  4. Iobroker startet nich mehr (mal wieder)
    1.0k
    6.1k
iobroker
35 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • K kleinfritzchen
    pi@iobroker:~ $ iobroker status
    iobroker is running
    Objects type: file
    States type: file
    pi@iobroker:~ $ iobroker list instances
    system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.backitup.0 : backitup - enabled
      system.adapter.cloud.0 : cloud - enabled
      system.adapter.daswetter.0 : daswetter - enabled
    • system.adapter.discovery.0 : discovery - enabled
      system.adapter.flot.0 : flot - enabled
    • system.adapter.info.0 : info - enabled
    • system.adapter.javascript.0 : javascript - enabled
    • system.adapter.mqtt.0 : mqtt - enabled, port: 1883
    • system.adapter.octoprint.0 : octoprint - enabled
    • system.adapter.parser.0 : parser - enabled
      system.adapter.ping.0 : ping - enabled
      system.adapter.pushover.0 : pushover - enabled
      system.adapter.rpi2.0 : rpi2 - enabled
    • system.adapter.scenes.0 : scenes - enabled
    • system.adapter.sonoff.0 : sonoff - enabled, port: 1885, bind: 0.0.0.0
      system.adapter.sql.0 : sql - enabled, port: 3306
    • system.adapter.systeminfo.0 : systeminfo - enabled
    • system.adapter.tankerkoenig.0 : tankerkoenig - enabled
    • system.adapter.telegram.0 : telegram - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.text2command.0 : text2command - enabled
      system.adapter.vis-bars.0 : vis-bars - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
      system.adapter.vis-weather.0 : vis-weather - enabled
      system.adapter.vis.0 : vis - enabled
    • system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • instance is alive
      pi@iobroker:~ $
    @kleinfritzchen Pack die Ausgaben bitte in Code-Tags </>. So mag das keiner entziffern.
    • K kleinfritzchen
      iobroker is running
      Objects type: file
      States type: file
      • instance is alive
        pi@iobroker:~ $
      kleinfritzchen
      @kleinfritzchen said in Iobroker startet nich mehr (mal wieder):
      > iobroker is running
      > Objects type: file
      > States  type: file
      > + system.adapter.backitup.0              : backitup    -  enabled
      > + system.adapter.discovery.0             : discovery   -  enabled
      > + system.adapter.info.0                  : info        -  enabled
      > + system.adapter.javascript.0            : javascript  -  enabled
      > + system.adapter.mqtt.0                  : mqtt        -  enabled, port: 1883
      > + system.adapter.octoprint.0             : octoprint   -  enabled
      > + system.adapter.parser.0                : parser      -  enabled
      > + system.adapter.scenes.0                : scenes      -  enabled
      > + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1885, bind: 0.0.0.0
      > + system.adapter.systeminfo.0            : systeminfo  -  enabled
      > + system.adapter.tankerkoenig.0          : tankerkoenig -  enabled
      > + system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
      > + system.adapter.text2command.0          : text2command -  enabled
      > + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      > + instance is alive
      > pi@iobroker:~ $```>
        kleinfritzchen
        pi@iobroker:~ $ iobroker version
        1.5.14
        pi@iobroker:~ $
        • K kleinfritzchen
          1.5.14
          pi@iobroker:~ $
          @kleinfritzchen
          Das ist ja ewig alt...
          Die Version passt nicht mehr zu dem upgedateten Admin, fürchte ich.
          Die Installationen sollten immer im Gleichschritt aktualisert werden.
          Ich weiß gar nicht wie man die sauber aktualisiert bekommt.
          Aktuell würde man
          iobroker stop
          iobroker update
          iobroker upgrade self
          iobroker start
          durchführen. Aber das wird vermutlich bei dir noch nicht funktionieren.
            @kleinfritzchen
            Aktuell würde man
            iobroker stop
            iobroker update
            iobroker start
            @Thomas-Braun sagte in Iobroker startet nich mehr (mal wieder):
            sollte aber.
            Das ging auch zu Zeiten des ioBroker-Altertums ;-)
              kleinfritzchen
              Danke!!!!!!!!
              Juhuuu es geht wieder!
              Besten dank für die Hilfe!! Ihr seid Spitze!!!
              MfG Fritz
              • K kleinfritzchen
                Danke!!!!!!!!
                MfG Fritz
                @kleinfritzchen Freut mich!
                Welche Versionen hast du denn da nun installiert?
                iobroker version
                nodejs -v
                node -v
                  kleinfritzchen
                  pi@iobroker:/opt/iobroker $ iobroker version
                  2.2.9
                  pi@iobroker:/opt/iobroker $ nodejs -v
                  v10.20.1
                  pi@iobroker:/opt/iobroker $ node -v
                  v10.20.1
                  • K kleinfritzchen
                    2.2.9
                    v10.20.1
                    v10.20.1
                    @kleinfritzchen
                    Defensiv. Aber das ist vermutlich für dich genau die richtige Herangehensweise. 👍
                      kleinfritzchen
                      Ja, anscheinend schon.
                      Bin schon mal froh das er wieder geht.Ich hab Mariadb mit auf dem pi und muss erst mal verstehen wie das mit den Backups von iobroker funktioniert wenn man mariadb verwendet.
                      K Thomas BraunT 2 Antworten Letzte Antwort
                      • K kleinfritzchen
                        kleinfritzchen
                        Damit ich nicht wieder so einen trabbel hab mach ich jetzt erst mal ein komplett Backup der Karte
                        • K kleinfritzchen
                          @kleinfritzchen Sind die miteinander verknüpft?
                            kleinfritzchen
                            ja, sind sie . Ich kann jetzt auf den Datensatz wieder zugreifen seit iobroker wieder vernünftig läuft. Ich hab das mal so eingerichtet das ich auch von einem anderen Rechner auf die Datenbank zugreifen konnte. Dies ging auch als Iobroker nicht richtig lief.
                            Seit dem Update hab ich grad das Problem das mir mein Script zum sichern der gesamten SD nicht mehr richtig arbeitet. Hier mal der Script:
                            pi@iobroker:~ $ cat backup1.sh
                            #!/bin/bash
                            #Festplatte einbinden
                            mount -t cifs -o user=RASPI_S,password=******,vers=1.0,rw,file_mode=0777,dir_mode=0777 //192.168.179.91/Sicherungen /mnt/nas
                            #Variablen
                            BACKUP_PFAD="/mnt/nas/Sicherung_iobroker"
                            BACKUP_ANZAHL="5"
                            BACKUP_NAME="iobroker"
                            #mysql stoppen
                            service mysql stop
                            #IOBroker stoppen
                            iobroker stop
                            #Backup erstellen
                            dd if=/dev/mmcblk0 of=${BACKUP_PFAD}/${BACKUP_NAME}-$(date +%Y%m%d).img bs=1MB
                            #Alte Sicherung löschen
                            pushd ${BACKUP_PFAD}; ls -tr ${BACKUP_PFAD}/${BACKUP_NAME}* | head -n -${BACKUP_ANZAHL} | xargs rm; popd
                            #Festplatte auswerfen
                            umount /mnt/nas
                            #IOBroker wieder starten
                            iobroker start
                            service mysql start
                              kleinfritzchen
                              da kommt folgende Fehlermeldung:
                              pi@iobroker:~ $ sudo ./backup1.sh
                              mount error(16): Device or resource busy
                              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                              dd: Fehler beim Lesen von '/dev/mmcblk0': Eingabe-/Ausgabefehler
                              5453+1 Datensätze ein
                              5453+1 Datensätze aus
                              5453524992 Bytes (5,5 GB, 5,1 GiB) kopiert, 498,177 s, 10,9 MB/s
                              /mnt/nas/Sicherung_iobroker /home/pi
                              ./backup1.sh: line 15: head: command not found
                              ./backup1.sh: line 15: xargs: command not found
                              ./backup1.sh: line 15: ls: command not found
                              /home/pi
                              ./backup1.sh: line 17: umount: command not found
                              ./backup1.sh: line 19: /usr/bin/iobroker: Eingabe-/Ausgabefehler
                              ./backup1.sh: line 20: /usr/sbin/service: Eingabe-/Ausgabefehler
                              pi@iobroker:~ $ Connection to 192.168.179.52 closed by remote host.
                              Connection to 192.168.179.52 closed.
                              Vor dem Update hat das einwandfrei funktioniert. Anscheinend wird head nicht erkannt. Es werden nur 5,1GB kopiert dann bricht er ab.
                              Kann das eine defekte Karte sein?
                              • K kleinfritzchen
                                /home/pi
                                @kleinfritzchen
                                Da wird auch noch anderes nicht gefunden.
                                Könnte eine sterbende Karte sein.
                                  kleinfritzchen
                                  sieht irgenwie so aus als ob da die Root Partition ne macke hat
                                  • K kleinfritzchen
                                    kleinfritzchen
                                    Die sd hatte schon mal nicht funktioniert und da hab ich sie auf eine bessere kopiert mit dd. Die lief dann wieder. Vielleicht hab ich dabei die Ferhler mit geklont.
                                    • K kleinfritzchen
                                      kleinfritzchen
                                      Die sd hatte schon mal nicht funktioniert und da hab ich sie auf eine bessere kopiert mit dd. Die lief dann wieder. Vielleicht hab ich dabei die Fehler mit geklont.
                                      ich versuch jetzt mal mein Glück mit raspiBackup
                                        kleinfritzchen
                                        Frage, kann das Problem mit mangelnden Speicher zu tun haben?
                                        df auf dem Raspi ergab:
                                        pi@iobroker:~ $ df
                                        Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
                                        /dev/root       15328624 3572776  11113384   25% /
                                        devtmpfs          469544       0    469544    0% /dev
                                        tmpfs             474152       0    474152    0% /dev/shm
                                        tmpfs             474152   12220    461932    3% /run
                                        tmpfs               5120       4      5116    1% /run/lock
                                        tmpfs             474152       0    474152    0% /sys/fs/cgroup
                                        /dev/mmcblk0p1     43436   22855     20582   53% /boot
                                        tmpfs              94828       0     94828    0% /run/user/1000
                                        pi@iobroker:~ $
                                        ```Das ist eine 16GB Karte, hat das vielleicht damit zu tun?
                                        • K kleinfritzchen
                                          pi@iobroker:~ $ df
                                          pi@iobroker:~ $
                                          kleinfritzchen
                                          pi@iobroker:~ $ df
                                          pi@iobroker:~ $
                                          J Thomas BraunT 2 Antworten Letzte Antwort
