  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
  • S Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    @Smartuser
    sudo apt update
    sudo apt dist-upgrade
    sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
    Hilft leider auch nicht.
    sudo apt update und sudo apt dist-upgrade durchgeführt, danach:
    rock64@rock64:~$ sudo apt install --reinstall libpixman-1-0 libpixman-1-dev
    Reading package lists... Done
    Building dependency tree
    0 upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 0 B/889 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 42427 files and directories currently installed.)
    Preparing to unpack .../libpixman-1-0_0.36.0-1_arm64.deb ...
    Unpacking libpixman-1-0:arm64 (0.36.0-1) over (0.36.0-1) ...
    Preparing to unpack .../libpixman-1-dev_0.36.0-1_arm64.deb ...
    Unpacking libpixman-1-dev:arm64 (0.36.0-1) over (0.36.0-1) ...
    Setting up libpixman-1-0:arm64 (0.36.0-1) ...
    Setting up libpixman-1-dev:arm64 (0.36.0-1) ...
    Processing triggers for libc-bin (2.28-10) ...
    rock64@rock64:~$
    Ist sauber durchgelaufen, zur sicherheit reboot durchgeführt. Danach ein adapter upgrade gestartet.
    Das Ergebnis bleibt unverändert.
    rock64@rock64:/opt/iobroker$ iobroker upgrade rpi2
    Update rpi2 from @1.1.1 to @1.2.0
    NPM version: 6.14.4
    npm install iobroker.rpi2@1.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    Update "system.adapter.rpi2.0"
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index.html index.html text/html
    Adapter "rpi2" updated
    @Smartuser sagte in Update js-controller und node.js:
    Hat doch funktioniert.
      Smartuser
      Ja ... die Updates funktionieren scheinbar immer. Das hatte ich oben auch so geschrieben:
      Zitat: Die Updates laufen trotz der Fehlermeldung.
      '________
      Allerdings scheint es zum Beispiel beim iot adapter nicht richtig zu funktionieren:
      rock64@rock64:~$ cd /opt/iobroker/
      rock64@rock64:/opt/iobroker$ iobroker upgrade iot
      Update iot from @1.4.12 to @1.4.14
      host.rock64 Adapter "system.adapter.iot.0" is stopped.
      NPM version: 6.14.4
      npm install iobroker.iot@1.4.14 --loglevel error --prefix "/opt/iobroker" (System call)
      gyp ERR! not ok
      Update "system.adapter.iot.0"
      upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
      upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js.map static/js/main.25253be6.chunk.js.map application/json
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js static/js/main.25253be6.chunk.js application/javascript
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.map static/js/2.d2785704.chunk.js.map application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.LICENSE.txt static/js/2.d2785704.chunk.js.LICENSE.txt text/plain
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js static/js/2.d2785704.chunk.js application/javascript
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js application/javascript
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      Adapter "iot" updated
      host.rock64 Adapter "system.adapter.iot.0" is started
      Hier tritt neben (oder durch?) das libvibs-problem noch ein problem mit sharp auf.
      Und dieser stört sich auch daran, er meldet im log immer:
      iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/main.js
      iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/alexaCustomBlood.js
      iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/getImage.js
      iot.0	2020-05-09 11:00:08.814	warn	Require stack:
      iot.0	2020-05-09 11:00:08.814	warn	(11435) Cannot initialize getImage: Error: Cannot find module 'sharp'
      Daher hätte ich gern die Fehler weg um auszuschließen, dass bei einigen Adaptern etwas schief läuft :)
      • S Smartuser
        '________
        NPM version: 6.14.4
        gyp ERR! not ok
        @Smartuser
        libvips und sharp hängen zusammen. Haben beide mit Bildbearbeitung zu tun.
        Dann lass uns mal genau schauen, mit was du da unterwegs bist:
        ldd --version
        lsb_release -a
        uname -a
          @Smartuser
          ldd --version
          lsb_release -a
          uname -a
          Smartuser
          @Smartuser
          ldd --version
          lsb_release -a
          uname -a
          Danke schonmal!
          So sieht das Ganze aus:
          rock64@rock64:~$ ldd --version
          ldd (Debian GLIBC 2.28-10) 2.28
          Copyright (C) 2018 Free Software Foundation, Inc.
          This is free software; see the source for copying conditions.  There is NO
          warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
          Written by Roland McGrath and Ulrich Drepper.
          rock64@rock64:~$
          rock64@rock64:~$ lsb_release -a
          No LSB modules are available.
          Distributor ID: Debian
          Description:    Debian GNU/Linux 10 (buster)
          Release:        10
          Codename:       buster
          rock64@rock64:~$
          rock64@rock64:~$ uname -a
          Linux rock64 4.4.213-rockchip64 #27 SMP Tue Apr 14 17:21:23 CEST 2020 aarch64 GNU/Linux
          rock64@rock64:~$
          • S Smartuser
            @Smartuser
            ldd --version
            lsb_release -a
            uname -a
            Danke schonmal!
            rock64@rock64:~$
            Release:        10
            Codename:       buster
            rock64@rock64:~$
            rock64@rock64:~$
            @Smartuser Noch was vergessen...
            Node ist sauber installiert? Und das System auch auf dem letzten Stand?
            nodejs -v
            sudo apt update && sudo apt dist-upgrade
              nodejs -v
              Smartuser
              nodejs -v
              rock64@rock64:~$ nodejs -v
              v12.16.3
              rock64@rock64:~$
              Interessant heute morgen brachte dist-upgrade keine Neuerungen, jetzt folgende:
              rock64@rock64:~$ sudo apt update && sudo apt dist-upgrade
              [sudo] password for rock64:
              Get:1 http://httpredir.debian.org/debian buster InRelease [121 kB]
              Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
              Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
              Get:5 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
              Get:6 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
              Hit:3 https://apt.armbian.com buster InRelease
              Get:7 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
              Get:8 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
              Get:9 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
              Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
              Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
              Get:12 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-09-1408.15.pdiff [198 B]
              Get:13 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-09-1408.15.pdiff [199 B]
              Get:14 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-09-1408.15.pdiff [241 B]
              Get:15 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-09-1408.15.pdiff [242 B]
              Get:16 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
              Get:17 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.1 MB]
              Get:18 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.3 MB]
              Get:19 http://httpredir.debian.org/debian buster/contrib arm64 Packages [46.8 kB]
              Get:20 http://httpredir.debian.org/debian buster/contrib armhf Packages [48.9 kB]
              Get:21 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.8 kB]
              Get:22 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.5 kB]
              Get:23 http://httpredir.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
              Get:24 http://httpredir.debian.org/debian buster/non-free armhf Packages [74.5 kB]
              Get:25 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
              Get:26 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
              Fetched 95.7 MB in 1min 9s (1,396 kB/s)
              25 packages can be upgraded. Run 'apt list --upgradable' to see them.
              N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.4'
              Calculating upgrade... Done
              The following packages will be upgraded:
                base-files distro-info-data fuse gir1.2-pango-1.0 iputils-arping iputils-ping libfuse2 libnss-myhostname libpam-systemd libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libsystemd0 libudev-dev
                libudev1 linux-libc-dev pango1.0-tools proftpd-basic systemd systemd-sysv tzdata udev wpasupplicant
              25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 11.8 MB of archives.
              After this operation, 50.2 kB of additional disk space will be used.
              Do you want to continue? [Y/n] y
              Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u4 [69.8 kB]
              Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u4 [99.9 kB]
              Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u4 [200 kB]
              Get:4 http://httpredir.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u4 [110 kB]
              Get:5 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u4 [313 kB]
              Get:6 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u4 [122 kB]
              Get:7 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u4 [3,256 kB]
              Get:8 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u4 [1,246 kB]
              Get:9 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u4 [146 kB]
              Get:10 http://httpredir.debian.org/debian buster/main arm64 tzdata all 2020a-0+deb10u1 [263 kB]
              Get:11 http://httpredir.debian.org/debian buster/main arm64 iputils-ping arm64 3:20180629-2+deb10u1 [42.9 kB]
              Get:12 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u2 [6,584 B]
              Get:13 http://httpredir.debian.org/debian buster/main arm64 fuse arm64 2.9.9-1+deb10u1 [71.4 kB]
              Get:14 http://httpredir.debian.org/debian buster/main arm64 libfuse2 arm64 2.9.9-1+deb10u1 [123 kB]
              Get:15 http://httpredir.debian.org/debian buster/main arm64 pango1.0-tools arm64 1.42.4-8~deb10u1 [55.2 kB]
              Get:16 http://httpredir.debian.org/debian buster/main arm64 libpango1.0-dev arm64 1.42.4-8~deb10u1 [139 kB]
              Get:17 http://httpredir.debian.org/debian buster/main arm64 libpango-1.0-0 arm64 1.42.4-8~deb10u1 [179 kB]
              Get:18 http://httpredir.debian.org/debian buster/main arm64 libpangoft2-1.0-0 arm64 1.42.4-8~deb10u1 [65.7 kB]
              Get:19 http://httpredir.debian.org/debian buster/main arm64 libpangocairo-1.0-0 arm64 1.42.4-8~deb10u1 [54.0 kB]
              Get:20 http://httpredir.debian.org/debian buster/main arm64 libpangoxft-1.0-0 arm64 1.42.4-8~deb10u1 [49.1 kB]
              Get:21 http://httpredir.debian.org/debian buster/main arm64 gir1.2-pango-1.0 arm64 1.42.4-8~deb10u1 [55.8 kB]
              Get:22 http://httpredir.debian.org/debian buster/main arm64 iputils-arping arm64 3:20180629-2+deb10u1 [20.2 kB]
              Get:23 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.118-2 [1,332 kB]
              Get:24 http://httpredir.debian.org/debian buster/main arm64 proftpd-basic arm64 1.3.6-4+deb10u5 [2,614 kB]
              Get:25 http://httpredir.debian.org/debian buster/main arm64 wpasupplicant arm64 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,166 kB]
              Fetched 11.8 MB in 7s (1,719 kB/s)
              Preconfiguring packages ...
              Preparing to unpack .../base-files_10.3+deb10u4_arm64.deb ...
              Unpacking base-files (10.3+deb10u4) over (10.3+deb10u3) ...
              Setting up base-files (10.3+deb10u4) ...
              Installing new version of config file /etc/debian_version ...
              Preparing to unpack .../systemd-sysv_241-7~deb10u4_arm64.deb ...
              Unpacking systemd-sysv (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../libpam-systemd_241-7~deb10u4_arm64.deb ...
              Unpacking libpam-systemd:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../libudev-dev_241-7~deb10u4_arm64.deb ...
              Unpacking libudev-dev:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../libsystemd0_241-7~deb10u4_arm64.deb ...
              Unpacking libsystemd0:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
              Setting up libsystemd0:arm64 (241-7~deb10u4) ...
              Preparing to unpack .../libnss-myhostname_241-7~deb10u4_arm64.deb ...
              Unpacking libnss-myhostname:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../systemd_241-7~deb10u4_arm64.deb ...
              Unpacking systemd (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../udev_241-7~deb10u4_arm64.deb ...
              Unpacking udev (241-7~deb10u4) over (241-7~deb10u3) ...
              Preparing to unpack .../libudev1_241-7~deb10u4_arm64.deb ...
              Unpacking libudev1:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
              Setting up libudev1:arm64 (241-7~deb10u4) ...
              Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
              Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
              Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_arm64.deb ...
              Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
              Preparing to unpack .../02-distro-info-data_0.41+deb10u2_all.deb ...
              Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
              Preparing to unpack .../03-fuse_2.9.9-1+deb10u1_arm64.deb ...
              Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
              Preparing to unpack .../04-libfuse2_2.9.9-1+deb10u1_arm64.deb ...
              Unpacking libfuse2:arm64 (2.9.9-1+deb10u1) over (2.9.9-1) ...
              Preparing to unpack .../05-pango1.0-tools_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking pango1.0-tools (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../06-libpango1.0-dev_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking libpango1.0-dev:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../07-libpango-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking libpango-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../08-libpangoft2-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../09-libpangocairo-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../10-libpangoxft-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../11-gir1.2-pango-1.0_1.42.4-8~deb10u1_arm64.deb ...
              Unpacking gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
              Preparing to unpack .../12-iputils-arping_3%3a20180629-2+deb10u1_arm64.deb ...
              Unpacking iputils-arping (3:20180629-2+deb10u1) over (3:20180629-2) ...
              Preparing to unpack .../13-linux-libc-dev_4.19.118-2_arm64.deb ...
              Unpacking linux-libc-dev:arm64 (4.19.118-2) over (4.19.98-1+deb10u1) ...
              Preparing to unpack .../14-proftpd-basic_1.3.6-4+deb10u5_arm64.deb ...
              Unpacking proftpd-basic (1.3.6-4+deb10u5) over (1.3.6-4+deb10u4) ...
              Preparing to unpack .../15-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_arm64.deb ...
              Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
              Setting up distro-info-data (0.41+deb10u2) ...
              Setting up libpango-1.0-0:arm64 (1.42.4-8~deb10u1) ...
              Setting up linux-libc-dev:arm64 (4.19.118-2) ...
              Setting up systemd (241-7~deb10u4) ...
              Setting up libfuse2:arm64 (2.9.9-1+deb10u1) ...
              Setting up iputils-arping (3:20180629-2+deb10u1) ...
              Setting up tzdata (2020a-0+deb10u1) ...
              Current default time zone: 'Etc/UTC'
              Local time is now:      Sat May  9 19:43:46 UTC 2020.
              Universal Time is now:  Sat May  9 19:43:46 UTC 2020.
              Run 'dpkg-reconfigure tzdata' if you wish to change it.
              Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
              Setting up proftpd-basic (1.3.6-4+deb10u5) ...
              usermod: no changes
              Setting up udev (241-7~deb10u4) ...
              update-initramfs: deferring update (trigger activated)
              Setting up libnss-myhostname:arm64 (241-7~deb10u4) ...
              Setting up libudev-dev:arm64 (241-7~deb10u4) ...
              Setting up libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) ...
              Setting up iputils-ping (3:20180629-2+deb10u1) ...
              Setting up libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) ...
              Setting up fuse (2.9.9-1+deb10u1) ...
              Setting up systemd-sysv (241-7~deb10u4) ...
              Setting up libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) ...
              Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
              Setting up gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) ...
              Setting up libpango1.0-dev:arm64 (1.42.4-8~deb10u1) ...
              Setting up libpam-systemd:arm64 (241-7~deb10u4) ...
              Processing triggers for man-db (2.8.5-2) ...
              Processing triggers for dbus (1.12.16-1) ...
              Processing triggers for initramfs-tools (0.133+deb10u1) ...
              update-initramfs: Generating /boot/initrd.img-4.4.213-rockchip64
              update-initramfs: Converting to u-boot format
              rock64@rock64:~$
              Leider zu früh gefreut, ich hab danach einen reboot ausgeführt, aber der Fehler besteht weiterhin.
              Hier beim Upgrade vom WEB-Adapter:
              rock64@rock64:/opt/iobroker$ iobroker upgrade web
              Update web from @3.0.7 to @3.0.8
              host.rock64 Adapter "system.adapter.web.0" is stopped.
              NPM version: 6.14.4
              npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
              gyp ERR! not ok
              upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
              upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
              upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
              upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
              upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
              upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
              upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
              upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
              upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
              upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
              upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
              upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
              upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
              upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
              upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
              upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
              upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
              upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
              upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
              upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
              upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
              upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
              upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
              upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
              upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
              upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
              upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
              upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
              upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
              upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
              upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
              upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
              upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
              upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
              upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
              upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
              upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
              upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
              Update "system.adapter.web.0"
              Adapter "web" updated
              host.rock64 Adapter "system.adapter.web.0" is started
              • S Smartuser
                nodejs -v
                v12.16.3
                rock64@rock64:~$
                usermod: no changes
                rock64@rock64:~$
                NPM version: 6.14.4
                gyp ERR! not ok
                @Smartuser Das ist klar, das auch ein dist-upgrade da nichts ändert. Du hast ja noch gar nichts kompiliert.
                Allerdings hast du da einen ziemlichen Wildwuchs in deinen Paketquellen.
                Gut (oder auch nicht), versuchen wir zu bauen:
                sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                  Smartuser
                  Wie gesagt ist ein "frisches" Image gewesen.😊 Von hier
                  rock64@rock64:/opt/iobroker$ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                  build-essential is already the newest version (12.6).
                  libcairo2-dev is already the newest version (1.16.0-4).
                  libgif-dev is already the newest version (5.1.4-3).
                  libjpeg-dev is already the newest version (1:1.5.2-2).
                  librsvg2-dev is already the newest version (2.44.10-2.1).
                  libpango1.0-dev is already the newest version (1.42.4-8~deb10u1).
                  libpixman-1-0 is already the newest version (0.36.0-1).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  • S Smartuser
                    Das heißt ja nix. Die Pakete sind überwiegend -dev. Normalerweise sind die nicht installiert. Wie dem auch sei.
                    cd /opt/iobroker
                    npm i sharp
                      cd /opt/iobroker
                      npm i sharp
                      Smartuser
                      schrieb am zuletzt editiert von Smartuser
                      cd /opt/iobroker
                      npm i sharp
                      rock64@rock64:/opt/iobroker$ npm i sharp
                      > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                      > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                      make: Entering directory '/opt/iobroker/node_modules/sharp/build'
                        CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                        AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                        COPY Release/nothing.a
                        TOUCH Release/obj.target/libvips-cpp.stamp
                        CXX(target) Release/obj.target/sharp/src/common.o
                      make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
                      gyp ERR! not ok
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the sharp@0.25.2 install script.
                      npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_10_27_487Z-debug.log
                      • S Smartuser
                        cd /opt/iobroker
                        npm i sharp
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        @Smartuser
                        sudo apt install libvips-dev
                        [Edit:] Ich sehe gerade, die dürfte zu alt sein.
                        apt policy libvips-dev
                        S 2 Antworten Letzte Antwort
                          @Smartuser
                          Smartuser
                          Ok ... jetzt wurde eine Menge sauber, ohne Fehler installiert
                          0 upgraded, 120 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 58.5 MB of archives.
                          After this operation, 218 MB of additional disk space will be used.
                          Ich spar mir mal den ganzen log. ;)
                          • S Smartuser
                            @Smartuser Wooo... Da zieht libvips aber einiges mit...
                            cd /opt/iobroker
                            npm i libvips
                              cd /opt/iobroker
                              npm i libvips
                              Smartuser
                              npm i libvips
                              Hmmm ....
                              rock64@rock64:/opt/iobroker$ npm i libvips
                              In file included from ../src/common.cc:23:
                              /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
                               #include <glib-object.h>
                              gyp ERR! not ok
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                              + libvips@0.0.2
                              added 1 package in 101.931s
                              22 packages are looking for funding
                                run `npm fund` for details
                              • S Smartuser
                                npm i libvips
                                Hmmm ....
                                gyp ERR! not ok
                                + libvips@0.0.2
                                @Smartuser
                                sudo apt install libglib2.0-dev
                                Dann nochmal bauen:
                                npm i libvips
                                  @Smartuser
                                  Dann nochmal bauen:
                                  npm i libvips
                                  Smartuser
                                  @Smartuser
                                  Dann nochmal bauen:
                                  npm i libvips
                                  Ist schon aktuell :(
                                  rock64@rock64:/opt/iobroker$ sudo apt install libglib2.0-dev
                                  libglib2.0-dev is already the newest version (2.58.3-2+deb10u2).
                                  libglib2.0-dev set to manually installed.
                                    @Smartuser
                                    Smartuser
                                    Ich seh grad, dass ich deinen editierten post nicht gesehen habe!
                                    Soll ich das nochmal ausführen?
                                    • S Smartuser
                                      @Smartuser
                                      Ja, lass mal sehen.
                                        @Smartuser
                                        Ja, lass mal sehen.
                                        Smartuser
                                        @Smartuser
                                        Ja, lass mal sehen.
                                        rock64@rock64:/opt/iobroker$ apt policy libvips-dev
                                        libvips-dev:
                                          Installed: 8.7.4-1
                                          Candidate: 8.7.4-1
                                          Version table:
                                         *** 8.7.4-1 500
                                                500 http://httpredir.debian.org/debian buster/main arm64 Packages
                                        • S Smartuser
                                          @Smartuser
                                          Ja, lass mal sehen.
                                          libvips-dev:
                                            Installed: 8.7.4-1
                                            Candidate: 8.7.4-1
                                            Version table:
                                           *** 8.7.4-1 500
                                          @Smartuser
                                          npm rebuild libvips --build-from-source
