  4. Iobroker startet nich mehr (mal wieder)
    1.0k
    6.1k
iobroker
35 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • K kleinfritzchen
    pi@iobroker:~ $ iobroker status
    iobroker is running
    Objects type: file
    States type: file
    pi@iobroker:~ $ iobroker list instances
    system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.backitup.0 : backitup - enabled
      system.adapter.cloud.0 : cloud - enabled
      system.adapter.daswetter.0 : daswetter - enabled
    • system.adapter.discovery.0 : discovery - enabled
      system.adapter.flot.0 : flot - enabled
    • system.adapter.info.0 : info - enabled
    • system.adapter.javascript.0 : javascript - enabled
    • system.adapter.mqtt.0 : mqtt - enabled, port: 1883
    • system.adapter.octoprint.0 : octoprint - enabled
    • system.adapter.parser.0 : parser - enabled
      system.adapter.ping.0 : ping - enabled
      system.adapter.pushover.0 : pushover - enabled
      system.adapter.rpi2.0 : rpi2 - enabled
    • system.adapter.scenes.0 : scenes - enabled
    • system.adapter.sonoff.0 : sonoff - enabled, port: 1885, bind: 0.0.0.0
      system.adapter.sql.0 : sql - enabled, port: 3306
    • system.adapter.systeminfo.0 : systeminfo - enabled
    • system.adapter.tankerkoenig.0 : tankerkoenig - enabled
    • system.adapter.telegram.0 : telegram - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.text2command.0 : text2command - enabled
      system.adapter.vis-bars.0 : vis-bars - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
      system.adapter.vis-weather.0 : vis-weather - enabled
      system.adapter.vis.0 : vis - enabled
    • system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • instance is alive
      pi@iobroker:~ $
    kleinfritzchen
    @kleinfritzchen said in Iobroker startet nich mehr (mal wieder):
    > iobroker is running
    > Objects type: file
    > States  type: file
    > + system.adapter.backitup.0              : backitup    -  enabled
    > + system.adapter.discovery.0             : discovery   -  enabled
    > + system.adapter.info.0                  : info        -  enabled
    > + system.adapter.javascript.0            : javascript  -  enabled
    > + system.adapter.mqtt.0                  : mqtt        -  enabled, port: 1883
    > + system.adapter.octoprint.0             : octoprint   -  enabled
    > + system.adapter.parser.0                : parser      -  enabled
    > + system.adapter.scenes.0                : scenes      -  enabled
    > + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1885, bind: 0.0.0.0
    > + system.adapter.systeminfo.0            : systeminfo  -  enabled
    > + system.adapter.tankerkoenig.0          : tankerkoenig -  enabled
    > + system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
    > + system.adapter.text2command.0          : text2command -  enabled
    > + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    > + instance is alive
    > pi@iobroker:~ $```>
      kleinfritzchen
      pi@iobroker:~ $ iobroker version
      1.5.14
      pi@iobroker:~ $
      • K kleinfritzchen
        1.5.14
        pi@iobroker:~ $
        @kleinfritzchen
        Das ist ja ewig alt...
        Die Version passt nicht mehr zu dem upgedateten Admin, fürchte ich.
        Die Installationen sollten immer im Gleichschritt aktualisert werden.
        Ich weiß gar nicht wie man die sauber aktualisiert bekommt.
        Aktuell würde man
        iobroker stop
        iobroker update
        iobroker upgrade self
        iobroker start
        durchführen. Aber das wird vermutlich bei dir noch nicht funktionieren.
          @kleinfritzchen
          Aktuell würde man
          iobroker stop
          iobroker update
          iobroker start
          @Thomas-Braun sagte in Iobroker startet nich mehr (mal wieder):
          sollte aber.
          Das ging auch zu Zeiten des ioBroker-Altertums ;-)
            kleinfritzchen
            Danke!!!!!!!!
            Juhuuu es geht wieder!
            Besten dank für die Hilfe!! Ihr seid Spitze!!!
            MfG Fritz
            • K kleinfritzchen
              Danke!!!!!!!!
              MfG Fritz
              @kleinfritzchen Freut mich!
              Welche Versionen hast du denn da nun installiert?
              iobroker version
              nodejs -v
              node -v
                kleinfritzchen
                pi@iobroker:/opt/iobroker $ iobroker version
                2.2.9
                pi@iobroker:/opt/iobroker $ nodejs -v
                v10.20.1
                pi@iobroker:/opt/iobroker $ node -v
                v10.20.1
                • K kleinfritzchen
                  2.2.9
                  v10.20.1
                  v10.20.1
                  @kleinfritzchen
                  Defensiv. Aber das ist vermutlich für dich genau die richtige Herangehensweise. 👍
                    kleinfritzchen
                    Ja, anscheinend schon.
                    Bin schon mal froh das er wieder geht.Ich hab Mariadb mit auf dem pi und muss erst mal verstehen wie das mit den Backups von iobroker funktioniert wenn man mariadb verwendet.
                    K Thomas BraunT 2 Antworten Letzte Antwort
                    • K kleinfritzchen
                      kleinfritzchen
                      Damit ich nicht wieder so einen trabbel hab mach ich jetzt erst mal ein komplett Backup der Karte
                      • K kleinfritzchen
                        @kleinfritzchen Sind die miteinander verknüpft?
                          kleinfritzchen
                          ja, sind sie . Ich kann jetzt auf den Datensatz wieder zugreifen seit iobroker wieder vernünftig läuft. Ich hab das mal so eingerichtet das ich auch von einem anderen Rechner auf die Datenbank zugreifen konnte. Dies ging auch als Iobroker nicht richtig lief.
                          Seit dem Update hab ich grad das Problem das mir mein Script zum sichern der gesamten SD nicht mehr richtig arbeitet. Hier mal der Script:
                          pi@iobroker:~ $ cat backup1.sh
                          #!/bin/bash
                          #Festplatte einbinden
                          mount -t cifs -o user=RASPI_S,password=******,vers=1.0,rw,file_mode=0777,dir_mode=0777 //192.168.179.91/Sicherungen /mnt/nas
                          #Variablen
                          BACKUP_PFAD="/mnt/nas/Sicherung_iobroker"
                          BACKUP_ANZAHL="5"
                          BACKUP_NAME="iobroker"
                          #mysql stoppen
                          service mysql stop
                          #IOBroker stoppen
                          iobroker stop
                          #Backup erstellen
                          dd if=/dev/mmcblk0 of=${BACKUP_PFAD}/${BACKUP_NAME}-$(date +%Y%m%d).img bs=1MB
                          #Alte Sicherung löschen
                          pushd ${BACKUP_PFAD}; ls -tr ${BACKUP_PFAD}/${BACKUP_NAME}* | head -n -${BACKUP_ANZAHL} | xargs rm; popd
                          #Festplatte auswerfen
                          umount /mnt/nas
                          #IOBroker wieder starten
                          iobroker start
                          service mysql start
                            kleinfritzchen
                            da kommt folgende Fehlermeldung:
                            pi@iobroker:~ $ sudo ./backup1.sh
                            mount error(16): Device or resource busy
                            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                            dd: Fehler beim Lesen von '/dev/mmcblk0': Eingabe-/Ausgabefehler
                            5453+1 Datensätze ein
                            5453+1 Datensätze aus
                            5453524992 Bytes (5,5 GB, 5,1 GiB) kopiert, 498,177 s, 10,9 MB/s
                            /mnt/nas/Sicherung_iobroker /home/pi
                            ./backup1.sh: line 15: head: command not found
                            ./backup1.sh: line 15: xargs: command not found
                            ./backup1.sh: line 15: ls: command not found
                            /home/pi
                            ./backup1.sh: line 17: umount: command not found
                            ./backup1.sh: line 19: /usr/bin/iobroker: Eingabe-/Ausgabefehler
                            ./backup1.sh: line 20: /usr/sbin/service: Eingabe-/Ausgabefehler
                            pi@iobroker:~ $ Connection to 192.168.179.52 closed by remote host.
                            Connection to 192.168.179.52 closed.
                            Vor dem Update hat das einwandfrei funktioniert. Anscheinend wird head nicht erkannt. Es werden nur 5,1GB kopiert dann bricht er ab.
                            Kann das eine defekte Karte sein?
                            • K kleinfritzchen
                              /home/pi
                              @kleinfritzchen
                              Da wird auch noch anderes nicht gefunden.
                              Könnte eine sterbende Karte sein.
                                kleinfritzchen
                                sieht irgenwie so aus als ob da die Root Partition ne macke hat
                                • K kleinfritzchen
                                  kleinfritzchen
                                  Die sd hatte schon mal nicht funktioniert und da hab ich sie auf eine bessere kopiert mit dd. Die lief dann wieder. Vielleicht hab ich dabei die Ferhler mit geklont.
                                  • K kleinfritzchen
                                    kleinfritzchen
                                    Die sd hatte schon mal nicht funktioniert und da hab ich sie auf eine bessere kopiert mit dd. Die lief dann wieder. Vielleicht hab ich dabei die Fehler mit geklont.
                                    ich versuch jetzt mal mein Glück mit raspiBackup
                                      kleinfritzchen
                                      Frage, kann das Problem mit mangelnden Speicher zu tun haben?
                                      df auf dem Raspi ergab:
                                      pi@iobroker:~ $ df
                                      Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
                                      /dev/root       15328624 3572776  11113384   25% /
                                      devtmpfs          469544       0    469544    0% /dev
                                      tmpfs             474152       0    474152    0% /dev/shm
                                      tmpfs             474152   12220    461932    3% /run
                                      tmpfs               5120       4      5116    1% /run/lock
                                      tmpfs             474152       0    474152    0% /sys/fs/cgroup
                                      /dev/mmcblk0p1     43436   22855     20582   53% /boot
                                      tmpfs              94828       0     94828    0% /run/user/1000
                                      pi@iobroker:~ $
                                      ```Das ist eine 16GB Karte, hat das vielleicht damit zu tun?
                                      • K kleinfritzchen
                                        pi@iobroker:~ $ df
                                        pi@iobroker:~ $
                                        kleinfritzchen
                                        pi@iobroker:~ $ df
                                        pi@iobroker:~ $
                                        J Thomas BraunT 2 Antworten Letzte Antwort
                                        • K kleinfritzchen
                                          pi@iobroker:~ $ df
                                          pi@iobroker:~ $
                                          Jan1
                                          @kleinfritzchen
                                          an der größe liegt es nicht direkt, allerdings stirbt eine 16er früher als eine 32, wesalb ich in meinem Pi immer eine 32er hatte und nie probleme mit der SD Karte. Es kommt eben auch drauf an wie man sie behandelt, Fakt viel Schreibzugriffe töten die Karte mit der zeit und eine 32er hat nunmal doppelt so viele zellen wie eine 16er.
