  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser sagte in Update js-controller und node.js:
    Adapter "rpi2" updated
    Hat doch funktioniert.
    Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    Ja ... die Updates funktionieren scheinbar immer. Das hatte ich oben auch so geschrieben:
    Zitat: Die Updates laufen trotz der Fehlermeldung.
    '________
    Allerdings scheint es zum Beispiel beim iot adapter nicht richtig zu funktionieren:
    rock64@rock64:~$ cd /opt/iobroker/
    rock64@rock64:/opt/iobroker$ iobroker upgrade iot
    Update iot from @1.4.12 to @1.4.14
    host.rock64 Adapter "system.adapter.iot.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.iot@1.4.14 --loglevel error --prefix "/opt/iobroker" (System call)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:10: fatal error: vips/vips8: No such file or directory
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Update "system.adapter.iot.0"
    upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
    upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js.map static/js/main.25253be6.chunk.js.map application/json
    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.25253be6.chunk.js static/js/main.25253be6.chunk.js application/javascript
    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.map static/js/2.d2785704.chunk.js.map application/json
    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js.LICENSE.txt static/js/2.d2785704.chunk.js.LICENSE.txt text/plain
    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2785704.chunk.js static/js/2.d2785704.chunk.js application/javascript
    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js precache-manifest.eb98f59fee6c2799b8871e4dd4a03e90.js application/javascript
    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    Adapter "iot" updated
    host.rock64 Adapter "system.adapter.iot.0" is started
    Hier tritt neben (oder durch?) das libvibs-problem noch ein problem mit sharp auf.
    Und dieser stört sich auch daran, er meldet im log immer:
    iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/main.js
    iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/alexaCustomBlood.js
    iot.0	2020-05-09 11:00:08.814	warn	- /opt/iobroker/node_modules/iobroker.iot/lib/getImage.js
    iot.0	2020-05-09 11:00:08.814	warn	Require stack:
    iot.0	2020-05-09 11:00:08.814	warn	(11435) Cannot initialize getImage: Error: Cannot find module 'sharp'
    Daher hätte ich gern die Fehler weg um auszuschließen, dass bei einigen Adaptern etwas schief läuft :)
    • S Smartuser
      '________
      NPM version: 6.14.4
      gyp ERR! not ok
      @Smartuser
      libvips und sharp hängen zusammen. Haben beide mit Bildbearbeitung zu tun.
      Dann lass uns mal genau schauen, mit was du da unterwegs bist:
      ldd --version
      lsb_release -a
      uname -a
        @Smartuser
        ldd --version
        lsb_release -a
        uname -a
        Smartuser
        @Smartuser
        ldd --version
        lsb_release -a
        uname -a
        Danke schonmal!
        So sieht das Ganze aus:
        rock64@rock64:~$ ldd --version
        ldd (Debian GLIBC 2.28-10) 2.28
        Copyright (C) 2018 Free Software Foundation, Inc.
        This is free software; see the source for copying conditions.  There is NO
        warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
        Written by Roland McGrath and Ulrich Drepper.
        rock64@rock64:~$
        rock64@rock64:~$ lsb_release -a
        No LSB modules are available.
        Distributor ID: Debian
        Description:    Debian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        rock64@rock64:~$
        rock64@rock64:~$ uname -a
        Linux rock64 4.4.213-rockchip64 #27 SMP Tue Apr 14 17:21:23 CEST 2020 aarch64 GNU/Linux
        rock64@rock64:~$
        • S Smartuser
          @Smartuser
          ldd --version
          lsb_release -a
          uname -a
          Danke schonmal!
          rock64@rock64:~$
          Release:        10
          Codename:       buster
          rock64@rock64:~$
          rock64@rock64:~$
          @Smartuser Noch was vergessen...
          Node ist sauber installiert? Und das System auch auf dem letzten Stand?
          nodejs -v
          sudo apt update && sudo apt dist-upgrade
            nodejs -v
            Smartuser
            nodejs -v
            rock64@rock64:~$ nodejs -v
            v12.16.3
            rock64@rock64:~$
            Interessant heute morgen brachte dist-upgrade keine Neuerungen, jetzt folgende:
            rock64@rock64:~$ sudo apt update && sudo apt dist-upgrade
            [sudo] password for rock64:
            Get:1 http://httpredir.debian.org/debian buster InRelease [121 kB]
            Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
            Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
            Get:5 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
            Get:6 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
            Hit:3 https://apt.armbian.com buster InRelease
            Get:7 http://httpredir.debian.org/debian buster/main arm64 Packages [10.5 MB]
            Get:8 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
            Get:9 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
            Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
            Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
            Get:12 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-09-1408.15.pdiff [198 B]
            Get:13 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-09-1408.15.pdiff [199 B]
            Get:14 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-09-1408.15.pdiff [241 B]
            Get:15 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-09-1408.15.pdiff [242 B]
            Get:16 http://httpredir.debian.org/debian buster/main armhf Packages [10.5 MB]
            Get:17 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.1 MB]
            Get:18 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.3 MB]
            Get:19 http://httpredir.debian.org/debian buster/contrib arm64 Packages [46.8 kB]
            Get:20 http://httpredir.debian.org/debian buster/contrib armhf Packages [48.9 kB]
            Get:21 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.8 kB]
            Get:22 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.5 kB]
            Get:23 http://httpredir.debian.org/debian buster/non-free arm64 Packages [64.3 kB]
            Get:24 http://httpredir.debian.org/debian buster/non-free armhf Packages [74.5 kB]
            Get:25 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
            Get:26 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
            Fetched 95.7 MB in 1min 9s (1,396 kB/s)
            Reading package lists... Done
            Building dependency tree
            25 packages can be upgraded. Run 'apt list --upgradable' to see them.
            N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.4'
            Calculating upgrade... Done
            The following packages will be upgraded:
              base-files distro-info-data fuse gir1.2-pango-1.0 iputils-arping iputils-ping libfuse2 libnss-myhostname libpam-systemd libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libsystemd0 libudev-dev
              libudev1 linux-libc-dev pango1.0-tools proftpd-basic systemd systemd-sysv tzdata udev wpasupplicant
            25 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 11.8 MB of archives.
            After this operation, 50.2 kB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Get:1 http://httpredir.debian.org/debian buster/main arm64 base-files arm64 10.3+deb10u4 [69.8 kB]
            Get:2 http://httpredir.debian.org/debian buster/main arm64 systemd-sysv arm64 241-7~deb10u4 [99.9 kB]
            Get:3 http://httpredir.debian.org/debian buster/main arm64 libpam-systemd arm64 241-7~deb10u4 [200 kB]
            Get:4 http://httpredir.debian.org/debian buster/main arm64 libudev-dev arm64 241-7~deb10u4 [110 kB]
            Get:5 http://httpredir.debian.org/debian buster/main arm64 libsystemd0 arm64 241-7~deb10u4 [313 kB]
            Get:6 http://httpredir.debian.org/debian buster/main arm64 libnss-myhostname arm64 241-7~deb10u4 [122 kB]
            Get:7 http://httpredir.debian.org/debian buster/main arm64 systemd arm64 241-7~deb10u4 [3,256 kB]
            Get:8 http://httpredir.debian.org/debian buster/main arm64 udev arm64 241-7~deb10u4 [1,246 kB]
            Get:9 http://httpredir.debian.org/debian buster/main arm64 libudev1 arm64 241-7~deb10u4 [146 kB]
            Get:10 http://httpredir.debian.org/debian buster/main arm64 tzdata all 2020a-0+deb10u1 [263 kB]
            Get:11 http://httpredir.debian.org/debian buster/main arm64 iputils-ping arm64 3:20180629-2+deb10u1 [42.9 kB]
            Get:12 http://httpredir.debian.org/debian buster/main arm64 distro-info-data all 0.41+deb10u2 [6,584 B]
            Get:13 http://httpredir.debian.org/debian buster/main arm64 fuse arm64 2.9.9-1+deb10u1 [71.4 kB]
            Get:14 http://httpredir.debian.org/debian buster/main arm64 libfuse2 arm64 2.9.9-1+deb10u1 [123 kB]
            Get:15 http://httpredir.debian.org/debian buster/main arm64 pango1.0-tools arm64 1.42.4-8~deb10u1 [55.2 kB]
            Get:16 http://httpredir.debian.org/debian buster/main arm64 libpango1.0-dev arm64 1.42.4-8~deb10u1 [139 kB]
            Get:17 http://httpredir.debian.org/debian buster/main arm64 libpango-1.0-0 arm64 1.42.4-8~deb10u1 [179 kB]
            Get:18 http://httpredir.debian.org/debian buster/main arm64 libpangoft2-1.0-0 arm64 1.42.4-8~deb10u1 [65.7 kB]
            Get:19 http://httpredir.debian.org/debian buster/main arm64 libpangocairo-1.0-0 arm64 1.42.4-8~deb10u1 [54.0 kB]
            Get:20 http://httpredir.debian.org/debian buster/main arm64 libpangoxft-1.0-0 arm64 1.42.4-8~deb10u1 [49.1 kB]
            Get:21 http://httpredir.debian.org/debian buster/main arm64 gir1.2-pango-1.0 arm64 1.42.4-8~deb10u1 [55.8 kB]
            Get:22 http://httpredir.debian.org/debian buster/main arm64 iputils-arping arm64 3:20180629-2+deb10u1 [20.2 kB]
            Get:23 http://httpredir.debian.org/debian buster/main arm64 linux-libc-dev arm64 4.19.118-2 [1,332 kB]
            Get:24 http://httpredir.debian.org/debian buster/main arm64 proftpd-basic arm64 1.3.6-4+deb10u5 [2,614 kB]
            Get:25 http://httpredir.debian.org/debian buster/main arm64 wpasupplicant arm64 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,166 kB]
            Fetched 11.8 MB in 7s (1,719 kB/s)
            Preconfiguring packages ...
            (Reading database ... 42427 files and directories currently installed.)
            Preparing to unpack .../base-files_10.3+deb10u4_arm64.deb ...
            Unpacking base-files (10.3+deb10u4) over (10.3+deb10u3) ...
            Setting up base-files (10.3+deb10u4) ...
            Installing new version of config file /etc/debian_version ...
            Preparing to unpack .../systemd-sysv_241-7~deb10u4_arm64.deb ...
            Unpacking systemd-sysv (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../libpam-systemd_241-7~deb10u4_arm64.deb ...
            Unpacking libpam-systemd:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../libudev-dev_241-7~deb10u4_arm64.deb ...
            Unpacking libudev-dev:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../libsystemd0_241-7~deb10u4_arm64.deb ...
            Unpacking libsystemd0:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
            Setting up libsystemd0:arm64 (241-7~deb10u4) ...
            Preparing to unpack .../libnss-myhostname_241-7~deb10u4_arm64.deb ...
            Unpacking libnss-myhostname:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../systemd_241-7~deb10u4_arm64.deb ...
            Unpacking systemd (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../udev_241-7~deb10u4_arm64.deb ...
            Unpacking udev (241-7~deb10u4) over (241-7~deb10u3) ...
            Preparing to unpack .../libudev1_241-7~deb10u4_arm64.deb ...
            Unpacking libudev1:arm64 (241-7~deb10u4) over (241-7~deb10u3) ...
            Setting up libudev1:arm64 (241-7~deb10u4) ...
            Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
            Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
            Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_arm64.deb ...
            Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
            Preparing to unpack .../02-distro-info-data_0.41+deb10u2_all.deb ...
            Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
            Preparing to unpack .../03-fuse_2.9.9-1+deb10u1_arm64.deb ...
            Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
            Preparing to unpack .../04-libfuse2_2.9.9-1+deb10u1_arm64.deb ...
            Unpacking libfuse2:arm64 (2.9.9-1+deb10u1) over (2.9.9-1) ...
            Preparing to unpack .../05-pango1.0-tools_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking pango1.0-tools (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../06-libpango1.0-dev_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking libpango1.0-dev:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../07-libpango-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking libpango-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../08-libpangoft2-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../09-libpangocairo-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../10-libpangoxft-1.0-0_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../11-gir1.2-pango-1.0_1.42.4-8~deb10u1_arm64.deb ...
            Unpacking gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
            Preparing to unpack .../12-iputils-arping_3%3a20180629-2+deb10u1_arm64.deb ...
            Unpacking iputils-arping (3:20180629-2+deb10u1) over (3:20180629-2) ...
            Preparing to unpack .../13-linux-libc-dev_4.19.118-2_arm64.deb ...
            Unpacking linux-libc-dev:arm64 (4.19.118-2) over (4.19.98-1+deb10u1) ...
            Preparing to unpack .../14-proftpd-basic_1.3.6-4+deb10u5_arm64.deb ...
            Unpacking proftpd-basic (1.3.6-4+deb10u5) over (1.3.6-4+deb10u4) ...
            Preparing to unpack .../15-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_arm64.deb ...
            Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
            Setting up distro-info-data (0.41+deb10u2) ...
            Setting up libpango-1.0-0:arm64 (1.42.4-8~deb10u1) ...
            Setting up linux-libc-dev:arm64 (4.19.118-2) ...
            Setting up systemd (241-7~deb10u4) ...
            Setting up libfuse2:arm64 (2.9.9-1+deb10u1) ...
            Setting up iputils-arping (3:20180629-2+deb10u1) ...
            Setting up tzdata (2020a-0+deb10u1) ...
            Current default time zone: 'Etc/UTC'
            Local time is now:      Sat May  9 19:43:46 UTC 2020.
            Universal Time is now:  Sat May  9 19:43:46 UTC 2020.
            Run 'dpkg-reconfigure tzdata' if you wish to change it.
            Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
            Setting up proftpd-basic (1.3.6-4+deb10u5) ...
            usermod: no changes
            Setting up udev (241-7~deb10u4) ...
            update-initramfs: deferring update (trigger activated)
            Setting up libnss-myhostname:arm64 (241-7~deb10u4) ...
            Setting up libudev-dev:arm64 (241-7~deb10u4) ...
            Setting up libpangoft2-1.0-0:arm64 (1.42.4-8~deb10u1) ...
            Setting up iputils-ping (3:20180629-2+deb10u1) ...
            Setting up libpangocairo-1.0-0:arm64 (1.42.4-8~deb10u1) ...
            Setting up fuse (2.9.9-1+deb10u1) ...
            Setting up systemd-sysv (241-7~deb10u4) ...
            Setting up libpangoxft-1.0-0:arm64 (1.42.4-8~deb10u1) ...
            Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
            Setting up gir1.2-pango-1.0:arm64 (1.42.4-8~deb10u1) ...
            Setting up libpango1.0-dev:arm64 (1.42.4-8~deb10u1) ...
            Setting up libpam-systemd:arm64 (241-7~deb10u4) ...
            Processing triggers for man-db (2.8.5-2) ...
            Processing triggers for dbus (1.12.16-1) ...
            Processing triggers for libc-bin (2.28-10) ...
            Processing triggers for initramfs-tools (0.133+deb10u1) ...
            update-initramfs: Generating /boot/initrd.img-4.4.213-rockchip64
            update-initramfs: Converting to u-boot format
            rock64@rock64:~$
            Leider zu früh gefreut, ich hab danach einen reboot ausgeführt, aber der Fehler besteht weiterhin.
            Hier beim Upgrade vom WEB-Adapter:
            rock64@rock64:/opt/iobroker$ iobroker upgrade web
            Update web from @3.0.7 to @3.0.8
            host.rock64 Adapter "system.adapter.web.0" is stopped.
            NPM version: 6.14.4
            npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
            gyp ERR! not ok
            upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
            upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
            upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
            upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
            upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
            upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
            upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
            upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
            upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
            upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
            upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
            upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
            upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
            upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
            upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
            upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
            upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
            upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
            upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
            upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
            upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
            upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
            upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
            upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
            upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
            upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
            upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
            upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
            upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
            upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
            upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
            upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
            upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
            upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
            upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
            upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
            upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
            upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
            Update "system.adapter.web.0"
            Adapter "web" updated
            host.rock64 Adapter "system.adapter.web.0" is started
            • S Smartuser
              nodejs -v
              v12.16.3
              rock64@rock64:~$
              usermod: no changes
              rock64@rock64:~$
              NPM version: 6.14.4
              gyp ERR! not ok
              @Smartuser Das ist klar, das auch ein dist-upgrade da nichts ändert. Du hast ja noch gar nichts kompiliert.
              Allerdings hast du da einen ziemlichen Wildwuchs in deinen Paketquellen.
              Gut (oder auch nicht), versuchen wir zu bauen:
              sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                Smartuser
                Wie gesagt ist ein "frisches" Image gewesen.😊 Von hier
                rock64@rock64:/opt/iobroker$ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                build-essential is already the newest version (12.6).
                libcairo2-dev is already the newest version (1.16.0-4).
                libgif-dev is already the newest version (5.1.4-3).
                libjpeg-dev is already the newest version (1:1.5.2-2).
                librsvg2-dev is already the newest version (2.44.10-2.1).
                libpango1.0-dev is already the newest version (1.42.4-8~deb10u1).
                libpixman-1-0 is already the newest version (0.36.0-1).
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                • S Smartuser
                  Das heißt ja nix. Die Pakete sind überwiegend -dev. Normalerweise sind die nicht installiert. Wie dem auch sei.
                  cd /opt/iobroker
                  npm i sharp
                    cd /opt/iobroker
                    npm i sharp
                    Smartuser
                    schrieb am zuletzt editiert von Smartuser
                    cd /opt/iobroker
                    npm i sharp
                    rock64@rock64:/opt/iobroker$ npm i sharp
                    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
                      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                      COPY Release/nothing.a
                      TOUCH Release/obj.target/libvips-cpp.stamp
                      CXX(target) Release/obj.target/sharp/src/common.o
                    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
                    gyp ERR! not ok
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the sharp@0.25.2 install script.
                    npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_10_27_487Z-debug.log
                    • S Smartuser
                      cd /opt/iobroker
                      npm i sharp
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      @Smartuser
                      sudo apt install libvips-dev
                      [Edit:] Ich sehe gerade, die dürfte zu alt sein.
                      apt policy libvips-dev
                      S 2 Antworten Letzte Antwort
                        @Smartuser
                        Smartuser
                        Ok ... jetzt wurde eine Menge sauber, ohne Fehler installiert
                        0 upgraded, 120 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 58.5 MB of archives.
                        After this operation, 218 MB of additional disk space will be used.
                        Ich spar mir mal den ganzen log. ;)
                        • S Smartuser
                          @Smartuser Wooo... Da zieht libvips aber einiges mit...
                          cd /opt/iobroker
                          npm i libvips
                            cd /opt/iobroker
                            npm i libvips
                            Smartuser
                            npm i libvips
                            Hmmm ....
                            rock64@rock64:/opt/iobroker$ npm i libvips
                            In file included from ../src/common.cc:23:
                            /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
                             #include <glib-object.h>
                            gyp ERR! not ok
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                            + libvips@0.0.2
                            added 1 package in 101.931s
                            22 packages are looking for funding
                              run `npm fund` for details
                            • S Smartuser
                              npm i libvips
                              Hmmm ....
                              gyp ERR! not ok
                              + libvips@0.0.2
                              @Smartuser
                              sudo apt install libglib2.0-dev
                              Dann nochmal bauen:
                              npm i libvips
                                @Smartuser
                                Dann nochmal bauen:
                                npm i libvips
                                Smartuser
                                @Smartuser
                                Dann nochmal bauen:
                                npm i libvips
                                Ist schon aktuell :(
                                rock64@rock64:/opt/iobroker$ sudo apt install libglib2.0-dev
                                libglib2.0-dev is already the newest version (2.58.3-2+deb10u2).
                                libglib2.0-dev set to manually installed.
                                  @Smartuser
                                  Smartuser
                                  Ich seh grad, dass ich deinen editierten post nicht gesehen habe!
                                  Soll ich das nochmal ausführen?
                                  • S Smartuser
                                    @Smartuser
                                    Ja, lass mal sehen.
                                      @Smartuser
                                      Ja, lass mal sehen.
                                      Smartuser
                                      @Smartuser
                                      Ja, lass mal sehen.
                                      rock64@rock64:/opt/iobroker$ apt policy libvips-dev
                                      libvips-dev:
                                        Installed: 8.7.4-1
                                        Candidate: 8.7.4-1
                                        Version table:
                                       *** 8.7.4-1 500
                                              500 http://httpredir.debian.org/debian buster/main arm64 Packages
                                      • S Smartuser
                                        @Smartuser
                                        Ja, lass mal sehen.
                                        libvips-dev:
                                          Installed: 8.7.4-1
                                          Candidate: 8.7.4-1
                                          Version table:
                                         *** 8.7.4-1 500
                                        @Smartuser
                                        npm rebuild libvips --build-from-source
                                          @Smartuser
                                          Smartuser
                                          rock64@rock64:/opt/iobroker$ npm rebuild libvips --build-from-source
                                          libvips@0.0.2 /opt/iobroker/node_modules/libvips
