  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 683.1k Aufrufe 89 Beobachtet
  • SteffS
    SteffS
    Steff
    schrieb am zuletzt editiert von Steff
    #897
    Hier mal nur der Log-Auszug, wenn alle Scripte deaktiviert sind.
    Ist vielleicht einfacher zu lesen.
    2020-05-10 11:15:47.091  - info: host.Smarthome "system.adapter.javascript.0" enabled
    2020-05-10 11:15:47.143  - info: host.Smarthome instance system.adapter.javascript.0 started with pid 20339
    2020-05-10 11:15:48.815  - info: javascript.0 (20339) starting. Version 4.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.0.20
    2020-05-10 11:15:48.868  - info: javascript.0 (20339) requesting all states
    2020-05-10 11:15:48.869  - info: javascript.0 (20339) requesting all objects
    2020-05-10 11:15:49.866  - info: javascript.0 (20339) received all objects
    2020-05-10 11:15:50.001  - info: javascript.0 (20339) received all states
    2020-05-10 11:15:54.389  - info: javascript.0 (20339) Start javascript script.js.common.Technikraum.Rauchmeldeanlage
    2020-05-10 11:15:54.430  - info: javascript.0 (20339) script.js.common.Technikraum.Rauchmeldeanlage: registered 4 subscriptions and 0 schedules
    2020-05-10 11:15:54.473  - error: javascript.0 (20339) uncaught exception: Cannot read property 'ts' of undefined
    2020-05-10 11:15:54.473  - error: javascript.0 (20339) TypeError: Cannot read property 'ts' of undefined
        at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
        at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
        at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
        at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
        at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
        at runMicrotasks (<anonymous>)
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-05-10 11:15:54.474  - info: javascript.0 (20339) Stop script script.js.common.Technikraum.Rauchmeldeanlage
    2020-05-10 11:15:54.483  - info: javascript.0 (20339) terminating
    2020-05-10 11:15:54.483  - info: javascript.0 (20339) Terminated (NO_ERROR): Without reason
    2020-05-10 11:15:55.016  - error: host.Smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-05-10 11:15:55.019  - error: host.Smarthome Caught by controller[1]: TypeError: Cannot read property 'ts' of undefined
    2020-05-10 11:15:55.019  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
    2020-05-10 11:15:55.019  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
    2020-05-10 11:15:55.020  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
    2020-05-10 11:15:55.020  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
    2020-05-10 11:15:55.020  - error: host.Smarthome Caught by controller[1]:     at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
    2020-05-10 11:15:55.020  - error: host.Smarthome Caught by controller[1]:     at runMicrotasks (<anonymous>)
    2020-05-10 11:15:55.020  - error: host.Smarthome Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-05-10 11:15:55.021  - info: host.Smarthome instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2020-05-10 11:15:55.021  - info: host.Smarthome Restart adapter system.adapter.javascript.0 because enabled
    2020-05-10 11:16:15.318  - info: host.Smarthome "system.adapter.javascript.0" disabled
    2020-05-10 11:16:26.692  - error: javascript.0 (20355) adapter disabled
    2020-05-10 11:16:26.695  - warn: javascript.0 (20355) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2020-05-10 11:16:27.228  - error: host.Smarthome instance system.adapter.javascript.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2020-05-10 11:16:27.229  - info: host.Smarthome Do not restart adapter system.adapter.javascript.0 because disabled or deleted
    Ahh.. das Script von der Rauchmeldeanlage läuft noch, habe es nun auch gestoppt aber Fehler tritt immer noch auf.
    ioBroker auf Intel NUC 7CJYH / Debian 13 "Trixie" / States & Objects in JSONL / Repo --> Beta / HM CCU2 V2.61.7 / Siemens LOGO! (0BA7 / 0BA8)
    Admin V7.8.24 / Node V22.22.2 / NPM V10.9.7 / JSC V7.1.2 / JSE V9.2.2
    • JB_SullivanJ JB_Sullivan
      Mal eine kurze Frage am Rande. Ich war jetzt eine Woche nicht aktiv und sehe heute, das schon wieder 9 Adapter Updates und ein js-controller Update anstehen.
      In welcher Reihenfolge machte man es am "Richtigsten"?
      Erst den js-controller und dann die Adapter Updates oder anders herum?
      apollon77A
      apollon77A
      #898
      @JB_Sullivan M Ende ist es egal - wenn ein Adapter eine bestimmte js-controller Version braucht kannst Du Ihn vorher nicht installieren ... also von daher an sich egal :-) Idealerweise schau die changelogs durch (Admin mouse over Info über dem Update button beim adapter) und schau was so drin steht
      • SteffS Steff
        wendy2702W
        wendy2702W
        #899
        @Steff welcher Fehler bleibt?
        Das der JavaScript Adapter neu startet?
        SteffS 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          SteffS
          SteffS
          Steff
          #900
          @wendy2702
          Richtig, der JS-Adapter startet ständig neu.
          • S steimi
            habe auf die 3.1.3 aktualisiert, nun bekomme ich immer mal wieder die nachfolgende Meldung im Log.
            admin.0	2020-05-10 10:02:15.506	error	(440) unknown user "undefined"
            apollon77A
            apollon77A
            #901
            @steimi Die 3.1.4 sollte nachher auch das fixen
            • SteffS Steff
              @wendy2702
              wendy2702W
              wendy2702W
              #902
              @Steff wie sieht das log jetzt aus
              • SteffS Steff
                Moin,
                wollte heute auch auf die 3.1.3 gehen. Habe ein Update gemacht und dann den Controller upgegraded. Nun will er nicht mehr.
                Der Controller beendet sich ständig neu. Habe dann den Controller wieder auf die 3.0.20 downgegraded ohne Erfolg. Er startet ständig neu. Habe meinen Rechner auch schon komplett neu gestartet. Fixer-Script jeweils nach dem Upgrade laufen gelassen. Habe mich dann entschlossen das Backup zurück zu sichern. Aber auch dann bleibt der Controller in der Start/Stop Schleife.
                Hier mal der Log-Auszug ab dem Restore
                iobroker.2020-05-10_cropped.log
                Was kann ich noch tun? Bin gerade echt ratlos!
                Gruß Steffen
                apollon77A
                apollon77A
                #903
                @Steff Alao da ist irgend ein kleiner bug im javascript adapter und dann wird aber dein ganzes iobroker mit einem SIGTERM scheinbar vom Betriebssystem gekillt. Reboote mal bzw schau mal ob /var/log/syslog was hergibt
                  SteffS
                  SteffS
                  Steff
                  #904
                  @wendy2702
                  Hier mal ein Log vom Start und ein anschliessender Restart
                  2020-05-10 11:35:32.142  - info: host.Smarthome "system.adapter.javascript.0" enabled
                  2020-05-10 11:35:32.174  - info: host.Smarthome instance system.adapter.javascript.0 started with pid 20479
                  2020-05-10 11:35:33.677  - info: javascript.0 (20479) starting. Version 4.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.0.20
                  2020-05-10 11:35:33.729  - info: javascript.0 (20479) requesting all states
                  2020-05-10 11:35:33.730  - info: javascript.0 (20479) requesting all objects
                  2020-05-10 11:35:34.699  - info: javascript.0 (20479) received all objects
                  2020-05-10 11:35:34.833  - info: javascript.0 (20479) received all states
                  2020-05-10 11:35:35.481  - error: javascript.0 (20479) uncaught exception: Cannot read property 'ts' of undefined
                  2020-05-10 11:35:35.482  - error: javascript.0 (20479) TypeError: Cannot read property 'ts' of undefined
                  2020-05-10 11:35:35.494  - info: javascript.0 (20479) terminating
                  2020-05-10 11:35:35.495  - info: javascript.0 (20479) Terminated (NO_ERROR): Without reason
                  2020-05-10 11:35:36.022  - error: host.Smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]: TypeError: Cannot read property 'ts' of undefined
                  2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
                  2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
                  2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
                  2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
                  2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
                  2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  2020-05-10 11:35:36.025  - info: host.Smarthome instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2020-05-10 11:35:36.025  - info: host.Smarthome Restart adapter system.adapter.javascript.0 because enabled
                  2020-05-10 11:36:06.053  - info: host.Smarthome instance system.adapter.javascript.0 started with pid 20503
                  2020-05-10 11:36:07.714  - info: javascript.0 (20503) starting. Version 4.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.0.20
                  2020-05-10 11:36:07.766  - info: javascript.0 (20503) requesting all states
                  2020-05-10 11:36:07.767  - info: javascript.0 (20503) requesting all objects
                  2020-05-10 11:36:08.683  - info: javascript.0 (20503) received all objects
                  2020-05-10 11:36:08.824  - info: javascript.0 (20503) received all states
                  2020-05-10 11:36:09.468  - error: javascript.0 (20503) uncaught exception: Cannot read property 'ts' of undefined
                  2020-05-10 11:36:09.469  - error: javascript.0 (20503) TypeError: Cannot read property 'ts' of undefined
                  2020-05-10 11:36:09.477  - info: javascript.0 (20503) terminating
                  2020-05-10 11:36:09.477  - info: javascript.0 (20503) Terminated (NO_ERROR): Without reason
                  2020-05-10 11:36:10.010  - error: host.Smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]: TypeError: Cannot read property 'ts' of undefined
                  2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
                  2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
                  2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
                  2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
                  2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
                  2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  2020-05-10 11:36:10.013  - info: host.Smarthome instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2020-05-10 11:36:10.013  - info: host.Smarthome Restart adapter system.adapter.javascript.0 because enabled
                  2020-05-10 11:36:14.480  - info: host.Smarthome "system.adapter.javascript.0" disabled
                  • apollon77A apollon77
                    SteffS
                    SteffS
                    Steff
                    #905
                    @apollon77
                    Ja da steht ziemlich viel drinne, was soll ich hier posten?
                    • SteffS Steff
                      Moin,
                      Gruß Steffen
                      apollon77A
                      apollon77A
                      #906
                      @Steff Bitte GitHub Issue zum javasctipt adapter anlegen und ggf erstmal das mirroring auschalten. Muss ich heute abend prüfen. Bzw welche javascript Version?
                      SteffS 2 Antworten Letzte Antwort
                        SteffS
                        SteffS
                        Steff
                        #907
                        @apollon77
                        Mach ich gern, wie schalte ich das Mirroring aus und was ist das überhaupt??
                        • SteffS Steff
                          @apollon77
                          apollon77A
                          apollon77A
                          #908
                          @Steff In den Adapter-Einstellungen vom JavaScript Adapter ist eine EInstellung. Da gibst Du auch einen Pfad an ... Was hast Du da stehen?
                          Das Feature synct die Skripte als Datein ins Dateisystem das man sie mit einem anderen Editor ändern kann
                            SteffS
                            SteffS
                            Steff
                            #909
                            @apollon77
                            Ach so, das hatte ich erst vor ca. 2 Wochen aktiviert, da gab es keine Probleme damit.
                            Ich habe da als Pfad das hier drin stehen --> /opt/iobroker/jscript/
                            • SteffS Steff
                              @apollon77
                              apollon77A
                              apollon77A
                              #910
                              @Steff Scheinbar gefällt Ihn irgendein Skript nicht. Aber das muss ich im Code suchen. Welche Javascript Version hast Du denn nun?
                              • J Jan1
                                @TH-G
                                Das Problem ist nicht 3.* sondern die fehlerhaften Scripte und da musst Du ansetzten, nicht am stabilen JS der jetzt eben Dinge nicht mehr durchgehen lässt, die nicht richtig sind, aber trotzdem funktioniert haben.
                                Wenn Du schon so ein guten Draht zu den Urhebern der Scripte hast, dann sollten die auch ihre Scripte anpassen. Nicht der Berg sollte zum Propheten ;-)
                                M
                                M
                                Maverick78
                                schrieb am zuletzt editiert von Maverick78
                                #911
                                @Jan1 Ich finde solche großkotzigen Bemerkungen echt daneben.
                                Ich habe mein Script gerade mit 3.0.20 und 3.1.3 überprüft und es läuft fehlerfrei, genau wie auch bei 2.2.9. Wenn es bei @TH-G mit 3.0.20 nicht läuft, liegt der verdacht nahe, das es sich hier um ein Problem mit 3.0.22 und seiner Node Version handelt. Meine Node Version ist 10.20.1
                                • apollon77A
                                  apollon77A
                                  #912
                                  Hi All,
                                  Version 3.1.4 vom js-controller der die oben genannten Fehler bzw "User undefined Meldungen" bei Nutzung von Binär-States ist auf dem Web ins Latest Repository. Sorry für die Umstände :-(
                                  Ingo
                                  S FeuersturmF 2 Antworten Letzte Antwort
                                    SteffS
                                    SteffS
                                    Steff
                                    #913
                                    @apollon77
                                    ich hatte vor dem Upgrade heute morgen den Controllere V3.0.20 und die JSE 4.5.1 drauf, und da bin ich dank meinem Backup wieder.
                                    • SteffS Steff
                                      @apollon77
                                      apollon77A
                                      apollon77A
                                      #914
                                      @Steff Hat er denn die Files bei Dir ins Filesystem gesynct? Hat das für alle geklappt? Aber ok, ich checke heute abend. An sich gab es da maximal Fixes und keine Änderungen in dem Sinne. Vllt hast Du ein altes Objekt was er nciht mag und bisher ignoriert hat oder so. ich checke mal. Bitte GitHub issue bei javascript mit dem Log.Danke!
                                        SteffS
                                        SteffS
                                        Steff
                                        #915
                                        @apollon77
                                        Mache ich später bin gerade am schrittweise Auftstarten meiner Scripte
                                          SteffS
                                          SteffS
                                          Steff
                                          #916
                                          @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                          @Steff .... erstmal das mirroring auschalten.
                                          Kurzer Zwischenstand, Mirroring ist aus JSController läuft wieder bin nun am Aufstarten meiner ganzen Scripte
                                          84.2k
