  4. Adapter lassen sich nicht mehr updaten ?
updateerrorlog
66 Beiträge 5 Kommentatoren 8.0k Aufrufe 5 Beobachtet
  • harrymH harrym
    @tr1plx fehler? noch immer der mim serialport?
    tr1plxT Offline
    tr1plxT Offline
    tr1plx
    @harrym said in Adapter lassen sich nicht mehr updaten ?:
    Ja. ich habe jetzt mal nur den Backitup einzeln versucht:
    $ ./iobroker upgrade backitup
    Update backitup from @1.5.6 to @1.5.7
    host.iobroker Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 6.14.5
    npm install iobroker.backitup@1.5.7 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’   v8::String::Utf8Value path(info[0]->ToString());                                                ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));        ^In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,                 from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void   void init(v8::Handle<v8::Object> target) {                 ^~~~~~../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token   void init(v8::Handle<v8::Object> target) {                                  ^../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~
    ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~                                    tzsetIn file included from ../../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
    ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’ NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
    make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
    gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.0-9-amd64gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.wm-bus/node_modules/serialportgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the serialport@6.2.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-13T19_58_42_071Z-debug.log
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    Adapter "backitup" updatedhost.iobroker Adapter "system.adapter.backitup.0" is started
    process exited with code 0
    nach kurzer Zeit erscheit er erneut unter updates.
    harrymH 1 Antwort Letzte Antwort
    • harrymH harrym
      Thomas BraunT Offline
      @harrym Ah, direkt drin, nicht über die Gruppe. Alles klar...
      • tr1plxT tr1plx
        NPM version: 6.14.5
        harrymH Offline
        harrymH Offline
        harrym
        @tr1plx sagte in Adapter lassen sich nicht mehr updaten ?:
        alles gut! adapter ist up2date .... ignoriere den "fehler" vom serialport
        ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
        tr1plxT 1 Antwort Letzte Antwort
        • harrymH harrym
          tr1plxT Offline
          tr1plxT Offline
          tr1plx
          @harrym
          nochmal, wie ganz am Anfang bereits gesagt.
          Die Updates kommen nach ein paar Minuten wieder !
          Die Instanz läuft, aber sie lässt sich nicht updaten.
          Was hat es denn mit dem Serialport auf sich?
          Thomas BraunT harrymH 2 Antworten Letzte Antwort
          • tr1plxT tr1plx
            @harrym
            @tr1plx
            iobroker update
            iobroker upgrade
            • tr1plxT tr1plx
              @harrym
              harrymH Offline
              harrymH Offline
              harrym
              @tr1plx wieso hast du 2 instanzen vom backitup installiert ??????
              • harrymH harrym
                @harrym sagte in Adapter lassen sich nicht mehr updaten ?:
                Eine für mysql, die andere für den iobroker... :-D
                  harrymH Offline
                  harrymH Offline
                  harrym
                  @Thomas-Braun ??????? häääääääääääää? versteh ich jetzt nicht ....
                  Thomas BraunT tr1plxT 2 Antworten Letzte Antwort
                  • harrymH harrym
                    chown: der Eigentümer von '/opt/iobroker/backups/iobroker_2020_05_13-02_00_20_iobroker_backupiobroker.tar.gz' wird geändert: Keine Berechtigung
                    chown: der Eigentümer von '/opt/iobroker/backups/mysql_2020_05_13-02_00_26_iobroker_backupiobroker.tar.gz' wird geändert: Keine Berechtigung
                    • harrymH harrym
                      tr1plxT Offline
                      tr1plxT Offline
                      tr1plx
                      @harrym
                      Nein.
                      backitup.0 macht eine CCU und eine SQL-Datenbank.
                      backitup.1 macht eine CCU in einem anderen Haushalt, der über VPN angebunden ist.
                      Pro Backitup-Adapter kann man leider nur eine CCU sichern :-)
                      • tr1plxT tr1plx
                        @harrym
                        Nein.
                        harrymH Offline
                        harrymH Offline
                        harrym
                        @tr1plx ah! DAS macht sinn! (y)
                        • harrymH harrym
                          tr1plxT Offline
                          tr1plxT Offline
                          tr1plx
                          @harrym Funktioniert auch einwandfrei, das eine ist mein ZuHause und das andere ist mein Elternhaus, wo ebenfalls HM-CCU läuft.
                          iobroker update
                          iobroker upgrade
                          iobroker start
                          -> noch immer keine Besserung seufz
                          • tr1plxT tr1plx
                            iobroker update
                            iobroker upgrade
                            iobroker start
                            @tr1plx
                            Konsolenoutput?
                            Kannst auch mal in das logfile schauen:
                            tail -f /opt/iobroker/log/iobroker.current.log
                            Rebuildet der da gerade alles mögliche?
                            • tr1plxT tr1plx
                              iobroker update
                              iobroker upgrade
                              iobroker start
                              harrymH Offline
                              harrymH Offline
                              harrym
                              @tr1plx mach mal die harte methode ;) adapter löschen .... neu installieren. war ja einiges ned ganz sauber bei deinem broker .....
                                @tr1plx
                                Konsolenoutput?
                                tr1plxT Offline
                                tr1plxT Offline
                                tr1plx
                                @Thomas-Braun
                                Konsolenoutput ist zu viel für einen Post. Aber Quasi die gleichen Meldungen wie bekannt. Hier ein Auszug:
                                Adapter "tinker"         is not installed.
                                Adapter "tino"           is not installed.
                                Adapter "tinyrx4"        is not installed.
                                Update tr-064 from @4.0.1 to @4.0.3
                                NPM version: 6.14.5
                                npm install iobroker.tr-064@4.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
        tzset
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2020-05-13T20_16_09_878Z-debug.log
                                upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                Adapter "tr-064" updated
                                Adapter "tradfri"        is not installed.
                                Adapter "trashschedule"  is not installed.
                                Adapter "tunnelbroker-endpoint-updater" is not installed.
                                Adapter "tuya"           is not installed.
                                Adapter "tvspielfilm"    is not installed.
                                Adapter "unifi"          is up to date.
                                Adapter "unifi-protect"  is not installed.
                                Adapter "upnp"           is up to date.
                                Adapter "vaillant"       is not installed.
                                Adapter "valloxmv"       is not installed.
                                Adapter "vcard"          is not installed.
                                Adapter "vedirect"       is not installed.
                                Adapter "velux"          is not installed.
                                Adapter "viessmann"      is not installed.
                                Adapter "viessmannapi"   is not installed.
                                Adapter "virtualpowermeter" is not installed.
                                Adapter "vis"            is up to date.
                                Adapter "vis-bars"       is up to date.
                                Adapter "vis-canvas-gauges" is up to date.
                                Adapter "vis-colorpicker" is up to date.
                                Adapter "vis-fancyswitch" is up to date.
                                Adapter "vis-google-fonts" is up to date.
                                Adapter "vis-history"    is up to date.
                                Adapter "vis-hqwidgets"  is up to date.
                                Adapter "vis-inventwo"   is not installed.
                                Adapter "vis-jqui-mfd"   is up to date.
                                Adapter "vis-justgage"   is up to date.
                                Adapter "vis-keyboard"   is up to date.
                                Adapter "vis-lcars"      is up to date.
                                Adapter "vis-map"        is up to date.
                                Adapter "vis-material"   is up to date.
                                Adapter "vis-material-webfont" is not installed.
                                Adapter "vis-materialdesign" is up to date.
                                Adapter "vis-metro"      is up to date.
                                Adapter "vis-players"    is up to date.
                                Adapter "vis-plumb"      is up to date.
                                Adapter "vis-rgraph"     is up to date.
                                Adapter "vis-timeandweather" is up to date.
                                Adapter "vis-weather"    is up to date.
                                Adapter "vodafone-speedtest" is not installed.
                                Adapter "volvo"          is not installed.
                                Adapter "vr200"          is not installed.
                                Adapter "vw-connect"     is not installed.
                                Adapter "weatherunderground" is not installed.
                                Adapter "web"            is up to date.
                                Adapter "web-speedy"     is up to date.
                                Adapter "weishaupt-wem"  is not installed.
                                Adapter "wiffi-wz"       is not installed.
                                Adapter "wifilight"      is not installed.
                                Adapter "windows-control" is not installed.
                                Adapter "wlanthermo-nano" is not installed.
                                Adapter "wled"           is not installed.
                                Adapter "wm-bus"         is not installed.
                                Adapter "wolf"           is not installed.
                                Adapter "worx"           is not installed.
                                Adapter "xbox"           is not installed.
                                Adapter "xs1"            is not installed.
                                Adapter "yahka"          is not installed.
                                Adapter "yamaha"         is up to date.
                                Adapter "yeelight-2"     is not installed.
                                Adapter "youtube"        is not installed.
                                Adapter "yr"             is not installed.
                                Adapter "zigbee"         is not installed.
                                Adapter "zoneminder"     is not installed.
                                Adapter "zont"           is not installed.
                                Adapter "zwave"          is not installed.
                                Adapter "zwave2"         is not installed.
                                • tr1plxT tr1plx
                                  @Thomas-Braun
                                  NPM version: 6.14.5
        tzset
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  schrieb am zuletzt editiert von harrym
                                  @tr1plx ja ... der will was mim serialport .... sein aber alles nur warnings bzw. infos ....
                                  lösch mal den adapter .... ist ja schnell wieder eingerichtet ;)
                                  serialport fragt nach node v8 ab ..... ?????
                                  • harrymH harrym
                                    tr1plxT Offline
                                    tr1plxT Offline
                                    tr1plx
                                    ok, aber ich glaube das bringt nichts. Denn als Update wird auch Philips Hue Bridge angeboten, ich hatte den mal installiert, es gibt aber keine Instanz. Wie also löschen wenn nicht da?
                                    • tr1plxT tr1plx
                                      harrymH Offline
                                      harrymH Offline
                                      harrym
                                      @tr1plx hue aus git oder offiziell?
                                      • harrymH harrym
                                        tr1plxT Offline
                                        tr1plxT Offline
                                        tr1plx
                                        Was ist denn serialport? Ist damit wirklich eine serielle Schnittstelle gemeint?
                                        • tr1plxT tr1plx
                                          harrymH Offline
                                          harrymH Offline
                                          harrym
                                          @tr1plx ja
