  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • O Offline
    O Offline
    oFbEQnpoLKKl6mbY5e13
    #592
    Schön, dass mit 3.0.20 der HMIP-Adapter wieder funktioniert. Totzdem schlägt der erste Start gegebenenfalls fehl oder er stürzt im Betrieb ab:
    hmip.0	2020-04-29 23:00:00.786	error	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:138:22)
    hmip.0	2020-04-29 23:00:00.786	error	at Receiver.getData (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:352:17)
    hmip.0	2020-04-29 23:00:00.786	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/receiver.js:413:14)
    hmip.0	2020-04-29 23:00:00.786	error	at Receiver.emit (events.js:310:20)
    hmip.0	2020-04-29 23:00:00.786	error	at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.hmip/node_modules/ws/lib/websocket.js:800:20)
    hmip.0	2020-04-29 23:00:00.786	error	at WebSocket.emit (events.js:310:20)
    hmip.0	2020-04-29 23:00:00.786	error	at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.hmip/api/hm-cloud-api.js:152:18)
    hmip.0	2020-04-29 23:00:00.786	error	at HmCloudAPI._parseEventdata (/opt/iobroker/node_modules/iobroker.hmip/api/hm-cloud-api.js:200:22)
    hmip.0	2020-04-29 23:00:00.786	error	at HmIpCloudAccesspointAdapter._eventRaised (/opt/iobroker/node_modules/iobroker.hmip/main.js:288:28)
    hmip.0	2020-04-29 23:00:00.786	error	at HmIpCloudAccesspointAdapter._updateHomeStates (/opt/iobroker/node_modules/iobroker.hmip/main.js:808:58)
    hmip.0	2020-04-29 23:00:00.786	error	(430) TypeError: Cannot read property 'id' of undefined
    hmip.0	2020-04-29 23:00:00.782	error	(430) uncaught exception: Cannot read property 'id' of undefined
    • O oFbEQnpoLKKl6mbY5e13
      apollon77A Online
      apollon77A Online
      #593
      @oFbEQnpoLKKl6mbY5e13 Issue im GitHub beim Adapter ist angelegt?
      O 1 Antwort Letzte Antwort
      • apollon77A apollon77
        O Offline
        O Offline
        #594
        @apollon77
        Es gab ja eines, was wohl vorschnell geschlossen wurde. Aber abgesehen davon bringt das wohl eh nichts, denn Jogibear macht ja am Adapter nichts mehr, was kein Vorwurf ist.
        • foxriver76F foxriver76
          Na du meinst doch oben dass dein Router neu gestartet wird. Währenddessen verlieren die Hosts logischerweise die Verbindung zueinander wenn sie über diesen verbunden sind.
          LJSven
          schrieb am zuletzt editiert von LJSven
          #595
          @foxriver76 sagte in js-controller 3.0 jetzt im Latest!:
          Der Host ist ja online, wenn ich auf Hosts gehe - trotzdem erscheint diese Meldung. Ebenso sind alle Adapter GRÜN, die auf den Host installiert sind. Die Meldung kommt über einige Stunden, da ist der Router längst neu gestartet.
            @apollon77
            apollon77A Online
            apollon77A Online
            #596
            @oFbEQnpoLKKl6mbY5e13 Leg es bitte an bzw reopen wenn falsch geschlossen. Kriegen wir alles irgendwie hin
            • crunchipC Offline
              crunchipC Offline
              #597
              ich habe gerade meinen proxmox Server neu gestartet und wollte das iobroker log im Anschluss betrachten, welche (Warn/Fehler-Meldungen) bei einem Neu-Start auftauchen, jedoch finde ich nun dieses vor
              bin im latest
              admin 4.1.1
              js-controller 3.0.20
              der Inhalt von diesem log besteht aus
              2020-05-01 00:00:52.952 - info: host.IoBroker iobroker.js-controller version 3.0.20 js-controller starting
              2020-05-01 00:00:52.962 - info: host.IoBroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
              2020-05-01 00:00:52.964 - info: host.IoBroker hostname: IoBroker, node: v10.20.1
              2020-05-01 00:00:52.967 - info: host.IoBroker ip addresses: xx.xx.xx.xx fe:xx:xx:xx:xx:xx
              2020-05-01 00:00:57.407 - info: host.IoBroker connected to Objects and States
              2020-05-01 00:00:58.974 - info: host.IoBroker 110 instances found
              2020-05-01 00:00:59.138 - info: host.IoBroker starting 71 instances
              2020-05-01 00:00:59.315 - info: host.IoBroker instance system.adapter.admin.0 started with pid 905
              2020-05-01 00:01:04.320 - info: host.IoBroker instance system.adapter.alexa2.0 started with pid 916
              2020-05-01 00:01:07.278 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 923
              2020-05-01 00:01:07.525 - info: admin.0 (905) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.20.1, js-controller: 3.0.20
              2020-05-01 00:01:07.762 - info: admin.0 (905) requesting all states
              2020-05-01 00:01:07.766 - info: admin.0 (905) requesting all objects
              2020-05-01 00:01:14.281 - info: host.IoBroker instance system.adapter.ble.0 started with pid 943
              2020-05-01 00:01:15.172 - info: host.IoBroker instance system.adapter.broadlink2.0 started with pid 950
              2020-05-01 00:01:18.289 - info: alexa2.0 (916) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.20.1, js-controller: 3.0.20
              edit: gerade noch entdeckt
              • apollon77A Online
                apollon77A Online
                #598
                Bist Deiner Zeit voraus, hä ;-) Zeitzohne prüfen?
                  crunchipC Offline
                  crunchipC Offline
                  #599
                  @apollon77 was soll sich da geändert haben? war doch nur ein Neustart!?
                  root@IoBroker:~# date
                  Do 30. Apr 23:09:06 CEST 2020
                  root@IoBroker:~# cat /etc/timezone
                  Europe/Berlin
                    Europe/Berlin
                    apollon77A Online
                    apollon77A Online
                    #600
                    @crunchip Interessant ... Ich hatte einen Bericht von einem befreundeten user das irgendwie die Zeiteinstellung des iobroker user ne andere war oder so ... bei dem ist das gestern passiert. Keine Idee warum
                      crunchipC Offline
                      crunchipC Offline
                      #601
                      @apollon77 auch wenn ich mich mit meinem user einlogge, stimmt die Zeit, oder meintest du etwas anderes?
                      Habe den Rechner auch nochmal neu gestartet, jedoch das gleiche wieder.
                      Das richtige log ist ja vorhanden, siehe screen von oben, da steht auch alles korrekt drin, nur das zusätzlich diese 2020 -05-01.gz aufgelistet ist
                      naja mal abwarten, was nach 0:00 Uhr passiert
                        #602
                        @crunchip
                        date -u
                          @crunchip
                          date -u
                          crunchipC Offline
                          crunchipC Offline
                          #603
                          @Thomas-Braun kommt aufs gleiche raus wie oben
                          root@IoBroker:~# date -u
                          Do 30. Apr 21:49:35 UTC 2020
                          jedenfalls stimmt seit dem erneuten Neustart die Betriebszeit wieder
                          Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                            #604
                            @crunchip
                            Was fährst du da für ein System?
                            timedatectl status
                            macht dich evtl. auch schlauer.
                              wendy2702W Offline
                              wendy2702W Offline
                              #605
                              @crunchip wie das gleiche wie oben?
                              Hier steht „UTC“ oder habe ich was verpasst
                              • wendy2702W wendy2702
                                crunchipC Offline
                                crunchipC Offline
                                #606
                                @wendy2702 ja UTC, oben CEST(2Std weiter) ist schon korrekt so
                                • wendy2702W Offline
                                  wendy2702W Offline
                                  #607
                                  War nur verwundert weil die Differenz keine 2 Stunden ist. Liegt aber wohl an der Differenz der Abfragen.
                                    @crunchip
                                    timedatectl status
                                    crunchipC Offline
                                    crunchipC Offline
                                    #608
                                    @Thomas-Braun ne Debian Vm in Proxmox
                                    root@IoBroker:~# timedatectl status
                                          Local time: Fr 2020-05-01 00:05:43 CEST
                                      Universal time: Do 2020-04-30 22:05:43 UTC
                                            RTC time: Fr 2020-05-01 00:05:43
                                     Network time on: yes
                                    NTP synchronized: yes
                                     RTC in local TZ: no
                                    zumindest geht das log richtig weiter,
                                       RTC in local TZ: no
                                      #609
                                      @crunchip
                                      Ich glaube da liegt der Hund begraben:
                                      RTC in local TZ: no
                                      Und in der Oberfläche von Proxmox steht sinngemäß:
                                      RTC in local TZ: yes
                                      Ich vermute das beißt sich irgendwie.
                                        @crunchip
                                        RTC in local TZ: no
                                        crunchipC Offline
                                        crunchipC Offline
                                        #610
                                        @Thomas-Braun ja, das habe ich schon gesehen, deswegen den screen mit angefügt, aber wie gesagt, es war nur ein Neustart
                                          #611
                                          @crunchip Ich denke die beiden Einstellungen sollten gleich sein.
                                          Hab nur keinen Idee ob man besser im System anfängt oder in den Proxmox-Einstellungen.
