  4. Test Adapter Worx v0.4.x
worxlandroid
198 Beiträge 36 Kommentatoren 41.7k Aufrufe 35 Beobachtet
  • lobomauL lobomau
    geht bei mir auch nicht, aber anderer Fehler:
    host.ioBrokerCT	2020-04-26 11:46:15.413	info	Restart adapter system.adapter.worx.0 because enabled
    host.ioBrokerCT	2020-04-26 11:46:15.412	info	instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
    worx.0	2020-04-26 11:46:14.825	info	(22295) Terminated (NO_ERROR): Without reason
    worx.0	2020-04-26 11:46:14.823	info	(22295) terminating
    worx.0	2020-04-26 11:46:14.803	info	(22295) cleaned everything up...
    worx.0	2020-04-26 11:46:14.802	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    worx.0	2020-04-26 11:46:14.802	error	at endReadableNT (_stream_readable.js:1187:12)
    worx.0	2020-04-26 11:46:14.802	error	at IncomingMessage.emit (events.js:322:22)
    worx.0	2020-04-26 11:46:14.802	error	at Object.onceWrapper (events.js:416:28)
    worx.0	2020-04-26 11:46:14.802	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
    worx.0	2020-04-26 11:46:14.802	error	at Request.emit (events.js:310:20)
    worx.0	2020-04-26 11:46:14.802	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
    worx.0	2020-04-26 11:46:14.802	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    worx.0	2020-04-26 11:46:14.802	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:46:31)
    worx.0	2020-04-26 11:46:14.802	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:104:33)
    worx.0	2020-04-26 11:46:14.802	error	at new StatusCodeError (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js:32:15)
    worx.0	2020-04-26 11:46:14.802	error	(22295) StatusCodeError: 422 - {"message":"Missing coordinates","code":"422.005"}
    worx.0	2020-04-26 11:46:14.800	error	(22295) uncaught exception: 422 - {"message":"Missing coordinates","code":"422.005"}
    worx.0	2020-04-26 11:46:08.393	info	(22295) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.worx, node: v12.16.2, js-controller: 3.0.18
    lobomauL Offline
    lobomauL Offline
    lobomau
    @lobomau sagte in Test Adapter Worx v0.4.x:
    Fehler gefunden! Ich hatte noch die alte App installiert. Da gab es keine Ortsbestimmung mit Koordinaten. Nun habe ich auch Werte bei "weather" :-D
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
      skokarl
      schrieb am zuletzt editiert von skokarl
      bei mir läuft alles wunderbar.....
      guckt auch mal rechts und links von dem Adapter.....z.b. was ihr alles so am System verändert habt......
      • cvidalC Offline
        cvidalC Offline
        cvidal
        Forum Testing
        So jetzt mit dem neuen Landroid 2019/20 läuft es. Warum das mit der Version 2017/18 bei mir nicht lief konnte ich nicht mehr herausfinden.
        • cvidalC cvidal
          dslraserD Offline
          dslraserD Offline
          dslraser
          @cvidal sagte in Test Adapter Worx v0.4.x:
          Ist schon irgendwie seltsam das Ganze...Bei mir läuft so einer jetzt die dritte Saison, erst mit dem alten Adapter und seit dieser Saison mit dem aktuellem Adapter ohne Probleme. Ich war (auf Holz klopf) noch nie gesperrt.
            skokarl
            Hat jemand ne Idee warum Edgecut nicht immer die Messer startet ?
            Letztes Jahr ging es eigentlich jedesmal......dieses Jahr startet er bei EdgeCut irgendwann mal
            die Messer, aber vielleicht nur bei jedem 5 ten Start, ansonsten macht er eben nur ne Zonenfahrt.
            hsteinmeH 1 Antwort Letzte Antwort
            • S skokarl
              hsteinmeH Online
              hsteinmeH Online
              hsteinme
              @skokarl sagte in Test Adapter Worx v0.4.x:
              Die MQTT-Schnittstelle kennt eigentlich keinen Kantenschnitt-Befehl. Der Worx-Adapter nutzt - wie manch andere Anwendung auch - einen "Indianertrick": Das Makro "edgecut" wird aus drei geschickt angeordneten Einzelbefehlen zusammengebastelt:
              • Zonentraining, um den Mäher auf kürzestem Wege Richtung Draht zu schicken
              • Pause
              • Heimfahrt
              Die letztgenannte Aktion schaltet die Messer ein und schickt den Mäher über den Draht zur Ladestation.
              Bei einer Diskussion in roboter-forum.com stellte sich heraus, das Positec seit FW 3.7 bei einer aus der Ferne gegebenen Kommandofolge Pause + Home die Messer abschaltet. Somit hat der frühere Kantenschnitt nun nur noch eine "Ehrenrunden-Funktion" 😞
              Dass bei Dir gelegentlich doch die Messer mitlaufen, wundert mich. Bist Du da sicher?
              • hsteinmeH hsteinme
                • Pause
                • Heimfahrt
                skokarl
                @hsteinme
                Danke für die tolle Erklärung.
                Ja, bin mir sicher. Ganz selten, aber trotzdem immer mal, schaltet er die Messer kurz nach der Ausfahrt ein.
                Aber eben nicht nachvollziehbar und ohne Logik.
                Leztes Jahr ging das noch super und zuverlässig.
                Ich hab auch ein paar mal den Parameter verändert .....
                und wie mähe ich jetzt die Kanten ????????
                hsteinmeH 2 Antworten Letzte Antwort
                • S skokarl
                  @hsteinme
                  hsteinmeH Online
                  hsteinmeH Online
                  hsteinme
                  Dieser Parameter hat keine Auswirkung auf die Messer. Er steuert lediglich den Zeitpunkt, wann das Pause-Kommando abgesetzt wird. Zuweilen wurde die Pause an einer Ecke im Drahtverlauf genommen, wobei beim nachfolgenden Home-Kommando der Mäher außerhalb des Drahtes landete. Mit dem Parameter kannst Du nun den Zeitpunkt und damit die Stelle der Pause verändern.
                  • S skokarl
                    @hsteinme
                    hsteinmeH Online
                    hsteinmeH Online
                    hsteinme
                    Von Hand 😛
                    Nein, per Adapter würde es heute nur gehen, wenn Du Deine gesamte Mäher-Ansteuerung völlig anders als bisher gestalten würdest. Deine Steuerung müsste dann grundsätzlich über das Setzen des Kalenders im Mäher erfolgen. Kurz vor einem anstehenden Mähauftrag manipulierst Du dann den Kalenderauftrag des aktuellen Tages mit Start, Dauer und evtl. Kantenschnittauftrag der anstehenden Mähaktion.
                    Solltest Du Dich entscheiden, diesen Weg zu gehen, dann beachte bitte unbedingt diesen Thread.
                      Von Hand 😛
                      hsteinmeH Online
                      hsteinmeH Online
                      hsteinme
                      @hsteinme sagte in Test Adapter Worx v0.4.x:
                      Von Hand
                      Das heißt ja nicht unbedingt, dass Du mit einer Bartschere in der Hand über den Draht auf den Knien zur Ladestation unterwegs bist. Zwei mögliche Varianten:
                      • Stell den Mäher kurz hinter der Ausfahrt der Ladestation mit der Nase Richtung Draht und drücke Home + Okay am Bedienfeld.
                      • Stelle am Bedienfeld oder in einer App eine geplante Ausfahrt im Mähkalender ein, die in zwei Minuten beginnen soll und die zwei Minuten dauern soll. In zwei Minuten beginnt dann der Kantenschnitt. Nach der Rückkehr in die Ladestation verlässt er diese (aus mir unerfindlichen Gründen) sofort wieder und setzt sogleich zur Heimfahrt an. Das ist also wohl ein doppelter Kantenschnitt.
                      Beides keine schönen Lösungen, aber vielleicht sind sie für eine Übergangszeit brauchbar.
                        Von Hand
                        skokarl
                        @hsteinme
                        woher in weißt Du das alles ? Du machst mir Angst ...
                        und jetzt ernsthaft, wenn ich nix manipuliere, sondern nur am Tablet start drücke, mäht er dann auch irgendwann Kanten ? Gibt es dahinter eine Logik ?
                        haselchenH hsteinmeH 2 Antworten Letzte Antwort
                        • S skokarl
                          @hsteinme
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @hsteinme
                          Geht der Kantenschnitt weiterhin mit der FW unter 3.07?
                          Wenn ja , einfach die Leute warnen nicht upzudaten.
                          Von der 3.07 gibt es nämlich keine Möglichkeit auf ein Downgrade mehr.
                          • haselchenH haselchen
                            @hsteinme
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @haselchen sagte in Test Adapter Worx v0.4.x:
                            war nicht die Rede von 3.7 ?
                            meine alte Kiste ist aus diesem Stand und es wird auch keine neuere Firmware angeboten. (der ist jetzt die 3.Saison hier, also von 2018, welches Modelljahr weiß ich aber nicht)
                            Ich kann ja morgen mal probieren, wenn es nicht wieder regnet, aber ich meine er macht noch edge cut per Script)
                            • dslraserD dslraser
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @dslraser
                              Vermutlich hast du ein älteres Modell.
                              Ich meine die 3.07 ist für 2019er Modelle
                              • S skokarl
                                @hsteinme
                                hsteinmeH Online
                                hsteinmeH Online
                                hsteinme
                                Durch fleißiges Lesen (und auch Schreiben) in roboter-forum.com.
                                Das wollte ich nicht. Mit Ehrfurcht bin ich auch schon zufrieden 😛
                                Von welcher Anwendung/App/Adapter/... und von welchem Start-Knopf sprichst Du gerade?
                                @haselchen
                                Lass uns drei Fälle betrachten:
                                • Am Bedienfeld Pause/Stop und dann Home + Okay drücken bewirkt weiterhin eine Heimfahrt mit Kantenschnitt, sofern die Batterie noch genügend "Saft" hat.
                                • Der Kantenschnitt als optionaler Teil eines Mähauftrags im Mähkalender ist ebenso weiterhin verfügbar, egal ob der Mähkalender über ein Bedienfeld oder per App bzw. per Adapter über den MQTT Server eingetütet wurde.
                                • Der bisherige Weg, die Kommandofolge Trainingsfahrt/Pause/Home über den MQTT Server an den Mäher zu senden ist ab 3.07 nur noch eine Heimfahrt ohne Messereinsatz. Diesen Weg hat der Worx Adapter im ioBroker genutzt, andere Adapter in anderen Automatisierungsprodukten (z.B. bei FHEM) sowie Eishas DeskApp
                                @dslraser:
                                Das war ein Vertipperlein meinerseits, 'tschuldigung.
                                @haselchen:
                                ... und für die 2020er
                                  @haselchen
                                  @dslraser:
                                  @haselchen:
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @hsteinme
                                  Viel geschrieben aber meine Frage nicht beantwortet 😉
                                  Update ich nicht , geht alles weiterhin so wie vorher mit dem Adapter, sprich Kantenschnitt auf Button Druck in einem Blockly?
                                  S hsteinmeH 2 Antworten Letzte Antwort
                                    @hsteinme
                                    skokarl
                                    @haselchen
                                    er hat im letzten Beitrag aber was dazu geschrieben
                                    • S skokarl
                                      @haselchen
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @skokarl
                                      Dann formuliere ist es eben mal so:
                                      Mag sich jemand von den Usern melden, der noch alles so nutzt wie letztes Jahr (FW unter 3.07) und den Kantenschnitt über den Adapter Datenpunkt macht, ob das noch alles so funktioniert.
                                        @hsteinme
                                        hsteinmeH Online
                                        hsteinmeH Online
                                        hsteinme
                                        Moment mal bitte. Du hast nach dem Verhalten "mit der FW unter 3.07" gefragt. Diese Frage habe ich ausführlichst beantwortet.
                                        Wenn Du das Verhalten "mit der FW vor 3.07" meintest, dann solltest Du auch bitte so fragen. Aber diese Frage habe ich schon im ersten Beitrag beantwortet, indem ich sagte, dass das "messerlose" Verhalten seit Version 3.07 da ist. Ist dann nicht klar, dass vor 3.07 Messer bei der Heimfahrt aktiv waren?
                                        Die Betrachtung von Jahren ist hier unsinnig. Es gibt nur Sinn, FW-Versionen zu betrachten. Also:
                                        • vor FW 3.07: Bei edgecut = true werden die Messer eingeschaltet
                                        • ab FW 3.07: Bei edgecut = true werden die Messer nicht mehr eingeschaltet
                                        Mag sich jemand von den Usern melden ...
                                        Beide obige Aussagen entstammen meiner eigenen Erfahrung.
                                        haselchenH SegwayS 2 Antworten Letzte Antwort
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #66
                                          @hsteinme
                                          Du siehst in meiner Fragestellung einen Unterschied in den Worten unter und vor????
                                          Wo bitte ist da der Unterschied?
                                          Aber egal (um es mit den Wendler Worten zu sagen), ich werde es einfach selber ausprobieren 😉
