  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • E e-s
    @apollon77
    Weiß nicht ob der Fehler schon bekannt ist Mir ist klar, gehört eigentlich zum devices Adapter. aber auf die schnelle ist es hier einfacher.
    Beim deinstallieren des devices Adapter:
    host.ubuntuserver	2020-04-27 21:33:52.259	info	iobroker exit 0
    host.ubuntuserver	2020-04-27 21:33:48.951	info	iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1
    host.ubuntuserver	2020-04-27 21:33:48.942	info	iobroker npm
    host.ubuntuserver	2020-04-27 21:33:29.801	error	Cannot write files: /opt/iobroker/iobroker-data/files/devices.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/devices.admin/_data.json'
    host.ubuntuserver	2020-04-27 21:33:29.649	info	iobroker npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11, 12, 13.npm WARN npm You can find the latest version at https://nodejs.org/
    host.ubuntuserver	2020-04-27 21:33:29.642	info	iobroker WARN npm npm does not support Node.js v14.0.0npm WARN npm You should probably upgrade to a newer version of node as wenpm WARN npm can't make any promises that npm will work with this versi
    host.ubuntuserver	2020-04-27 21:33:29.641	info	iobroker npm
    host.ubuntuserver	2020-04-27 21:33:28.975	info	iobroker npm uninstall iobroker.devices --error --prefix "/opt/iobroker" (System call)
    host.ubuntuserver	2020-04-27 21:33:28.824	info	iobroker host.ubuntuserver object devices.admin deletedhost.ubuntuserver Deleting 2 object(s).
    host.ubuntuserver	2020-04-27 21:33:28.804	info	iobroker host.ubuntuserver file devices.admin deleted
    readDir	2020-04-27 21:33:28.770	warn	will not read this directory () in future versions: devices is not an object of type "meta"
    readDir	2020-04-27 21:33:28.764	warn	will not read this directory (widgets/devices.html/) in future versions: vis is not an object of type "meta"
    readDir	2020-04-27 21:33:28.756	warn	will not read this directory (widgets/devices/) in future versions: vis is not an object of type "meta"
    host.ubuntuserver	2020-04-27 21:33:27.181	info	iobroker host.ubuntuserver Counted 1 adapter for devices
    host.ubuntuserver	2020-04-27 21:33:27.176	info	iobroker host.ubuntuserver Counted 1 meta of devices
    host.ubuntuserver	2020-04-27 21:33:27.104	info	iobroker Delete adapter "devices"
    host.ubuntuserver	2020-04-27 21:33:24.465	info	iobroker del devices
    Ach ja, gehört zum bosesoundtouch:
    bosesoundtouch.0	2020-04-27 21:13:19.940	info	(18695) connecting to host ws://192.168.2.128:8080/
    bosesoundtouch.0	2020-04-27 21:13:18.684	info	(18695) starting. Version 0.9.2 in /opt/iobroker/node_modules/iobroker.bosesoundtouch, node: v14.0.0, js-controller: 3.0.19
    bosesoundtouch.0	2020-04-27 21:13:18.679	error	(18695) : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
    wendy2702W Offline
    wendy2702W Offline
    #492
    @e-s sagte in js-controller 3.0 jetzt im Latest!:
    Glaube in deinem Fall ziemlich eindeutig.
    • E e-s
      @wendy2702
      könnte auch sein, sonst macht 14 aber scheinbar keine Probleme
      #493
      @e-s Offenbar node nicht richtig installiert. Dein npm kommt aus einer anderen Version.
      E 1 Antwort Letzte Antwort
        e-s
        #494
        @Thomas-Braun @wendy2702
        build@ubuntuserver:/opt/iobroker$ npm
        npm WARN npm npm does not support Node.js v14.0.0
        npm WARN npm can't make any promises that npm will work with this version.
        npm WARN npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11, 12, 13.
        Wenn ich mich recht erinnere, dann meckert npm rum wenn es nicht aktuell ist und man ein Update machen kann. So wie ich das verstehe ist npm einfach offiziell noch nicht soweit node14 zu benutzen, oder?
        Aber ich glaube das ist nur ein Hinweis den ich ignorieren kann.
        • E e-s
          #495
          @e-s Ein aktuelles npm funktioniert auch mit einem aktuellen node. Hier läuft auch node 14 und npm, allerdings ohne die Meldungen die du da siehst.
          npm -v
          6.14.4
          Ignorieren würde ich das nicht, das sorgt früher oder später für Ärger.
            npm -v
            6.14.4
            e-s
            #496
            @Thomas-Braun
            ok, danke erstmal. den npm Fehler habe ich jetzt weg. Dafür habe ich einen Fehler im npm rebuild vom serialport, wofür auch immer der ist.
               V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
            /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3642:37: note:   candidate expects 3 arguments, 2 provided
            ../src/serialport.cpp:331:96: error: no matching function for call to âv8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)â
                 results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
            In file included from /home/iobroker/.cache/node-gyp/14.0.0/include/node/node.h:67:0,
                             from ../../nan/nan.h:56,
                             from ../src/./serialport.h:6,
                             from ../src/serialport.cpp:1:
            /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3639:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)
            /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3639:37: note:   candidate expects 3 arguments, 2 provided
            /home/iobroker/.cache/node-gyp/14.0.0/include/node/v8.h:3642:37: note: candidate: v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)
            ../src/serialport.cpp:336:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
               data->callback.Call(2, argv);
            In file included from ../src/./serialport.h:6:0,
            ../../nan/nan.h:1742:3: note: declared here
               Call(int argc, v8::Local<v8::Value> argv[]) const {
            ../src/serialport.cpp: In function âvoid EIO_AfterGetBaudRate(uv_work_t*)â:
            ../src/serialport.cpp:378:106: error: no matching function for call to âv8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)â
                 results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
            ../src/serialport.cpp:383:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp: In function âvoid EIO_AfterDrain(uv_work_t*)â:
            ../src/serialport.cpp:424:30: warning: âv8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) constâ is deprecated [-Wdeprecated-declarations]
               data->callback.Call(1, argv);
            ../src/serialport.cpp: At global scope:
            ../src/serialport.cpp:460:17: error: variable or field âinitâ declared void
               void init(v8::Handle<v8::Object> target) {
            ../src/serialport.cpp:460:17: error: âHandleâ is not a member of âv8â
            ../src/serialport.cpp:460:34: error: expected primary-expression before â>â token
            ../src/serialport.cpp:460:36: error: âtargetâ was not declared in this scope
            ../src/serialport.cpp:460:36: note: suggested alternative: âtzsetâ
                                                tzset
            In file included from ../../nan/nan.h:56:0,
            ../src/serialport.cpp:485:25: error: âinitâ was not declared in this scope
             NODE_MODULE(serialport, init);
            /home/iobroker/.cache/node-gyp/14.0.0/include/node/node.h:731:36: note: in definition of macro âNODE_MODULE_Xâ
                   (node::addon_register_func) (regfunc),                          \
            ../src/serialport.cpp:485:1: note: in expansion of macro âNODE_MODULEâ
            ../src/serialport.cpp:485:25: note: suggested alternative: âintâ
            serialport.target.mk:114: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
            make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
            make: Verzeichnis â/opt/iobroker/node_modules/serialport/buildâ wird verlassen
            gyp ERR! build error
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
            gyp ERR! System Linux 4.15.0-96-generic
            gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/serialport
            gyp ERR! node -v v14.0.0
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the serialport@6.2.2 install script.
            npm ERR!     /home/iobroker/.npm/_logs/2020-04-27T21_15_55_218Z-debug.log
            apollon77A K 2 Antworten Letzte Antwort
            • E e-s
              @Thomas-Braun
                                                  tzset
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              #497
              @e-s Da scheint irgendeiner Deiner Adapter noch serialpot 6 zu nutzen was mit Node 12 schon nicht mehr geescheit tut. Also hier wäre der Tipp mal die Adapter zu prüfen die Seriell arbeiten ob es Updates gibt
              • E e-s
                @Thomas-Braun
                                                    tzset
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                Kueppert
                #498
                @e-s könnte zB der Zigbee-Adapter sein. Ich hab den auch drauf und auch WARN Meldungen gehabt beim Update von Node. Allerdings keine ERR-Meldungen.
                • apollon77A apollon77
                  e-s
                  #499
                  @apollon77
                  Einer von euch ist Schuld... 😊
                  serialport nutzt keiner meiner Adapter, aber ich habe herausgefunden, das discovery das braucht.
                  Da ich aber den Adapter gelöscht habe, wurden die Abhängigkeiten nicht mehr angepasst bzw überprüft.
                  Also hätte beim löschen des Adapters auch die zusätzlichen deps gelöscht werden müssen, das wiederum ist auch blöd wenn mehrere Adapter die Abhängigkeit brauchen.
                  Ein Teufelskreis, ich werde jetzt kurz discovery installieren und somit hoffen das serialport dann auf 8.0.7 angehoben wird, so wie es im git steht.
                  Oder habt Ihr eine bessere Idee?
                  • E e-s
                    @apollon77
                    #500
                    @e-s @apollon77
                    genau das Problem hab ich auch...
                    Der Discovery wird ja nur nach dem Einrichten gebraucht, daher gelöscht.. 2 Jahre her.. 🤦
                    • MiGollerM Offline
                      MiGollerM Offline
                      MiGoller
                      #501
                      Hallo zusammen.
                      Vielen Dank für die gute Arbeit! Das möchte ich erst einmal loswerden.
                      Beim Upgrade des js-controllers von 2.2.9 auf 3.0.19 auf meiner Prod-Umgebung habe ich allerdings folgende Meldung bei der Installation gesehen.
                      $ sudo iobroker upgrade self
                      Update js-controller from @2.2.9 to @3.0.19
                      NPM version: 6.14.4
                      npm install iobroker.js-controller@3.0.19 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                      (node:14431) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                          at _0x411ccb._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115051)
                          at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      (node:14431) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      (node:14431) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      Müsste da nicht wahrscheinlich callback statt allback stehen? Habe mir den Code noch nicht angeschaut.
                      Viele Grüße, MiGoller
                      ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
                      MiGollerM B 2 Antworten Letzte Antwort
                        @e-s @apollon77
                        e-s
                        schrieb am zuletzt editiert von e-s
                        #502
                        @ilovegym @apollon77
                        Mach das bloß nicht manuell...
                        discovery installíeren hat nichts gebracht, also habe ich mit
                        npm i serialport@8.0.7
                        aktualisiert.
                        Dann kam aber der nächste Fehler, bluetooth -hci-socket wollte nicht, also auch den aktualiert obwohl ich den nicht benötige.
                        npm i @abandonware/bluetooth-hci-socket@0.5.3-5
                        jetzt kam ein Fehler von @serialport/bindings
                        npm i @serialport/bindings@@8.0.7
                        anschließend gab es keine Fehler mehr bei npm rebuild
                        • MiGollerM MiGoller
                          Hallo zusammen.
                          NPM version: 6.14.4
                          MiGollerM Offline
                          MiGollerM Offline
                          MiGoller
                          #503
                          @MiGoller sagte in js-controller 3.0 jetzt im Latest!:
                          Hallo zusammen.
                          NPM version: 6.14.4
                          Hallo zusammen, nachdem auch die Version 3.0.18 in Verbindung mit Redis kein lauffähiges System mehr hervorgebracht hat, habe ich einen "Rücksturz" auf 2.2.9 durchgeführt. Letzt läuft es erst einmal wieder.
                          Könnte da ein Zusammenhang mit meiner Redis-Konfiguration bestehen, die unter Version 2 des Controllers problemlos läuft?
                            Hallo zusammen.
                            NPM version: 6.14.4
                            blackeagle998
                            #504
                            Hallo zusammen.
                            NPM version: 6.14.4
                            Hallo, ich habe gerade exakt den gleichen Fehler, ebenfalls von Version 2.2.9 zu 3.0.19.
                            khgK 1 Antwort Letzte Antwort
                            • apollon77A Offline
                              #505
                              Der controller 3.0.20 ist auf Github - der fixt das ... sorry ...
                              Sollte bald im Latest Repo sein, alternativ IM IOBROKER-VERZEICHNIS(!!) ein "npm install iobroker.js-controller@3.0.20" ausführen
                              Changelog:
                              3.0.20 (2020-04-28) Release Elena
                              • (Apollon77) make sure disabling instances while installation is running do not crash the controller (Sentry IOBROKER-JS-CONTROLLER-Z)
                              • (From Forum) prevent error on backup restore
                              • (Apollon77) Make sure error handing do not throw exception
                              • (Apollon77) Catch all errors when trying to store the File DB (Sentry IOBROKER-JS-CONTROLLER-14/15)
                              • (Apollon77) Make sure also edge cases on start adapter are handled correctly (Sentry IOBROKER-JS-CONTROLLER-12)
                              • (Apollon77) Use 3.3.4 of objects library to prevent an error from 3.3.3
                              ? sigi234S 2 Antworten Letzte Antwort
                              • B blackeagle998
                                Hallo zusammen.
                                NPM version: 6.14.4
                                khgK Offline
                                khgK Offline
                                khg
                                #506
                                update js-controller 3.0.18 --> 30.19 nicht möglich.
                                Node.js v12.16.2
                                NPM 6.14.4
                                Detail:
                                int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
                                In file included from ../src/epoll.cc:11:
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Localv8::Context) const’
                                V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                                ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/epoll.cc:247:47: error: no matching function for call to ‘v8::Value::Int32Value()’
                                int err = epoll->Remove(info[0]->Int32Value());
                                In file included from ../src/epoll.cc:12:
                                ../src/epoll.cc: At global scope:
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
                                NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
                                ../src/epoll.cc:381:1: note: in expansion of macro ‘NODE_MODULE’
                                NODE_MODULE(epoll, Epoll::Init)
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/node_object_wrap.h:85:78: required from here
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
                                )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                reinterpret_cast<Callback>(callback), type);
                                , typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
                                ../../nan/nan_object_wrap.h:66:61: required from here
                                /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
                                )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                make: *** [epoll.target.mk:111: Release/obj.target/epoll/src/epoll.o] Fehler 1
                                gyp ERR! stack Error: make failed with exit code: 2
                                gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                gyp ERR! stack at ChildProcess.emit (events.js:310:20)
                                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                gyp ERR! System Linux 5.4.28-rockchip
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
                                gyp ERR! node -v v12.16.2
                                gyp ERR! not ok
                                (node:19963) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                                (node:19963) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                (node:19963) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code
                                bleibt hier händen und Abbruch mit Ctrl-C.
                                iobroker start
                                iobroker status
                                (node:26663) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
                                (node:26663) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                (node:26663) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                • khgK khg
                                  Node.js v12.16.2
                                  NPM 6.14.4
                                  Detail:
                                  gyp ERR! not ok
                                  iobroker start
                                  iobroker status
                                  sigi234S Online
                                  sigi234S Online
                                  #507
                                  @khg
                                  Bitte benutzt die Code Tags Funktion -> </>
                                  Hier gehts zur Hilfe.
                                  • E e-s
                                    aktualisiert.
                                    #508
                                    @e-s Hi, Danke, hat geholfen. Musste noch node-gyp drüberbügeln, dann war da auch Ruhe.
                                    • sigi234S sigi234
                                      @khg
                                      khgK Offline
                                      khgK Offline
                                      khg
                                      schrieb am zuletzt editiert von khg
                                      #509
                                      @sigi234 sagte in js-controller 3.0 jetzt im Latest!:
                                      ok, schaue ich mir an,
                                      eben wurde der js-controller 3.0.20 erstellt und das Problem ist damit behoben.
                                        Changelog:
                                        #510
                                        @apollon77
                                        Also, die Elena verträgt sich wohl ganz gut mit der Silvia, Tessa und Buster. Mit der Debbie schau ich die Tage dann noch.. :-)
                                          Changelog:
                                          sigi234S Online
                                          sigi234S Online
                                          #511
                                          @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                          Diesmal geht es bei mir nicht.
                                          C:\Program Files\iobroker\Test>iobroker upgrade self
                                          Update js-controller from @3.0.19 to @3.0.20
                                          NPM version: 6.9.0
                                          npm install iobroker.js-controller@3.0.20 --loglevel error --unsafe-perm (System call)
                                          npm ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller
                                          npm ERR! code EBUSY
                                          npm ERR! errno -4082
                                          npm ERR! syscall rename
                                          npm ERR! EBUSY: resource busy or locked, rename 'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller' -> 'C:\Program Files\iobroker\Test\node_modules\.iobroker.js-controller.DELETE'
                                          npm ERR!     C:\Program Files\iobroker\Test\env\npm-cache\_logs\2020-04-28T11_49_52_485Z-debug.log
                                          host.Medion(Test) Cannot install iobroker.js-controller@3.0.20: 4294963214
                                          Wollen zu viele gleichzeitig updaten?
