  4. [How-to] Node.js für ioBroker richtig updaten
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 1.1m Aufrufe 112 Beobachtet
  • S SolarGuido
    @Homoran
    ich habe es ja fast befürchtet:
    root@ioBroker-OPiplus2e:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Ign:1 http://httpredir.debian.org/debian stretch InRelease
    OK:2 http://security.debian.org stretch/updates InRelease
    OK:3 http://httpredir.debian.org/debian stretch-updates InRelease
    OK:4 http://httpredir.debian.org/debian stretch-backports InRelease
    OK:5 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
    OK:6 http://httpredir.debian.org/debian stretch Release
    OK:7 http://ppa.launchpad.net/linuxuprising/java/ubuntu disco InRelease
    OK:9 http://ppa.launchpad.net/openjdk-r/ppa/ubuntu disco InRelease
    OK:10 https://deb.nodesource.com/node_12.x stretch InRelease
    OK:8 https://apt.armbian.com stretch InRelease
    Ign:11 https://download.webmin.com/download/repository sarge InRelease
    OK:12 https://download.webmin.com/download/repository sarge Release
    ## Confirming "stretch" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/stretch/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb https://deb.nodesource.com/node_12.x stretch main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_12.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    OK:1 http://security.debian.org stretch/updates InRelease
    Ign:2 http://httpredir.debian.org/debian stretch InRelease
    OK:8 http://ppa.launchpad.net/linuxuprising/java/ubuntu disco InRelease
    OK:7 https://apt.armbian.com stretch InRelease
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    root@ioBroker-OPiplus2e:/opt/iobroker# sudo apt-get install -y nodejs
    Die folgenden NEUEN Pakete werden installiert:
      nodejs
    0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Es müssen noch 0 B von 15,9 MB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 83,7 MB Plattenplatz zusätzlich benutzt.
    Vormals nicht ausgewähltes Paket nodejs wird gewählt.
    (Lese Datenbank ... 75054 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../nodejs_12.16.2-1nodesource1_armhf.deb ...
    Entpacken von nodejs (12.16.2-1nodesource1) ...
    nodejs (12.16.2-1nodesource1) wird eingerichtet ...
    Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
    root@ioBroker-OPiplus2e:/opt/iobroker# node -v
    v8.16.0
    ich hab auch :
    sudo apt-get --purge remove node
    sudo apt-get --purge remove nodejs
    sudo apt-get autoremove
    sudo reboot
    hat auch nix gebracht bringt immer wieder bei node -v die 8.16.0
    das komische, er sagt keine Installation gefunden...
    starte ich iobroker:
    Plattform: linux
    Betriebssystem: linux
    Die Architektur: arm
    CPUs: 4
    Geschwindigkeit: 1296 MHz
    Modell: ARMv7 Processor rev 5 (v7l)
    RAM: 1.9 GB
    System-Betriebszeit: 00:20:32
    Node.js: v8.16.0
    Datenträgergröße: 14.1 GiB
    Datenträger verfügbar: 7.2 GiB
    Adapter-Anzahl: 345
    NPM: v6.4.1
    Betriebszeit: 00:00:30
    Aktive Instanzen: 7 (war gerade am starten außer java braucht ja 10 minimum) läuft alles ...
    nodejs ist schon die neueste Version (12.16.2-1nodesource1).
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    v8.16.0
    root@ioBroker-OPiplus2e:/opt/iobroker# ^C
    root@ioBroker-OPiplus2e:/opt/iobroker# nodejs -v
    v12.16.2
    root@ioBroker-OPiplus2e:/opt/iobroker# npm -v
    6.4.1
    LoL
    eine Idee was ich machen kann?
    S
    S
    SolarGuido
    schrieb am zuletzt editiert von SolarGuido
    #404
    ich habs:
    To manually remove node js, npm and node_modules from Ubuntu, you need to do the following steps.
    First of all you need to run the following command from command terminal as sudo.
    sudo rm -rf /usr/local/bin/npm /usr/local/share/man/man1/node* /usr/local/lib/dtrace/node.d ~/.npm ~/.node-gyp /opt/local/bin/node opt/local/include/node /opt/local/lib/node_modules
    Remove node or node_modules directories from /usr/local/lib with the help of following command.
    sudo rm -rf /usr/local/lib/node*
    Remove node or node_modules directories from /usr/local/include with the help of following command.
    sudo rm -rf /usr/local/include/node*
    Remove any node file or dir from /usr/local/bin with the help of following command.
    sudo rm -rf /usr/local/bin/node*
    Go to home directory and remove any node or node_modules directory, if exists.
    Now it is done
    und danach neu starten (habe opt/iobroker sicherheitshalber kurz umbenannt beim Neustart)
    danach
    root@ioBroker-OPiplus2e:/opt/iobroker# curl -sL https://deb.nodesource.com/setup        _12.x | sudo -E bash -
    + apt-get update
    OK:4 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
    OK:5 http://httpredir.debian.org/debian stretch-backports InRelease
    OK:7 http://httpredir.debian.org/debian stretch Release
    OK:6 https://apt.armbian.com stretch InRelease
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/stretch/Rel        ease'
    OK
    + echo 'deb https://deb.nodesource.com/node_12.x stretch main' > /etc/apt/source        s.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_12.x stretch main' >> /etc/apt/s        ources.list.d/nodesource.list
    + apt-get update
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/s        ources.list.d/yarn.list
      nodejs
    v12.16.2
    hat geklappt.
    da NPM rebuild nicht lief hab ich dann "node reinstall.js" gestartet. In der Anleitung ist es nicht deutlich, habe es im Forum gefunden. Eventuell in der Anleitung erwähnen, nur ein Hinweis...
    Nur ist das auch auf Fehler ...
    • S SolarGuido
      ich habs:
      Now it is done
      danach
      + apt-get update
      OK
      + apt-get update
        nodejs
      v12.16.2
      hat geklappt.
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #405
      @SolarGuido Merkwürdige Zusammenstellung in den sources hast du... disco stretch sarge... Das passt hinten und vorne nicht zueinander.
        S
        S
        SolarGuido
        #406
        @Thomas-Braun
        das ist ja armbian, in erster line Stretch, das webmin sarge keine ahnung läuft schon immer und one fehler dürfte aber damit nix zu tun haben.
        Ich hab jetzt iobroker komplett neu installieren müssen. ist das korrekt das da nur npm 6 läuft?
        Habe jetzt die alte iobroker-data rein kopiert nur verstehe ich das in der Anleitung nicht da steht :
        Anschließend wieder ioBroker starten. Der Rest läuft dann wie bei c) und dauert seine Zeit.
        ok, das bedeutet nach dem start installiert er alle adapter neu , scheint zu gehen 4 sind schon installiert :-)
        lattform: linux
        CPUs: 4
        RAM: 1.9 GB
        System-Betriebszeit: 02:26:04
        Node.js: v12.16.2
        NPM: 6.14.4
        Adapter-Anzahl: 345
        Betriebszeit: 00:06:14
        Aktive Instanzen: 4
        so sieht das jetzt aus...
        und alle Adapter wurden neu installiert. Alle Daten und Settings blieben erhalten und sogar Javascript läuft jetzt wieder :-)
        Danach auch noch 4 Adpter update gemacht ging ohne Fehler. Alle Instanzen grün.
        Nur der admin2.0 Adapter ist nicht mehr da , macht aber auch nicht viel...
        und "iot.0 2020-04-20 02:43:06.696 warn (4995) Cannot initialize getImage: Error: Cannot find module 'sharp'"
        wieder mal dieser sharp den ich nicht habe...
        und beim iot.adapter kommt kein update bei LastFunktion; last controlled function, was schon weniger nice ist...
        testen muss ich morgen gehe pennen
        • S SolarGuido
          @Thomas-Braun
          lattform: linux
          CPUs: 4
          RAM: 1.9 GB
          Node.js: v12.16.2
          NPM: 6.14.4
          Adapter-Anzahl: 345
          Aktive Instanzen: 4
          Thomas BraunT
          Thomas BraunT
          #407
          @SolarGuido
          Ich würde da dringend die ganzen Repos rauswerfen die nicht zu stretch passen. Gerade webmin kann dir grundlegende Pakete zerbröseln. Hat seinen Grund, dass z. B ubuntu webmin bei sich rausgeworfen hat.
            @SolarGuido
            S
            S
            SolarGuido
            #408
            @Thomas-Braun
            ok danke für den tip, verstehe auch nicht warum da sarge drin ist...
            habe es gerade mal nach geuckt die unterscheiden wohl nicht nach irgend einer debian version. Webmin bietet nur das eine an. Es gibt auch nur eine version für alle debian vesionen. Scheint also ok zu sei läuft auch schon seit 2 Jahren ohne probleme.
            ja ich arbeitet auch mit putty , aber ich mag webmin trotzdem für einige Dinge sehr komfortable
            • S
              S
              SolarGuido
              #409
              Es läuft alles jetzt. Der IOT Adapter macht irgendwie nix mehr in
              lastCommand
              state
              Last command
              lastFunction
              state
              Last controlled function
              state
              lastResponse
              state
              Last textual response
              state
              hab jetzt meine betroffenen Scripte auf Alexa History umgestellt. Das hat wohl auch nix mit nodejs zu tun. Ich hab den iot mal downgrade gemacht bis 3er version, hilft nix. denke das ist ein grundsätzliches problem.
              Anonsten scheint alles zu laufen, hab mal das log gecheckt und einiges getestet. bisher nix negativ aufgefallen.
              Ich gaube auch der Weg neue Installation iobroker, danach den data ordner austauschen , dann neu starten und warten, ist am saubersten.
              Jedenfalls Danke für die unterstützung
              • H
                H
                Hc-Yami
                #410
                Die Anleitung oben sucht noch nach node.js Versionen 10. Das müsste noch auf 12. geändert werden da der Info Adapter ja nun eine 12er Version empfiehlt. :)
                • H Hc-Yami
                  #411
                  @Hc-Yami dann musst du nur die 10.x gegen eine 12.x und irgendwann gegen eine 14.x austauschen.
                  Das war zum Erstellungsdatum des Posts eben die 10.x
                  H 1 Antwort Letzte Antwort
                    H
                    H
                    Hc-Yami
                    #412
                    @Homoran hey das weiß ich. Nur kann ich mir vorstellen, dass es Leute wie mich gibt die einfach Googlen "iobroker node.js update" dann den Thread finden und die Anleitung durchgehen. Es wäre ja dann cool wenn das dann auch wieder angepasst wird. Demnach denke ich es ist sinnvoll den Post anzupassen. :)
                    • StabilostickS Stabilostick
                      MOD-EDIT: Dieser Thread und insbesondere diese Anleitung ist von 2019 und somit veraltet
                      aktuell ist
                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                      Update März 2023: Die aktuelle Anleitung findet ihr hier : https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18
                      1. Einleitung
                      Node.js ist die Laufzeitumgebung der Programmiersprache JavaScript, in der ioBroker geschrieben ist. Ohne Node.js funktioniert ioBroker nicht.
                      Wie bei vielen Open-Source-Technologien üblich, entwickelt sich Node.js schnell weiter. Kleinere Updates, die die Stabilität und Sicherheit steigern oder gar neue Funktionen hinzufügen, erscheinen fast wöchentlich.
                      Node.js-Versionen mit gerader Hauptversionsnummer werden als LTS-Versionen (Long Term Support) bezeichnet und einige Jahre gepflegt (z.B. 8.x). In 2017 war das Node.js 8, 2018 kam Node.js 10, dann 12.x hinzu und im Oktober 2021 wird Node.js 14 den LTS-Status erhalten.
                      Im gleichem Zug erreichen frühere LTS-Versionen ihr Lebensende (EOL, End of Life). So hat Node.js 6 im April 2019 den EOL-Status erhalten und bekommt damit keine Updates mehr, Nodejs 8.x ist seit November 2019 raus.
                      Alle Node.js-Versionen mit ungeraden Versionsnummern sind Entwicklungsversionen und sollten nicht produktiv genutzt werden.
                      Auch ioBroker wird stetig weiterentwickelt und nutzt die neuen Funktionen aktueller Node.js-Versionen. Obwohl der ioBroker js-controller mit Versionen 1.4.x bzw. 1.5.x noch Node.js 4 unterstützt, fordern neue Adapter immer häufiger mindestens Node.js 8 als Grundvoraussetzung.
                      Ab der Version 2.0 des js-controllers (das Freigabedatum ist noch nicht bekannt) sind die Anpassungen so tiefgreifend, dass die Node.js-Versionen 4 und 6 nicht mehr unterstützt werden können.
                      Ab Version 3.0/3.1 vom Controller, der gerade (Stand 24.4.2020) im Latest Repository ist, wird Nodejs 10.x Minimum sein.
                      Alle paar Jahre steht also für eine ioBroker-Installation ein Update von Node.js an. Dieser Artikel soll zusammenfassen wir man dazu am besten vorgeht.
                      2. Wer sollte updaten?
                      Aktuell empfehlen wir, bei ioBroker-Neuinstallationen mindestens Node.js 10, besser noch 12.x. zu verwenden. Es sind wenige Adapter bekannt, die nicht mit Node 10/12 funktionieren: Details dazu in https://forum.iobroker.net/topic/30561/status-iobroker-und-node-js-12-x
                      Windows-Anwendern empfehlen wir, auf jeden Fall am Test des neuen Windows-Installers teilzunehmen: https://forum.iobroker.net/post/266623
                      Der zukünftige Windows-Installer für ioBroker wird eine Funktion erhalten, bestehende Installationen automatisch auf aktuelle js-controller- und Node.js-Versionen zu migrieren, ohne dass man die Kommandozeile bemühen muss.
                      Bevor man beginnt, sollte man in der Befehlszeile mit dem Befehl
                      node -v
                      überprüfen, welche Version von Node.js gerade installiert ist. Eine gute Idee ist es, diese Versionsangabe auch mit der Node.js-Version im Übersichts-Fenster des ioBroker-Admins für diesen Host zu vergleichen. Sollten sich die Versionen unterscheiden, sind mehrere Node.js-Varianten installiert, was zu Problemen führen kann.
                      Grundsätzlich gilt: Sollte das ioBroker-System stabil laufen, muss Node.js auch nicht auf Gedeih und Verderb upgedated werden. Wenn aber die Installation bestimmter Adapter fehlschlägt (wohlmöglich sogar mit entsprechender Fehlermeldung) oder eine Node-Version < 4 für einen js-controller > Version 1.4.x eingesetzt wird, sollte über ein Node.js-Update nachgedacht werden. Es sind auch Probleme für die Node.js-Versionen 8.0 - 8.12 mit volllaufendem RAM bekannt, so dass wir auch hier ein Update empfehlen.
                      Wie bereits gesagt: Sollte das ioBroker-System stabil laufen und ist die Installation technisch nicht gefordert, muss Node.js auch nicht auf Gedeih und Verderb upgedated werden.
                      3. Was sollte ich vor dem Update tun?
                      Hinweis: Falls die Version des js-controllers <= 1.5.12 ist, muss VOR dem Update in den Einstellungen der Admin-Instanz "Verschlüsselung (https) benutzen" ausgeschaltet werden. Das in ioBroker bis dahin integrierte Zertifikat kann zu Problemen beim Starten des Admin bei Node.js-Versionen >= 10 führen.
                      Damit es nach dem Update zu keinen Inkompatibilitäten oder Probleme kommt sollte man alle Adapter prüfen und aktualisieren. Vor allem Adapter mit nativen Bestandteilen, wie alles mit Serialport oder Bluetooth können Probleme bereiten. Hier am besten die Adapter-Readme's per Admin oder im GitHub prüfen, ob neue Versionen zur Verfügung stehen die die geplante Node.js Version explizit erst unterstützen. Auch wenn diese Versionen ggf. noch im "Latest" Repository sind muss man diese vorher aktualisieren. Alternativ wartet man mit der ganzen Update-Aktion bis die neuen Versionen im "Stable" Repository sind, schreibt den Entwickler dazu an oder fragt im Forum nach.
                      Wenn man diesen Schritt nicht durchführt kann es zu unnötigen Problemen beim update der Adapter kommen!
                      4. Step-by-step-Anleitung für Unix-Systeme
                      • Zuerst muss natürlich unbedingt ein Backup erstellt werden. Dazu kann z.B. der BackItUp-Adapter genutzt oder der Kommandozeilenbefehl
                        cd /opt/iobroker
                        iobroker backup
                        ausgeführt werden. Das Backup sollte aktuell sein, damit möglichst keine Daten verloren gehen.
                      • Anschließend ioBroker stoppen, damit Updates keine Nebeneffekte oder Abstürze verursachen.
                        iobroker stop
                        Bitte anschließend im Webbrowser prüfen, dass der ioBroker-Admin danach wirklich nicht mehr startet. Sollte er weiterhin aufrufbar sein, dann den Rechner neu starten und nochmals „iobroker stop“ ausführen und erneut testen. Für die Techniker unter uns: Man kann auch mit einem Tool wie "top" prüfen, ob noch Prozesse existieren, die mit "io." beginnen. Die dann mit einem beherzten "sudo kill -9 <ProzessID>" zwangsbeenden.
                      • Jetzt aktualisiert man Node.js auf die gewünschte neue Version.
                        Unter Linux reicht es, dazu den Nodesource-Installationsbefehl für das jeweilige Betriebssystem auszuführen. Verschiedene Varianten sind unter https://github.com/nodesource/distributions#debinstall gelistet.
                        Zum Beispiel lauten die Befehle für einen Raspberry Pi der ein Debian bzw. Raspbian-Image verwendet wie folgt, wenn man nicht als root-User (z.B. richtig mit dem User "pi") angemeldet ist:
                        curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                      Für nodejs 12 einfach in der URL oben anstelle der 10 eine 12 reinpacken.
                      Für macOS gibt einen Installer auf https://nodejs.org/en/download/ , den man einfach ausführt.
                      Ob die Aktualisierung geklappt hat, kann man wieder mit dem Befehl
                      node -v
                      überprüfen.
                      • Da die Installation von Node.js einige Einstellungen am System verändert haben kann, ist es jetzt ratsam, den ioBroker-Installationsfixer aufzurufen. Das geschieht mit dem Befehl
                        curl -sL https://iobroker.net/fix.sh | bash -
                        Er stellt unter anderem die für den Betrieb von ioBroker notwendigen Sicherheitseinstellungen wieder her.
                      • Bei einer Aktualisierung von Node.js müssen bereits installierte JavaScript- Module im ioBroker-Ordner aktualisiert werden, da sonst Fehler bei deren Ausführung auftreten.
                        Um diese zu aktualisieren gibt es mehrere Möglichkeiten:
                        a) ab js-controller 3.0: Automatischer Rebuild
                        ioBroker versucht seit dem js-controller 3.0 automatisch Adapter zu erkennen die nicht starten weil Sie aktualisiert werden müssen. Dies funktioniert so das die typischen Fehlermeldungen erkannt werden und ioBroker dann die Aktualisierung versucht. Zuerst wird ein "rebuild" des betroffenen Adapters ausgeführt, falls das nicht hilft werden die Adapter-Abhängigkeiten aktualisiert. Daher kann es sein das der Adapter mehrfach ersucht wird neu zu starten. Hier bitte Geduld haben!
                        Bei einigen Adaptern (zB iot die optionale native Abhängigkeiten haben) funktioniert die automatische Erkennung nicht und das rebuild muss manuell angestoßen werden. Hier zu gibt es iobroker rebuild adaptername und falls das nicht reicht iobroker rebuild adaptername --install. Das einfach manuell ausführen. Damit sollte alles idealerweise automatisiert erledigt sein. Falls hie rirgendetwas gar nicht geht dann helfen die weiteren Optionen.
                        b) npm rebuild
                        Der erste Versuch sollte immer mit dem Befehl "npm rebuild" im ioBroker Verzeichnis stattfinden, weil dies am saubersten funktioniert und direkt von der Paketverwaltung ausgeführt wird. Im Idealfall dauert das ein paar Minuten und es könnten ein paar Warnungen gelistet werden.
                        Falls es aber Fehler gibt, werden wir zusammen versuchen im nächsten Post alle bekannten Fälle mit Ihren Lösungsansätzen zu sammeln. Wenn das funktioniert ist dies der schnellste und sauberste Weg.
                        c) reinstall-Skript
                        Sollte das nicht klappen, beinhaltet der js-Controller ein reinstall-Skript ("reinstall.sh" bzw. ab js-controller 1.5.x "reinstall.js"). Dieses Skript erkennt alle installierten ioBroker-Adapter, löscht diese dann aus dem node_modules-Verzeichnis und installiert sie neu. Dieser Ansatz ist etwas aufwändiger als "npm rebuild", erfüllt aber den gleichen Zweck. Das funktioniert generell gut, man sollte den Prozess aber nicht abbrechen. Falls es doch passiert oder es Probleme beim Starten nach dieser Prozedur gibt, dann am besten den Weg im nächsten Punkt wählen.
                        Das reinstall.sh-Skript welches im js-controller 1.4 mitgeliefert wurde hat ein Formatierungsproblem und muss vorher noch für Linux mit den Befehlen
                        cd /opt/iobroker
                        sudo mv reinstall.sh reinstall.dos
                        sudo tr -d '\r' < reinstall.dos > reinstall.sh
                        sudo chmod +x reinstall.sh
                        korrigiert werden, damit es funktioniert.
                        d) Reset aller Module in node_modules
                        Eine weitere Variante, die gründlich ist, aber etwas Zeit kostet, ist der Ansatz einfach alles Alte unter Beibehaltung der Daten und Einstellungen neu zu installieren. Wichtig ist, das iobroker-data Verzeichnis nicht zu verändern. Häufig können mit dieser Vorgehensweise auch andere (verborgene) Installationsfehler repariert werden.
                        Dazu löscht man zuerst das gesamte node_modules Verzeichnis im ioBroker-Verzeichnis.
                        cd /opt/iobroker
                        sudo rm -r node_modules/
                        Nachdem der Befehl abgesetzt wurde, fragt das Programm, ob in den Ordner "hinabgestiegen" werden soll (sofern es ein tieferer Unterordner ist) und ob der (schreibgeschützte) Ordner wirklich gelöscht werden soll - beides bestätigt man mit "Ja" (j) oder "Yes" (y).
                        Danach installiert man den Controller in der relevanten Version (hier z.B. 2.2.8 der zum Zeitpunkt des Schreibens die aktuelle "Stable"-Version ist):
                        npm install iobroker.js-controller@2.2.8 --production
                        Anschließend startet man ioBroker.
                        iobroker start
                        ioBroker wird korrekterweise feststellen, dass die Adapter, die er starten will, nicht installiert sind - und diese einfach automatisch nachinstallieren. Je nach System kann dies einige Zeit dauern - gern auch ein paar Stunden (oder bei langsamen SD-Karten die ganze Nacht). Aber danach ist alles aktualisiert. Der Installationsfortschritt ist im Admin im Log-Fenster zu sehen.
                        Zu beachten ist, dass Adapter, die man manuell von GitHub installiert hat, den Fehler Can not parse null/io-package.json:Error: ENOENT: no suche file or directory ... im ioBroker-Log erzeugen.
                        Diese Adapter nach Abschluss der automatischen Installationssequenz wie gehabt über das Adapterfenster manuell von GitHub nachinstallieren und nach der Installation die bestehende diesbezügliche Instanz von Hand starten.
                        Ratsam ist es auch, im Log nach der Installation nach dem Wort yourself zu suchen. Hier werden ggf. npm-Module angezeigt, die nicht automatisch installiert wurden. Sie können/sollten manuell über die Kommandozeile mit npm i <Packetname>@<version>, ausgeführt im iobroker-Ordner, nachinstalliert werden. Dazu zuerst den ioBroker stoppen, npm ausführen und dann den ioBroker wieder starten.
                        Wenn man dabei npm als root-User per Hand in der Kommandozeile ausgeführt hat, schlage ich zur Korrektur eventueller Berechtigungsfehler vor, vor dem Start von ioBroker das Fixerscript laufen zu lassen.
                        cd /opt/iobroker
                        iobroker stop
                        iobroker start
                        e) Neuinstallation mit Restore
                        Eine kleine Abwandlung der letzten Variante ist eine Neuinstallation. Hierbei sichert man das "iobroker-data" Verzeichnis (oder nutzt das Backup von oben). Dann löscht man das gesamte ioBroker-Verzeichnis und nutzt den Installer.
                        cp -r /opt/iobroker/iobroker-data <Pfad_zum_sicheren_Ort>
                        sudo rm -r /opt/iobroker/
                        sudo mkdir /opt/iobroker
                        cd /opt/iobroker
                        curl -sL https://iobroker.net/install.sh | bash -
                        Direkt danach stoppt man ioBroker wieder (der ja nach der Installation automatisch gestartet wird).
                        iobroker stop
                        Dann löscht man den neu erstellen „iobroker-data“- Ordner und kopiert anschließend das gesicherte alte „iobroker-data“-Verzeichnis mit den darin enthaltenen Datenbanken und Dateien dorthin zurück.
                        rm -r /opt/iobroker/iobroker-data
                        cp -r <Pfad_zum_sicheren_Ort> /opt/iobroker/iobroker-data
                      5. Zu guter Letzt
                      Bitte gebt euer Feedback, was bei euch wie gut funktioniert, was ihr immer nutzt und was die Probleme und eure Lösungen sind.
                      Viele Grüße,
                      stabilostick
                      #413
                      @Hc-Yami sagte in [How-to] Node.js für ioBroker richtig updaten:
                      Vielleicht wird es nicht ganz so deutlich, wie beabsichtigt. Aber die weiter fortgesetze Timeline wird schon besprochen
                      @Stabilostick sagte in [How-to] Node.js für ioBroker richtig updaten:
                      Node.js-Versionen mit gerader Hauptversionsnummer werden als LTS-Versionen (Long Term Support) bezeichnet und einige Jahre gepflegt (z.B. 8.x). In 2017 war das Node.js 8, 2018 kam Node.js 10 hinzu und im Oktober 2019 wird Node.js 12 den LTS-Status erhalten.
                      mindestens Node.js 10. zu verwenden.
                      • MichiganM
                        MichiganM
                        Michigan
                        #414
                        Moin, ich hoffe ich bin hier richtig
                        seit dem ich eben node.js auf 12.x und aktualisiert habe kommt wenn ich ein Adapter aktualisieren möchte diese Meldung.
                        Beispiel am Ping Adapter:
                        $ ./iobroker upgrade history
                        Update history from @1.9.3 to @1.9.4
                        NPM version: 6.14.4
                        npm install iobroker.history@1.9.4 --loglevel error --prefix "/opt/iobroker" (System call)
                        ╭─────────────────────────────────────────────────────────╮│                                                         ││ Manual installation of ioBroker is no longer supported  ││ on Linux, OSX and FreeBSD!                              ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation  ││                                                         │╰─────────────────────────────────────────────────────────╯
                        npm ERR! code ELIFECYCLEnpm ERR! errno 100npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`npm ERR! Exit status 100npm ERR! npm ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-24T11_19_06_212Z-debug.log
                        ERROR: host.raspberrypi Cannot install iobroker.history@1.9.4: 100
                        Nodes zeigt er mir mit v12.16.2 aktuell an
                        wo hab ich den Fehler gemacht? 🙄
                        es Läuft alles auf ein PI 3
                        mfg
                        Michiagn
                        • S
                          S
                          strago
                          #415
                          Hallo Zusammen,
                          Nach dem Update auf node.js 12.x auf meinem Slave (Raspberry pi 3) funktioniert leider der i2c adapter nicht mehr.
                          folgende Fehlermeldung kommt:
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.981	error	instance system.adapter.i2c.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.981	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.981	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.980	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.980	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:28)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.979	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.979	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.978	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.978	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.978	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.977	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.977	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.976	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.976	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.975	error	Caught by controller[0]: was compiled against a different Node.js version using
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.975	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.974	error	Caught by controller[0]: ^
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.974	error	Caught by controller[0]: throw e
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:03:47.973	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
                          bzw. bei der erneuten Installation des Adapters kommen folgende Fehler:
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:04.917	error	iobroker host.raspberrypi-Erdgeschoss Cannot install iobroker.i2c: 1
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:04.891	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-04-24T11_09_04_808Z-debug.log
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:04.797	info	iobroker ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:04.794	info	iobroker ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:04.792	info	iobroker npm
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.624	info	iobroker gyp ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.621	info	iobroker stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:310:20)gyp ERR! stack at Process.
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.619	info	iobroker ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR!
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.616	info	iobroker gyp
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.614	info	iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Error 1
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.172	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no mat
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.168	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no ma
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.162	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: err
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.156	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: err
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.147	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no ma
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.142	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no ma
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.134	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matchi
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.130	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no match
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.125	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matchi
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.120	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no match
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.115	info	iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching fun
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.110	info	iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching fu
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.104	info	iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.100	info	iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.094	info	iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.091	info	iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.083	info	iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error:
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.078	info	iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error:
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.069	info	iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matchin
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.065	info	iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matchi
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.058	info	iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.054	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: not
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.051	info	iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.044	info	iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.041	info	iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.034	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: not
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.029	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: not
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.026	info	iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:02.014	info	iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:43: warning: cast between incompatible function types from
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.976	info	iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node_object_wrap.h:26, from ../node_modules/nan/n
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.973	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27, f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.970	info	iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.965	info	iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node_object_wrap.h:26, from ../node_modules/nan/n
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.913	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompati
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.901	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:../node_modu
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.893	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.890	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27, f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.888	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:../node_modules/nan/nan
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.881	info	iobroker In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.878	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.868	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.865	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:../node_modules/nan/nan.h:916:53: error: no matching functi
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.861	info	iobroker In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.858	info	iobroker In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.855	info	iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.812	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:5531:23: not
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.809	info	iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.792	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:4275:31: not
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.789	info	iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.766	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27, f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.763	info	iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_i
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.752	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27, f
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:09:01.750	info	iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_i
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:08:25.873	info	iobroker npm install iobroker.i2c --loglevel error --prefix "/opt/iobroker" (System call)
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:08:25.870	info	iobroker NPM version: 6.14.4
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:08:25.040	info	iobroker install iobroker.i2c
                          host.raspberrypi-Erdgeschoss	2020-04-24 13:08:22.963	info	iobroker url "iobroker.i2c"
                          Mit node.js 10.20.1 läuft der Adapter noch.
                          Der Entwickler @UncleSam ist aktuell leider nicht wirklich erreichbar.
                          Anpassungen am Adapter kann ich leider nicht vornehmen.
                          Vielleicht hat jemand einen Tipp.
                          Danke!
                          sg
                          Strago
                            #416
                            Muss ich was tun bei der Fehlermeldung:
                            020-04-24 16:49:17.704	warn	the module (for instance, using `npm rebuild` or `npm install`).
                            iot.0	2020-04-24 16:49:17.704	warn	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            iot.0	2020-04-24 16:49:17.704	warn	NODE_MODULE_VERSION 64. This version of Node.js requires
                            iot.0	2020-04-24 16:49:17.704	warn	was compiled against a different Node.js version using
                            iot.0	2020-04-24 16:49:17.704	warn	(8213) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node
                            npm rebuild nach dem Update auf Version 12 hab ich gemacht.
                              GlasfaserG
                              GlasfaserG
                              #417
                              @Brainbug sagte in [How-to] Node.js für ioBroker richtig updaten:
                              (for instance, using npm rebuild or npm install).
                              Steht dort !
                                #418
                                Ja hab ich vergessen zu schreiben dass ich das auch gemacht habe im iobroker Verzeichnis.
                                Hab ein zweites mal npm rebuild gemacht und jetzt ist es anscheinend weg.
                                • MathiasJM
                                  MathiasJM
                                  MathiasJ
                                  #419
                                  IObroker auf einer frischen SD neu aufgesetzt.
                                  Ich habe absichtlich neu augfesetzt, damit ich zurück zu Node10.x kann, sollte Radar nicht laufen.
                                  Aber sogar Radar funktioniert mit Node 12.x.
                                  jetzt laufen alle Instanzen, die ich installiert habe unter Node 12.x und dem JS-Contoller 3.x
                                  IObroker auf dem NUC als VM.
                                  • N
                                    N
                                    Nas007
                                    #420
                                    Hallo ich hab das ganze nach Anleitung von 10.x auf 12.x upgedated. Dabei kamen folgende Fehler:
                                    Ich habe deb iobroker trotzdem gestartet und scheinbar funktioniert alles und die Version ist auch up to date.
                                    Was sagen diese Fehler oben aus?
                                    • G
                                      G
                                      G4l4h4d
                                      #421
                                      Bei mir läuft ioBroker auf einem Proxmox mit Ubuntu.
                                      Beim Update bekomme ich folgende Meldung.
                                      root@ioBroker:~# curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                                      + apt-get update
                                      Ign:1 http://archive.ubuntu.com/ubuntu disco InRelease
                                      Ign:2 http://archive.ubuntu.com/ubuntu disco-updates InRelease
                                      Hit:3 https://deb.nodesource.com/node_10.x disco InRelease
                                      Ign:4 http://archive.ubuntu.com/ubuntu disco-security InRelease
                                      Hit:5 https://repos.influxdata.com/debian disco InRelease
                                      Err:6 http://archive.ubuntu.com/ubuntu disco Release
                                        404  Not Found [IP: 91.189.88.142 80]
                                      Err:7 http://archive.ubuntu.com/ubuntu disco-updates Release
                                      Err:8 http://archive.ubuntu.com/ubuntu disco-security Release
                                      Reading package lists... Done
                                      E: The repository 'http://archive.ubuntu.com/ubuntu disco Release' no longer has a Release file.
                                      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                      N: See apt-secure(8) manpage for repository creation and user configuration details.
                                      E: The repository 'http://archive.ubuntu.com/ubuntu disco-updates Release' no longer has a Release file.
                                      E: The repository 'http://archive.ubuntu.com/ubuntu disco-security Release' no longer has a Release file.
                                      Error executing command, exiting
                                      Wenn ich mit Node-v die Version prüfe, steht immer noch die 10.... drin.
                                      Kann mich jemand unterstützen?
                                      apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                                      • N Nas007
                                        apollon77A
                                        apollon77A
                                        #422
                                        @Nas007 auf manchen Systemen meckern optionale Pakete beim bauen. Alles ok.
                                        N 1 Antwort Letzte Antwort
                                        • G G4l4h4d
                                          + apt-get update
                                          apollon77A
                                          apollon77A
                                          #423
                                          @G4l4h4d Ubuntu 19.04 ist keine LTS Version und damit ist der Support ausgelaufen Siehe https://wiki.ubuntuusers.de/Disco_Dingo/
                                          Solltest auf 20.04 gehen.
                                          Bei Ubuntu immer die LTS Versionen nehmen 18.04, 20.04 uä. Bei den anderen muss man alle halbe Jahr das os updaten.
                                          33.2k
                                          84.4k
