  4. JavaScript
  5. Javascript spinnt
Javascript spinnt
blocklyjavascript
38 Beiträge 3 Kommentatoren 5.3k Aufrufe 1 Beobachtet
    @Homoran
      <variables>
        <variable type="undefined" id="Druckwaechter">Druckwaechter</variable>
      </variables>
      <block type="on_ext" id="7dfyAn6SRa*[nLlE6wNr" x="88" y="-688">
        <mutation items="1"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="22fT?@[Ak,Y,5ARfKDR0">
            <field name="oid">hm-rpc.0.JEQ0646431.1.STATE</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id=")z={;q=@viwHI1]x-E!n">
            <value name="IF0">
              <block type="logic_compare" id="/jjj`+cYZAPxHH@;p6IO">
                <field name="OP">EQ</field>
                <value name="A">
                  <block type="get_value" id="AT;0x.hm%lz`yuC5zo!~">
                    <field name="OID">hm-rpc.0.JEQ0646431.1.STATE</field>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_boolean" id="zJR/?W/^sfA1]`#W_fHR">
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="update" id="w^oDcGY.)jHQKrSZ8_$b">
                <mutation delay_input="false"></mutation>
                <field name="OID">Messwerte.0.Pool.Logdaten</field>
                <value name="VALUE">
                  <block type="text_join" id="u=RwAsZJ_SKtf1W^#7G5">
                    <value name="ADD0">
                      <block type="text" id="dt=P;{^t[WY;|UfTC].9">
                        <field name="TEXT">&lt;h3&gt;Pumpe an!&lt;/h3&gt;</field>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="comment" id="R!/_I]Eg.Mr8B6BQvpzB">
                    <field name="COMMENT">Überprüfung ob sich nach Start Druck aufbaut</field>
                    <next>
                      <block type="timeouts_setinterval" id="(dmS[J9=$HE%={VXvnap">
                        <field name="NAME">Druckwaechter</field>
                        <field name="INTERVAL">2000</field>
                        <field name="UNIT">ms</field>
                          <block type="controls_if" id="~lhx*Vs2ryN|,wqvP!x)">
                            <mutation elseif="2"></mutation>
                            <value name="IF0">
                              <block type="logic_operation" id="?Ikqjg(-]06dNHALPyD:" inline="false">
                                <field name="OP">AND</field>
                                <value name="A">
                                  <block type="logic_compare" id="b;EdBH]KsuEYFoEOJRBj">
                                    <value name="A">
                                      <block type="get_value" id="Nf}+:qJmE!{r;HPgq08/">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_boolean" id=";fO$:Hlx9-gvh3~7Sa}J">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_compare" id="DIsH6?CKt#eeQqseF[*t">
                                    <field name="OP">LT</field>
                                    <value name="A">
                                      <block type="math_arithmetic" id="Kl3]R#u544Gw=Ay0)w*/" inline="false">
                                        <value name="A">
                                          <shadow type="math_number" id="INcml)H.rD~u^7J:xt(0">
                                            <field name="NUM">1</field>
                                          </shadow>
                                          <block type="get_value" id="Y6f4Pem}L6T`1T`$8#T8">
                                            <field name="OID">hm-rpc.0.NEQ1547414.3.STATE</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="p+mI@^)NJ3V2%8C!BoGN">
                                          </shadow>
                                          <block type="get_value" id="PTrh,nQk_e1_(`lNtDr,">
                                            <field name="OID">Messwerte.0.Pool.Druckoffset</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id=")%M0Vs[*Thkh@[P[)fJ5">
                                        <field name="NUM">40</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="update" id="n=2V{qw*}vbeW+j*|3|4">
                                <field name="OID">Messwerte.0.Pool.Aus-Counter</field>
                                  <block type="math_arithmetic" id="zxVr.v)8$`]wuc@gZYJx">
                                    <field name="OP">ADD</field>
                                    <value name="A">
                                      <shadow type="math_number" id="d,c/@aBkqFRf?N@Yr-5G">
                                      </shadow>
                                      <block type="get_value" id="W7K[HLit6M;jMhECjdo4">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="1kl!u(,!aJwjF!_1ef%r">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="update" id="FQJt6GsNG#O5-`rURd@b">
                                      <block type="text_join" id="V(kh7O_8ml6ima2V=!(H">
                                        <value name="ADD0">
                                          <block type="text" id="Kd1m25}S19}M!hrCL4e,">
                                            <field name="TEXT">Der Pumpendruck beträgt </field>
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="math_arithmetic" id="u[,4FDg:-2rbUkFQ20vt" inline="false">
                                            <value name="A">
                                              </shadow>
                                              <block type="get_value" id="$.~H$I;sBm?`%oi4myvz">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                              <block type="get_value" id="i2Ym%.6b/*hby$T3xxS9">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="Wrz~UGhB4XFYt@[aiX*O">
                                            <field name="TEXT">kPa, Pumpe zieht Luft!</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <value name="IF1">
                              <block type="logic_operation" id="|lv!dTbr^IxwOdd|IJgr" inline="false">
                                <value name="A">
                                  <block type="logic_operation" id=";1(v^[i=sQ}QPd`Nt;sI" inline="false">
                                    <value name="A">
                                      <block type="logic_compare" id="]=?Iqha}AKv$sl9yLKC.">
                                        <value name="A">
                                          <block type="get_value" id="|yRK#Er%v%mJ))t}Vl1J">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <block type="logic_boolean" id="y{QTTF,sNl0=?M`;xGxC">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_compare" id="@FdJz}BkDt0yP`5pV6}(">
                                        <field name="OP">LTE</field>
                                        <value name="A">
                                          <block type="get_value" id="3%]u)I^}Kk;]o8ELq6Q#">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <block type="math_number" id="NXsORCA+acza*%?E%wLq">
                                            <field name="NUM">25</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_compare" id="Q[q#b4SqBT8h;F^i/Zjv">
                                    <field name="OP">GT</field>
                                    <value name="A">
                                      <block type="math_arithmetic" id="6*z48,4kjj2}MCg~ZLjG" inline="false">
                                        <value name="A">
                                          </shadow>
                                          <block type="get_value" id="H=E3)e95V8jZ8]pdse%@">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          <block type="get_value" id="+d1+[1Z#U`5~./W%B}0A">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id="v({r^T(a[x=KmK|YmuqN">
                                        <field name="NUM">70</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO1">
                              <block type="update" id="?`(,B+MiC#:t+,!{9M!|">
                                  <block type="text_join" id="ZzygAs|4A8^9~PUdyf7*">
                                    <value name="ADD0">
                                      <block type="text" id="zr,%jgd/n~n9@ytoH?tu">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="math_arithmetic" id="~FK)M+G_7Ne%6v0ChmVE" inline="false">
                                        <value name="A">
                                          </shadow>
                                          <block type="get_value" id="[$afhI/0-qJxDKj$QVZc">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          <block type="get_value" id="1OgHM*qIdtfWM-gEF3//">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="w,_a2K$?2?2*iflXYnj)">
                                        <field name="TEXT">kPa, Pumpe OK!</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="timeouts_clearinterval" id="|{Dx7@}:?^_iT2M|_G8?">
                                    <next>
                                      <block type="update" id="!dT6Nrdz[0Y;|!wj|G=1">
                                          <block type="math_number" id="TzTku,Loj.[xHXB24mY}">
                                            <field name="NUM">0</field>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="update" id="iE~B{eq9,^?Ez!Vf?uHR">
                                            <field name="OID">Messwerte.0.Pool.Not-Aus</field>
                                              <block type="logic_boolean" id="q^Xs3OBbw0WoN$E{[EIE">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <value name="IF2">
                              <block type="logic_compare" id="%Fq@t|QV#;J`%V|SU=Ge">
                                <value name="A">
                                  <block type="get_value" id="5kxD)T_,/44`#Cahfk{~">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="lf+nFS}/i^VYH4dtC$}d">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO2">
                              <block type="timeouts_clearinterval" id="a%U@19LgX0PO$Me/}nib">
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_compare" id=":iR2b(rLjoeR?4xjuuON">
                <value name="A">
                  <block type="get_value" id="!L[!9l3mD;7AvQ~rDmeF">
                  </block>
                </value>
                <value name="B">
                  <block type="logic_boolean" id="z~E`0R`q#Y/i;D7?+I}y">
                  </block>
                </value>
              </block>
            </value>
              <block type="update" id="^1$tmg]Y7!4P|:ll$NBe">
                  <block type="text_join" id="LrZELm6;8l:R+9*:fL:F">
                    <value name="ADD0">
                      <block type="text" id=".Z]]b@r=0Lu1sNu{xXi%">
                        <field name="TEXT">&lt;h3&gt;Pumpe aus!&lt;/h3&gt;</field>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="on_ext" id="HS#;aW-p`y;to-YSLL4J">
            <value name="OID0">
              <shadow type="field_oid" id="b6JuvqEA44nm61[N@lVo">
                <field name="oid">Messwerte.0.Pool.Aus-Counter</field>
              </shadow>
            </value>
            <value name="OID1">
              <shadow type="field_oid" id=".N=f*k[2D4pNthJgu~Y{">
                <field name="oid">hm-rpc.0.NEQ1547414.3.STATE</field>
              </shadow>
            </value>
            <value name="OID2">
              <shadow type="field_oid" id="WrxSTGGW1Wq?LE@DC.~p">
                <field name="oid">hm-rpc.0.LEQ0773306.2.TEMPERATURE</field>
              </shadow>
            </value>
              <block type="controls_if" id="%U70Es]yX`L}p/[AxjP1">
                <mutation elseif="3"></mutation>
                <value name="IF0">
                  <block type="logic_compare" id="8!Jg:Bfu6Q4A+KLnT,*b">
                    <value name="A">
                      <block type="get_value" id="$IKf6j:rw8w^!*VjbOZ:">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="%5eQ}+7UY^z$?FPGnl],">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="comment" id="$-$=odn6^k,(+zergHsH">
                    <field name="COMMENT">Pumpe Not-Aus bei zu wenig Druck</field>
                    <next>
                      <block type="update" id="l)3U8yrX.QDU4uyjxbsi">
                          <block type="text_join" id="8`@-PwY?(}*=(F{Pkj^U">
                            <mutation items="6"></mutation>
                            <value name="ADD0">
                              <block type="text" id="?n:DHx}IsNd:O,1Cky.U">
                                <field name="TEXT">&lt;h2&gt;ALARM!&lt;/h2&gt;</field>
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="~dF0?`~[/Y(#|~:*HRo%">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="$RmFWA-Gp,gl}b!1(z.U">
                                <field name="TEXT"> mal Unterdruck. </field>
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="M*E=O7VC|IUA#E=#4FMN">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="math_arithmetic" id="D)c}D]clt6IUeh/e@{?p" inline="false">
                                <value name="A">
                                  </shadow>
                                  <block type="get_value" id="E.7$4A7|g=*^K@Q#@7bt">
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                  <block type="get_value" id="bk+r$]_Yl*(rg8.$?Map">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD5">
                              <block type="text" id=":UP_kmS=l!}iC1aw~FYB">
                                <field name="TEXT">kPa.&lt;br&gt; &lt;br&gt;</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="6E[YV0{Ys9KXi%Dby6~F">
                            <mutation delay_input="true"></mutation>
                            <field name="DELAY_MS">1000</field>
                              <block type="logic_boolean" id="p49UcVMoLiob~E|/-1@m">
                              </block>
                            </value>
                            <next>
                              <block type="update" id="!xVxSwtk;%ke@qXZJ?zs">
                                  <block type="logic_boolean" id="D3v792$dfR`IrOu2@In:">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="YSAo!-{JFc!$wao4+j2m">
                    <value name="A">
                      <block type="math_arithmetic" id="@J=anf+JX]jD@hsfW0hw" inline="false">
                        <value name="A">
                          </shadow>
                          <block type="get_value" id="{h:u=^)@q2k4wQoackld">
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                          <block type="get_value" id="_#6yu!U/WKN%|GqKSdsd">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="8nW/qBp)(S8kB#B0Q/ek">
                        <field name="NUM">120</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="comment" id="srcU:kt;_7KKmMXkC/3D">
                    <field name="COMMENT">Pumpe Not-Aus bei zu viel Druck</field>
                    <next>
                      <block type="update" id="2#JIoZ;N,+))BBX:ml;p">
                          <block type="text_join" id="N@U]PeHQscf7^LU7q7[,">
                            <value name="ADD0">
                              <block type="text" id="{d5wnGEgZ{umbsQrj_kt">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="text" id="m}^$`#~WSKX{k(f9@%=y">
                                <field name="TEXT">&lt;strong&gt;Überdruck!&lt;/strong&gt;</field>
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="asVh@FD5s2m+)`%v(#s9">
                                <field name="TEXT">&lt;br&gt;</field>
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="jb?})50m{;]e5^y5FnfD">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="math_arithmetic" id="bFwHCSei$rE73tfm{UOh" inline="false">
                                <value name="A">
                                  </shadow>
                                  <block type="get_value" id="_044cd+z(,rh,9g][*B#">
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                  <block type="get_value" id="bq{9Tw,lD8(R=)Z`gWZq">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="ADD5">
                              <block type="text" id="gU/?A(+09:=1:TTlw?AI">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="o$;obhX]9oIG*at)L|l3">
                            <field name="DELAY_MS">2000</field>
                              <block type="logic_boolean" id="OA|qAe.cxIeZVf8+rgBQ">
                              </block>
                            </value>
                            <next>
                              <block type="update" id="Gc9;Y}V;+n%s3b0brc-N">
                                  <block type="logic_boolean" id="s`(EWr~/BB}V^^WX.z?s">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF2">
                  <block type="logic_compare" id="vig:OLc#4v0Jj)l)=Je/">
                    <value name="A">
                      <block type="get_value" id="=Ub`*$LBbPvdLZ3,GEmU">
                        <field name="OID">hm-rpc.0.LEQ0773306.2.TEMPERATURE</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="6Q`pFPW8Zt=4wFL`^B1X">
                        <field name="NUM">28</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="comment" id="O:bB$YmPnM9|H8UW`aUb">
                    <field name="COMMENT">Pumpe Not-Aus bei zu hoher Temperatur</field>
                    <next>
                      <block type="update" id="bJkQKjD~r}v_XiyCVE0(">
                          <block type="text_join" id=")qKjGD+*k!8_^MP^`/oV">
                            <value name="ADD0">
                              <block type="text" id="riC$J#F=X=O#(:Ohpnil">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="text" id="K-=H$hk=!7kqFb;FVN}P">
                                <field name="TEXT">&lt;strong&gt;Wasser zu warm!&lt;/strong&gt;</field>
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="@W3G/*SnLN8;yjaJBS}+">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="PO-x3Iuu+|)KEc]n_`E_">
                                <field name="TEXT">Die Wassertemperatur beträgt </field>
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="get_value" id="+hG5nSCDExGo{(#/G2tX">
                              </block>
                            </value>
                            <value name="ADD5">
                              <block type="text" id="#(Q+P)v=TLb^+n,w8aWz">
                                <field name="TEXT">°C.&lt;br&gt; &lt;br&gt;</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="EAJlBjqtK*l+uBYur3Y#">
                              <block type="logic_boolean" id="fVJuavjl.jsO06[aPo)F">
                              </block>
                            </value>
                            <next>
                              <block type="update" id="{!_mR[3~qClN^`A@Q!Tb">
                                <field name="OID">Messwerte.0.Pool.Overheat</field>
                                  <block type="logic_boolean" id="0ct/Oo|oXSpZS-VWrrBv">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF3">
                  <block type="logic_compare" id="=thx*obAlc;Pam/}0pPf">
                    <value name="A">
                      <block type="get_value" id="hBucm0?}qRs/{?1{qn%/">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="3+w/B{M]ER1k8H.oN$BW">
                        <field name="NUM">26</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO3">
                  <block type="update" id="0Y#]wiHNblXC@bWi[%=P">
                      <block type="logic_boolean" id="JL[0+M`$vBEE]Dcd[zs1">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    Musste ich auf zwei Posts verteilen
    paul53P
    paul53P
    @Homoran
    Habe "Pumpenwächter" mal verbessert und hoffe, dass es so zuverlässiger läuft.
     <variables>
       <variable type="" id="Yhi6L$#9ow5|s7Jzml9/">value</variable>
       <variable type="" id="G;[*0*e+|FLxIBWQ?*45">druck</variable>
       <variable type="" id="VA5v~sVeM3MnJiV[ytx3">aus_counter</variable>
     </variables>
     <block type="procedures_defnoreturn" id="IgiB--VCkqYFl?t9j=01" x="1012" y="-1138">
       <field name="NAME">Not_Aus</field>
       <statement name="STACK">
             </block>
           </value>
           <next>
                 </block>
               </value>
             </block>
           </next>
         </block>
       </statement>
     </block>
     <block type="on_ext" id="7dfyAn6SRa*[nLlE6wNr" x="519" y="-1111">
       <value name="OID0">
         </shadow>
       </value>
           <value name="IF0">
             <block type="variables_get" id="iu%_ub!E+6~#q4_,A}/U">
               <field name="VAR" id="Yhi6L$#9ow5|s7Jzml9/" variabletype="">value</field>
             </block>
           </value>
                   <value name="ADD0">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                   <next>
                           <value name="IF0">
                               <value name="A">
                                 <block type="variables_get" id="3o+{b{HJ;:j-mxz:~W:W">
                                   <field name="VAR" id="G;[*0*e+|FLxIBWQ?*45" variabletype="">druck</field>
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                                   <value name="ADD0">
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id="D9Ll={@$`RYHRj{^CN^`">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="math_change" id="?=,w8-!SQr!Dc#L4Sxi3">
                                   <field name="VAR" id="VA5v~sVeM3MnJiV[ytx3" variabletype="">aus_counter</field>
                                   <value name="DELTA">
                                     <shadow type="math_number" id=")XQXyP6cyUlwk@nA,-]C">
                                     </shadow>
                                   </value>
                                   <next>
                                     <block type="controls_if" id="rk%Q_o*tq-78prD`YgJy">
                                       <value name="IF0">
                                           <value name="A">
                                             <block type="variables_get" id="0+d^@TVbroJ{(ru3U7rl">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                           <next>
                                               <next>
                                                       <value name="ADD0">
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                         <block type="variables_get" id="/II*(4_ktC4]ztatNDT*">
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         </block>
                                                       </value>
                                                       <value name="ADD4">
                                                         <block type="variables_get" id="YYS4xBaHK$iXv1M|yW2D">
                                                         </block>
                                                       </value>
                                                       <value name="ADD5">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="procedures_callnoreturn" id="}k57ggKysD3)_iu|OPi=">
                                                       <mutation name="Not_Aus"></mutation>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <statement name="ELSE">
                                   <value name="ADD0">
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id="f[Y,?Ct#`o0w=H|=wyKr">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                   <next>
                                     <block type="variables_set" id="wRJQ^AST.Bn@#X{{mK7a">
                                         <block type="math_number" id="M~Ep{n3b2S6BP*({irQ9">
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
             <block type="timeouts_clearinterval" id="lFQYnd;.XpmUjMY?u{~i">
               <next>
                 <block type="variables_set" id="SE*I|jbZ7sVdfbu5pHt%">
                     <block type="math_number" id="M-;)GJH$vQoNw;,go_D`">
                     </block>
                   </value>
                   <next>
                           <value name="ADD0">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
       <next>
           <value name="OID0">
             <shadow type="field_oid" id="y8{BV1mex2n*6^/a:#4.">
             </shadow>
             <block type="text" id="|G)E)|3fWs.Kb_GnTv4G">
               <field name="TEXT">hm-rpc.0.NEQ1547414.3.STATE</field>
             </block>
           </value>
             <block type="variables_set" id="3~Cm|IJku:CqV%[t}/*,">
                   <value name="A">
                     </shadow>
                     <block type="variables_get" id="RIiQl|w=7ZKhq?Gop4y[">
                     </block>
                   </value>
                   <value name="B">
                     </shadow>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                   <value name="IF0">
                       <value name="A">
                         <block type="variables_get" id="[T{qgrx/ka=uQct;L.rj">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                       <next>
                               <value name="ADD0">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 </block>
                               </value>
                               <value name="ADD2">
                                 </block>
                               </value>
                               <value name="ADD3">
                                 </block>
                               </value>
                               <value name="ADD4">
                                 <block type="variables_get" id="~x8q@FJ0#)?A{C@ZpPb*">
                                 </block>
                               </value>
                               <value name="ADD5">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="procedures_callnoreturn" id="nv|r:KV%#/O_+z?Q;0(r">
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
           <next>
             <block type="on_ext" id="SO])Tk/2c!54xtFB_[oL">
               <value name="OID0">
                 <shadow type="field_oid" id="pmVg4L-MWaXOHI*aWJ!`">
                 </shadow>
                 <block type="text" id="P|5rvg`CN~1X8Gzipc-p">
                   <field name="TEXT">hm-rpc.0.LEQ0773306.2.TEMPERATURE</field>
                 </block>
               </value>
                 <block type="controls_if" id="EqoCaflD;)3U~6bU/XLm">
                   <value name="IF0">
                       <value name="A">
                         <block type="variables_get" id="0Bp/Hs;pjf3X(vR~)U59">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                       <next>
                               <value name="ADD0">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 </block>
                               </value>
                               <value name="ADD2">
                                 </block>
                               </value>
                               <value name="ADD3">
                                 </block>
                               </value>
                               <value name="ADD4">
                                 <block type="variables_get" id="zb(jL3^bs}fEFF%{tvf/">
                                 </block>
                               </value>
                               <value name="ADD5">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF1">
                       <value name="A">
                         <block type="variables_get" id="z]QkSzInZL]iENdGFqe2">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
      @Homoran
       <variables>
       </variables>
               </block>
             </value>
             <next>
                   </block>
                 </value>
               </block>
             </next>
           </block>
         </statement>
       </block>
         <value name="OID0">
           </shadow>
         </value>
             <value name="IF0">
               </block>
             </value>
                     <value name="ADD0">
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                     <next>
                             <value name="IF0">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                                     <value name="ADD0">
                                       </block>
                                     </value>
                                     <value name="ADD1">
                                       </block>
                                     </value>
                                     <value name="ADD2">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                       </shadow>
                                     </value>
                                     <next>
                                         <value name="IF0">
                                             <value name="A">
                                               </block>
                                             </value>
                                             <value name="B">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                             <next>
                                                 <next>
                                                         <value name="ADD0">
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           </block>
                                                         </value>
                                                         <value name="ADD2">
                                                           </block>
                                                         </value>
                                                         <value name="ADD3">
                                                           </block>
                                                         </value>
                                                         <value name="ADD4">
                                                           </block>
                                                         </value>
                                                         <value name="ADD5">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                                     <value name="ADD0">
                                       </block>
                                     </value>
                                     <value name="ADD1">
                                       </block>
                                     </value>
                                     <value name="ADD2">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
                 <next>
                       </block>
                     </value>
                     <next>
                             <value name="ADD0">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
         <next>
             <value name="OID0">
               </shadow>
               </block>
             </value>
                     <value name="A">
                       </shadow>
                       </block>
                     </value>
                     <value name="B">
                       </shadow>
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                         <next>
                                 <value name="ADD0">
                                   </block>
                                 </value>
                                 <value name="ADD1">
                                   </block>
                                 </value>
                                 <value name="ADD2">
                                   </block>
                                 </value>
                                 <value name="ADD3">
                                   </block>
                                 </value>
                                 <value name="ADD4">
                                   </block>
                                 </value>
                                 <value name="ADD5">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
             <next>
                 <value name="OID0">
                   </shadow>
                   </block>
                 </value>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                         <next>
                                 <value name="ADD0">
                                   </block>
                                 </value>
                                 <value name="ADD1">
                                   </block>
                                 </value>
                                 <value name="ADD2">
                                   </block>
                                 </value>
                                 <value name="ADD3">
                                   </block>
                                 </value>
                                 <value name="ADD4">
                                   </block>
                                 </value>
                                 <value name="ADD5">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      Danke - solltest du aber nicht selber machen ;-)
      sehe ich mir heute abend an.
      Allerdings:
      Ich habe aber inzwischen im Forum einige Threads gefunden, die seltsames Verhalten bie früher problemlos laufenden Scripten beschreiben.
      Ich habe diese Threads nicht vollständig gelesen, weiß daher nicht ob es da vergleichbare Szenarien gibt.
        @Homoran
         <variables>
         </variables>
                 </block>
               </value>
               <next>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
         </block>
           <value name="OID0">
             </shadow>
           </value>
               <value name="IF0">
                 </block>
               </value>
                       <value name="ADD0">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                       <next>
                               <value name="IF0">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                       <value name="ADD0">
                                         </block>
                                       </value>
                                       <value name="ADD1">
                                         </block>
                                       </value>
                                       <value name="ADD2">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                         </shadow>
                                       </value>
                                       <next>
                                           <value name="IF0">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                               <next>
                                                   <next>
                                                           <value name="ADD0">
                                                             </block>
                                                           </value>
                                                           <value name="ADD1">
                                                             </block>
                                                           </value>
                                                           <value name="ADD2">
                                                             </block>
                                                           </value>
                                                           <value name="ADD3">
                                                             </block>
                                                           </value>
                                                           <value name="ADD4">
                                                             </block>
                                                           </value>
                                                           <value name="ADD5">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                                       <value name="ADD0">
                                         </block>
                                       </value>
                                       <value name="ADD1">
                                         </block>
                                       </value>
                                       <value name="ADD2">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
                   <next>
                         </block>
                       </value>
                       <next>
                               <value name="ADD0">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
               <value name="OID0">
                 </shadow>
                 </block>
               </value>
                       <value name="A">
                         </shadow>
                         </block>
                       </value>
                       <value name="B">
                         </shadow>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                       <value name="IF0">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                           <next>
                                   <value name="ADD0">
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     </block>
                                   </value>
                                   <value name="ADD3">
                                     </block>
                                   </value>
                                   <value name="ADD4">
                                     </block>
                                   </value>
                                   <value name="ADD5">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                   <value name="OID0">
                     </shadow>
                     </block>
                   </value>
                       <value name="IF0">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                           <next>
                                   <value name="ADD0">
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     </block>
                                   </value>
                                   <value name="ADD3">
                                     </block>
                                   </value>
                                   <value name="ADD4">
                                     </block>
                                   </value>
                                   <value name="ADD5">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                       <value name="IF1">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
        </xml>
        @paul53 sagte in Javascript spinnt:
        Auch auf die Gefahr hin, dass ich in zehn Minuten widerrufen muss:
        Es läuft bis jetzt ohne Probleme.
        Dass es auf Anhieb laufen würde war mir ja klar. Daraufhin habe ich auch noch nicht allzu tief in den Code gesehen. Ein paar Dinge wie Objects als text sind mir zwar auch aufgefallen, aber die alles umfassende Frage bleibt:
        Hast du im Wissen um den neuen Compiler etwas geändert, das im Hintergrund anders läuft?
        Ich verstehe nämlich nach wie vor nicht, warum das log geschrieben wurde aber der direkt darauf folgende Befehl die zyklische Ausführung zu beenden eben nicht
        Bild Text
        Oder lag es daran, dass ich am code nichts geändert und dein Skript als neues Skript angelegt habe???
        Neu gestartet habe ich seitdem beide Blocklys und die Instanzen nicht mehr, einige Änderunge, die ich noch in der Pumpensteuerung einbauen wollte habe ich mir bis jetzt verkniffen.
          Bild Text
          paul53P
          paul53P
          @Homoran sagte:
          Wenn mehrere Zyklen gleichzeitig laufen, greift "stop" nicht.
          @Homoran sagte in Javascript spinnt:
          Das musste ich machen, da ich "Select ID" nicht verwenden kann (fremdes System).
            @Homoran sagte:
            @paul53 Das klingt logisch!
            Und bei mir wurde jedesmal wenn der Druck zu niedrig war ein neuer Zyklus gestartet 🤦
            bleibt nur noch die Frage, warum es die jahre vorher lief
              paul53P
              paul53P
              @Homoran sagte:
              Ich glaube mich zu erinnern, dass der Zyklus beim normalen Ausschalten der Pumpe nicht gestoppt wurde, so dass beim nächsten Einschalten evtl. ein weiterer Zyklus gestartet wurde.
                @Homoran sagte:
                @Homoran sagte:
                Genau so war es.
                Kann sein, dass ich beim "Aufräumen" den stop cycle Baustein da mal rausgenommen hatte
                  @AlCalzone sagte:
                  lädst du das bereits integrierte Modul?
                  Ja.
                  Die Fehlermeldung erhalte ich aber auch bei dem zusätzlich installierten Modul "xml2js".
                  AlCalzoneA
                  AlCalzoneA
                  AlCalzone
                  Kannst du es bitte mal mit folgender Option versuchen (sollte in 4.5.0 enthalten sein)
                  Dort die Module eintragen, die als fehlend angemeckert werden. Die installierten werden nicht automatisch aktiviert, weil manche (gibt eins von Google) so verdammt viele Typdefinitionen enthalten, dass der Adapter direkt mal 200 MB mehr RAM benötigt.
                  • AlCalzoneA AlCalzone
                    paul53P
                    paul53P
                    @AlCalzone sagte:
                    Wird in 4.5.1 trotz Eintrag angemeckert.
                      @AlCalzone sagte:
                      AlCalzoneA
                      AlCalzoneA
                      AlCalzone
                      @paul53 Danke für den Test. Kann sein, dass ich für JS noch was anders machen muss. Habs immer nur in TS getestet.
                      84.2k
