  4. Restore funktioniert nicht
restore backup backitup
33 Beiträge 5 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • K Karsten69
    @Homoran
    Hallo Homoran,
    ja habe ich, ist der Zeitpunkt wichtig?
    @Karsten69 sagte in Restore funktioniert nicht:
    @Homoran
    Hallo Homoran,
    in deinem Fall wäre es anscheinend vor dem Restore.
    Aber:
    kann ggf. das Backup schon einen Schuss gehabt haben?
      @Homoran
      Hallo Homoran,
      Aber:
      Karsten69
      @Homoran Lasse den Fix gerade nochmal laufen, habe mir das Backup von meinem NAS runter kopiert, kann auch mal eines von Gestern Nacht nehmen.
        Karsten69
        Habe gerade nach dem Fixer nochmal neu gebootet und ein Backup von Gestern Nacht genommen mit dem gleichen Ergebnis:
        Log Backitup Restore:
        [DEBUG] [iobroker] Start ioBroker Restore ...
        [DEBUG] [iobroker] iobroker controller daemon is not running
        [DEBUG] [iobroker] host.RaspiIObroker OK.
        [DEBUG] [iobroker] host.RaspiIObroker Clear all objects and states...
        [DEBUG] [iobroker] clean 552 objects...
        [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
        [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
        [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
        [ERROR] [iobroker] [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
        [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
        [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
        [DEBUG] [iobroker] clean 1440 states...
        [DEBUG] [iobroker] host.RaspiIObroker done.
        [DEBUG] [iobroker] host.RaspiIObroker Processed 0/1055 states
        [DEBUG] [iobroker] host.RaspiIObroker Processed 200/1055 states
        [DEBUG] [iobroker] host.RaspiIObroker Processed 400/1055 states
        [DEBUG] [iobroker] host.RaspiIObroker Processed 600/1055 states
        [DEBUG] [iobroker] host.RaspiIObroker Processed 800/1055 states
        [DEBUG] [iobroker] host.RaspiIObroker Processed 1000/1055 states
        [DEBUG] [iobroker] 1055 states restored.
        [DEBUG] [iobroker] host.RaspiIObroker Processed 0/1152 objects
        [DEBUG] [iobroker] host.RaspiIObroker Processed 200/1152 objects
        [DEBUG] [iobroker] host.RaspiIObroker Processed 400/1152 objects
        [ERROR] [iobroker] /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385
        [ERROR] [iobroker] && _objects[_index].id.match(/^system\.adapter\./)
        [ERROR] [iobroker] ^
        [ERROR] [iobroker] TypeError: Cannot read property 'match' of null
        [ERROR] [iobroker] at BackupRestore._setObjHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385:36)
        [ERROR] [iobroker] at runCallback (timers.js:706:11)
        [ERROR] [iobroker] at tryOnImmediate (timers.js:676:5)
        [ERROR] [iobroker] at processImmediate (timers.js:658:5)
        [DEBUG] [iobroker] ioBroker Restore completed successfully
        [EXIT] 1 **** Restore completed successfully!! ****
        The log can be closed ...
          Karsten69
          Hier der Log aus dem IObroker
          backitup.0	2020-04-25 16:17:39.083	warn	(1781) Cannot read log file: ReferenceError: config is not defined
          backitup.0	2020-04-25 16:17:39.081	error	(1781) [ERROR] [iobroker] at processImmediate (timers.js:658:5)
          backitup.0	2020-04-25 16:17:39.080	error	(1781) [ERROR] [iobroker] at tryOnImmediate (timers.js:676:5)
          backitup.0	2020-04-25 16:17:39.079	error	(1781) [ERROR] [iobroker] at runCallback (timers.js:706:11)
          backitup.0	2020-04-25 16:17:39.079	error	(1781) [ERROR] [iobroker] at BackupRestore._setObjHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385:36)
          backitup.0	2020-04-25 16:17:39.078	error	(1781) [ERROR] [iobroker] TypeError: Cannot read property 'match' of null
          backitup.0	2020-04-25 16:17:39.077	error	(1781) [ERROR] [iobroker] ^
          backitup.0	2020-04-25 16:17:39.076	error	(1781) [ERROR] [iobroker] && _objects[_index].id.match(/^system\.adapter\./)
          backitup.0	2020-04-25 16:17:39.076	error	(1781) [ERROR] [iobroker] /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385
          backitup.0	2020-04-25 16:17:39.070	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.070	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.069	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.068	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.067	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.066	error	(1781) [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
          backitup.0	2020-04-25 16:17:39.013	info	(1781) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.20.1
          host.RaspiIObroker	2020-04-25 16:17:34.840	info	instance system.adapter.backitup.0 started with pid 1781
          admin.0	2020-04-25 16:17:23.937	info	(1766) Use link "http://localhost:8081" to configure.
          admin.0	2020-04-25 16:17:23.936	info	(1766) http server listening on port 8081
          admin.0	2020-04-25 16:17:23.871	info	(1766) received all objects
          admin.0	2020-04-25 16:17:23.494	info	(1766) requesting all objects
          admin.0	2020-04-25 16:17:23.492	info	(1766) requesting all states
          admin.0	2020-04-25 16:17:23.447	info	(1766) starting. Version 3.7.8 in /opt/iobroker/node_modules/iobroker.admin, node: v10.20.1
          host.RaspiIObroker	2020-04-25 16:17:21.233	info	instance system.adapter.admin.0 started with pid 1766
          info.0	2020-04-25 16:17:05.143	info	(1262) Popup news was read...
          host.RaspiIObroker	2020-04-25 16:17:04.820	info	Restart adapter system.adapter.backitup.0 because enabled
          host.RaspiIObroker	2020-04-25 16:17:04.819	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          backitup.0	2020-04-25 16:17:04.289	warn	(1281) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          backitup.0	2020-04-25 16:17:04.283	error	(1281) backitup.0 already running
          info.0	2020-04-25 16:17:03.299	info	(1262) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.20.1
          host.RaspiIObroker	2020-04-25 16:17:01.228	info	instance system.adapter.backitup.0 started with pid 1281
          host.RaspiIObroker	2020-04-25 16:16:57.226	info	instance system.adapter.info.0 started with pid 1262
          discovery.0	2020-04-25 16:16:55.125	info	(1244) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.20.1
          host.RaspiIObroker	2020-04-25 16:16:53.223	info	instance system.adapter.discovery.0 started with pid 1244
          host.RaspiIObroker	2020-04-25 16:16:51.212	info	Restart adapter system.adapter.admin.0 because enabled
          host.RaspiIObroker	2020-04-25 16:16:51.212	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          admin.0	2020-04-25 16:16:50.695	warn	(1233) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          admin.0	2020-04-25 16:16:50.692	error	(1233) admin.0 already running
          host.RaspiIObroker	2020-04-25 16:16:49.236	info	instance system.adapter.admin.0 started with pid 1233
          host.RaspiIObroker	2020-04-25 16:16:49.207	warn	logger system.adapter.javascript.0.logging was deleted
          host.RaspiIObroker	2020-04-25 16:16:49.204	info	starting 4 instances
          host.RaspiIObroker	2020-04-25 16:16:49.195	info	4 instances found
          host.RaspiIObroker	2020-04-25 16:16:49.137	info	connected to Objects and States
          host.RaspiIObroker	2020-04-25 16:16:48.911	info	ip addresses: 192.168.1.150 fe80::8f36:4258:8398:8abf
          host.RaspiIObroker	2020-04-25 16:16:48.909	info	hostname: RaspiIObroker, node: v10.20.1
          host.RaspiIObroker	2020-04-25 16:16:48.908	info	Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
          host.RaspiIObroker	2020-04-25 16:16:48.901	info	iobroker.js-controller version 2.2.9 js-controller starting
          host.RaspiIObroker	2020-04-25 16:16:37.061	info	terminated
          host.RaspiIObroker	2020-04-25 16:16:36.982	info	All instances are stopped.
          host.RaspiIObroker	2020-04-25 16:16:36.982	info	instance system.adapter.backitup.0 terminated with code 156 (156)
          host.RaspiIObroker	2020-04-25 16:16:36.981	info	instance system.adapter.admin.0 terminated with code 156 (156)
          host.RaspiIObroker	2020-04-25 16:16:36.979	info	instance system.adapter.discovery.0 terminated with code 156 (156)
          host.RaspiIObroker	2020-04-25 16:16:36.974	info	instance system.adapter.info.0 terminated with code 156 (156)
          admin.0	2020-04-25 16:16:36.478	info	(1090) Got terminate signal TERMINATE_YOURSELF
          host.RaspiIObroker	2020-04-25 16:16:36.468	info	stopInstance system.adapter.backitup.0 send kill signal
          host.RaspiIObroker	2020-04-25 16:16:36.466	info	stopInstance system.adapter.info.0 send kill signal
          host.RaspiIObroker	2020-04-25 16:16:36.465	info	stopInstance system.adapter.discovery.0 send kill signal
          backitup.0	2020-04-25 16:16:36.469	info	(1105) Got terminate signal TERMINATE_YOURSELF
          info.0	2020-04-25 16:16:36.467	info	(599) Got terminate signal TERMINATE_YOURSELF
          discovery.0	2020-04-25 16:16:36.466	info	(584) Got terminate signal TERMINATE_YOURSELF
          host.RaspiIObroker	2020-04-25 16:16:36.464	info	stopInstance system.adapter.admin.0 send kill signal
          host.RaspiIObroker	2020-04-25 16:16:36.456	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
          host.RaspiIObroker	2020-04-25 16:16:36.455	info	stopInstance system.adapter.info.0 (force=false, process=true)
          host.RaspiIObroker	2020-04-25 16:16:36.447	info	stopInstance system.adapter.discovery.0 (force=false, process=true)
          host.RaspiIObroker	2020-04-25 16:16:36.446	info	stopInstance system.adapter.admin.0 (force=false, process=true)
          backitup.0	2020-04-25 16:16:36.456	info	(1105) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          admin.0	2020-04-25 16:16:36.454	info	(1090) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          discovery.0	2020-04-25 16:16:36.453	info	(584) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          info.0	2020-04-25 16:16:36.450	info	(599) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          • K Karsten69
            @Karsten69 OK!
            dann bin ich leider auch überfragt.
            Die üblichen Fragen nach den Versionen schenke ich mir mal, da ehe ich davon aus, dass du da selber nach gesehen hast
              Karsten69
              Frag ruhig, vieleicht habe ich was übersehen, was brauchst du?
              • K Karsten69
                was brauchst du?
                naja, alles ;-)
                node -v
                nodejs -v
                npm -v
                js-controller
                admin
                und alles was mir auf die Schnelle nicht einfällt ;-)
                  was brauchst du?
                  naja, alles ;-)
                  node -v
                  nodejs -v
                  npm -v
                  js-controller
                  admin
                  Karsten69
                  @Homoran
                  node v10.20.1
                  nodejs v10.20.1
                  npm 6.14.4
                  Admin 3.7.8
                  JS 2.2.9
                    Karsten69
                    Habe diesmal extra nicht Latest genommen 😧
                      Karsten69
                      Habe hier vom November noch ein Total Backup, habe aber irgendwo gelesen man soll immer das Minimal nehmen.
                      • K Karsten69
                        ein Total Backup
                        ein Total Backup darf nur auf der selben Hardware und dem selben Softwareunterbau wieder hergestellt werden!
                        Bei den Versionen sehe ich nichts was zu Problemen führen könnte.
                        Den Restore hast du aber wie im ersten Post über die Konsole nach kopieren der BUP-Datei in /opt/iobroker/backups/
                        durchgeführt?
                          Karsten69
                          Nein diesmal über das Webinterface, probiere es nochmal über die Konsole.
                            Karsten69
                            Gleiches Ergebnis😵
                            pi@RaspiIObroker:/opt/iobroker $ sudo iobroker restore 2
                            host.RaspiIObroker Using backup file iobroker_2020_04_24-02_00_20_backupiobroker.tar.gz
                              Karsten69
                              Ist vieleicht eine blöde Frage, aber ich versuche es mal, ich habe keine große IObroker Installation, kann es sein das das Backup nur 1,8MB groß ist?
                              • K Karsten69
                                ja!
                                da ist nur die Konfiguration drin gespeichert, alles andere wird neu angelegt und kompiliert
                                • K Karsten69
                                  mit backitup?
                                    mit backitup?
                                    Karsten69
                                    @Homoran Jap
                                    • K Karsten69
                                      @Homoran Jap
                                      @Karsten69 dann kann @simatec vielleicht weiterhelfen
                                        Karsten69
                                        @Homoran Sorry aber ich bin nicht so der Forumsspezi, wie erreiche ich das @simatec das hier liest?
                                        • K Karsten69
                                          Das haben wir beide gerade gemacht ;-)
