  4. HS100 Adapter Fehlermeldungen
    6.8k
hs100 adapterfehler im log
190 Beiträge 23 Kommentatoren 37.0k Aufrufe 22 Beobachtet
    Berchemer
    schrieb am zuletzt editiert von Berchemer
    #87
    Und erneut:
    2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.132
    2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.131
    2020-05-07 15:43:41.237 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
    2020-05-07 15:43:41.299 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
    2020-05-07 15:43:42.399 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.132
    2020-05-07 15:43:42.461 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
    2020-05-07 15:43:43.271 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.132
    2020-05-07 15:43:43.333 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.131
    2020-05-07 15:43:43.707 - debug: hs100.0 (13537) Day value HS110(EU) 0.332 192.1.1.132
    2020-05-07 15:43:43.768 - debug: hs100.0 (13537) Day value HS110(EU) 0.228 192.1.1.131
    2020-05-07 15:45:41.068 - debug: hs100.0 (13537) HS Plug 192.1.1.132
    2020-05-07 15:45:41.070 - debug: hs100.0 (13537) HS Plug 192.1.1.131
    2020-05-07 15:45:41.224 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
    2020-05-07 15:45:41.287 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
    2020-05-07 15:45:42.345 - error: hs100.0 (13537) uncaught exception: TCP Socket Closed. segment:0 hadError:false
    2020-05-07 15:45:42.346 - error: hs100.0 (13537) Error: TCP Socket Closed. segment:0 hadError:false
    at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    at Object.onceWrapper (events.js:417:26)
    at Socket.emit (events.js:310:20)
    at TCP. (net.js:672:12)
    2020-05-07 15:45:42.348 - info: hs100.0 (13537) terminating
    2020-05-07 15:45:42.349 - info: hs100.0 (13537) Terminated (NO_ERROR): Without reason
    2020-05-07 15:45:42.450 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
    2020-05-07 15:45:42.870 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
    2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
    2020-05-07 15:45:42.871 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
    2020-05-07 15:45:42.871 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
    2020-05-07 15:46:12.886 - info: host.SERVER instance system.adapter.hs100.0 started with pid 5874
    2020-05-07 15:46:13.079 - debug: hs100.0 (5874) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2020-05-07 15:46:13.090 - debug: hs100.0 (5874) Objects client ready ... initialize now
    2020-05-07 15:46:13.091 - debug: hs100.0 (5874) Objects create System PubSub Client
    2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects create User PubSub Client
    2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects client initialize lua scripts
    2020-05-07 15:46:13.101 - debug: hs100.0 (5874) Objects connected to redis: 0.0.0.0:9001
    2020-05-07 15:46:13.102 - debug: hs100.0 (5874) objectDB connected
    2020-05-07 15:46:13.103 - debug: hs100.0 (5874) Redis States: Use Redis connection: 0.0.0.0:9000
    2020-05-07 15:46:13.109 - debug: hs100.0 (5874) States create User PubSub Client
    2020-05-07 15:46:13.110 - debug: hs100.0 (5874) States create System PubSub Client
    2020-05-07 15:46:13.117 - debug: hs100.0 (5874) States connected to redis: 0.0.0.0:9000
    2020-05-07 15:46:13.118 - debug: hs100.0 (5874) statesDB connected
    2020-05-07 15:46:13.294 - info: hs100.0 (5874) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
    2020-05-07 15:46:13.305 - debug: hs100.0 (5874) Host = SERVER
    2020-05-07 15:46:13.333 - debug: hs100.0 (5874) undefined generated 192.1.1.131
    2020-05-07 15:46:13.375 - debug: hs100.0 (5874) undefined generated 192.1.1.132
    2020-05-07 15:46:13.537 - debug: hs100.0 (5874) HS Plug 192.1.1.132
    2020-05-07 15:46:13.539 - debug: hs100.0 (5874) HS Plug 192.1.1.131
    2020-05-07 15:46:13.873 - debug: hs100.0 (5874) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:46:13
    2020-05-07 15:46:15.424 - debug: hs100.0 (5874) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:46:15
    2020-05-07 15:46:16.588 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.131
    2020-05-07 15:46:17.458 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.131
    2020-05-07 15:46:17.824 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.132
    2020-05-07 15:46:17.894 - debug: hs100.0 (5874) Day value HS110(EU) 0.228 192.1.1.131
    2020-05-07 15:46:19.132 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.132
    2020-05-07 15:46:20.438 - debug: hs100.0 (5874) Day value HS110(EU) 0.333 192.1.1.132
    • arteckA Offline
      arteckA Offline
      arteck
      #88
      version 1.1.5 ist draussen
      wenns damit nicht besser ist muss ich ein issue erstellen .. bei tplink-smarthome-api
      das ist nicht meine bibliothek.. und hab keine einfluss druff
      B 2 Antworten Letzte Antwort
        Berchemer
        #89
        Und wieder fast 24 Stunden später 😬
        2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.132
        2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.131
        2020-05-08 15:38:23.087 - debug: hs100.0 (5127) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
        2020-05-08 15:38:23.111 - debug: hs100.0 (5127) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
        2020-05-08 15:38:24.273 - debug: hs100.0 (5127) Refresh Data HS110 192.1.1.131
        2020-05-08 15:38:25.146 - debug: hs100.0 (5127) Month value HS110(EU) 192.1.1.131
        2020-05-08 15:38:25.581 - debug: hs100.0 (5127) Day value HS110(EU) 0.262 192.1.1.131
        2020-05-08 15:38:29.058 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.058 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.059 - debug: hs100.0 (5127) Send error setDevState : Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.061 - info: hs100.0 (5127) terminating
        2020-05-08 15:38:29.061 - info: hs100.0 (5127) Terminated (NO_ERROR): Without reason
        2020-05-08 15:38:29.188 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.188 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.475 - debug: hs100.0 (5127) Day value HS110(EU) 0.333 192.1.1.132
        2020-05-08 15:38:29.576 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
        2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
        2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
        2020-05-08 15:38:29.578 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
        2020-05-08 15:38:29.578 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
        2020-05-08 15:38:59.591 - info: host.SERVER instance system.adapter.hs100.0 started with pid 11771
        2020-05-08 15:38:59.780 - debug: hs100.0 (11771) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2020-05-08 15:38:59.790 - debug: hs100.0 (11771) Objects client ready ... initialize now
        2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create System PubSub Client
        2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create User PubSub Client
        2020-05-08 15:38:59.792 - debug: hs100.0 (11771) Objects client initialize lua scripts
        2020-05-08 15:38:59.799 - debug: hs100.0 (11771) Objects connected to redis: 0.0.0.0:9001
        2020-05-08 15:38:59.800 - debug: hs100.0 (11771) objectDB connected
        2020-05-08 15:38:59.801 - debug: hs100.0 (11771) Redis States: Use Redis connection: 0.0.0.0:9000
        2020-05-08 15:38:59.806 - debug: hs100.0 (11771) States create User PubSub Client
        2020-05-08 15:38:59.807 - debug: hs100.0 (11771) States create System PubSub Client
        2020-05-08 15:38:59.813 - debug: hs100.0 (11771) States connected to redis: 0.0.0.0:9000
        2020-05-08 15:38:59.814 - debug: hs100.0 (11771) statesDB connected
        2020-05-08 15:38:59.984 - info: hs100.0 (11771) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
        2020-05-08 15:38:59.992 - debug: hs100.0 (11771) Host = SERVER
        2020-05-08 15:39:00.036 - debug: hs100.0 (11771) undefined generated 192.1.1.131
        2020-05-08 15:39:00.078 - debug: hs100.0 (11771) undefined generated 192.1.1.132
        2020-05-08 15:39:00.316 - debug: hs100.0 (11771) HS Plug 192.1.1.132
        2020-05-08 15:39:00.317 - debug: hs100.0 (11771) HS Plug 192.1.1.131
        2020-05-08 15:39:02.320 - debug: hs100.0 (11771) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
        2020-05-08 15:39:02.324 - debug: hs100.0 (11771) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
        2020-05-08 15:39:03.482 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.132
        2020-05-08 15:39:03.487 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.131
        2020-05-08 15:39:04.353 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.132
        2020-05-08 15:39:04.358 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.131
        2020-05-08 15:39:04.791 - debug: hs100.0 (11771) Day value HS110(EU) 0.333 192.1.1.132
        2020-05-08 15:39:04.794 - debug: hs100.0 (11771) Day value HS110(EU) 0.262 192.1.1.131
        2020-05-08 15:40:00.015 - info: host.SERVER instance system.adapter.dwd.0 started with pid 12366
        2020-05-08 15:40:00.685 - info: dwd.0 (12366) starting. Version 2.4.8 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
        2020-05-08 15:40:01.386 - info: dwd.0 (12366) Terminated (NO_ERROR): Without reason
        2020-05-08 15:40:01.893 - info: host.SERVER instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
        • arteckA arteck
          Berchemer
          #90
          @arteck sagte in HS100 Adapter Fehlermeldungen:
          Dann installiere ich erneut :-)
          Btw. Der Beitrag von eben war noch mit der alten Version!
          • arteckA arteck
            Berchemer
            #91
            Sorry :-(
            Etwas mehr als 21 Stunden hat der Adapter durchgehalten :-)
            Nach "normaler" Installation (Update) des Adapters über den Infotab habe ich sicherheitshalber trotzdem noch einmal upload angeklickt. System danach neu gestartet. Und etwas mehr als 21 Stunden später:
            2020-05-09 14:27:02.185 - debug: hs100.0 (12363) HS Plug 192.1.1.132
            2020-05-09 14:27:02.186 - debug: hs100.0 (12363) HS Plug 192.1.1.131
            2020-05-09 14:27:02.400 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:27:02
            2020-05-09 14:27:03.562 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
            2020-05-09 14:27:04.434 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
            2020-05-09 14:27:04.870 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
            2020-05-09 14:27:05.512 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:27:05
            2020-05-09 14:27:06.675 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
            2020-05-09 14:27:07.547 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
            2020-05-09 14:27:07.983 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
            2020-05-09 14:29:02.188 - debug: hs100.0 (12363) HS Plug 192.1.1.132
            2020-05-09 14:29:02.189 - debug: hs100.0 (12363) HS Plug 192.1.1.131
            2020-05-09 14:29:02.392 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
            2020-05-09 14:29:02.395 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
            2020-05-09 14:29:03.554 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
            2020-05-09 14:29:03.557 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
            2020-05-09 14:29:04.429 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
            2020-05-09 14:29:04.439 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
            2020-05-09 14:29:04.861 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
            2020-05-09 14:29:04.865 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
            2020-05-09 14:31:02.191 - debug: hs100.0 (12363) HS Plug 192.1.1.132
            2020-05-09 14:31:02.193 - debug: hs100.0 (12363) HS Plug 192.1.1.131
            2020-05-09 14:31:03.665 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:31:03
            2020-05-09 14:31:04.828 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
            2020-05-09 14:31:05.699 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
            2020-05-09 14:31:06.135 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
            2020-05-09 14:31:12.193 - debug: hs100.0 (12363) IP not found : 192.1.1.131
            2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.132
            2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.131
            2020-05-09 14:33:02.462 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:02
            2020-05-09 14:33:02.754 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
            2020-05-09 14:33:03.043 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
            2020-05-09 14:33:03.332 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
            2020-05-09 14:33:07.852 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:07
            2020-05-09 14:33:17.854 - error: hs100.0 (12363) uncaught exception: TCP Timeout
            2020-05-09 14:33:17.854 - error: hs100.0 (12363) Error: TCP Timeout
            at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            at listOnTimeout (internal/timers.js:549:17)
            at processTimers (internal/timers.js:492:7)
            2020-05-09 14:33:17.855 - debug: hs100.0 (12363) Error getDevice192.1.1.131
            2020-05-09 14:33:17.857 - info: hs100.0 (12363) terminating
            2020-05-09 14:33:17.857 - info: hs100.0 (12363) Terminated (NO_ERROR): Without reason
            2020-05-09 14:33:18.393 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Timeout
            2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[1]: at processTimers (internal/timers.js:492:7)
            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
            2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
            2020-05-09 14:33:18.397 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
            2020-05-09 14:33:18.398 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
            2020-05-09 14:33:48.516 - info: host.SERVER instance system.adapter.hs100.0 started with pid 28253
            2020-05-09 14:33:48.766 - debug: hs100.0 (28253) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects client ready ... initialize now
            2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects create System PubSub Client
            2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects create User PubSub Client
            2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects client initialize lua scripts
            2020-05-09 14:33:48.787 - debug: hs100.0 (28253) Objects connected to redis: 0.0.0.0:9001
            2020-05-09 14:33:48.790 - debug: hs100.0 (28253) objectDB connected
            2020-05-09 14:33:48.791 - debug: hs100.0 (28253) Redis States: Use Redis connection: 0.0.0.0:9000
            2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create User PubSub Client
            2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create System PubSub Client
            2020-05-09 14:33:48.803 - debug: hs100.0 (28253) States connected to redis: 0.0.0.0:9000
            2020-05-09 14:33:48.803 - debug: hs100.0 (28253) statesDB connected
            2020-05-09 14:33:48.976 - info: hs100.0 (28253) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
            2020-05-09 14:33:48.985 - debug: hs100.0 (28253) Host = SERVER
            2020-05-09 14:33:49.007 - debug: hs100.0 (28253) create state
            2020-05-09 14:33:49.008 - debug: hs100.0 (28253) undefined generated 192.1.1.131
            2020-05-09 14:33:49.050 - debug: hs100.0 (28253) create state
            2020-05-09 14:33:49.050 - debug: hs100.0 (28253) undefined generated 192.1.1.132
            2020-05-09 14:33:49.352 - debug: hs100.0 (28253) HS Plug 192.1.1.132
            2020-05-09 14:33:49.354 - debug: hs100.0 (28253) HS Plug 192.1.1.131
            2020-05-09 14:33:51.380 - debug: hs100.0 (28253) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:51
            2020-05-09 14:33:52.543 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.132
            2020-05-09 14:33:53.449 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.132
            2020-05-09 14:33:53.884 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
            2020-05-09 14:33:56.679 - debug: hs100.0 (28253) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:56
            2020-05-09 14:33:57.841 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.131
            2020-05-09 14:33:58.713 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.131
            2020-05-09 14:33:59.153 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.219 IP : 192.1.1.131
            • B Berchemer
              Sorry :-(
              skokarl
              #92
              @Berchemer @arteck
              Sag mal.....kann es sein, dass da irgendwas volläuft ?
              Kann doch nicht sein das es einen Tag funktioniert und dann plötzlich nicht mehr ?
              nur so eine Idee ....
              B arteckA 2 Antworten Letzte Antwort
              • S skokarl
                @Berchemer @arteck
                Berchemer
                #93
                @skokarl
                Wegen Vollaufen...
                Ich habe jetzt mal die RAM-Daten unter system.host.Server zum protokollieren im sql eingetragen.
                Aber bei 16 gb insgesamt und 8gb frei sollte es eigentlich kein RAM-Problem sein.
                Es ist halt mal nen versuch wert.
                Ich tippe zwar eher auf mein WLAN, aber selbst dann sollte zumindest der Fehler abgefangen werden können und ggf. eine Warnmeldung ausgegeben werden.
                Vielleicht ist es also tatsächlich in der TP-Link-API zu suchen, wie ARTECK es sagte.
                • S skokarl
                  @Berchemer @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #94
                  @skokarl nein da läuft nix voll..
                  die Dose antwortet nicht .. warum auch immer..
                  kann sein das es ein Zufall ist und diese langsam den Geist aufgibt.. ja währe ein Zufall..
                  aber anders kann ich es nir nicht erklären.. ich hab auch mehrere Dose im Einsatz ..
                  in version 1.1.5 ist ruhe
                  ich krieg die exception nicht abgefangen... in Verbindung mit den neuen js-controller restriktionen
                  das kommt noch dazu.. deshalb restartet sich der Adapter neu
                  @Berchemer kannst die Dose mit einer andreren ersetzten .. zumindest testweise
                  S B 2 Antworten Letzte Antwort
                  • arteckA arteck
                    skokarl
                    #95
                    @skokarl nein die Dose antwortet nicht .. warum auch immer.. kann sein das es ein zufall ist und diese langsam den geist aufgibt.. ja währe ein zufall.. aber anders kann ich es nir nicht erklären.. ich hab auch mehrere Dose im einsatz .. in version 1.1.5 ist ruhe
                    also ich hab auch Ruhe.
                    • WinniW Offline
                      WinniW Offline
                      Winni
                      #96
                      Meine Dose ist neu, Hardware 2.0 und Firmware 1.5.6. Läuft ohne Probleme.
                      • arteckA arteck
                        Berchemer
                        #97
                        Das habe ich jetzt leider nicht verstanden 😕
                        PS: Habe in der Nacht auch wieder einige Meldungen gehabt, die ich hier nicht mehr gepostet habe. Sind ja immer die Gleichen.
                        • B Berchemer
                          skokarl
                          #98
                          @Berchemer sagte in HS100 Adapter Fehlermeldungen:
                          Du sollst zwei Steckdosen wechseln .... 😬 😀
                          • S skokarl
                            Berchemer
                            #99
                            @skokarl
                            Ok, ok, ok... ;-)
                            Versuche es mal morgen, wenn ich mehr Zeit und Muße habe :-)
                            • B Berchemer
                              @skokarl
                              Ok, ok, ok... ;-)
                              Berchemer
                              #100
                              @skokarl
                              Ok, ok, ok... ;-)
                              Habe jetzt mal beide Steckdosen vertauscht.
                              Die aus der Küche im Erdgeschoss ins Schlafzimmer im Obergeschoss und umgekehrt.
                              Alles neu gestartet, aber noch js-controller 3.1.4
                              Mal schauen, was das System bis morgen sagt :-)
                                Berchemer
                                #101
                                In 17 Stunden insgesamt 5 Fehler. Immer die Gleichen, wie unten angegeben 😢
                                2020-05-13 02:29:16.795 - debug: hs100.0 (15163) HS Plug 192.1.1.132
                                2020-05-13 02:29:16.797 - debug: hs100.0 (15163) HS Plug 192.1.1.131
                                2020-05-13 02:29:17.044 - debug: hs100.0 (15163) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:29:17
                                2020-05-13 02:29:17.124 - debug: hs100.0 (15163) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:29:17
                                2020-05-13 02:29:18.206 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.131
                                2020-05-13 02:29:18.287 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.132
                                2020-05-13 02:29:19.078 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.131
                                2020-05-13 02:29:19.163 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.132
                                2020-05-13 02:29:19.513 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
                                2020-05-13 02:29:19.594 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
                                2020-05-13 02:31:16.799 - debug: hs100.0 (15163) HS Plug 192.1.1.132
                                2020-05-13 02:31:16.800 - debug: hs100.0 (15163) HS Plug 192.1.1.131
                                2020-05-13 02:31:17.086 - debug: hs100.0 (15163) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:31:17
                                2020-05-13 02:31:17.121 - debug: hs100.0 (15163) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:31:17
                                2020-05-13 02:31:18.249 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.131
                                2020-05-13 02:31:19.120 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.131
                                2020-05-13 02:31:19.556 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
                                2020-05-13 02:31:23.103 - error: hs100.0 (15163) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                2020-05-13 02:31:23.103 - error: hs100.0 (15163) Error: TCP Socket Closed. segment:0 hadError:false
                                2020-05-13 02:31:23.104 - debug: hs100.0 (15163) Error getDevice192.1.1.131
                                2020-05-13 02:31:23.106 - info: hs100.0 (15163) terminating
                                2020-05-13 02:31:23.106 - info: hs100.0 (15163) Terminated (NO_ERROR): Without reason
                                2020-05-13 02:31:23.617 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                2020-05-13 02:31:23.617 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
                                2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
                                2020-05-13 02:31:23.618 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                2020-05-13 02:31:23.618 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                2020-05-13 02:31:53.638 - info: host.SERVER instance system.adapter.hs100.0 started with pid 27783
                                2020-05-13 02:31:53.893 - debug: hs100.0 (27783) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2020-05-13 02:31:53.903 - debug: hs100.0 (27783) Objects client ready ... initialize now
                                2020-05-13 02:31:53.903 - debug: hs100.0 (27783) Objects create System PubSub Client
                                2020-05-13 02:31:53.904 - debug: hs100.0 (27783) Objects create User PubSub Client
                                2020-05-13 02:31:53.904 - debug: hs100.0 (27783) Objects client initialize lua scripts
                                2020-05-13 02:31:53.912 - debug: hs100.0 (27783) Objects connected to redis: 0.0.0.0:9001
                                2020-05-13 02:31:53.915 - debug: hs100.0 (27783) objectDB connected
                                2020-05-13 02:31:53.916 - debug: hs100.0 (27783) Redis States: Use Redis connection: 0.0.0.0:9000
                                2020-05-13 02:31:53.920 - debug: hs100.0 (27783) States create User PubSub Client
                                2020-05-13 02:31:53.920 - debug: hs100.0 (27783) States create System PubSub Client
                                2020-05-13 02:31:53.928 - debug: hs100.0 (27783) States connected to redis: 0.0.0.0:9000
                                2020-05-13 02:31:53.928 - debug: hs100.0 (27783) statesDB connected
                                2020-05-13 02:31:54.074 - info: hs100.0 (27783) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                2020-05-13 02:31:54.081 - debug: hs100.0 (27783) Host = SERVER
                                2020-05-13 02:31:54.102 - debug: hs100.0 (27783) create state
                                2020-05-13 02:31:54.104 - debug: hs100.0 (27783) undefined generated 192.1.1.131
                                2020-05-13 02:31:54.105 - debug: hs100.0 (27783) create state
                                2020-05-13 02:31:54.105 - debug: hs100.0 (27783) undefined generated 192.1.1.132
                                2020-05-13 02:31:54.260 - debug: hs100.0 (27783) HS Plug 192.1.1.132
                                2020-05-13 02:31:54.261 - debug: hs100.0 (27783) HS Plug 192.1.1.131
                                2020-05-13 02:31:54.426 - debug: hs100.0 (27783) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:31:54
                                2020-05-13 02:31:54.717 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.132
                                2020-05-13 02:31:55.152 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.132
                                2020-05-13 02:31:55.418 - debug: hs100.0 (27783) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:31:55
                                2020-05-13 02:31:56.000 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.131
                                2020-05-13 02:31:56.314 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
                                2020-05-13 02:31:57.017 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.131
                                2020-05-13 02:31:57.452 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
                                2020-05-13 05:13:54.499 - debug: hs100.0 (27783) HS Plug 192.1.1.132
                                2020-05-13 05:13:54.500 - debug: hs100.0 (27783) HS Plug 192.1.1.131
                                2020-05-13 05:13:54.681 - debug: hs100.0 (27783) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 05:13:54
                                2020-05-13 05:13:55.843 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.131
                                2020-05-13 05:13:56.715 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.131
                                2020-05-13 05:13:57.150 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
                                2020-05-13 05:14:00.827 - debug: hs100.0 (27783) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 05:14:00
                                2020-05-13 05:14:01.989 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.132
                                2020-05-13 05:14:02.861 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.132
                                2020-05-13 05:14:12.864 - error: hs100.0 (27783) uncaught exception: TCP Timeout
                                2020-05-13 05:14:12.865 - error: hs100.0 (27783) Error: TCP Timeout
                                2020-05-13 05:14:12.866 - info: hs100.0 (27783) terminating
                                2020-05-13 05:14:12.867 - info: hs100.0 (27783) Terminated (NO_ERROR): Without reason
                                2020-05-13 05:14:13.385 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Timeout
                                2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at listOnTimeout (internal/timers.js:549:17)
                                2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at processTimers (internal/timers.js:492:7)
                                2020-05-13 05:14:13.386 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                2020-05-13 05:14:13.386 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                2020-05-13 05:14:43.410 - info: host.SERVER instance system.adapter.hs100.0 started with pid 24105
                                2020-05-13 05:14:43.590 - debug: hs100.0 (24105) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2020-05-13 05:14:43.600 - debug: hs100.0 (24105) Objects client ready ... initialize now
                                2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects create System PubSub Client
                                2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects create User PubSub Client
                                2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects client initialize lua scripts
                                2020-05-13 05:14:43.611 - debug: hs100.0 (24105) Objects connected to redis: 0.0.0.0:9001
                                2020-05-13 05:14:43.612 - debug: hs100.0 (24105) objectDB connected
                                2020-05-13 05:14:43.613 - debug: hs100.0 (24105) Redis States: Use Redis connection: 0.0.0.0:9000
                                2020-05-13 05:14:43.618 - debug: hs100.0 (24105) States create User PubSub Client
                                2020-05-13 05:14:43.619 - debug: hs100.0 (24105) States create System PubSub Client
                                2020-05-13 05:14:43.626 - debug: hs100.0 (24105) States connected to redis: 0.0.0.0:9000
                                2020-05-13 05:14:43.626 - debug: hs100.0 (24105) statesDB connected
                                2020-05-13 05:14:43.788 - info: hs100.0 (24105) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                2020-05-13 05:14:43.795 - debug: hs100.0 (24105) Host = SERVER
                                2020-05-13 05:14:43.823 - debug: hs100.0 (24105) create state
                                2020-05-13 05:14:43.824 - debug: hs100.0 (24105) undefined generated 192.1.1.131
                                2020-05-13 05:14:43.825 - debug: hs100.0 (24105) create state
                                2020-05-13 05:14:43.826 - debug: hs100.0 (24105) undefined generated 192.1.1.132
                                2020-05-13 05:14:44.060 - debug: hs100.0 (24105) HS Plug 192.1.1.132
                                2020-05-13 05:14:44.061 - debug: hs100.0 (24105) HS Plug 192.1.1.131
                                2020-05-13 05:14:45.369 - debug: hs100.0 (24105) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 05:14:45
                                2020-05-13 05:14:46.087 - debug: hs100.0 (24105) Refresh Data HS110 192.1.1.131
                                2020-05-13 05:14:47.249 - debug: hs100.0 (24105) Month value Model : HS110(EU) IP : 192.1.1.131
                                2020-05-13 05:14:47.685 - debug: hs100.0 (24105) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
                                2020-05-13 05:14:48.934 - debug: hs100.0 (24105) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 05:14:48
                                2020-05-13 05:14:51.260 - debug: hs100.0 (24105) Refresh Data HS110 192.1.1.132
                                2020-05-13 05:14:52.131 - debug: hs100.0 (24105) Month value Model : HS110(EU) IP : 192.1.1.132
                                2020-05-13 05:14:52.567 - debug: hs100.0 (24105) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
                                • B Berchemer
                                  @skokarl
                                  Ok, ok, ok... ;-)
                                  skokarl
                                  #102
                                  @skokarl
                                  Ok, ok, ok... ;-)
                                  wichtig ist ja nur ob die Streckdose die gleiche bleibt, dann ist es vermutlich echt die Dose.
                                  • S skokarl
                                    @skokarl
                                    Ok, ok, ok... ;-)
                                    Berchemer
                                    #103
                                    @skokarl sagte in HS100 Adapter Fehlermeldungen:
                                    Mag sein. Wobei in der Vergangenheit der Fehler auch mal von der .132er Steckdose ausgelöst wurde.
                                    Und ansonsten funktioniert die Dose ja eigentlich. Zumindest was das Schalten angeht.
                                    Müsste man den Fehler nicht trotzdem abfangen können/müssen und statt dessen ggf. mit einer Warnmeldung versehen?
                                    Wodurch kommt eigentlich so ein Timeout zustande? Der Adapter erwartet eine Meldung von der Steckdose. Diese bleibt aus und dann kommt ein Timeout oder? Bei schlechten WLAN könnte so etwas immer mal wieder auftauchen und sollte eigentlich nicht zu einem Abbruch der API mit einem Fehler führen. Meine ich zumindest.
                                    Nicht dass ich an der Stecke klebe...
                                    Wenn die weiter muckt, wird sie durch eine innr ersetzt und gut ist ;-)
                                    • B Berchemer
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #104
                                      @Berchemer nicht der Adapter erwartet dieRrückmeldung sondern die Zwischenschicht.. auf der baut der Adapter auf ..
                                      hier knallts
                                      • arteckA arteck
                                        hier knallts
                                        Berchemer
                                        #105
                                        hier knallts
                                        Yeppp. Ist mir schon klar. Meinte ich ja auch mit
                                        " ... nicht zu einem Abbruch der API mit einem Fehler führen."
                                        Oder sollte man statt API eher Socket sagen?
                                        Ist wohl so, dass Du vielleicht doch ein Issue bei dem API-Ersteller (oder so) machen solltest.
                                        Wenn nicht schon geschehen ;-)
                                        Danke auch dafür :-) 👍
                                          Berchemer
                                          #106
                                          Habe den .131'er seit 23 Stunden offline.
                                          Zwischendurch gab es auch mal einen Neustart des Servers.
                                          Keine Fehlermeldung seither.
                                          Warte aber lieber bis morgen :-)
