    Malz1902
    schrieb am zuletzt editiert von Malz1902
    #1816
    Ich habe bei 3 Rollos die gleiche Sonnenschutzeinstellung, 2 sind runtergefahren, 1 nicht.
    shuttercontrol.0	2020-05-08 12:35:00.009	debug	(14669) Sun Elevation: 53.9°
    shuttercontrol.0	2020-05-08 12:35:00.007	debug	(14669) Sun Azimut: 157.1°
    shuttercontrol.0	2020-05-08 12:34:54.343	debug	(14669) insidetemperature changed: zigbee.0.00158d000410c77b.temperature
    shuttercontrol.0	2020-05-08 12:34:45.949	debug	(14669) insidetemperature changed: zigbee.0.00158d00044b332b.temperature
    shuttercontrol.0	2020-05-08 12:33:53.992	debug	(14669) insidetemperature changed: zigbee.0.00158d000410c77b.temperature
    shuttercontrol.0	2020-05-08 12:33:50.205	debug	(14669) system.adapter.admin.0: logging true
    shuttercontrol.0	2020-05-08 12:33:35.269	debug	(14669) outsidetemperature changed: zigbee.0.00158d00045c07b2.temperature
    shuttercontrol.0	2020-05-08 12:32:53.946	debug	(14669) system.adapter.admin.0: logging false
    shuttercontrol.0	2020-05-08 12:32:26.411	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
    shuttercontrol.0	2020-05-08 12:32:02.450	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
    shuttercontrol.0	2020-05-08 12:32:02.289	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
    shuttercontrol.0	2020-05-08 12:32:02.281	debug	(14669) save current height: 0% from RolloKindRechtsSeite00111A4991DE15:4.LEVEL
    shuttercontrol.0	2020-05-08 12:32:02.280	info	(14669) Set ID: RolloKindRechtsSeite00111A4991DE15:4.LEVEL value: 0%
    shuttercontrol.0	2020-05-08 12:32:02.280	debug	(14669) Sunprotect for RolloKindRechtsSeite00111A4991DE15:4.LEVEL is active
    shuttercontrol.0	2020-05-08 12:31:54.804	debug	(14669) system.adapter.admin.0: logging true
    shuttercontrol.0	2020-05-08 12:30:50.696	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
    shuttercontrol.0	2020-05-08 12:30:32.340	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
    shuttercontrol.0	2020-05-08 12:30:32.151	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
    shuttercontrol.0	2020-05-08 12:30:32.144	debug	(14669) save current height: 25% from RolloEsszimmer00111A49915663:4.LEVEL
    shuttercontrol.0	2020-05-08 12:30:32.143	info	(14669) Set ID: RolloEsszimmer00111A49915663:4.LEVEL value: 25%
    shuttercontrol.0	2020-05-08 12:30:32.143	debug	(14669) Sunprotect for RolloEsszimmer00111A49915663:4.LEVEL is active
    Kannst Du mir sagen warum?
    Und dann hab ich noch ein Rollo im Schlafzimmer, das hat die gleiche Einstellung bzgl Sonnenschutz wie das Rollo Ankleide, dies ist auch nicht runtergefhren, dies war aber auch nicht komplett offen bei 100% sondern stand bei 50 % ist es deswegen nicht runter gefahren?
    • M Malz1902
      simatecS Offline
      simatecS Offline
      simatec
      #1817
      @Malz1902 sagte in Test Adapter shuttercontrol v0.5.x:
      genau das ist der Grund. Laut Doku bewirkt manuelles eingreifen ein deaktivieren der Automatik bis zum nächsten runterfahren.
      zu dem anderen Problem müsste ich deine Config sehen
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • M Malz1902
        @simatec said in Test Adapter shuttercontrol v0.5.x:
        @Malz1902
        Mache mal bitte ein Issue auf, damit ich mir das anschauen kann
        wenn du mir sagst wie das geht :-D
        simatecS Offline
        simatecS Offline
        simatec
        #1818
        @Malz1902
        https://github.com/simatec/ioBroker.shuttercontrol/issues
        • simatecS simatec
          @Malz1902
          Malz1902
          #1819
          anbei meine Configsystem.adapter.shuttercontrol.0.json
          • I innriver
            @innriver
            Um dem fehler auf den Grund zu gehen, würde ich dich bitten, alle Werte vom Lichtsensor inkl. der ID de Lichtsensors mal bei der Außentemperatur einzutragen und dann erneut zu testen.
            Wenn ich die Werte vom Lichtsensor auf die Außentemperatur verlege fährt der Rollladen so wie er soll! Also bei Abdunklung auch wieder hoch.
            I Offline
            I Offline
            innriver
            #1820
            @innriver said in Test Adapter shuttercontrol v0.5.x:
            @innriver
            @innriver
            OK werde den Fehler fixen
            @2hot4you
            Die Hysterese arbeitet in Prozent.
            Wenn du bei 4000 z.B. 10 % eingestellt hast, fahren sie unter 3600 Lux wieder hoch
            Hier scheint doch immer noch ein Fehler vorzuliegen. Denn wenn nur der Helligkeitssensor verwendet wird und die entsprechenden Werte auch beim Helligkeitssensor eingetragen werden, der Rollladen erst wieder hochfährt wenn der Bereich der Himmelsrichtung verlassen wird und nicht wenn die Helligkeit unter den Wert fällt!
            • I innriver
              @innriver
              @innriver
              @2hot4you
              simatecS Offline
              simatecS Offline
              simatec
              #1821
              @innriver
              Genau, denn es gab noch kein Update
                Malz1902
                #1822
                hmm auch die anderen rollos sind nicht wieder hoch gefahren. diese sind zwar runtegefahren nachdem die Sollwert Temperatur und Himmelsrichtung erreicht wurde, aber nachdem die Hmmelsrichtung größerwar als der angegeben Wert + Bereich der Himmelsrichtung sind die Rollos nicht wieder hochgefahren
                Kann es sein das auch zum Runterfahren der Sollwert Außentemperatur UND die Hmmelsrichtung außerhalb der Wertelaut der Einstellungen sein müssen?
                • M Malz1902
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #1823
                  Welcher Rollladen ist denn gefahren und welcher nicht?
                  • simatecS simatec
                    Malz1902
                    #1824
                    runter ist Ankleide und Schlafzimmer nicht gefahren, aber Schlafzimmer ist ja nicht gefahren, weil dieser nicht auf 100 % war.
                    Nachdem ich die Instanz neugestartet hatte ist auch das Rollo Ankleide laut Sonnenschutzeinstellung runtergefahren.
                    Hochgefahren sind leider alle Rollos die Sonnenschutzeinstellungen haben nicht dies betrifft KücheGarten, Esszimmer, EsszimmerHSE, Kind Links Gaube, Kid Rechts Gaube und Kind rechts seite
                    Ich teste heute mal nur die Einstellung Hmmelsrichtung, die Rollos auf der Südseite sind auch hon runtergefahren, da doe Sonnenrichtung 80 bereits erreicht hat, mal schauen ob diese dann heute Nachmittag/Abend auch wieder hoch fahren.
                    • M Malz1902
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #1825
                      @Malz1902
                      Konnte erstmal keinen Fehler feststellen..
                      Schaue mir nachher mal den Code dazu an
                      • simatecS simatec
                        @Malz1902
                        Malz1902
                        #1826
                        @Malz1902
                        Super danke
                        • M Malz1902
                          @Malz1902
                          Super danke
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #1827
                          @Malz1902
                          So ich habe noch einmal geschaut ...
                          Im Code passt alles. Was ich vermute, dass deine Hysterese zu hoch ist.
                          Dein Rolladen würde bei einer Hysterese von 10 erst bei einer Temperatur von unter 22,5 Grad hochfahren.
                          Setze die mal auf 5.
                          Fahren die Rollläden beim erreichen der Himmelsrichtung?
                          Sonst setze mal autodrive auf hoch und runter
                          Stelle mal die Instanz auf debug und poste mal die Logs wenn die Werte erreicht sind und er nicht fahren sollte
                          • simatecS Offline
                            simatecS Offline
                            simatec
                            #1828
                            Habe gerade mal die Version 0.6.0 auf Github gepusht ... Wer testen will, kann hier gerne berichten ...
                            • simatecS simatec
                              @Malz1902
                              Malz1902
                              #1829
                              @Malz1902
                              Habe mal 2 Rollos exemplarisch genommen, beide haben die gleichen Einstellungen.
                              2020-05-09 09:11:27.924 - debug: shuttercontrol.0 (24124) Sun Azimut: 98.8°
                              2020-05-09 09:11:27.927 - debug: shuttercontrol.0 (24124) Sun Elevation: 29.2°
                              2020-05-09 09:11:28.930 - debug: shuttercontrol.0 (24124) goldenHourEnd today: 06:40
                              2020-05-09 09:11:28.933 - debug: shuttercontrol.0 (24124) goldenHour today: 20:22
                              2020-05-09 09:11:28.934 - debug: shuttercontrol.0 (24124) current day: 6
                              2020-05-09 09:11:28.935 - debug: shuttercontrol.0 (24124) Sunrise today: 05:51
                              2020-05-09 09:11:28.937 - debug: shuttercontrol.0 (24124) Sunset today: 21:10
                              2020-05-09 09:11:28.940 - debug: shuttercontrol.0 (24124) Starting up shutters GoldenHour area: 06:50
                              2020-05-09 09:11:28.941 - debug: shuttercontrol.0 (24124) Shutdown shutters GoldenHour area: 20:52
                              2020-05-09 09:11:28.942 - debug: shuttercontrol.0 (24124) Starting up shutters Sunrise area: 06:01
                              2020-05-09 09:11:28.942 - debug: shuttercontrol.0 (24124) Shutdown shutters Sunset area: 21:40
                              2020-05-09 09:11:28.975 - debug: shuttercontrol.0 (24124) Starting up shutters living area: 8:30
                              2020-05-09 09:11:28.985 - debug: shuttercontrol.0 (24124) Starting up shutters sleep area: 9:00
                              2020-05-09 09:11:28.997 - debug: shuttercontrol.0 (24124) Shutdown shutters living area: 21:40
                              2020-05-09 09:11:29.009 - debug: shuttercontrol.0 (24124) Shutdown shutters sleep area: 21:40
                              2020-05-09 09:12:00.052 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 24180
                              2020-05-09 09:12:07.282 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                              2020-05-09 09:12:10.072 - debug: shuttercontrol.0 (24124) Sunprotect for RolloEsszimmerHSE00111A49915582:4.LEVEL is active
                              2020-05-09 09:12:10.074 - info: shuttercontrol.0 (24124) Set ID: RolloEsszimmerHSE00111A49915582:4.LEVEL value: 25%
                              2020-05-09 09:12:10.076 - debug: shuttercontrol.0 (24124) save current height: 25% from RolloEsszimmerHSE00111A49915582:4.LEVEL
                              2020-05-09 09:12:10.085 - debug: shuttercontrol.0 (24124) shutter state changed: hm-rpc.1.00111A49915582.4.LEVEL
                              2020-05-09 09:12:10.277 - debug: shuttercontrol.0 (24124) shutter state changed: hm-rpc.1.00111A49915582.4.LEVEL
                              2020-05-09 09:12:20.069 - debug: shuttercontrol.0 (24124) Sunprotect for RolloKuecheGarten00111A4991568A:4.LEVEL is active
                              2020-05-09 09:12:20.070 - info: shuttercontrol.0 (24124) Set ID: RolloKuecheGarten00111A4991568A:4.LEVEL value: 25%
                              2020-05-09 09:12:20.072 - debug: shuttercontrol.0 (24124) save current height: 25% from RolloKuecheGarten00111A4991568A:4.LEVEL
                              Also runtergefahren sind beide sehr gut
                              2020-05-09 14:17:06.854 - debug: shuttercontrol.0 (6947) insidetemperature changed: zigbee.0.00158d0004117847.temperature
                              2020-05-09 14:17:42.770 - debug: shuttercontrol.0 (6947) outsidetemperature changed: zigbee.0.00158d00045c07b2.temperature
                              2020-05-09 14:20:00.026 - debug: shuttercontrol.0 (6947) Sun Azimut: 200.6°
                              2020-05-09 14:20:00.028 - debug: shuttercontrol.0 (6947) Sun Elevation: 54.5°
                              2020-05-09 14:20:00.070 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 13785
                              2020-05-09 14:20:05.750 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                              2020-05-09 14:20:33.751 - debug: shuttercontrol.0 (6947) outsidetemperature changed: zigbee.0.00158d00045c07b2.temperature
                              2020-05-09 14:20:42.140 - debug: shuttercontrol.0 (6947) Sunprotect for RolloEsszimmerHSE00111A49915582:4.LEVEL is not active
                              2020-05-09 14:20:42.140 - info: shuttercontrol.0 (6947) Set ID: RolloEsszimmerHSE00111A49915582:4.LEVEL value: 100%
                              2020-05-09 14:20:42.141 - debug: shuttercontrol.0 (6947) save current height: 100% from RolloEsszimmerHSE00111A49915582:4.LEVEL
                              Hochgefharen ist aber nur 1. Hatte die Einstellungen auf nur Himmelsrichtung bei der Sonnenschutzeinstellung.
                              Mein Beeich für die Himmelsrichtung ist 165 +-85
                              simatecS 2 Antworten Letzte Antwort
                              • M Malz1902
                                @Malz1902
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #1830
                                @Malz1902
                                Aber die Himmelsrichtung kann doch heute noch nicht erreicht sein. Bei 165 Grad +- 85 Grad ist das Maximum erst bei 250 Grad erreicht
                                • M Malz1902
                                  @Malz1902
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #1831
                                  @Malz1902
                                  Was hast du für Aktoren?
                                  Stimmen die Level nch dem fahren der Rollläden zu 100% überein, oder gibt es leichte Abweichungen.
                                  Manche Aktoren setzen z.B. bei 100% nicht exakt den Wert sondern 99,3% oder der gleichen.
                                  Sollte das der Fall sein, musst du in den Extraeinstellungen den Abgleich aktivieren
                                  • simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1832
                                    Ab sofort ist die Version 0.6.0 auf Github und ab spätestens heute Nacht im latest verfügbar.
                                    Changelog
                                    0.6.0 (10.05.2020)
                                    • (simatec) added sentry.io
                                    • (simatec) added node Support
                                    • (simatec) many small Bugfixes
                                    • (simatec) node 8 support removed
                                    • (5G7K) added new feature for sunprotect
                                    • (5G7K) added more debug logs
                                    • simatecS simatec
                                      @Malz1902
                                      Malz1902
                                      #1833
                                      @simatec said in Test Adapter shuttercontrol v0.6.x:
                                      @Malz1902
                                      das war von gestern
                                      @Malz1902
                                      von Homematic Ip HmIP-BROLL, werde das mit den abgleich mal aktivieren
                                        Malz1902
                                        #1834
                                        Ich glaube ich habe das Problem gefunden liegt an meinem Script. Und zwar haben die HmIP Rollo Aktoren als Datenpunkte 3:LEVEL und 4:LEVEL. Wenn das Rollo fahren soll über Änderungen im ioBroker (VIS, shuttercontrol) so ändert man LEVEL:4, fährt man das Rollo aber manuell über den Schalter, und man stopt nach einer gewissen Zeit, so steht bei Level:4 nicht der aktuelle Level vom Rollo 83 % sondern es steht dort dann entweder 0 % wenn man das Rollo runtergefahren hat und gestoppt hat oder es steht 100 % wenn man das Rollo etwas hoch gefahren hat und gestoppt hat. Und ich hattte ein Script geschrieben, welches Level 4 anpasst wenn Level 3 geändert wurde,, dass führt wohl dazu, dass shutercontroll denkt, man hätte manuell noch etwas nach der Sonnenschutzeinstellung geändert und fährt somit nicht mehr
                                          Kugelkopf
                                          #1835
                                          @simatec
                                          Habe gerade eben die aktuellste Version von deinem Git installiert und habe folgenden grafischen Fehler rechts bei den Buttons entdeckt.
