  4. Restore funktioniert nicht
restore backup backitup
33 Beiträge 5 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • K Karsten69
    Habe hier vom November noch ein Total Backup, habe aber irgendwo gelesen man soll immer das Minimal nehmen.
    @Karsten69 sagte in Restore funktioniert nicht:
    ein Total Backup
    ein Total Backup darf nur auf der selben Hardware und dem selben Softwareunterbau wieder hergestellt werden!
    Bei den Versionen sehe ich nichts was zu Problemen führen könnte.
    Den Restore hast du aber wie im ersten Post über die Konsole nach kopieren der BUP-Datei in /opt/iobroker/backups/
    durchgeführt?
      Karsten69
      Nein diesmal über das Webinterface, probiere es nochmal über die Konsole.
        Karsten69
        Gleiches Ergebnis😵
        pi@RaspiIObroker:/opt/iobroker $ sudo iobroker restore 2
        host.RaspiIObroker Using backup file iobroker_2020_04_24-02_00_20_backupiobroker.tar.gz
        iobroker controller daemon is not running
        host.RaspiIObroker OK.
        host.RaspiIObroker Clear all objects and states...
        clean 552 objects...
        [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
        [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
        [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
        [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
        [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
        [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
        clean 1440 states...
        host.RaspiIObroker done.
        host.RaspiIObroker Processed 0/1055 states
        host.RaspiIObroker Processed 200/1055 states
        host.RaspiIObroker Processed 400/1055 states
        host.RaspiIObroker Processed 600/1055 states
        host.RaspiIObroker Processed 800/1055 states
        host.RaspiIObroker Processed 1000/1055 states
        1055 states restored.
        host.RaspiIObroker Processed 0/1152 objects
        host.RaspiIObroker Processed 200/1152 objects
        host.RaspiIObroker Processed 400/1152 objects
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385
                    && _objects[_index].id.match(/^system\.adapter\./)
        TypeError: Cannot read property 'match' of null
            at BackupRestore._setObjHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385:36)
            at runCallback (timers.js:706:11)
            at tryOnImmediate (timers.js:676:5)
            at processImmediate (timers.js:658:5)
          Karsten69
          Ist vieleicht eine blöde Frage, aber ich versuche es mal, ich habe keine große IObroker Installation, kann es sein das das Backup nur 1,8MB groß ist?
          • K Karsten69
            ja!
            da ist nur die Konfiguration drin gespeichert, alles andere wird neu angelegt und kompiliert
            • K Karsten69
              mit backitup?
                mit backitup?
                Karsten69
                @Homoran Jap
                • K Karsten69
                  @Homoran Jap
                  @Karsten69 dann kann @simatec vielleicht weiterhelfen
                    Karsten69
                    @Homoran Sorry aber ich bin nicht so der Forumsspezi, wie erreiche ich das @simatec das hier liest?
                    • K Karsten69
                      Das haben wir beide gerade gemacht ;-)
                        Karsten69
                        @Homoran 👍 vielen Dank für deine Hilfe.
                        • K Karsten69
                          simatecS Online
                          simatecS Online
                          simatec
                          @Karsten69
                          Ich gehe davon aus, dass dies ein Fehler im js-controller ist. Ob der in der 3er Version bereits gefixt ist, kann ich nicht sagen.
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                          • K Karsten69
                            Hallo liebe Gemeinde,
                            habe mir Heute Morgen mein System zerschossen, und nicht wieder zum laufen gebracht.
                            Hatte hier noch einen nagelneuen Pi4 liegen und habe gedacht ist ja kein Problem hast ja ein Backup von letzter Nacht.
                            Habe also alles nach diesen Anleitungen https://www.iobroker.net/#de/documentation/install/linux.md
                            und https://forum.iobroker.net/topic/27271/howto-iobroker-restore-unter-linux-durchführen neu aufgesetzt.
                            Leider spuckt er mir Fehlermeldungen aus und übernimmt meine gesicherten Daten nicht.
                            Wäre echt nett wenn sich das mal jemand anschauen könnte, bin echt verzweifelt.
                            Gruß Karsten
                            joergeliJ Online
                            joergeliJ Online
                            joergeli
                            schrieb am zuletzt editiert von joergeli
                            @Karsten69
                            Ich hatte letzte Woche die gleiche Fehlermeldung "TypeError: Cannot read property 'match' of null" bei einem Restore.
                            Geholfen hat mir der Tip von janschmidt76 in diesem Thread:
                            probleme-beim-restore
                            also das hier: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js in Zeile 385 die Bedingung "&& _objects[_index].id != null" ergänzt (s.u., Zeile 4)
                            Hinweis:
                            Das Backup hatte ich erst einen Tag zuvor manuell mit "iobroker backup" erstellt.
                            K 2 Antworten Letzte Antwort
                            • joergeliJ joergeli
                              @Karsten69
                              Hinweis:
                              Karsten69
                              @joergeli sorry für die späte Antwort, konnte nicht früher an einen Rechner.
                              Vielen Dank dafür, werde das mal probieren.
                                @Karsten69
                                Hinweis:
                                Karsten69
                                @joergeli Super, vielen Dank für den Tip, hatte mir am Samstag mit einem uralt image geholfen, damit hier überhaupt wieder etwas läuft, jetzt ist alles wieder da 👍 ein Herzlicher Dank geht natürlich auch an @janschmidt76
                                joergeliJ 1 Antwort Letzte Antwort
                                • K Karsten69
                                  joergeliJ Online
                                  joergeliJ Online
                                  joergeli
                                  @Karsten69
                                  Freut mich, ich habe auch Blut und Wasser geschwitzt, als mein Restore nicht funktionierte.
                                  @simatec
                                  Frage: Wenn ich mich nicht irre, bist Du doch "Mr. BackItUp"?
                                  Könnte man die obige Zeile nicht standardmäßig in /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js einbauen, oder hat das nur was mit iobroker.js-controller, bzw. manuellem Backup/Restore zu tun?
                                  Jörg
                                    @Karsten69
                                    @simatec
                                    Jörg
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    @joergeli
                                    Welchen js-controller nutzt du?
                                    Ich bin mir nicht sicher, ob das mit js-controller 3 bereits gefixt wurde.
                                    Falls nicht, mache im js-controller github mal ein Issue auf.
                                    Ich gehe aber davon aus, dass dies @apollon77 bereits auf dem Schirm hat.
                                    • simatecS simatec
                                      @joergeli
                                      joergeliJ Online
                                      joergeliJ Online
                                      joergeli
                                      @simatec
                                      Ich verwende z. Zt. noch den js-controller 2.2.9.
                                      (bin etwas vorsichtig bei neueren Versionen, auch bei Adaptern und warte mit Updates lieber 1-2 Wochen, bis evtl. vorhandene Fehler erkannt und behoben wurden)
                                      OK, wenn das mit dem js-controller 3 schon gefixed wurde, war es bei @Karsten69 und mir wohl ein ungünstiger Zeitpunkt, daß wir unsere Restores noch mit dem 2.2.9 durchgeführt haben.
                                      Jörg
                                      • simatecS simatec
                                        @Karsten69
                                        Ne es ist bisher nicht gefixt weil KEINER den Fehler und/oder den Fix mal gemeldet hat ... wird ab 3.0.20 drin sein...
                                        Bei früherer Meldung hätte das sogar vor 4 Monaten noch in die 2.2 gepasst. Sowas finde ich eeecht schade
                                        • apollon77A apollon77
                                          joergeliJ Online
                                          joergeliJ Online
                                          joergeli
                                          @apollon77
                                          Asche auf mein Haupt, aber mir ist das Problem erstmalig letzte Woche bei meinem allerersten Restore aufgefallen.
                                          Ich wusste nicht, wo es her kommt und meine Vermutung war, daß mit meinen Objekten irgendwas nicht in Ordnung war, d.h. daß ich das Problem selbst verschuldet hatte.
                                          Somit war ich froh, daß ich eine Lösung von @Karsten69 gefunden hatte.
                                          Das es mit dem js-controller zu tun haben könnte ist mir erst heute durch @simatec's Antwort bewusst geworden.
                                          Also nix für ungut ...
                                          Jörg
