  4. Material Design Widgets: Wetter View
material design widgetsviswetterdaswetterweatherundergroundpollenflugstatusanzeigejavascript
721 Beiträge 82 Kommentatoren 310.3k Aufrufe 91 Beobachtet
  • sigi234S sigi234
    @RalfEngelberth
    Welche Version von Material Design Widgets hast du?
    R
    R
    RalfEngelberth
    #74
    • R RalfEngelberth
      sigi234S
      sigi234S
      #75
      @RalfEngelberth
      Skript ok, alles Richtig eingestellt?
      R 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @RalfEngelberth
        R
        R
        RalfEngelberth
        #76
        @sigi234 Skript läuft.
        Einstellungen im Skript habe ich nur die Region vom Pollenflug geändert.
        sigi234S K 2 Antworten Letzte Antwort
        • R RalfEngelberth
          sigi234S
          sigi234S
          #77
          @RalfEngelberth sagte in Material Design Widgets: Wetter View:
          Was steht bei dir in den Objekten unter Chart?
          • sigi234S sigi234
            R
            R
            RalfEngelberth
            #78
            {"axisLabels":["1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"graphs":[{"data":[9,8,6,6,5,5,6,7,9,11,12,13,14,16,16,16,16,16,15,12,11,10,9,8],"type":"line","color":"gray","legendText":"Temperatur","line_pointSizeHover":5,"line_pointSize":0,"line_Tension":0.3,"yAxis_show":false,"yAxis_gridLines_show":false,"yAxis_gridLines_ticks_length":5,"yAxis_min":0,"yAxis_max":25,"yAxis_step":5,"yAxis_position":"left","yAxis_appendix":" °C","yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","displayOrder":0,"tooltip_AppendText":" °C","datalabel_backgroundColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"datalabel_color":"white","datalabel_offset":-10,"datalabel_fontFamily":"RobotoCondensed-Light","datalabel_fontSize":12,"datalabel_borderRadius":6,"datalabel_steps":2,"line_PointColor":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorder":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"line_PointColorBorderHover":["#58a9b0","#53a3af","#4897ad","#4897ad","#4391ac","#4391ac","#4897ad","#4d9dae","#58a9b0","#63b4b3","#68bab4","#6ec0b5","#73c6b6","#56b589","#56b589","#56b589","#56b589","#56b589","#65bd9f","#68bab4","#63b4b3","#5eafb1","#58a9b0","#53a3af"],"use_gradient_color":true,"gradient_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}],"use_line_gradient_fill_color":true,"line_gradient_fill_color":[{"value":-20,"color":"#5b2c6f66"},{"value":0,"color":"#2874a666"},{"value":14,"color":"#73c6b666"},{"value":22,"color":"#00800066"},{"value":27,"color":"#ffa50066"},{"value":35,"color":"#ff000066"}]},{"data":[10,10,10,10,10,10,10,10,0,0,0,0,0,0,0,0,0,0,0,1,2,2,2,3],"type":"line","color":"#0d47a1","legendText":"Regenwahrscheinlichkeit","line_UseFillColor":true,"line_pointSize":0,"line_pointSizeHover":5,"yAxis_min":0,"yAxis_max":100,"yAxis_maxSteps":10,"yAxis_position":"left","yAxis_gridLines_show":false,"yAxis_gridLines_border_show":false,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","yAxis_appendix":" %","displayOrder":1,"tooltip_AppendText":" %","datalabel_show":false}]}
            • R RalfEngelberth
              sigi234S
              sigi234S
              #79
              @RalfEngelberth
              Ok, was sagt die Console unter F12
              • sigi234S sigi234
                @RalfEngelberth
                R
                R
                RalfEngelberth
                #80
                @sigi234 Ich hoffe, ich habe hier das Richtige.
                sigi234S ScroungerS 2 Antworten Letzte Antwort
                • R RalfEngelberth
                  sigi234S
                  sigi234S
                  #81
                  @RalfEngelberth
                  Ok, das sollte sich @Scrounger mal ansehen. Ev. meldet er sich.
                  • sigi234S sigi234
                    @RalfEngelberth
                    R
                    R
                    RalfEngelberth
                    #82
                    @sigi234 ok
                    • R RalfEngelberth
                      ScroungerS
                      ScroungerS
                      Scrounger
                      #83
                      ![Bild Text](c1f6d83c-180b-4d24-83d7-886db20e68a0-image.png Bild Link)
                      Das ist ein Edge spezifischer Fehler, der bei mir auch kommt. Das muss ich mir in Ruhe anschauen und im MDW fixen
                      • ScroungerS Scrounger
                        R
                        R
                        RalfEngelberth
                        #84
                        @Scrounger sagte in Material Design Widgets: Wetter View:
                        Habe gerade den Firefox installiert.
                        Damit geht es
                        ScroungerS 1 Antwort Letzte Antwort
                        • R RalfEngelberth
                          Damit geht es
                          ScroungerS
                          ScroungerS
                          Scrounger
                          #85
                          @RalfEngelberth
                          Ja auch mit Chrome geht es, nur halt der Edge macht hier probleme.
                          Hab den Fehler behoben, fix gibts dann in der nächsten version.
                          Falls du nicht warten willst kannst von github installieren -> danach muss iobroker upload vis ausgeführt werden!
                            @RalfEngelberth
                            A
                            A
                            Aiouh
                            #86
                            @Scrounger
                            darf man hier auch ein Lob loswerden, nicht nur Probleme ?
                            Ich bin als ziemlicher Neuling einfach nach der Anleitung vorgegangen und ALLES hat auf Anhieb funktioniert.
                            Vielen Dank für die klasse Arbeit (Kaffee ist unterwegs ;) )
                            Gruss Karl-Heinz
                            • S
                              S
                              Smart86
                              schrieb am zuletzt editiert von Smart86
                              #87
                              Sehr cooles Plugin. Ein kleines Problem habe ich aber noch, vielleicht gibt es ja eine einfache Lösung. Am Handy im Hochformat überlagern sich leider die Zahlen mit den Icons. Hat wer ne Idee?
                              • A Aiouh
                                @Scrounger
                                Gruss Karl-Heinz
                                ScroungerS
                                ScroungerS
                                Scrounger
                                #88
                                @Aiouh sagte in Material Design Widgets: Wetter View:
                                @Scrounger
                                Gruss Karl-Heinz
                                Ich weiß zwar nicht ob das die Forumsregeln gestatten ;-) aber ich freue mich immer über ein Lob, genauso wie zu lesen, wenn meine Projekte bei Euch funktionieren!
                                @Smart86 sagte in Material Design Widgets: Wetter View:
                                Das musst du über das Widget Grid View einstellen. Dort kannst du festlegen ab welcher Auflösung die Regeln für Handy / Tablet und Desktop gelten und für diese dann die Spalten einstellen. Das Widget hat auch einen Auflösungsassitenten, der dir hilft die entsprechenden Auflösung zu erkennen.
                                Am besten einfach mal mit rum spielen, dann bekommst den Dreh raus.
                                  @Scrounger
                                  Gruss Karl-Heinz
                                  S
                                  S
                                  Smart86
                                  #89
                                  Vielen Dank. Habe es in den Einstellungen gefunden bzw. die Spaltenanzahl geändert. Jetzt schaut es gut aus .-)
                                  • H
                                    H
                                    HoffmannOs
                                    #90
                                    Ich suche mir schon nen Wolf, wie kann ich denn die Cards die derzeit in Weiss sind an mein Design im Script anpassen?
                                    • H HoffmannOs
                                      sigi234S
                                      sigi234S
                                      #91
                                      @HoffmannOs sagte in Material Design Widgets: Wetter View:
                                      • H
                                        H
                                        Hoovercraft
                                        schrieb am zuletzt editiert von Hoovercraft
                                        #92
                                        Hier stand mal eine Fehlerbeschreibung, konnte sie aber selbst fixen.
                                        Wunderground scheint die Koordinaten nicht zu mögen. Nachdem ich meine Stadt mit Namen angegeben habe, sind die FM weg.
                                        • dirk1962D
                                          dirk1962D
                                          dirk1962
                                          #93
                                          Kann bitte einer erklären, wie ihr die einzelnen Views in eure vis integriert habt.
                                          Jeden einzelnen view in eure kopiert oder gibt es eine andere Lösung?
                                          NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                                          GlasfaserG ScroungerS 2 Antworten Letzte Antwort
                                          84.2k
