  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser
    libpixman-1-0 set to manually installed
    Musst du also mal manuell angelegt haben. Bei Upgrades wird der dann nicht mehr angepasst.
    klausiob
    schrieb am zuletzt editiert von klausiob
    @Thomas-Braun Habe auch nochmal die Essentials wie oben installiert. War auch alles aktuell, nur gif noch dazu installiert.
    Meldete auch
    libpixman-1-0 set to manually installed.
    obwohl ich nie was manuell installiert hatte.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 9.6 (stretch)
    Release:        9.6
    Codename:       stretch
    Also bringt buster-Installation auch nichts?
    $ ./iobroker upgrade hs100
    Update hs100 from @1.1.2 to @1.1.5
    NPM version: 6.14.4npm install iobroker.hs100@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
    ERR!
    sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
    info
     sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^compilation terminated.
    make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.14.79-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [3] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
    Adapter "system.adapter.hs100.0" restarted.
    Update "system.adapter.hs100.0"
    upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index_m.html index_m.html text/html
    upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
    upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
    Adapter "hs100" updated
    process exited with code 0
    Problem bleibt bei fast jedem Adapteruodate. Problem liegt doch offenbar in dem Bereich.
    info
    Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
    node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
    • S Smartuser
      @Thomas-Braun sagte in Update js-controller und node.js:
      @Smartuser
      Moin ...
      nein eigentlich nicht. Es ist ein frisch aufgesetztes Buster (Stable). Iobroker drauf, Backup eingespielt, proftp und cifs pakete drauf ... fertig.
      Wenn libpixman manuell installiert wurde, müsste es bei der Installation von iobroker passiert sein.
      Kann das sein?
      Wie bekomme ich es behoben, so dass es wieder bei den upgrades mit angepasst wird?
      @Smartuser
      sudo apt update
      sudo apt dist-upgrade
      sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
      • K klausiob
        Meldete auch
        Release:        9.6
        Codename:       stretch
        ERR!
        info
        gyp
         ERR! build error
        info
        @klausiob sagte in Update js-controller und node.js:
        libvips >= 8.9.1
        Muss in dieser Version installiert sein. Das ist auf stretch aber blöder hantier. Da muss einiges umgebaut werden.
          libvips >= 8.9.1
          klausiob
          @Thomas-Braun
          Hilft das hier weiter?
          • K klausiob
            @Thomas-Braun
            @klausiob Mir schon. Muss dir aber ja helfen...
            Von der Seite her weiß ich ja, das es blöder Hantier auf einem Stretch mit ARM-Architektur und glibc < 2.28 ist.
              @Smartuser
              sudo apt update
              Smartuser
              schrieb am zuletzt editiert von Smartuser
              @Smartuser
              sudo apt update
              Hilft leider auch nicht.
              sudo apt update und sudo apt dist-upgrade durchgeführt, danach:
              rock64@rock64:~$ sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
              Reading package lists... Done
              Building dependency tree
              0 upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded.
              Need to get 0 B/889 kB of archives.
              After this operation, 0 B of additional disk space will be used.
              (Reading database ... 42427 files and directories currently installed.)
              Preparing to unpack .../libpixman-1-0_0.36.0-1_arm64.deb ...
              Unpacking libpixman-1-0:arm64 (0.36.0-1) over (0.36.0-1) ...
              Preparing to unpack .../libpixman-1-dev_0.36.0-1_arm64.deb ...
              Unpacking libpixman-1-dev:arm64 (0.36.0-1) over (0.36.0-1) ...
              Setting up libpixman-1-0:arm64 (0.36.0-1) ...
              Setting up libpixman-1-dev:arm64 (0.36.0-1) ...
              Processing triggers for libc-bin (2.28-10) ...
              rock64@rock64:~$
              Ist sauber durchgelaufen, zur sicherheit reboot durchgeführt. Danach ein adapter upgrade gestartet.
              Das Ergebnis bleibt unverändert.
              rock64@rock64:/opt/iobroker$ iobroker upgrade rpi2
              Update rpi2 from @1.1.1 to @1.2.0
              NPM version: 6.14.4
              npm install iobroker.rpi2@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
              ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
              info sharp Attempting to build from source via node-gyp but this may fail due to the above error
              ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
              make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
              gyp ERR! build error
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! System Linux 4.4.213-rockchip64
              gyp ERR! node -v v12.16.3
              gyp ERR! not ok
              upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
              Update "system.adapter.rpi2.0"
              upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
              upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
              upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
              Adapter "rpi2" updated
              • S Smartuser
                @Smartuser
                sudo apt update
                rock64@rock64:~$
                NPM version: 6.14.4
                gyp ERR! not ok
                @Smartuser sagte in Update js-controller und node.js:
                Hat doch funktioniert.
                  Smartuser
                  Ja ... die Updates funktionieren scheinbar immer. Das hatte ich oben auch so geschrieben:
                  Zitat: Die Updates laufen trotz der Fehlermeldung.
                  '________
                  Allerdings scheint es zum Beispiel beim iot adapter nicht richtig zu funktionieren:
                  rock64@rock64:~$ cd /opt/iobroker/
                  rock64@rock64:/opt/iobroker$ iobroker upgrade iot
                  Update iot from @1.4.12 to @1.4.14
                  host.rock64 Adapter "system.adapter.iot.0" is stopped.
                  NPM version: 6.14.4
                  npm install iobroker.iot@1.4.14 --loglevel error --prefix "/opt/iobroker" (System call)
                  gyp ERR! not ok
                  Update "system.adapter.iot.0"
                  upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
                  upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
                  upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js.map static/js/main.25253be6.chunk.js.map application/json
                  upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js static/js/main.25253be6.chunk.js application/javascript
                  upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.map static/js/2.d2785704.chunk.js.map application/json
                  upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.LICENSE.txt static/js/2.d2785704.chunk.js.LICENSE.txt text/plain
                  upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js static/js/2.d2785704.chunk.js application/javascript
                  upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
                  upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
                  upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
                  upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
                  upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
                  upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js application/javascript
                  upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
                  upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
                  upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
                  upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                  upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
                  upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
                  upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
                  upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                  Adapter "iot" updated
                  host.rock64 Adapter "system.adapter.iot.0" is started
                  Hier tritt neben (oder durch?) das libvibs-problem noch ein problem mit sharp auf.
                  Und dieser stört sich auch daran, er meldet im log immer:
                  iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/main.js
                  iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/alexaCustomBlood.js
                  iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/getImage.js
                  iot.0	2020-05-09 11:00:08.814	warn	Require stack:
                  iot.0	2020-05-09 11:00:08.814	warn	(11435) Cannot initialize getImage: Error: Cannot find module 'sharp'
                  Daher hätte ich gern die Fehler weg um auszuschließen, dass bei einigen Adaptern etwas schief läuft :)
                  • S Smartuser
                    '________
                    NPM version: 6.14.4
                    gyp ERR! not ok
                    @Smartuser
                    libvips und sharp hängen zusammen. Haben beide mit Bildbearbeitung zu tun.
                    Dann lass uns mal genau schauen, mit was du da unterwegs bist:
                    ldd --version
                    lsb_release -a
                    uname -a
                      @Smartuser
                      ldd --version
                      lsb_release -a
                      uname -a
                      Smartuser
                      @Smartuser
                      ldd --version
                      lsb_release -a
                      uname -a
                      Danke schonmal!
                      So sieht das Ganze aus:
                      rock64@rock64:~$ ldd --version
                      ldd (Debian GLIBC 2.28-10) 2.28
                      Copyright (C) 2018 Free Software Foundation, Inc.
                      This is free software; see the source for copying conditions.  There is NO
                      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                      Written by Roland McGrath and Ulrich Drepper.
                      rock64@rock64:~$
                      rock64@rock64:~$ lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Debian
                      Description:    Debian GNU/Linux 10 (buster)
                      Release:        10
                      Codename:       buster
                      rock64@rock64:~$
                      rock64@rock64:~$ uname -a
                      Linux rock64 4.4.213-rockchip64 #27 SMP Tue Apr 14 17:21:23 CEST 2020 aarch64 GNU/Linux
                      rock64@rock64:~$
                      • S Smartuser
                        @Smartuser
                        ldd --version
                        lsb_release -a
                        uname -a
                        Danke schonmal!
                        rock64@rock64:~$
                        Release:        10
                        Codename:       buster
                        rock64@rock64:~$
                        rock64@rock64:~$
                        @Smartuser Noch was vergessen...
                        Node ist sauber installiert? Und das System auch auf dem letzten Stand?
                        nodejs -v
                        sudo apt update && sudo apt dist-upgrade
                          nodejs -v
                          Smartuser
                          nodejs -v
                          rock64@rock64:~$ nodejs -v
                          v12.16.3
                          rock64@rock64:~$
                          Interessant heute morgen brachte dist-upgrade keine Neuerungen, jetzt folgende:
                          rock64@rock64:~$ sudo apt update && sudo apt dist-upgrade
                          [sudo] password for rock64:
                          Get:1 http://httpredir.debian.org/debian buster InRelease [121 kB]
                          Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
                          Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
                          Get:5 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
                          Get:6 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
                          Hit:3 https://apt.armbian.com buster InRelease
                          Get:7 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
                          Get:8 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
                          Get:9 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
                          Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
                          Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
                          Get:12 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-09-1408.15.pdiff [198 B]
                          Get:13 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-09-1408.15.pdiff [199 B]
                          Get:14 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-09-1408.15.pdiff [241 B]
                          Get:15 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-09-1408.15.pdiff [242 B]
                          Get:16 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
                          Get:17 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.1 MB]
                          Get:18 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.3 MB]
                          Get:19 http://httpredir.debian.org/debian buster/contrib arm64 Packages [46.8 kB]
                          Get:20 http://httpredir.debian.org/debian buster/contrib armhf Packages [48.9 kB]
                          Get:21 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.8 kB]
                          Get:22 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.5 kB]
                          Get:23 http://httpredir.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
                          Get:24 http://httpredir.debian.org/debian buster/non-free armhf Packages [74.5 kB]
                          Get:25 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
                          Get:26 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
                          Fetched 95.7 MB in 1min 9s (1,396 kB/s)
                          25 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.4'
                          Calculating upgrade... Done
                          The following packages will be upgraded:
                            base-files distro-info-data fuse gir1.2-pango-1.0 iputils-arping iputils-ping libfuse2 libnss-myhostname libpam-systemd libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libsystemd0 libudev-dev
                            libudev1 linux-libc-dev pango1.0-tools proftpd-basic systemd systemd-sysv tzdata udev wpasupplicant
                          25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 11.8 MB of archives.
                          After this operation, 50.2 kB of additional disk space will be used.
                          Do you want to continue? [Y/n] y
                          Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u4 [69.8 kB]
                          Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u4 [99.9 kB]
                          Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u4 [200 kB]
                          Get:4 http://httpredir.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u4 [110 kB]
                          Get:5 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u4 [313 kB]
                          Get:6 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u4 [122 kB]
                          Get:7 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u4 [3,256 kB]
                          Get:8 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u4 [1,246 kB]
                          Get:9 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u4 [146 kB]
                          Get:10 http://httpredir.debian.org/debian buster/main arm64 tzdata all 2020a-0+deb10u1 [263 kB]
                          Get:11 http://httpredir.debian.org/debian buster/main arm64 iputils-ping arm64 3:20180629-2+deb10u1 [42.9 kB]
                          Get:12 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u2 [6,584 B]
                          Get:13 http://httpredir.debian.org/debian buster/main arm64 fuse arm64 2.9.9-1+deb10u1 [71.4 kB]
                          Get:14 http://httpredir.debian.org/debian buster/main arm64 libfuse2 arm64 2.9.9-1+deb10u1 [123 kB]
                          Get:15 http://httpredir.debian.org/debian buster/main arm64 pango1.0-tools arm64 1.42.4-8~deb10u1 [55.2 kB]
                          Get:16 http://httpredir.debian.org/debian buster/main arm64 libpango1.0-dev arm64 1.42.4-8~deb10u1 [139 kB]
                          Get:17 http://httpredir.debian.org/debian buster/main arm64 libpango-1.0-0 arm64 1.42.4-8~deb10u1 [179 kB]
                          Get:18 http://httpredir.debian.org/debian buster/main arm64 libpangoft2-1.0-0 arm64 1.42.4-8~deb10u1 [65.7 kB]
                          Get:19 http://httpredir.debian.org/debian buster/main arm64 libpangocairo-1.0-0 arm64 1.42.4-8~deb10u1 [54.0 kB]
                          Get:20 http://httpredir.debian.org/debian buster/main arm64 libpangoxft-1.0-0 arm64 1.42.4-8~deb10u1 [49.1 kB]
                          Get:21 http://httpredir.debian.org/debian buster/main arm64 gir1.2-pango-1.0 arm64 1.42.4-8~deb10u1 [55.8 kB]
                          Get:22 http://httpredir.debian.org/debian buster/main arm64 iputils-arping arm64 3:20180629-2+deb10u1 [20.2 kB]
                          Get:23 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.118-2 [1,332 kB]
                          Get:24 http://httpredir.debian.org/debian buster/main arm64 proftpd-basic arm64 1.3.6-4+deb10u5 [2,614 kB]
                          Get:25 http://httpredir.debian.org/debian buster/main arm64 wpasupplicant arm64 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,166 kB]
                          Fetched 11.8 MB in 7s (1,719 kB/s)
                          Preconfiguring packages ...
                          Preparing to unpack .../base-files_10.3+deb10u4_arm64.deb ...
                          Unpacking base-files (10.3+deb10u4) over (10.3+deb10u3) ...
                          Setting up base-files (10.3+deb10u4) ...
                          Installing new version of config file /etc/debian_version ...
                          Preparing to unpack .../systemd-sysv_241-7~deb10u4_arm64.deb ...
                          Unpacking systemd-sysv (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../libpam-systemd_241-7~deb10u4_arm64.deb ...
                          Unpacking libpam-systemd:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../libudev-dev_241-7~deb10u4_arm64.deb ...
                          Unpacking libudev-dev:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../libsystemd0_241-7~deb10u4_arm64.deb ...
                          Unpacking libsystemd0:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                          Setting up libsystemd0:arm64 (241-7~deb10u4) ...
                          Preparing to unpack .../libnss-myhostname_241-7~deb10u4_arm64.deb ...
                          Unpacking libnss-myhostname:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../systemd_241-7~deb10u4_arm64.deb ...
                          Unpacking systemd (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../udev_241-7~deb10u4_arm64.deb ...
                          Unpacking udev (241-7~deb10u4) over (241-7~deb10u3) ...
                          Preparing to unpack .../libudev1_241-7~deb10u4_arm64.deb ...
                          Unpacking libudev1:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                          Setting up libudev1:arm64 (241-7~deb10u4) ...
                          Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
                          Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
                          Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_arm64.deb ...
                          Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                          Preparing to unpack .../02-distro-info-data_0.41+deb10u2_all.deb ...
                          Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
                          Preparing to unpack .../03-fuse_2.9.9-1+deb10u1_arm64.deb ...
                          Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
                          Preparing to unpack .../04-libfuse2_2.9.9-1+deb10u1_arm64.deb ...
                          Unpacking libfuse2:arm64 (2.9.9-1+deb10u1) over (2.9.9-1) ...
                          Preparing to unpack .../05-pango1.0-tools_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking pango1.0-tools (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../06-libpango1.0-dev_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking libpango1.0-dev:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../07-libpango-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking libpango-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../08-libpangoft2-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../09-libpangocairo-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../10-libpangoxft-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../11-gir1.2-pango-1.0_1.42.4-8~deb10u1_arm64.deb ...
                          Unpacking gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                          Preparing to unpack .../12-iputils-arping_3%3a20180629-2+deb10u1_arm64.deb ...
                          Unpacking iputils-arping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                          Preparing to unpack .../13-linux-libc-dev_4.19.118-2_arm64.deb ...
                          Unpacking linux-libc-dev:arm64 (4.19.118-2) over (4.19.98-1+deb10u1) ...
                          Preparing to unpack .../14-proftpd-basic_1.3.6-4+deb10u5_arm64.deb ...
                          Unpacking proftpd-basic (1.3.6-4+deb10u5) over (1.3.6-4+deb10u4) ...
                          Preparing to unpack .../15-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_arm64.deb ...
                          Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
                          Setting up distro-info-data (0.41+deb10u2) ...
                          Setting up libpango-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                          Setting up linux-libc-dev:arm64 (4.19.118-2) ...
                          Setting up systemd (241-7~deb10u4) ...
                          Setting up libfuse2:arm64 (2.9.9-1+deb10u1) ...
                          Setting up iputils-arping (3:20180629-2+deb10u1) ...
                          Setting up tzdata (2020a-0+deb10u1) ...
                          Current default time zone: 'Etc/UTC'
                          Local time is now:      Sat May  9 19:43:46 UTC 2020.
                          Universal Time is now:  Sat May  9 19:43:46 UTC 2020.
                          Run 'dpkg-reconfigure tzdata' if you wish to change it.
                          Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
                          Setting up proftpd-basic (1.3.6-4+deb10u5) ...
                          usermod: no changes
                          Setting up udev (241-7~deb10u4) ...
                          update-initramfs: deferring update (trigger activated)
                          Setting up libnss-myhostname:arm64 (241-7~deb10u4) ...
                          Setting up libudev-dev:arm64 (241-7~deb10u4) ...
                          Setting up libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                          Setting up iputils-ping (3:20180629-2+deb10u1) ...
                          Setting up libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                          Setting up fuse (2.9.9-1+deb10u1) ...
                          Setting up systemd-sysv (241-7~deb10u4) ...
                          Setting up libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                          Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
                          Setting up gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) ...
                          Setting up libpango1.0-dev:arm64 (1.42.4-8~deb10u1) ...
                          Setting up libpam-systemd:arm64 (241-7~deb10u4) ...
                          Processing triggers for man-db (2.8.5-2) ...
                          Processing triggers for dbus (1.12.16-1) ...
                          Processing triggers for initramfs-tools (0.133+deb10u1) ...
                          update-initramfs: Generating /boot/initrd.img-4.4.213-rockchip64
                          update-initramfs: Converting to u-boot format
                          rock64@rock64:~$
                          Leider zu früh gefreut, ich hab danach einen reboot ausgeführt, aber der Fehler besteht weiterhin.
                          Hier beim Upgrade vom WEB-Adapter:
                          rock64@rock64:/opt/iobroker$ iobroker upgrade web
                          Update web from @3.0.7 to @3.0.8
                          host.rock64 Adapter "system.adapter.web.0" is stopped.
                          NPM version: 6.14.4
                          npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                          gyp ERR! not ok
                          upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                          upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                          upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                          upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                          upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                          upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                          upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                          upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                          upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                          upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                          upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                          upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                          upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                          upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                          upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                          upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                          upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                          upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                          upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                          upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                          upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                          upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                          upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                          upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                          upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                          upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                          upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                          upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                          upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                          upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                          upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                          upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                          upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                          upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                          upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                          upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                          upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                          upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                          Update "system.adapter.web.0"
                          Adapter "web" updated
                          host.rock64 Adapter "system.adapter.web.0" is started
                          • S Smartuser
                            nodejs -v
                            v12.16.3
                            rock64@rock64:~$
                            usermod: no changes
                            rock64@rock64:~$
                            NPM version: 6.14.4
                            gyp ERR! not ok
                            @Smartuser Das ist klar, das auch ein dist-upgrade da nichts ändert. Du hast ja noch gar nichts kompiliert.
                            Allerdings hast du da einen ziemlichen Wildwuchs in deinen Paketquellen.
                            Gut (oder auch nicht), versuchen wir zu bauen:
                            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                              Smartuser
                              Wie gesagt ist ein "frisches" Image gewesen.😊 Von hier
                              rock64@rock64:/opt/iobroker$ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                              build-essential is already the newest version (12.6).
                              libcairo2-dev is already the newest version (1.16.0-4).
                              libgif-dev is already the newest version (5.1.4-3).
                              libjpeg-dev is already the newest version (1:1.5.2-2).
                              librsvg2-dev is already the newest version (2.44.10-2.1).
                              libpango1.0-dev is already the newest version (1.42.4-8~deb10u1).
                              libpixman-1-0 is already the newest version (0.36.0-1).
                              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                              • S Smartuser
                                Das heißt ja nix. Die Pakete sind überwiegend -dev. Normalerweise sind die nicht installiert. Wie dem auch sei.
                                cd /opt/iobroker
                                npm i sharp
                                  cd /opt/iobroker
                                  npm i sharp
                                  Smartuser
                                  cd /opt/iobroker
                                  npm i sharp
                                  rock64@rock64:/opt/iobroker$ npm i sharp
                                  > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                                  > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                                  make: Entering directory '/opt/iobroker/node_modules/sharp/build'
                                    CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                                    AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                                    COPY Release/nothing.a
                                    TOUCH Release/obj.target/libvips-cpp.stamp
                                    CXX(target) Release/obj.target/sharp/src/common.o
                                  make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
                                  gyp ERR! not ok
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 1
                                  npm ERR! sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the sharp@0.25.2 install script.
                                  npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_10_27_487Z-debug.log
                                  • S Smartuser
                                    cd /opt/iobroker
                                    npm i sharp
                                    gyp ERR! not ok
                                    npm ERR! errno 1
                                    npm ERR!
                                    @Smartuser
                                    sudo apt install libvips-dev
                                    [Edit:] Ich sehe gerade, die dürfte zu alt sein.
                                    apt policy libvips-dev
                                    S 2 Antworten Letzte Antwort
                                      @Smartuser
                                      Smartuser
                                      Ok ... jetzt wurde eine Menge sauber, ohne Fehler installiert
                                      0 upgraded, 120 newly installed, 0 to remove and 0 not upgraded.
                                      Need to get 58.5 MB of archives.
                                      After this operation, 218 MB of additional disk space will be used.
                                      Ich spar mir mal den ganzen log. ;)
                                      • S Smartuser
                                        @Smartuser Wooo... Da zieht libvips aber einiges mit...
                                        cd /opt/iobroker
                                        npm i libvips
                                          cd /opt/iobroker
                                          npm i libvips
                                          Smartuser
                                          npm i libvips
                                          Hmmm ....
                                          rock64@rock64:/opt/iobroker$ npm i libvips
                                          In file included from ../src/common.cc:23:
                                          /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
                                           #include <glib-object.h>
                                          gyp ERR! not ok
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                          + libvips@0.0.2
                                          added 1 package in 101.931s
                                          22 packages are looking for funding
                                            run `npm fund` for details
