberry@loxberry:~ $ sudo nodejs -v
    [sudo] password for loxberry:
    Sorry, user loxberry is not allowed to execute '/usr/bin/nodejs -v' as root on loxberry.
    @C3PO
    Als loxberry
    groups
    C 1 Antwort Letzte Antwort
      @C3PO
      Als loxberry
      groups
      C3PO
      @Thomas-Braun
      loxberry@loxberry:~ $ groups
      loxberry tty dialout sudo audio www-data gpio
      • C C3PO
        @Thomas-Braun
        @C3PO Dann klemmen die den user noch irgendwo anders ab.
        Soll mir jetzt auch egal sein...
        iobroker status
          iobroker status
          C3PO
          @Thomas-Braun
           iobroker status
          Socket.io Server detected. Please update to js-controller 2.0 or higher!
          No iobroker host is running.
          Objects type: file
          States  type: file
          • C C3PO
            @Thomas-Braun
             iobroker status
            Objects type: file
            States  type: file
            @C3PO
            Keine Ahnung wie die 'Kollegen' von LoxBerry da im System rumfuhrwerken.
            Sieht auf jedenfalls für mich äußerst schräg aus.
            In /opt/iobroker
            npm install iobroker.js-controller
              @C3PO
              In /opt/iobroker
              C3PO
              @Thomas-Braun
              root@loxberry:/opt/iobroker# npm install iobroker.js-controller
              > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.14.4
              > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              + iobroker.js-controller@2.2.9
              updated 1 package in 32.054s
              3 packages are looking for funding
                run `npm fund` for details
              • C C3PO
                @Thomas-Braun
                NPM version: 6.14.4
                @C3PO Stop mal den LoxBerry Server Kram auf der Kiste.
                Als root
                netstat -tulpen | grep -v 127.0.0.1
                  Als root
                  C3PO
                  schrieb am zuletzt editiert von C3PO
                  @Thomas-Braun
                  root@loxberry:/# netstat -tulpen | grep -v 127.0.0.1
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18602      1081/java
                  tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      0          14524      718/mosquitto
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16342      1174/dnsmasq
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17422      736/sshd
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          14530      718/mosquitto
                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          17692      835/smbd
                  tcp        1      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      0          14527      718/mosquitto
                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          17693      835/smbd
                  tcp6       0      0 :::81                   :::*                    LISTEN      0          14553      824/apache2
                  tcp6       0      0 :::6066                 :::*                    LISTEN      0          14559      824/apache2
                  tcp6       0      0 :::8883                 :::*                    LISTEN      0          14525      718/mosquitto
                  tcp6       0      0 :::53                   :::*                    LISTEN      0          16344      1174/dnsmasq
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17424      736/sshd
                  tcp6       0      0 :::1883                 :::*                    LISTEN      0          14531      718/mosquitto
                  tcp6       0      0 :::445                  :::*                    LISTEN      0          17690      835/smbd
                  tcp6       0      0 :::139                  :::*                    LISTEN      0          17691      835/smbd
                  udp        0      0 0.0.0.0:50000           0.0.0.0:*                           0          17971      1081/java
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          17976      1081/java
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16341      1174/dnsmasq
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13093      526/dhclient
                  udp        0      0 0.0.0.0:11884           0.0.0.0:*                           1001       17871      1074/perl
                  udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          15597      712/nmbd
                  udp        0      0 192.168.1.57:137        0.0.0.0:*                           0          15596      712/nmbd
                  udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15586      712/nmbd
                  udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          15599      712/nmbd
                  udp        0      0 192.168.1.57:138        0.0.0.0:*                           0          15598      712/nmbd
                  udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15587      712/nmbd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          19641      1081/java
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13472      167/avahi-daemon: r
                  udp        0      0 0.0.0.0:56045           0.0.0.0:*                           108        13474      167/avahi-daemon: r
                  udp6       0      0 :::42310                :::*                                108        13475      167/avahi-daemon: r
                  udp6       0      0 :::53                   :::*                                0          16343      1174/dnsmasq
                  udp6       0      0 :::5353                 :::*                                108        13473      167/avahi-daemon: r
                  Ich glaub ein zweiter raspberry für ioBroker wäre einfacher
                  • C C3PO
                    @Thomas-Braun
                    @C3PO sagte in neu installierter ioBroker über Browser nicht erreichbar:
                    Der Port 9001 ist bei dir schon von mosquitto blockiert. Da läuft beim iobroker das:
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16990      704/iobroker.js-con
                    Thomas BraunT C 2 Antworten Letzte Antwort
                      @Thomas-Braun
                        C3PO
                        @Thomas-Braun
                        kann man das beim ioBroker über die console ändern?
                        • C C3PO
                          @Thomas-Braun
                          @C3PO Da laufen die db vom broker drauf. Ich vermute, da schauen ziemlich viele Adapter nach. Ob und wie man die Ports umbiegen kann weiß ich nicht. Kann vielleicht @apollon77 was zu sagen. Da sind meine Kenntnisse am Ende.
                          C apollon77A 2 Antworten Letzte Antwort
                            C3PO
                            @Thomas-Braun
                            ok, dann nochmal vielen Dank für dein Mühen.
                            Thomas BraunT harrymH 2 Antworten Letzte Antwort
                            • C C3PO
                              @Thomas-Braun
                              @C3PO
                              Du kannst den mosquitto auch mal stoppen
                              service mosquitto stop
                              oder
                              systemctl stop mosquitto.service
                              Dann
                              iobroker restart
                              Mich würde aber doch noch interessieren, wo der sudo kastriert wurde:
                              ls -la /usr/bin/sudo
                              • C C3PO
                                @Thomas-Braun
                                harrymH Offline
                                harrymH Offline
                                harrym
                                schrieb am zuletzt editiert von harrym
                                @C3PO ind der config vom mosquitto kannst du einen beliebigen port vergeben .....
                                https://mosquitto.org/man/mosquitto-conf-5.html
                                ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                  @Thomas-Braun iobroker setup custom ... da kann der port angegeben werden
                                    @C3PO
                                    oder
                                    Dann
                                    iobroker restart
                                    C3PO
                                    @Thomas-Braun
                                    sieht so aus:
                                    loxberry@loxberry:~ $ ls -la /usr/bin/sudo
                                    -rwsr-xr-x 1 root root 147560 Feb  2 08:41 /usr/bin/sudo
                                    • apollon77A apollon77
                                      C3PO
                                      @apollon77
                                      Es war der Port :-)
                                      hab jetzt 9001 zu 9101 und 9000 zu 9100 gemacht.
                                      Sind die ports in Adaptern hart kodiert?
                                      auf den iobroker komm ich jetzt :-)
                                      Vielen Dank.
                                      • C C3PO
                                        @apollon77
                                        Es war der Port :-)
                                        Vielen Dank.
                                        @C3PO alle Adapter nutzen diese zentrale konfig. Sollte also tun
