  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
  • K klausiob
    @Thomas-Braun
    Vorschlag 1 bringt folgendes Ergebnis:
    :/opt/iobroker $ npm i canvas
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
     #include <vips/vips8>
    compilation terminated.
    sharp.target.mk:130: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
    make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.14.79-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v10.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.20.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.14.79-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v10.20.1
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.6.1 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-05-02T06_59_03_859Z-debug.log
    Bei Vorschlag 2:
    E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/t/tiff/libtiff5_4.0.8-2+deb9u4_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
    E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
    Bin offenbar nicht der einzigste mit dem Fehler: Link Text
    Der Vorschlag hier hat auch nichts gebracht:
    sudo apt-get remove build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
    Paket »libgif-dev« ist nicht installiert, wird also auch nicht entfernt.
    Paket »libjpeg-dev« ist nicht installiert, wird also auch nicht entfernt.
    Paket »libpango1.0-dev« ist nicht installiert, wird also auch nicht entfernt.
    Paket »librsvg2-dev« ist nicht installiert, wird also auch nicht entfernt.
    Paket »libcairo2-dev« ist nicht installiert, wird also auch nicht entfernt.
    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
      g++ g++-6 libstdc++-6-dev
    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
    Die folgenden Pakete werden ENTFERNT:
      build-essential
    0 aktualisiert, 0 neu installiert, 1 zu entfernen und 91 nicht aktualisiert.
    Nach dieser Operation werden 20,5 kB Plattenplatz freigegeben.
    Möchten Sie fortfahren? [J/n] j
    (Lese Datenbank ... 41607 Dateien und Verzeichnisse sind derzeit installiert.)
    Entfernen von build-essential (12.3) ...
    Da muß wohl ein Profi mal drauf gucken. Das habe ich noch gefunden:
    Link Text
    @klausiob
    sudo apt update
    und dann nochmal die Pakete wie oben beschrieben installieren. Welches System hast du da eigentlich?
      @klausiob
      sudo apt update
      klausiob
      schrieb am zuletzt editiert von klausiob
      @Thomas-Braun Installation der Pakete lief erstmal fehlerfrei durch. Dummerweise scheint iobroker trotz o.g. Fehler die Updates zu installieren. Daher mußte ich jetzt ein anderen Adapter nehmen. Da kommen jetzt andere Fehler, aber offenbar zum gleichen Thema "imageprocessing" :
      $ ./iobroker upgrade shelly
      Update shelly from @3.2.5 to @3.2.6
      NPM version: 6.14.4
      npm install iobroker.shelly@3.2.6 --loglevel error --prefix "/opt/iobroker" (System call)
      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:189:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data > imgdOffset, "image data overlaps with another structure");
           ~~~~~~~~~~~^~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg)
      ../src/bmp/BMPParser.cc:204:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
           ~~~~~~~~~~~~~~~~~~~~~~^~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg)
      ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:../src/Canvas.cc:415:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]     if (canvas->nBytes() > node::Buffer::kMaxLength) {         ~~~~~~~~~~~~~~~~~^~~~~~
      ERR!
      sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1info sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
      ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      Killed
      ERROR: host.hsmart Cannot install iobroker.shelly@3.2.6: 137
      Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
      node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
      • K klausiob
        NPM version: 6.14.4
        ERR!
        gyp
         ERR! build error
        Killed
        @klausiob Was für ein System läuft da?
        lsb_release -a
          lsb_release -a
          klausiob
          @Thomas-Braun sagte in Update js-controller und node.js:
          lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 9.6 (stretch)
          Release:        9.6
          Codename:       stretch
          • K klausiob
            lsb_release -a
            Release:        9.6
            Codename:       stretch
            @klausiob Du brauchst ein aktuelles libvips bzw. libvips-dev
            Ich fürchte nur, das baut keiner für Stretch.
            K S 2 Antworten Letzte Antwort
              klausiob
              @Thomas-Braun Also Sackgasse? Das war aber die letztes Jahr empfohlene Disribution für den Raspi und Iobroker. Da können die doch einen nicht hängen lassen, noch dazu weil andere wohl auch das Problem haben nach dem Update von node und js-controller.
              Welche Alternativen gibts? Will evtl. auf einen Raspi 4 umsteigen und da muß ich ja eh allse neu aufsetzen.
              VG klausiob
              Thomas BraunT K 2 Antworten Letzte Antwort
              • K klausiob
                VG klausiob
                @klausiob
                Ich fahre ein raspbian Buster/stable bei mir. Ein dist-upgrade ist ja kein Hexenwerk.
                • K klausiob
                  VG klausiob
                  klausiob
                  @Homoran Ist es notwendig das rasbian stretch auf buster upzugraden, um die Fehler, die auch andere haben Fehlermeldung bei manuelles Update / Adapter zu vermeiden? Leider hat die Lösung gelöst - Was bedeudet diese Fehlermeldung? nicht funktioniert.
                    Smartuser
                    Hallöchen,
                    ich häng mich hier mal mit dran. Nur an Stretch allein scheint es nicht zu liegen. Bei buster tritt auch diese Medlung auf.
                    rock64@rock64:/opt/iobroker$ iobroker upgrade backitup
                    Update backitup from @1.4.5 to @1.5.6
                    host.rock64 Adapter "system.adapter.backitup.0" is stopped.
                    NPM version: 6.14.4
                    npm install iobroker.backitup@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
                    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
                    ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
                    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                    gyp ERR! System Linux 4.4.213-rockchip64
                    gyp ERR! node -v v12.16.3
                    gyp ERR! not ok
                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                    Update "system.adapter.backitup.0"
                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                    Adapter "backitup" updated
                    host.rock64 Adapter "system.adapter.backitup.0" is started
                    Die Updates laufen trotz der Fehlermeldung.
                    Hardware: Rock64
                    JS-Controller: 3.0.20
                    Dist (stable buster):
                    rock64@rock64:/opt/iobroker$ lsb_release -a
                    Distributor ID: Debian
                    Description:    Debian GNU/Linux 10 (buster)
                    Release:        10
                    Codename:       buster
                    Node/NodeJS:
                    rock64@rock64:/opt/iobroker$ node -v
                    v12.16.3
                    rock64@rock64:/opt/iobroker$ nodejs -v
                    v12.16.3
                    • S Smartuser
                      Hallöchen,
                      NPM version: 6.14.4
                      gyp ERR! not ok
                      Hardware: Rock64
                      Release:        10
                      Codename:       buster
                      Node/NodeJS:
                      v12.16.3
                      v12.16.3
                      @Smartuser sagte in Update js-controller und node.js:
                      Nein, auch in buster muss man noch Hand anlegen. Aber deutlich weniger als unter stretch.
                        Smartuser
                        Ja scheint so :)
                        Hast du einen Tip/Link wie und wo man Hand anlegt um die Meldungen wegzubekommen?
                        Die Suche hat mir leider noch nicht weitergeholfen.
                        • S Smartuser
                          Ja scheint so :)
                          @Smartuser
                          Leg mal so Hand an:
                          sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                            @Smartuser
                            Leg mal so Hand an:
                            Smartuser
                            @Smartuser
                            Leg mal so Hand an:
                            Danke für deine schnellen Rückmeldungen.👍
                            In dem Fall ist scheinbar alles schon in der aktuellsten Version vorhanden:
                            rock64@rock64:~$ sudo apt-get install build-essential libcairo2-dev libpango1.0-        dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                            [sudo] password for rock64:
                            Reading package lists... Done
                            Building dependency tree
                            build-essential is already the newest version (12.6).
                            libcairo2-dev is already the newest version (1.16.0-4).
                            libgif-dev is already the newest version (5.1.4-3).
                            libjpeg-dev is already the newest version (1:1.5.2-2).
                            librsvg2-dev is already the newest version (2.44.10-2.1).
                            libpango1.0-dev is already the newest version (1.42.4-7~deb10u1).
                            libpixman-1-0 is already the newest version (0.36.0-1).
                            libpixman-1-0 set to manually installed.
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            rock64@rock64:~$
                            • S Smartuser
                              @Smartuser
                              Leg mal so Hand an:
                              rock64@rock64:~$
                              @Smartuser
                              Musst du also mal manuell angelegt haben. Bei Upgrades wird der dann nicht mehr angepasst.
                              S K 2 Antworten Letzte Antwort
                                @Smartuser
                                Smartuser
                                @Smartuser
                                Moin ...
                                nein eigentlich nicht. Es ist ein frisch aufgesetztes Buster (Stable). Iobroker drauf, Backup eingespielt, proftp und cifs pakete drauf ... fertig.
                                Wenn libpixman manuell installiert wurde, müsste es bei der Installation von iobroker passiert sein.
                                Kann das sein?
                                Wie bekomme ich es behoben, so dass es wieder bei den upgrades mit angepasst wird?
                                  @Smartuser
                                  klausiob
                                  @Thomas-Braun Habe auch nochmal die Essentials wie oben installiert. War auch alles aktuell, nur gif noch dazu installiert.
                                  Meldete auch
                                  obwohl ich nie was manuell installiert hatte.
                                  Release:        9.6
                                  Codename:       stretch
                                  Also bringt buster-Installation auch nichts?
                                  $ ./iobroker upgrade hs100
                                  Update hs100 from @1.1.2 to @1.1.5
                                  NPM version: 6.14.4npm install iobroker.hs100@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
                                  ERR!
                                  info
                                  ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^compilation terminated.
                                  gyp
                                   ERR! build error
                                  upload [3] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
                                  Adapter "system.adapter.hs100.0" restarted.
                                  Update "system.adapter.hs100.0"
                                  upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index_m.html index_m.html text/html
                                  upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
                                  upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
                                  Adapter "hs100" updated
                                  process exited with code 0
                                  Problem bleibt bei fast jedem Adapteruodate. Problem liegt doch offenbar in dem Bereich.
                                  info
                                  • S Smartuser
                                    @Smartuser
                                    Moin ...
                                    Kann das sein?
                                    @Smartuser
                                    sudo apt update
                                    sudo apt dist-upgrade
                                    sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
                                    • K klausiob
                                      Meldete auch
                                      Release:        9.6
                                      Codename:       stretch
                                      ERR!
                                      info
                                      gyp
                                       ERR! build error
                                      info
                                      @klausiob sagte in Update js-controller und node.js:
                                      libvips >= 8.9.1
                                      Muss in dieser Version installiert sein. Das ist auf stretch aber blöder hantier. Da muss einiges umgebaut werden.
                                        libvips >= 8.9.1
                                        klausiob
                                        @Thomas-Braun
                                        Hilft das hier weiter?
                                        • K klausiob
                                          @Thomas-Braun
                                          @klausiob Mir schon. Muss dir aber ja helfen...
                                          Von der Seite her weiß ich ja, das es blöder Hantier auf einem Stretch mit ARM-Architektur und glibc < 2.28 ist.
