  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser
    sudo apt update
    sudo apt dist-upgrade
    sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
    Smartuser
    schrieb am zuletzt editiert von Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    @Smartuser
    sudo apt update
    Hilft leider auch nicht.
    sudo apt update und sudo apt dist-upgrade durchgeführt, danach:
    rock64@rock64:~$ sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
    Reading package lists... Done
    Building dependency tree
    0 upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 0 B/889 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 42427 files and directories currently installed.)
    Preparing to unpack .../libpixman-1-0_0.36.0-1_arm64.deb ...
    Unpacking libpixman-1-0:arm64 (0.36.0-1) over (0.36.0-1) ...
    Preparing to unpack .../libpixman-1-dev_0.36.0-1_arm64.deb ...
    Unpacking libpixman-1-dev:arm64 (0.36.0-1) over (0.36.0-1) ...
    Setting up libpixman-1-0:arm64 (0.36.0-1) ...
    Setting up libpixman-1-dev:arm64 (0.36.0-1) ...
    Processing triggers for libc-bin (2.28-10) ...
    rock64@rock64:~$
    Ist sauber durchgelaufen, zur sicherheit reboot durchgeführt. Danach ein adapter upgrade gestartet.
    Das Ergebnis bleibt unverändert.
    rock64@rock64:/opt/iobroker$ iobroker upgrade rpi2
    Update rpi2 from @1.1.1 to @1.2.0
    NPM version: 6.14.4
    npm install iobroker.rpi2@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    Update "system.adapter.rpi2.0"
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
    Adapter "rpi2" updated
    • S Smartuser
      @Smartuser
      sudo apt update
      rock64@rock64:~$
      NPM version: 6.14.4
      gyp ERR! not ok
      @Smartuser sagte in Update js-controller und node.js:
      Hat doch funktioniert.
        Smartuser
        Ja ... die Updates funktionieren scheinbar immer. Das hatte ich oben auch so geschrieben:
        Zitat: Die Updates laufen trotz der Fehlermeldung.
        '________
        Allerdings scheint es zum Beispiel beim iot adapter nicht richtig zu funktionieren:
        rock64@rock64:~$ cd /opt/iobroker/
        rock64@rock64:/opt/iobroker$ iobroker upgrade iot
        Update iot from @1.4.12 to @1.4.14
        host.rock64 Adapter "system.adapter.iot.0" is stopped.
        NPM version: 6.14.4
        npm install iobroker.iot@1.4.14 --loglevel error --prefix "/opt/iobroker" (System call)
        gyp ERR! not ok
        Update "system.adapter.iot.0"
        upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
        upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
        upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js.map static/js/main.25253be6.chunk.js.map application/json
        upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js static/js/main.25253be6.chunk.js application/javascript
        upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.map static/js/2.d2785704.chunk.js.map application/json
        upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.LICENSE.txt static/js/2.d2785704.chunk.js.LICENSE.txt text/plain
        upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js static/js/2.d2785704.chunk.js application/javascript
        upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
        upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
        upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
        upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
        upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
        upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js application/javascript
        upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
        upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
        upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
        upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
        upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
        upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
        upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
        Adapter "iot" updated
        host.rock64 Adapter "system.adapter.iot.0" is started
        Hier tritt neben (oder durch?) das libvibs-problem noch ein problem mit sharp auf.
        Und dieser stört sich auch daran, er meldet im log immer:
        iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/main.js
        iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/alexaCustomBlood.js
        iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/getImage.js
        iot.0	2020-05-09 11:00:08.814	warn	Require stack:
        iot.0	2020-05-09 11:00:08.814	warn	(11435) Cannot initialize getImage: Error: Cannot find module 'sharp'
        Daher hätte ich gern die Fehler weg um auszuschließen, dass bei einigen Adaptern etwas schief läuft :)
        • S Smartuser
          '________
          NPM version: 6.14.4
          gyp ERR! not ok
          @Smartuser
          libvips und sharp hängen zusammen. Haben beide mit Bildbearbeitung zu tun.
          Dann lass uns mal genau schauen, mit was du da unterwegs bist:
          ldd --version
          lsb_release -a
          uname -a
            @Smartuser
            ldd --version
            lsb_release -a
            uname -a
            Smartuser
            @Smartuser
            ldd --version
            lsb_release -a
            uname -a
            Danke schonmal!
            So sieht das Ganze aus:
            rock64@rock64:~$ ldd --version
            ldd (Debian GLIBC 2.28-10) 2.28
            Copyright (C) 2018 Free Software Foundation, Inc.
            This is free software; see the source for copying conditions.  There is NO
            warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
            Written by Roland McGrath and Ulrich Drepper.
            rock64@rock64:~$
            rock64@rock64:~$ lsb_release -a
            No LSB modules are available.
            Distributor ID: Debian
            Description:    Debian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            rock64@rock64:~$
            rock64@rock64:~$ uname -a
            Linux rock64 4.4.213-rockchip64 #27 SMP Tue Apr 14 17:21:23 CEST 2020 aarch64 GNU/Linux
            rock64@rock64:~$
            • S Smartuser
              @Smartuser
              ldd --version
              lsb_release -a
              uname -a
              Danke schonmal!
              rock64@rock64:~$
              Release:        10
              Codename:       buster
              rock64@rock64:~$
              rock64@rock64:~$
              @Smartuser Noch was vergessen...
              Node ist sauber installiert? Und das System auch auf dem letzten Stand?
              nodejs -v
              sudo apt update && sudo apt dist-upgrade
                nodejs -v
                Smartuser
                nodejs -v
                rock64@rock64:~$ nodejs -v
                v12.16.3
                rock64@rock64:~$
                Interessant heute morgen brachte dist-upgrade keine Neuerungen, jetzt folgende:
                rock64@rock64:~$ sudo apt update && sudo apt dist-upgrade
                [sudo] password for rock64:
                Get:1 http://httpredir.debian.org/debian buster InRelease [121 kB]
                Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
                Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
                Get:5 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
                Get:6 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
                Hit:3 https://apt.armbian.com buster InRelease
                Get:7 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
                Get:8 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
                Get:9 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
                Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
                Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
                Get:12 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-09-1408.15.pdiff [198 B]
                Get:13 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-09-1408.15.pdiff [199 B]
                Get:14 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-09-1408.15.pdiff [241 B]
                Get:15 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-09-1408.15.pdiff [242 B]
                Get:16 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
                Get:17 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.1 MB]
                Get:18 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.3 MB]
                Get:19 http://httpredir.debian.org/debian buster/contrib arm64 Packages [46.8 kB]
                Get:20 http://httpredir.debian.org/debian buster/contrib armhf Packages [48.9 kB]
                Get:21 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.8 kB]
                Get:22 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.5 kB]
                Get:23 http://httpredir.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
                Get:24 http://httpredir.debian.org/debian buster/non-free armhf Packages [74.5 kB]
                Get:25 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
                Get:26 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
                Fetched 95.7 MB in 1min 9s (1,396 kB/s)
                25 packages can be upgraded. Run 'apt list --upgradable' to see them.
                N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.4'
                Calculating upgrade... Done
                The following packages will be upgraded:
                  base-files distro-info-data fuse gir1.2-pango-1.0 iputils-arping iputils-ping libfuse2 libnss-myhostname libpam-systemd libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libsystemd0 libudev-dev
                  libudev1 linux-libc-dev pango1.0-tools proftpd-basic systemd systemd-sysv tzdata udev wpasupplicant
                25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 11.8 MB of archives.
                After this operation, 50.2 kB of additional disk space will be used.
                Do you want to continue? [Y/n] y
                Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u4 [69.8 kB]
                Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u4 [99.9 kB]
                Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u4 [200 kB]
                Get:4 http://httpredir.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u4 [110 kB]
                Get:5 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u4 [313 kB]
                Get:6 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u4 [122 kB]
                Get:7 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u4 [3,256 kB]
                Get:8 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u4 [1,246 kB]
                Get:9 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u4 [146 kB]
                Get:10 http://httpredir.debian.org/debian buster/main arm64 tzdata all 2020a-0+deb10u1 [263 kB]
                Get:11 http://httpredir.debian.org/debian buster/main arm64 iputils-ping arm64 3:20180629-2+deb10u1 [42.9 kB]
                Get:12 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u2 [6,584 B]
                Get:13 http://httpredir.debian.org/debian buster/main arm64 fuse arm64 2.9.9-1+deb10u1 [71.4 kB]
                Get:14 http://httpredir.debian.org/debian buster/main arm64 libfuse2 arm64 2.9.9-1+deb10u1 [123 kB]
                Get:15 http://httpredir.debian.org/debian buster/main arm64 pango1.0-tools arm64 1.42.4-8~deb10u1 [55.2 kB]
                Get:16 http://httpredir.debian.org/debian buster/main arm64 libpango1.0-dev arm64 1.42.4-8~deb10u1 [139 kB]
                Get:17 http://httpredir.debian.org/debian buster/main arm64 libpango-1.0-0 arm64 1.42.4-8~deb10u1 [179 kB]
                Get:18 http://httpredir.debian.org/debian buster/main arm64 libpangoft2-1.0-0 arm64 1.42.4-8~deb10u1 [65.7 kB]
                Get:19 http://httpredir.debian.org/debian buster/main arm64 libpangocairo-1.0-0 arm64 1.42.4-8~deb10u1 [54.0 kB]
                Get:20 http://httpredir.debian.org/debian buster/main arm64 libpangoxft-1.0-0 arm64 1.42.4-8~deb10u1 [49.1 kB]
                Get:21 http://httpredir.debian.org/debian buster/main arm64 gir1.2-pango-1.0 arm64 1.42.4-8~deb10u1 [55.8 kB]
                Get:22 http://httpredir.debian.org/debian buster/main arm64 iputils-arping arm64 3:20180629-2+deb10u1 [20.2 kB]
                Get:23 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.118-2 [1,332 kB]
                Get:24 http://httpredir.debian.org/debian buster/main arm64 proftpd-basic arm64 1.3.6-4+deb10u5 [2,614 kB]
                Get:25 http://httpredir.debian.org/debian buster/main arm64 wpasupplicant arm64 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,166 kB]
                Fetched 11.8 MB in 7s (1,719 kB/s)
                Preconfiguring packages ...
                Preparing to unpack .../base-files_10.3+deb10u4_arm64.deb ...
                Unpacking base-files (10.3+deb10u4) over (10.3+deb10u3) ...
                Setting up base-files (10.3+deb10u4) ...
                Installing new version of config file /etc/debian_version ...
                Preparing to unpack .../systemd-sysv_241-7~deb10u4_arm64.deb ...
                Unpacking systemd-sysv (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../libpam-systemd_241-7~deb10u4_arm64.deb ...
                Unpacking libpam-systemd:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../libudev-dev_241-7~deb10u4_arm64.deb ...
                Unpacking libudev-dev:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../libsystemd0_241-7~deb10u4_arm64.deb ...
                Unpacking libsystemd0:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                Setting up libsystemd0:arm64 (241-7~deb10u4) ...
                Preparing to unpack .../libnss-myhostname_241-7~deb10u4_arm64.deb ...
                Unpacking libnss-myhostname:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../systemd_241-7~deb10u4_arm64.deb ...
                Unpacking systemd (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../udev_241-7~deb10u4_arm64.deb ...
                Unpacking udev (241-7~deb10u4) over (241-7~deb10u3) ...
                Preparing to unpack .../libudev1_241-7~deb10u4_arm64.deb ...
                Unpacking libudev1:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
                Setting up libudev1:arm64 (241-7~deb10u4) ...
                Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
                Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
                Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_arm64.deb ...
                Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                Preparing to unpack .../02-distro-info-data_0.41+deb10u2_all.deb ...
                Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
                Preparing to unpack .../03-fuse_2.9.9-1+deb10u1_arm64.deb ...
                Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
                Preparing to unpack .../04-libfuse2_2.9.9-1+deb10u1_arm64.deb ...
                Unpacking libfuse2:arm64 (2.9.9-1+deb10u1) over (2.9.9-1) ...
                Preparing to unpack .../05-pango1.0-tools_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking pango1.0-tools (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../06-libpango1.0-dev_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking libpango1.0-dev:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../07-libpango-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking libpango-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../08-libpangoft2-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../09-libpangocairo-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../10-libpangoxft-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../11-gir1.2-pango-1.0_1.42.4-8~deb10u1_arm64.deb ...
                Unpacking gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
                Preparing to unpack .../12-iputils-arping_3%3a20180629-2+deb10u1_arm64.deb ...
                Unpacking iputils-arping (3:20180629-2+deb10u1) over (3:20180629-2) ...
                Preparing to unpack .../13-linux-libc-dev_4.19.118-2_arm64.deb ...
                Unpacking linux-libc-dev:arm64 (4.19.118-2) over (4.19.98-1+deb10u1) ...
                Preparing to unpack .../14-proftpd-basic_1.3.6-4+deb10u5_arm64.deb ...
                Unpacking proftpd-basic (1.3.6-4+deb10u5) over (1.3.6-4+deb10u4) ...
                Preparing to unpack .../15-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_arm64.deb ...
                Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
                Setting up distro-info-data (0.41+deb10u2) ...
                Setting up libpango-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                Setting up linux-libc-dev:arm64 (4.19.118-2) ...
                Setting up systemd (241-7~deb10u4) ...
                Setting up libfuse2:arm64 (2.9.9-1+deb10u1) ...
                Setting up iputils-arping (3:20180629-2+deb10u1) ...
                Setting up tzdata (2020a-0+deb10u1) ...
                Current default time zone: 'Etc/UTC'
                Local time is now:      Sat May  9 19:43:46 UTC 2020.
                Universal Time is now:  Sat May  9 19:43:46 UTC 2020.
                Run 'dpkg-reconfigure tzdata' if you wish to change it.
                Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
                Setting up proftpd-basic (1.3.6-4+deb10u5) ...
                usermod: no changes
                Setting up udev (241-7~deb10u4) ...
                update-initramfs: deferring update (trigger activated)
                Setting up libnss-myhostname:arm64 (241-7~deb10u4) ...
                Setting up libudev-dev:arm64 (241-7~deb10u4) ...
                Setting up libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                Setting up iputils-ping (3:20180629-2+deb10u1) ...
                Setting up libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                Setting up fuse (2.9.9-1+deb10u1) ...
                Setting up systemd-sysv (241-7~deb10u4) ...
                Setting up libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) ...
                Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
                Setting up gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) ...
                Setting up libpango1.0-dev:arm64 (1.42.4-8~deb10u1) ...
                Setting up libpam-systemd:arm64 (241-7~deb10u4) ...
                Processing triggers for man-db (2.8.5-2) ...
                Processing triggers for dbus (1.12.16-1) ...
                Processing triggers for initramfs-tools (0.133+deb10u1) ...
                update-initramfs: Generating /boot/initrd.img-4.4.213-rockchip64
                update-initramfs: Converting to u-boot format
                rock64@rock64:~$
                Leider zu früh gefreut, ich hab danach einen reboot ausgeführt, aber der Fehler besteht weiterhin.
                Hier beim Upgrade vom WEB-Adapter:
                rock64@rock64:/opt/iobroker$ iobroker upgrade web
                Update web from @3.0.7 to @3.0.8
                host.rock64 Adapter "system.adapter.web.0" is stopped.
                NPM version: 6.14.4
                npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                gyp ERR! not ok
                upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                Update "system.adapter.web.0"
                Adapter "web" updated
                host.rock64 Adapter "system.adapter.web.0" is started
                • S Smartuser
                  nodejs -v
                  v12.16.3
                  rock64@rock64:~$
                  usermod: no changes
                  rock64@rock64:~$
                  NPM version: 6.14.4
                  gyp ERR! not ok
                  @Smartuser Das ist klar, das auch ein dist-upgrade da nichts ändert. Du hast ja noch gar nichts kompiliert.
                  Allerdings hast du da einen ziemlichen Wildwuchs in deinen Paketquellen.
                  Gut (oder auch nicht), versuchen wir zu bauen:
                  sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                    Smartuser
                    Wie gesagt ist ein "frisches" Image gewesen.😊 Von hier
                    rock64@rock64:/opt/iobroker$ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                    build-essential is already the newest version (12.6).
                    libcairo2-dev is already the newest version (1.16.0-4).
                    libgif-dev is already the newest version (5.1.4-3).
                    libjpeg-dev is already the newest version (1:1.5.2-2).
                    librsvg2-dev is already the newest version (2.44.10-2.1).
                    libpango1.0-dev is already the newest version (1.42.4-8~deb10u1).
                    libpixman-1-0 is already the newest version (0.36.0-1).
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    • S Smartuser
                      Das heißt ja nix. Die Pakete sind überwiegend -dev. Normalerweise sind die nicht installiert. Wie dem auch sei.
                      cd /opt/iobroker
                      npm i sharp
                        cd /opt/iobroker
                        npm i sharp
                        Smartuser
                        cd /opt/iobroker
                        npm i sharp
                        rock64@rock64:/opt/iobroker$ npm i sharp
                        > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                        > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                        make: Entering directory '/opt/iobroker/node_modules/sharp/build'
                          CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                          AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                          COPY Release/nothing.a
                          TOUCH Release/obj.target/libvips-cpp.stamp
                          CXX(target) Release/obj.target/sharp/src/common.o
                        make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
                        gyp ERR! not ok
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the sharp@0.25.2 install script.
                        npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_10_27_487Z-debug.log
                        • S Smartuser
                          cd /opt/iobroker
                          npm i sharp
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          @Smartuser
                          sudo apt install libvips-dev
                          [Edit:] Ich sehe gerade, die dürfte zu alt sein.
                          apt policy libvips-dev
                          S 2 Antworten Letzte Antwort
                            @Smartuser
                            Smartuser
                            Ok ... jetzt wurde eine Menge sauber, ohne Fehler installiert
                            0 upgraded, 120 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 58.5 MB of archives.
                            After this operation, 218 MB of additional disk space will be used.
                            Ich spar mir mal den ganzen log. ;)
                            • S Smartuser
                              @Smartuser Wooo... Da zieht libvips aber einiges mit...
                              cd /opt/iobroker
                              npm i libvips
                                cd /opt/iobroker
                                npm i libvips
                                Smartuser
                                npm i libvips
                                Hmmm ....
                                rock64@rock64:/opt/iobroker$ npm i libvips
                                In file included from ../src/common.cc:23:
                                /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
                                 #include <glib-object.h>
                                gyp ERR! not ok
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                + libvips@0.0.2
                                added 1 package in 101.931s
                                22 packages are looking for funding
                                  run `npm fund` for details
                                • S Smartuser
                                  npm i libvips
                                  Hmmm ....
                                  gyp ERR! not ok
                                  + libvips@0.0.2
                                  @Smartuser
                                  sudo apt install libglib2.0-dev
                                  Dann nochmal bauen:
                                  npm i libvips
                                    @Smartuser
                                    Dann nochmal bauen:
                                    npm i libvips
                                    Smartuser
                                    @Smartuser
                                    Dann nochmal bauen:
                                    npm i libvips
                                    Ist schon aktuell :(
                                    rock64@rock64:/opt/iobroker$ sudo apt install libglib2.0-dev
                                    libglib2.0-dev is already the newest version (2.58.3-2+deb10u2).
                                    libglib2.0-dev set to manually installed.
                                      @Smartuser
                                      Smartuser
                                      Ich seh grad, dass ich deinen editierten post nicht gesehen habe!
                                      Soll ich das nochmal ausführen?
                                      • S Smartuser
                                        @Smartuser
                                        Ja, lass mal sehen.
                                          @Smartuser
                                          Ja, lass mal sehen.
                                          Smartuser
                                          @Smartuser
                                          Ja, lass mal sehen.
                                          rock64@rock64:/opt/iobroker$ apt policy libvips-dev
                                          libvips-dev:
                                            Installed: 8.7.4-1
                                            Candidate: 8.7.4-1
                                            Version table:
                                           *** 8.7.4-1 500
                                                  500 http://httpredir.debian.org/debian buster/main arm64 Packages
