  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 499.1k Aufrufe 94 Beobachtet
    für die, die es verwenden, habe die Ansicht Tageswerte für Deutschland und Global angepasst
    für Deutschland
     "datasource": "InfluxDB-corona",
     "aliasColors": {
       "Genesen": "dark-green",
       "Kritisch": "dark-purple",
       "Sterbefälle": "dark-red",
       "aktiv": "dark-orange",
       "infiziert": "dark-blue"
     "bars": true,
     "dashLength": 10,
     "dashes": false,
     "fill": 1,
     "fillGradient": 0,
     "gridPos": {
       "h": 6,
       "w": 12,
       "x": 0,
       "y": 13
     "hiddenSeries": false,
     "id": 26,
     "legend": {
       "avg": false,
       "current": true,
       "hideEmpty": false,
       "hideZero": false,
       "max": false,
       "min": false,
       "show": true,
       "total": false,
       "values": true
     "lines": false,
     "linewidth": 1,
     "nullPointMode": "null",
     "options": {
       "dataLinks": []
     "percentage": false,
     "pointradius": 2,
     "points": false,
     "renderer": "flot",
     "seriesOverrides": [
         "alias": "Sterbefälle"
         "alias": "Kritisch"
         "alias": "aktiv"
         "alias": "infiziert"
         "alias": "Genesen"
     "spaceLength": 10,
     "stack": true,
     "steppedLine": false,
     "targets": [
         "alias": "Kritisch",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "orderByTime": "ASC",
         "policy": "default",
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "D",
         "resultFormat": "time_series",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "infiziert",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "A",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "aktiv",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "B",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Sterbefälle",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "C",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Genesen",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "E",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
     "thresholds": [],
     "timeFrom": "7d",
     "timeRegions": [],
     "timeShift": null,
     "title": "Tageswerte Deutschland",
     "tooltip": {
       "shared": true,
       "sort": 0,
       "value_type": "individual"
     "transparent": true,
     "type": "graph",
     "xaxis": {
       "buckets": null,
       "mode": "time",
       "name": null,
       "show": true,
       "values": []
     "yaxes": [
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
     "yaxis": {
       "align": false,
       "alignLevel": null
    für Global
     "aliasColors": {
     "bars": true,
     "dashLength": 10,
     "dashes": false,
     "fill": 1,
     "fillGradient": 0,
     "gridPos": {
       "h": 6,
       "w": 12,
       "x": 0,
       "y": 19
     "id": 27,
     "legend": {
       "avg": false,
       "current": true,
       "hideEmpty": false,
       "hideZero": false,
       "max": false,
       "min": false,
       "show": true,
       "total": false,
       "values": true,
       "alignAsTable": false
     "lines": false,
     "linewidth": 1,
     "options": {
       "dataLinks": []
     "pointradius": 2,
     "points": false,
     "renderer": "flot",
         "alias": "Kritisch"
         "alias": "aktiv"
         "alias": "Genesen"
     "spaceLength": 10,
     "stack": true,
     "targets": [
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "D",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "A",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "aktiv",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "B",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "C",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Genesen",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "E",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
     "thresholds": [],
     "timeFrom": "7d",
     "timeRegions": [],
     "timeShift": null,
     "title": "Tageswerte Global",
     "tooltip": {
       "shared": true,
       "sort": 0,
     "type": "graph",
     "xaxis": {
       "buckets": null,
       "mode": "time",
       "name": null,
       "show": true,
       "values": []
     "yaxes": [
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
     "yaxis": {
       "align": false,
       "alignLevel": null
    ChaotC Offline
    ChaotC Offline
    Chaot
    #519
    @crunchip
    Die Formel für die Tageswerte scheint nur zu funktionieren wenn die Werte bei 0 starten.
    Ist für mich jetzt nicht wichtig, aber zur allgemeinen Info.
    • ChaotC Chaot
      @crunchip
      crunchipC Abwesend
      crunchipC Abwesend
      #520
      @Chaot wenn ich die Zahlen mit meinem Vergleiche, sind die geringfügig anders als deine
      als Beispiel, deine Sterberate bei Tageswerte liegt bei 154, rechts im Graphen hast du nen wert von 134
        ChaotC Offline
        ChaotC Offline
        Chaot
        #521
        @crunchip Ach ja. Der Fehler sitzt vorm Monitor. Sorry. Wer lesen kann....🤦
          Semenchkare
          #522
          mittlerweile funktionieren die Datenpunkte der Kreise, der Abgleich mit dem RKI passt, auch wenn die Hacken im Einstellungsmenü nicht bei den entsprechenden Kreisen/Länder erscheinen.
          Die Zahlen des RKi sind aber deutlich von denen unseres Landratsamtes unterschieden, ich habe das Tagelang verfolgt. RKI 318 Fälle, Ortenaukreis 483 Fälle, da liegen mindestens 3 Tage Versatz drin.
          Leider veröffentlicht unser Landrkeis die Zahlen immer nur als PDF Link.
          Ein weiteres Thema, ich möchte gerne die Widgets probieren. Da Fällt mir auf, das nur im Firefox das "Hauseigene" widget überhaupt erscheint und ich es dann in einen View bekomme, allerdings Auswahl nur länder. Rufe ich den Vis editor oder den View im Chrome auf ->werden nicht angezeigt.
          Leider kann ich keiner der hier gezeigten Widgets importieren, denn nach Import wird nichts angezeigt...
          Ich habe den SQL-Adapter im Einsatz mit anderen Datenpunkten, ich logge mittlerweise den Kreis, das Bundesland und 4 Länder mit. Evtl. versuche ich am nächsten Corona-Wochenende mal ein Flot-Diagramm hinzubekommen...
          Viele Grüße
          Semenchkare
          raspberry 5 8GB mit iobroker,
          raspberry 5 8GB mit Raspberrymatic
          sissiwupS 1 Antwort Letzte Antwort
          • S Semenchkare
            sissiwupS Offline
            sissiwupS Offline
            sissiwup
            #523
            @Semenchkare sagte in Test Coronavirus Statistics for ioBroker:
            ja, leider sind einige Kreise bei der Meldung an das RKI sehr langsam.
            Das sieht man gut auf den RKI-Charts, wenn dort viele "orange" Balken
            auftauchen, dann hängt die Meldung der Kreise zeitlich hinterher.
            Das sind die gemeldeten Werte ...
            MfG
            Sissi
            1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
            • jackblacksonJ Offline
              jackblackson
              schrieb am zuletzt editiert von jackblackson
              #524
              Hat jemand eine Idee, wieso das Widget plötzlich unsichtbar ist? Alle Länder-Widgets sind unsichtbar, die Welt ist noch sichtbar. Schon versucht: Neustart vis, neustart corona-adapter, upload von beidem, neustart ioBroker..bleibt leer. Wenn ich von Deutschland auf Welt wechsle, kommt wieder was. War Version 0.4.9, seit heute Morgen ist es leer, hab grad noch das Update auf 0.5.1 gemacht, leider immer noch..ist nicht nur im Editor, sondern auch in der normalen Ansicht leer.
              • jackblacksonJ jackblackson
                sigi234S Online
                sigi234S Online
                #525
                @jackblackson
                Kann ich bestätigen, muss sich @Dutchman ansehen.
                • sigi234S sigi234
                  @jackblackson
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #526
                  @sigi234 countries api funktioniert nicht
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    #527
                    Widget funktioniert wieder
                    jackblacksonJ 1 Antwort Letzte Antwort
                      jackblackson
                      #528
                      @crunchip Perfekt, geht bei mir auch. D.h. im Widget nimmt er nicht die Objekte, sondern ruft direkt die Daten ab?
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #529
                        @jackblackson sagte in Test Coronavirus Statistics for ioBroker:
                        jup, @Bluefox war so net die ein zu bauen
                        kenne mich mit frontend nicht aus wen jemand die. auf di states umbiegen koennte wahre das praktisch
                          Kampfratte
                          #530
                          Jo, die scheinen heute an der API herumgebastelt zu haben. Hatte in den Top 5 auch "World" drin. Also die Zahlen der ganzen Welt auf Platz 1 und USA dann erst auf Platz 2. Ist aber dann wieder raus genommen worden.
                          • K Kampfratte
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #531
                            @Kampfratte sagte in Test Coronavirus Statistics for ioBroker:
                            Jup und danke für den PR aber was n api Fehler ☺️
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #532
                              Version 0.5.4 released :
                              • DutchmanD Dutchman
                                jackblackson
                                #533
                                @Dutchman Das mit den Tests ist cool. Aber die Zahl ist noch 0, auch auf deren Website, ich vermute mal, da sind sie erst noch am Einarbeiten, oder?
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #534
                                  Bei mir ist da nix 0 ?
                                    jackblackson
                                    #535
                                    @Dutchman So sieht es bei mir aus, hab den Adapter grad extra nochmal neu gestartet:
                                    DutchmanD crunchipC 2 Antworten Letzte Antwort
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #536
                                      ah check, global totals und nicht die pro land.... ja der wert ist noch lehr in der API
                                      https://corona.lmao.ninja/all
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #537
                                        @jackblackson bei coronavirus-statistics.0.global_continents.World_Sum.testsPerOneMillion wirst du fündig
                                        • frankjokeF Offline
                                          frankjokeF Offline
                                          frankjoke
                                          #538
                                          Übrigens,
                                          habe auf https://forum.iobroker.net/topic/31782/corona-daten-nach-mysql-importieren/16 gepostet dass ich eine kleine WebApp für Corona-Datenvenanalyse und Vergleich gemacht habe: https://frankjoke.github.io/coronafj/
                                          Frank,
                                          NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                                          Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                                          DutchmanD M 2 Antworten Letzte Antwort
