  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @klausiob Du brauchst ein aktuelles libvips bzw. libvips-dev
    Ich fürchte nur, das baut keiner für Stretch.
    Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    Hallöchen,
    ich häng mich hier mal mit dran. Nur an Stretch allein scheint es nicht zu liegen. Bei buster tritt auch diese Medlung auf.
    rock64@rock64:/opt/iobroker$ iobroker upgrade backitup
    Update backitup from @1.4.5 to @1.5.6
    host.rock64 Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.backitup@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    Update "system.adapter.backitup.0"
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    Adapter "backitup" updated
    host.rock64 Adapter "system.adapter.backitup.0" is started
    Die Updates laufen trotz der Fehlermeldung.
    Hardware: Rock64
    JS-Controller: 3.0.20
    Dist (stable buster):
    rock64@rock64:/opt/iobroker$ lsb_release -a
    No LSB modules are available.
    Distributor ID: Debian
    Description:    Debian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    Node/NodeJS:
    rock64@rock64:/opt/iobroker$ node -v
    v12.16.3
    rock64@rock64:/opt/iobroker$ nodejs -v
    v12.16.3
    • S Smartuser
      Hallöchen,
      NPM version: 6.14.4
      gyp ERR! not ok
      Hardware: Rock64
      Release:        10
      Codename:       buster
      Node/NodeJS:
      v12.16.3
      v12.16.3
      @Smartuser sagte in Update js-controller und node.js:
      Nein, auch in buster muss man noch Hand anlegen. Aber deutlich weniger als unter stretch.
        Smartuser
        Ja scheint so :)
        Hast du einen Tip/Link wie und wo man Hand anlegt um die Meldungen wegzubekommen?
        Die Suche hat mir leider noch nicht weitergeholfen.
        • S Smartuser
          Ja scheint so :)
          @Smartuser
          Leg mal so Hand an:
          sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
            @Smartuser
            Leg mal so Hand an:
            Smartuser
            @Smartuser
            Leg mal so Hand an:
            Danke für deine schnellen Rückmeldungen.👍
            In dem Fall ist scheinbar alles schon in der aktuellsten Version vorhanden:
            rock64@rock64:~$ sudo apt-get install build-essential libcairo2-dev libpango1.0-        dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
            [sudo] password for rock64:
            Reading package lists... Done
            Building dependency tree
            build-essential is already the newest version (12.6).
            libcairo2-dev is already the newest version (1.16.0-4).
            libgif-dev is already the newest version (5.1.4-3).
            libjpeg-dev is already the newest version (1:1.5.2-2).
            librsvg2-dev is already the newest version (2.44.10-2.1).
            libpango1.0-dev is already the newest version (1.42.4-7~deb10u1).
            libpixman-1-0 is already the newest version (0.36.0-1).
            libpixman-1-0 set to manually installed.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            rock64@rock64:~$
            • S Smartuser
              @Smartuser
              Leg mal so Hand an:
              rock64@rock64:~$
              @Smartuser
              Musst du also mal manuell angelegt haben. Bei Upgrades wird der dann nicht mehr angepasst.
              S K 2 Antworten Letzte Antwort
                @Smartuser
                Smartuser
                @Smartuser
                Moin ...
                nein eigentlich nicht. Es ist ein frisch aufgesetztes Buster (Stable). Iobroker drauf, Backup eingespielt, proftp und cifs pakete drauf ... fertig.
                Wenn libpixman manuell installiert wurde, müsste es bei der Installation von iobroker passiert sein.
                Kann das sein?
                Wie bekomme ich es behoben, so dass es wieder bei den upgrades mit angepasst wird?
                  @Smartuser
                  klausiob
                  schrieb am zuletzt editiert von klausiob
                  @Thomas-Braun Habe auch nochmal die Essentials wie oben installiert. War auch alles aktuell, nur gif noch dazu installiert.
                  Meldete auch
                  obwohl ich nie was manuell installiert hatte.
                  Distributor ID: Raspbian
                  Description:    Raspbian GNU/Linux 9.6 (stretch)
                  Release:        9.6
                  Codename:       stretch
                  Also bringt buster-Installation auch nichts?
                  $ ./iobroker upgrade hs100
                  Update hs100 from @1.1.2 to @1.1.5
                  NPM version: 6.14.4npm install iobroker.hs100@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
                  ERR!
                  sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
                  info
                   sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                  ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^compilation terminated.
                  make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                  gyp
                   ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.14.79-v7+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                  upload [3] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
                  Adapter "system.adapter.hs100.0" restarted.
                  Update "system.adapter.hs100.0"
                  upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index_m.html index_m.html text/html
                  upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
                  upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
                  Adapter "hs100" updated
                  process exited with code 0
                  Problem bleibt bei fast jedem Adapteruodate. Problem liegt doch offenbar in dem Bereich.
                  info
                  Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                  node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                  • S Smartuser
                    @Smartuser
                    Moin ...
                    Kann das sein?
                    @Smartuser
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
                    • K klausiob
                      Meldete auch
                      Release:        9.6
                      Codename:       stretch
                      ERR!
                      info
                      gyp
                       ERR! build error
                      info
                      @klausiob sagte in Update js-controller und node.js:
                      libvips >= 8.9.1
                      Muss in dieser Version installiert sein. Das ist auf stretch aber blöder hantier. Da muss einiges umgebaut werden.
                        libvips >= 8.9.1
                        klausiob
                        @Thomas-Braun
                        Hilft das hier weiter?
                        • K klausiob
                          @Thomas-Braun
                          @klausiob Mir schon. Muss dir aber ja helfen...
                          Von der Seite her weiß ich ja, das es blöder Hantier auf einem Stretch mit ARM-Architektur und glibc < 2.28 ist.
                            @Smartuser
                            sudo apt update
                            Smartuser
                            schrieb am zuletzt editiert von Smartuser
                            @Smartuser
                            sudo apt update
                            Hilft leider auch nicht.
                            sudo apt update und sudo apt dist-upgrade durchgeführt, danach:
                            rock64@rock64:~$ sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
                            0 upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded.
                            Need to get 0 B/889 kB of archives.
                            After this operation, 0 B of additional disk space will be used.
                            (Reading database ... 42427 files and directories currently installed.)
                            Preparing to unpack .../libpixman-1-0_0.36.0-1_arm64.deb ...
                            Unpacking libpixman-1-0:arm64 (0.36.0-1) over (0.36.0-1) ...
                            Preparing to unpack .../libpixman-1-dev_0.36.0-1_arm64.deb ...
                            Unpacking libpixman-1-dev:arm64 (0.36.0-1) over (0.36.0-1) ...
                            Setting up libpixman-1-0:arm64 (0.36.0-1) ...
                            Setting up libpixman-1-dev:arm64 (0.36.0-1) ...
                            Processing triggers for libc-bin (2.28-10) ...
                            rock64@rock64:~$
                            Ist sauber durchgelaufen, zur sicherheit reboot durchgeführt. Danach ein adapter upgrade gestartet.
                            Das Ergebnis bleibt unverändert.
                            rock64@rock64:/opt/iobroker$ iobroker upgrade rpi2
                            Update rpi2 from @1.1.1 to @1.2.0
                            NPM version: 6.14.4
                            npm install iobroker.rpi2@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
                            gyp ERR! not ok
                            upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                            Update "system.adapter.rpi2.0"
                            upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                            upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                            upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
                            Adapter "rpi2" updated
                            • S Smartuser
                              @Smartuser
                              sudo apt update
                              rock64@rock64:~$
                              NPM version: 6.14.4
                              gyp ERR! not ok
                              Hat doch funktioniert.
                                Smartuser
                                Ja ... die Updates funktionieren scheinbar immer. Das hatte ich oben auch so geschrieben:
                                Zitat: Die Updates laufen trotz der Fehlermeldung.
                                '________
                                Allerdings scheint es zum Beispiel beim iot adapter nicht richtig zu funktionieren:
                                rock64@rock64:~$ cd /opt/iobroker/
                                rock64@rock64:/opt/iobroker$ iobroker upgrade iot
                                Update iot from @1.4.12 to @1.4.14
                                host.rock64 Adapter "system.adapter.iot.0" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.iot@1.4.14 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                Update "system.adapter.iot.0"
                                upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
                                upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
                                upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js.map static/js/main.25253be6.chunk.js.map application/json
                                upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js static/js/main.25253be6.chunk.js application/javascript
                                upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.map static/js/2.d2785704.chunk.js.map application/json
                                upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.LICENSE.txt static/js/2.d2785704.chunk.js.LICENSE.txt text/plain
                                upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js static/js/2.d2785704.chunk.js application/javascript
                                upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
                                upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
                                upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
                                upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
                                upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
                                upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js application/javascript
                                upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
                                upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
                                upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
                                upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
                                upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
                                upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
                                upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                Adapter "iot" updated
                                host.rock64 Adapter "system.adapter.iot.0" is started
                                Hier tritt neben (oder durch?) das libvibs-problem noch ein problem mit sharp auf.
                                Und dieser stört sich auch daran, er meldet im log immer:
                                iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/main.js
                                iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/alexaCustomBlood.js
                                iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/getImage.js
                                iot.0	2020-05-09 11:00:08.814	warn	Require stack:
                                iot.0	2020-05-09 11:00:08.814	warn	(11435) Cannot initialize getImage: Error: Cannot find module 'sharp'
                                Daher hätte ich gern die Fehler weg um auszuschließen, dass bei einigen Adaptern etwas schief läuft :)
                                • S Smartuser
                                  '________
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  @Smartuser
                                  libvips und sharp hängen zusammen. Haben beide mit Bildbearbeitung zu tun.
                                  Dann lass uns mal genau schauen, mit was du da unterwegs bist:
                                  ldd --version
                                  lsb_release -a
                                  uname -a
                                    @Smartuser
                                    ldd --version
                                    lsb_release -a
                                    uname -a
                                    Smartuser
                                    @Smartuser
                                    ldd --version
                                    lsb_release -a
                                    uname -a
                                    Danke schonmal!
                                    So sieht das Ganze aus:
                                    rock64@rock64:~$ ldd --version
                                    ldd (Debian GLIBC 2.28-10) 2.28
                                    Copyright (C) 2018 Free Software Foundation, Inc.
                                    This is free software; see the source for copying conditions.  There is NO
                                    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                                    Written by Roland McGrath and Ulrich Drepper.
                                    rock64@rock64:~$
                                    rock64@rock64:~$ lsb_release -a
                                    Release:        10
                                    Codename:       buster
                                    rock64@rock64:~$
                                    rock64@rock64:~$ uname -a
                                    Linux rock64 4.4.213-rockchip64 #27 SMP Tue Apr 14 17:21:23 CEST 2020 aarch64 GNU/Linux
                                    rock64@rock64:~$
                                    • S Smartuser
                                      @Smartuser
                                      ldd --version
                                      lsb_release -a
                                      uname -a
                                      Danke schonmal!
                                      rock64@rock64:~$
                                      Release:        10
                                      Codename:       buster
                                      rock64@rock64:~$
                                      rock64@rock64:~$
                                      @Smartuser Noch was vergessen...
                                      Node ist sauber installiert? Und das System auch auf dem letzten Stand?
                                      nodejs -v
                                      sudo apt update && sudo apt dist-upgrade
                                        nodejs -v
                                        Smartuser
                                        nodejs -v
                                        rock64@rock64:~$ nodejs -v
                                        v12.16.3
                                        rock64@rock64:~$
                                        Interessant heute morgen brachte dist-upgrade keine Neuerungen, jetzt folgende:
                                        rock64@rock64:~$ sudo apt update && sudo apt dist-upgrade
                                        Get:1 http://httpredir.debian.org/debian buster InRelease [121 kB]
                                        Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
                                        Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
                                        Get:5 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
                                        Get:6 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
                                        Hit:3 https://apt.armbian.com buster InRelease
                                        Get:7 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
                                        Get:8 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
                                        Get:9 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
                                        Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
                                        Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
                                        Get:12 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-09-1408.15.pdiff [198 B]
                                        Get:13 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-09-1408.15.pdiff [199 B]
                                        Get:14 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-09-1408.15.pdiff [241 B]
                                        Get:15 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-09-1408.15.pdiff [242 B]
                                        Get:16 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
                                        Get:17 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.1 MB]
                                        Get:18 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.3 MB]
                                        Get:19 http://httpredir.debian.org/debian buster/contrib arm64 Packages [46.8 kB]
                                        Get:20 http://httpredir.debian.org/debian buster/contrib armhf Packages [48.9 kB]
                                        Get:21 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.8 kB]
                                        Get:22 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.5 kB]
                                        Get:23 http://httpredir.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
                                        Get:24 http://httpredir.debian.org/debian buster/non-free armhf Packages [74.5 kB]
                                        Get:25 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
                                        Get:26 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
                                        Fetched 95.7 MB in 1min 9s (1,396 kB/s)
                                        25 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.4'
                                        Calculating upgrade... Done
                                        The following packages will be upgraded:
                                          base-files distro-info-data fuse gir1.2-pango-1.0 iputils-arping iputils-ping libfuse2 libnss-myhostname libpam-systemd libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libsystemd0 libudev-dev
                                          libudev1 linux-libc-dev pango1.0-tools proftpd-basic systemd systemd-sysv tzdata udev wpasupplicant
                                        25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 11.8 MB of archives.
                                        After this operation, 50.2 kB of additional disk space will be used.
                                        Do you want to continue? [Y/n] y
                                        Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u4 [69.8 kB]
                                        Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u4 [99.9 kB]
                                        Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u4 [200 kB]
                                        Get:4 http://httpredir.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u4 [110 kB]
                                        Get:5 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u4 [313 kB]
                                        Get:6 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u4 [122 kB]
                                        Get:7 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u4 [3,256 kB]
                                        Get:8 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u4 [1,246 kB]
                                        Get:9 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u4 [146 kB]
                                        Get:10 http://httpredir.debian.org/debian buster/main arm64 tzdata all 2020a-0+deb10u1 [263 kB]
                                        Get:11 http://httpredir.debian.org/debian buster/main arm64 iputils-ping arm64 3:20180629-2+deb10u1 [42.9 kB]
                                        Get:12 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u2 [6,584 B]
                                        Get:13 http://httpredir.debian.org/debian buster/main arm64 fuse arm64 2.9.9-1+deb10u1 [71.4 kB]
                                        Get:14 http://httpredir.debian.org/debian buster/main arm64 libfuse2 arm64 2.9.9-1+deb10u1 [123 kB]
                                        Get:15 http://httpredir.debian.org/debian buster/main arm64 pango1.0-tools arm64 1.42.4-8~deb10u1 [55.2 kB]
                                        Get:16 http://httpredir.debian.org/debian buster/main arm64 libpango1.0-dev arm64 1.42.4-8~deb10u1 [139 kB]
                                        Get:17 http://httpredir.debian.org/debian buster/main arm64 libpango-1.0-0 arm64 1.42.4-8~deb10u1 [179 kB]
                                        Get:18 http://httpredir.debian.org/debian buster/main arm64 libpangoft2-1.0-0 arm64 1.42.4-8~deb10u1 [65.7 kB]
                                        Get:19 http://httpredir.debian.org/debian buster/main arm64 libpangocairo-1.0-0 arm64 1.42.4-8~deb10u1 [54.0 kB]
                                        Get:20 http://httpredir.debian.org/debian buster/main arm64 libpangoxft-1.0-0 arm64 1.42.4-8~deb10u1 [49.1 kB]
                                        Get:21 http://httpredir.debian.org/debian buster/main arm64 gir1.2-pango-1.0 arm64 1.42.4-8~deb10u1 [55.8 kB]
                                        Get:22 http://httpredir.debian.org/debian buster/main arm64 iputils-arping arm64 3:20180629-2+deb10u1 [20.2 kB]
                                        Get:23 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.118-2 [1,332 kB]
                                        Get:24 http://httpredir.debian.org/debian buster/main arm64 proftpd-basic arm64 1.3.6-4+deb10u5 [2,614 kB]
                                        Get:25 http://httpredir.debian.org/debian buster/main arm64 wpasupplicant arm64 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,166 kB]
                                        Fetched 11.8 MB in 7s (1,719 kB/s)
                                        Preconfiguring packages ...
                                        Preparing to unpack .../base-files_10.3+deb10u4_arm64.deb ...
                                        Unpacking base-files (10.3+deb10u4) over (10.3+deb10u3) ...
                                        Setting up base-files (10.3+deb10u4) ...
                                        Installing new version of config file /etc/debian_version ...
                                        Preparing to unpack .../systemd-sysv_241-7~deb10u4_arm64.deb ...
                                        Unpacking systemd-sysv (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../libpam-systemd_241-7~deb10u4_arm64.deb ...
                                        Unpacking libpam-systemd:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../libudev-dev_241-7~deb10u4_arm64.deb ...
                                        Unpacking libudev-dev:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../libsystemd0_241-7~deb10u4_arm64.deb ...
                                        Unpacking libsystemd0:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Setting up libsystemd0:arm64 (241-7~deb10u4) ...
                                        Preparing to unpack .../libnss-myhostname_241-7~deb10u4_arm64.deb ...
                                        Unpacking libnss-myhostname:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../systemd_241-7~deb10u4_arm64.deb ...
                                        Unpacking systemd (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../udev_241-7~deb10u4_arm64.deb ...
                                        Unpacking udev (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Preparing to unpack .../libudev1_241-7~deb10u4_arm64.deb ...
                                        Unpacking libudev1:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                                        Setting up libudev1:arm64 (241-7~deb10u4) ...
                                        Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
                                        Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
                                        Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_arm64.deb ...
                                        Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                                        Preparing to unpack .../02-distro-info-data_0.41+deb10u2_all.deb ...
                                        Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
                                        Preparing to unpack .../03-fuse_2.9.9-1+deb10u1_arm64.deb ...
                                        Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
                                        Preparing to unpack .../04-libfuse2_2.9.9-1+deb10u1_arm64.deb ...
                                        Unpacking libfuse2:arm64 (2.9.9-1+deb10u1) over (2.9.9-1) ...
                                        Preparing to unpack .../05-pango1.0-tools_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking pango1.0-tools (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../06-libpango1.0-dev_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking libpango1.0-dev:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../07-libpango-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking libpango-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../08-libpangoft2-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../09-libpangocairo-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../10-libpangoxft-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../11-gir1.2-pango-1.0_1.42.4-8~deb10u1_arm64.deb ...
                                        Unpacking gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                                        Preparing to unpack .../12-iputils-arping_3%3a20180629-2+deb10u1_arm64.deb ...
                                        Unpacking iputils-arping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                                        Preparing to unpack .../13-linux-libc-dev_4.19.118-2_arm64.deb ...
                                        Unpacking linux-libc-dev:arm64 (4.19.118-2) over (4.19.98-1+deb10u1) ...
                                        Preparing to unpack .../14-proftpd-basic_1.3.6-4+deb10u5_arm64.deb ...
                                        Unpacking proftpd-basic (1.3.6-4+deb10u5) over (1.3.6-4+deb10u4) ...
                                        Preparing to unpack .../15-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_arm64.deb ...
                                        Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
                                        Setting up distro-info-data (0.41+deb10u2) ...
                                        Setting up libpango-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up linux-libc-dev:arm64 (4.19.118-2) ...
                                        Setting up systemd (241-7~deb10u4) ...
                                        Setting up libfuse2:arm64 (2.9.9-1+deb10u1) ...
                                        Setting up iputils-arping (3:20180629-2+deb10u1) ...
                                        Setting up tzdata (2020a-0+deb10u1) ...
                                        Current default time zone: 'Etc/UTC'
                                        Local time is now:      Sat May  9 19:43:46 UTC 2020.
                                        Universal Time is now:  Sat May  9 19:43:46 UTC 2020.
                                        Run 'dpkg-reconfigure tzdata' if you wish to change it.
                                        Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
                                        Setting up proftpd-basic (1.3.6-4+deb10u5) ...
                                        usermod: no changes
                                        Setting up udev (241-7~deb10u4) ...
                                        update-initramfs: deferring update (trigger activated)
                                        Setting up libnss-myhostname:arm64 (241-7~deb10u4) ...
                                        Setting up libudev-dev:arm64 (241-7~deb10u4) ...
                                        Setting up libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up iputils-ping (3:20180629-2+deb10u1) ...
                                        Setting up libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up fuse (2.9.9-1+deb10u1) ...
                                        Setting up systemd-sysv (241-7~deb10u4) ...
                                        Setting up libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
                                        Setting up gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up libpango1.0-dev:arm64 (1.42.4-8~deb10u1) ...
                                        Setting up libpam-systemd:arm64 (241-7~deb10u4) ...
                                        Processing triggers for man-db (2.8.5-2) ...
                                        Processing triggers for dbus (1.12.16-1) ...
                                        Processing triggers for initramfs-tools (0.133+deb10u1) ...
                                        update-initramfs: Generating /boot/initrd.img-4.4.213-rockchip64
                                        update-initramfs: Converting to u-boot format
                                        rock64@rock64:~$
                                        Leider zu früh gefreut, ich hab danach einen reboot ausgeführt, aber der Fehler besteht weiterhin.
                                        Hier beim Upgrade vom WEB-Adapter:
                                        rock64@rock64:/opt/iobroker$ iobroker upgrade web
                                        Update web from @3.0.7 to @3.0.8
                                        host.rock64 Adapter "system.adapter.web.0" is stopped.
                                        NPM version: 6.14.4
                                        npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                                        gyp ERR! not ok
                                        upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                                        upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                        upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                        upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                                        upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                                        upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                                        upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                                        upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                                        upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                                        upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                                        upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                                        upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                                        upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                                        upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                                        upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                                        upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                                        upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                                        upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                                        upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                                        upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                                        upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                        upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                        upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                        upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                        upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                        upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                        upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                        upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                        upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                        upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                        upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                        upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                        upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                        upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                        upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                        upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                        upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                        upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                        Update "system.adapter.web.0"
                                        Adapter "web" updated
                                        host.rock64 Adapter "system.adapter.web.0" is started
                                        • S Smartuser
                                          nodejs -v
                                          v12.16.3
                                          rock64@rock64:~$
                                          usermod: no changes
                                          rock64@rock64:~$
                                          NPM version: 6.14.4
                                          gyp ERR! not ok
                                          @Smartuser Das ist klar, das auch ein dist-upgrade da nichts ändert. Du hast ja noch gar nichts kompiliert.
                                          Allerdings hast du da einen ziemlichen Wildwuchs in deinen Paketquellen.
                                          Gut (oder auch nicht), versuchen wir zu bauen:
