  4. Z-Wave Adapter
Z-Wave Adapter
110 Beiträge 13 Kommentatoren 35.3k Aufrufe
  • Lenny.CBL Offline
    Lenny.CBL Offline
    Lenny.CB
    #79
    @versteckt:
    Hallo, hab in GitHub eine neue main.js hochgeladen.
    Bitte nur diese austauschen und neustarten, ansonsten müsstest du alles nochmals installieren.
    LG Christian `
    getan… jetzt keine "roten" Log-Eiträge mehr...
    is es egal welche node-Version ich habe? zurzeit ist 0.12.6 installiert...
     Zeit
    Nachricht
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE9.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE8.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE7.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE6.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE5.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE4.ready' not found for stateChange
    zwave-0	2016-03-25 19:34:28	info	Scan completed
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:9 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:8 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:7 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:6 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:5 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWPE Wall Plug","producttype":"0x0600","productid":"0x1000","type":"Binary Switch","name":"","loc":"
    zwave-0	2016-03-25 19:34:28	info	node ready nodeid:4 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
    zwave-0	2016-03-25 19:34:27	info	node9: timeout, currently not implemented
    zwave-0	2016-03-25 19:34:17	info	node9: timeout, currently not implemented
    zwave-0	2016-03-25 19:34:05	info	node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
    zwave-0	2016-03-25 19:33:59	info	node9: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	node8: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	node7: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	node6: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	node5: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	node4: nop, currently not implemented
    zwave-0	2016-03-25 19:33:59	info	nodeid 9 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:59	info	nodeid 8 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:59	info	nodeid 7 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:58	info	nodeid 6 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:58	info	nodeid 5 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:58	info	nodeid 4 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:58	info	nodeid 1 is now available, but maybe not ready
    zwave-0	2016-03-25 19:33:58	info	driver ready: homeid = f331c5f6
    zwave-0	2016-03-25 19:33:58	info	scanning homeid=0xf331c5f6...
    zwave-0	2016-03-25 19:33:58	info	connected: homeid = 1.4.0
    zwave-0	2016-03-25 19:33:56	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
    host-iobroker	2016-03-25 19:33:52	info	instance system.adapter.zwave.0 started with pid 2462
    host-iobroker	2016-03-25 19:33:52	info	object change system.adapter.zwave.0
    edit: die FIBAROS lassen sich über VIS ansteuern… :-)
    • V Offline
      V Offline
      versteckt
      #80
      Hallo, na das Log sieht ja schon mal gut aus.
      Ich arbeite mit 4.x habe aber auch mit 0.12 angefangen, sollte ansich kein Problem sein.
      Seit letztens sollte auch die 0.10er funktionieren, aber die ist offiziell nicht supported damit.
      Bitte ausgiebig testen und mir Bescheid geben.
      LG Christian
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • V Offline
        V Offline
        versteckt
        #81
        Achja, die "warn" und "info" Einträge sind im Moment nur noch zur Lesbarkeit drinnen, sind aber nicht
        als Fehlereinträge zusehen.
        • Lenny.CBL Offline
          Lenny.CBL Offline
          Lenny.CB
          #82
          @versteckt:
          LG Christian `
          jo, wie immer, Danke für die schnelle Hilfe…!
          Was hast du denn für ein BS? Wheezy, Jessie???
          Ich hatte in den lestzen Tagen echt viel probiert...
          Banana pro mit Jessie mit Node 4.4.0 --> nur Installationsfehler
          Banana pro mit Wheezy mit Node 4.4.0 --> nur Installationsfehler
          Banana pro mit Wheezy mit Node 0.10* --> Installation klappt auch ohne "-unsafe -perm" Zeugs
          Banana pro mit Wheezy mit Node 0.12* --> Installation klappt auch ohne "-unsafe -perm" Zeugs
          Dachte mir, "musste doch mal das System aktualisieren" bums, Ende...
          "never touch a running system!" ist wohl doch was dran an dem Spruch... :lol:
          • AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #83
            @versteckt:
            .) Statusmeldung des Adapters wie "alle Nodes fertig geladen", "Treiber/Controller fertig initialisiert"
            -> erledigt `
            Der Knaller, wird gleich ausprobiert!
            @versteckt:
            .) aktivieren/deaktivieren des inclusion/exclusion Modus der zwave-Platine
            -> Siehe hierzu https://github.com/OpenZWave/node-openz … ME-mgmt.md
            -> ...If your OZW version is 1.3 or greater, then there's a whole bunch of new calls, which effectively replace the old BeginControllerCommand. There's also no CancelControllerCommand thus you can't cancel any pending commands (they simply timeout)... `
            Der Link ist mir bekannt. Ich hatte eine Weile damit gespielt, selbst per Skript eine eigene Instanz des Treibers zu initialisieren, das hat mir aber üblicherweise nur den RasPi aufgehängt oder die ioBroker-Prozesse abgeschossen.
            Habe mir mal die neue main.js angeschaut. Sehe ich das richtig, dass ich nur den State "zwave.0.GLOBAL_ACTION" überschreiben muss, um die von mir gewünschte Funktionalität zu erreichen?
            Viele Grüße und danke für die superschnelle Reaktion!
            • V Offline
              V Offline
              versteckt
              #84
              Hallo, ja, kannst du normal überschreiben.
              Hab es noch nicht dokumentiert, aber grundsätzlich ist es möglich die Funktionen per Javascript Adapter auszuführen.
              Du musst nur die richtigen Parameter übergeben.
              Falls es nicht funktioniert, muss ich noch was anpassen.
              LG Christian
                AlCalzoneA Offline
                AlCalzone
                #85
                Hab es gerade mal ausprobiert, die .ready-States werden korrekt gesetzt.
                Die Fernsteuerung des Adapters funktioniert über das Setzen des States leider nicht, da ein State im "javascript.0"-Namespace erstellt wird, was im zwave-Adapter im falschen Codepfad landet. Außerdem ist der Wert des States "null" und nicht das Objekt, das ich übergebe:
                var stateName = "zwave.0.GLOBAL_ACTION";
                var newState = {action: "remove_device"};
                createState(stateName, newState, true);
                Im Prinzip möchte ich vom Skripting-Adapter aus in diesen Codepfad eingreifen:
                https://github.com/husky-koglhof/ioBrok … in.js#L173
                Edit: hab gerade deine Antwort gesehen, wie stelle ich das an, per JS die Funktionen auszuführen?
                • V Offline
                  V Offline
                  versteckt
                  #86
                  Ich schreib dir das morgen zusammen, heute bin ich schon weg vom Rechner.
                  LG Christian
                  • V Offline
                    V Offline
                    versteckt
                    #87
                    Guten Morgen!
                    Meine Mädels sind alle schon unterwegs, darum gibt es um die Uhrzeit schon ein Update:
                    In GitHub ist nun die Version 0.3.0 integriert.
                    Damit ist es nun möglich, direkt über Javascript / VIS / etc. eine Aktion an den zWave Adapter zu übermitteln.
                    Beispiel Javascript:
                    // Only for Documentation, all valid actions
                    var actions = ['reset', 'assign_return_route', 'delete_all_return_routes', 'create_primary', 'replace_failed_node', 'transfer_primary',
                                    'replication_send', 'add_button', 'remove_button', 'add_device', 'remove_device', 'receive_config', 'refresh_node', 'remove_failed_node',
                                    'has_node_failed', 'request_node_neighbor_update', 'assign_return_route', 'delete_all_return_routes', 'send_node_information',
                                    'request_network_update', 'refresh_device', 'healNetwork', 'updatenode', 'association', 'naming'];
                    // Nodeid is always needed, get it from e.g. input from vis
                    var nodeid = 10;
                    // Action is always needed, get it from e.g. listbox from vis
                    var action = 'naming';
                    // ButtonID is only needed for action = adddButton, removeButton
                    var buttonid = 1;
                    // Name and Location are needed only needed for action = naming
                    var deviceName = 'New Name of Device';
                    var deviceLocation = 'New Location of Device';
                    // Heal and Count are needed only needed for action = healNetwork
                    var heal = true;
                    var count = 5;
                    // Group and Nodes are needed only needed for action = association
                    var group = 'GROUP NAME FROM ASSOCIATIONS';
                    var nodes = [1,2,3];
                    buildAction(action, nodeid, undefined, undefined, deviceName, deviceLocation, undefined, undefined);
                    // Build correct Action
                    function buildAction(executeAction, nodeid, heal, count, device_name, device_location, groupid, nodes) {
                        switch (executeAction) {
                            case 'association':
                                submitAction(executeAction, nodeid, undefined, undefined, undefined, undefined, undefined, groupid, nodes);
                                break;
                            case 'updatenode':
                                submitAction(executeAction, nodeid);
                                break;
                            case 'heal':
                                submitAction(executeAction, nodeid, undefined, undefined, undefined, heal, count);
                                break;
                            case 'add_device':
                                submitAction(executeAction);
                                break;
                            case 'remove_device':
                                break;
                            case 'receive_config':
                                break;
                            case 'refresh_node':
                                break;
                            case 'remove_failed_node':
                                break;
                            case 'has_node_failed':
                                break;
                            case 'request_node_neighbor_update':
                                break;
                            case 'send_node_information':
                                break;
                            case 'request_network_update':
                                break;
                            case 'refresh_device':
                                break;
                            case 'naming':
                                submitAction(executeAction, nodeid, undefined, device_name, device_location);
                                break;
                            case 'reset':
                                break;
                            case 'assign_return_route':
                                break;
                            case 'delete_all_return_routes':
                                break;
                            case 'create_primary':
                                break;
                            case 'replace_failed_node':
                                break;
                            case 'transfer_primary':
                                break;
                            case 'replication_send':
                                break;
                            case 'add_button':
                                submitAction(executeAction, nodeid, buttonid);
                                break;
                            case 'remove_button':
                                break;
                            default:
                                break;
                    // Submit Action back to zWave Adapter
                    function submitAction(action, nodeid, buttonid, name, location, heal, count, group, nodes) {
                        if (nodeid !== undefined) {
                            if (buttonid !== undefined) {
                                setState('zwave.0.NODE' + nodeid + ".GLOBAL_ACTION", {
                                    val: {nodeid: nodeid, action: action, buttonid: buttonid},
                                    ack: true});
                            } else if (name !== undefined && location !== undefined) {
                                    val: {nodeid: nodeid, action: action, name: name, location: location},
                                    ack: true
                            } else if (heal !== undefined) {
                                setState('zwave.0.GLOBAL_ACTION', {
                                    val: {nodeid: nodeid, action: action, heal: heal, count: count},
                                    ack: true
                            } else if (group !== undefined) {
                                    val: {nodeid: nodeid, action: action, group: group, target_nodeid: nodes},
                                    ack: true
                            } else {
                                    val: {nodeid: nodeid, action: action},
                                    ack: true
                        } else {
                                val: {action:action},
                                ack: true
                    In diesem Beispiel wird der Name und die Location des Node 10 verändert.
                    Wenn man den Befehl "buildAction(…)" dementsprechend anders parametrisiert, dann natürlich auch andere Actions.
                    Man kann aber auch direkt in die Variable zwave.0.NODE<id>.GLOBAL_ACTION z.B.
                    {"val":{"nodeid":10,"action":"naming","name":"New Name of Device","location":"New Location of Device"}}
                    reinschreiben.
                    Ich bin grade am überlegen, ob ich mir damit nicht selbst ein vis Widget baue...
                    LG Christian</id>
                      AlCalzoneA Offline
                      AlCalzone
                      #88
                      Funktioniert einwandfrei!
                      Gibt es eigentlich eine Möglichkeit, den Adapter zu updaten ohne jedesmal openzwave neu zu kompilieren?
                      Okay, habe gerade nen kleinen Bug gefunden. Bei re-initialisieren des Adapters werden die GLOBAL_ACTION und ready states der einzelnen Nodes nicht gelöscht.
                      • V Offline
                        V Offline
                        versteckt
                        #89
                        Hallo, ja ist im Plan für die nächste Version.
                        Im Moment waren einfach immer Fehler drinnen, welche tlw. durch eine neue openzwave Version
                        behoben wurden.
                        • V Offline
                          V Offline
                          versteckt
                          #90
                          Hallo, ist in GitHub jetzt drinnen.
                          Es wurde die preinstall.js dementsprechend angepasst.
                          Wenn die beiden Dateien
                          /usr/local/lib/libopenzwave.so und
                          /usr/local/etc/openzwave/manufacturer_specific.xml
                          existieren, wird keine erneute openzwave Installation durchgeführt.
                          • Lenny.CBL Offline
                            Lenny.CBL Offline
                            Lenny.CB
                            #91
                            Hallo Christian,
                            die Version 0.3.0 ist jetzt auch bei mir drauf.
                            Installation lief ohne Fehler durch. Habe jetzt auch keine Fehler mehr im Log.
                            Nur eins wundert mich etwas. Was hat die zwave-Instanz mit der mit der rpc-Instanz zu tun?
                            Im Log habe ich Warnhinweise:
                            zwave.0	2016-03-27 10:36:32	warn	zwave.0 Object 'hm-rpc.1.CUX1200014.1.HUMIDITY' not found for stateChange
                            zwave-0	2016-03-27 10:36:30	warn	Object 'hm-rpc.1.CUX1200032.1.HUM_MAX_24H' not found for stateChange
                            Das betrifft meine CuxD-Geräte die offensichtlich durch den rpc-Adapter falsch erkannt werden. (es fehlen sämtliche Humidity-Kanäle)
                            Das war mal in einer früheren rpc-Version anders.
                            Grüße, Lenny
                            • V Offline
                              V Offline
                              versteckt
                              #92
                              Ist nur ein Logeintrag, weil alles State Changes überwacht werden.
                              Klarer Fall von, das muss noch raus.
                              Gesendet von meinem iPhone mit Tapatalk
                              • ruhr70R Offline
                                ruhr70R Offline
                                ruhr70
                                #93
                                Jetzt habe ich die letzten Stunden mit dem ZWave Adapter verbracht… Die Installation ist ein steiniger Weg ;-)
                                Ist... es ist noch nicht vorbei ;-)
                                Pi 3
                                Z-WAVE USB-Stick ZMEEUZB1 (ZME_UZB1)
                                Z-Wave Adapter 0.3.0
                                Fibaro Motion Sensor
                                Fibaro Wall Plug
                                Die Installation lief nicht auf Anhieb. Ich bekomme hie nicht mehr alles zusammen. Es war aber mehrmals Installation/Deinstallation angesagt. Beim letzte funktionierenden Versuch musste der Adapter ein zweites Mal gestartet werden, damit er läuft.
                                Aktueller Staus:
                                Adapter ist installiert und beendet sich erst einmal nciht mehr selbst (SIGTERM oder davor mit dem 103()).
                                Geräte sind erkannt. Der Motion Sensor sowohl auf der extra Admin Seite, als auch in den ioBroker Objekten. Der Wall-Plug nur in den ioBroker Objekten.
                                Dann diverse Versuche, Statusänderungen zue rehalten (kommen keine), dafür aber folgende Fehlermeldung im Log:
                                host-rasp31 2016-04-17 19:19:53 info instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                zwave-0 2016-04-17 19:19:51 info node4: nop, currently not implemented
                                TypeError: 2016-04-17 19:19:51 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
                                TypeError: 2016-04-17 19:19:51 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                                TypeError: 2016-04-17 19:19:51 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                TypeError: 2016-04-17 19:19:51 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                TypeError: 2016-04-17 19:19:51 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                                TypeError: 2016-04-17 19:19:51 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                TypeError: 2016-04-17 19:19:51 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                TypeError: 2016-04-17 19:19:51 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                                TypeError: 2016-04-17 19:19:51 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                                TypeError: 2016-04-17 19:19:51 error at Socket. (/opt/iobroker/node_modules/iobroker.zwave/main.js:308:76)
                                TypeError: 2016-04-17 19:19:51 error Cannot read property 'split' of undefined
                                uncaught 2016-04-17 19:19:51 error exception: Cannot read property 'split' of undefined
                                zwave-0 2016-04-17 19:19:51 error Add Associaton for 3: 3
                                zwave-0 2016-04-17 19:19:51 error Remove Associaton for 3: 1
                                zwave-0 2016-04-17 19:17:58 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 19:17:57 warn Object 'web.0.connected' not found for stateChange
                                history-1 2016-04-17 19:16:44 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.history
                                iobroker 2016-04-17 19:16:43 info exit 0
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1 created
                                host-rasp31 2016-04-17 19:16:43 info instance system.adapter.history.1 started with pid 5621
                                host-rasp31 2016-04-17 19:16:43 info object change system.adapter.history.1
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.alive created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.connected created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memHeapUsed created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memHeapTotal created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memRss created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.uptime created
                                iobroker 2016-04-17 19:16:43 info host.rasp31 create instance history
                                iobroker 2016-04-17 19:16:41 info add history
                                zwave-0 2016-04-17 18:39:27 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:39:26 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:38:44 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:38:43 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:35:55 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:35:53 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:35:01 warn Object 'web.0.connected' not found for stateChange
                                zwave-0 2016-04-17 18:35:00 warn Object 'web.0.connected' not found for stateChange
                                host-rasp31 2016-04-17 18:34:06 warn instance system.adapter.zwave.0 already running with pid 3472
                                zwave-0 2016-04-17 18:33:56 info node2: node dead (Undead Undead Undead), currently not implemented
                                zwave-0 2016-04-17 18:33:56 info Scan completed
                                Es wurden ein Haufen Datenpunkte angelegt. Gefüllt wird allerdings keiner.
                                Dann gibt es beim Adapter 4 Nodes:
                                1- USB Stick
                                2 - ?
                                3 - Motion Sensor
                                4 - Wall Plug
                                ioBroker/Zustände zeigt bei dem Motion Sensor Werte an. Für den Wall-Plug (Node 4) kommen keine Werte.
                                Die Meldungen nach dem Neustart des Adapters, da er nach der Fehlermeldung oben beendet wurde:
                                zwave-0	2016-04-17 19:39:08	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:38:58	info	node2: timeout, currently not implemented
                                zwave-0	2016-04-17 19:38:52	info	node2: node dead (Undead Undead Undead), currently not implemented
                                sql-0	2016-04-17 19:38:52	info	sendTo "getHistory" to system.adapter.admin.0 from system.adapter.sql.0: {"step":null,"error":null}
                                sql-0	2016-04-17 19:38:52	info	No Data
                                admin-0	2016-04-17 19:38:52	info	sendTo "getHistory" to system.adapter.sql.0 from system.adapter.admin.0: {"id":"zwave.0.NODE3.SENSOR_MULTILEVEL.Temperature_1","options":{"end":1460914742,"count":50,"instance":"sql.0","from":true,"a
                                zwave-0	2016-04-17 19:38:48	info	nodeid 2 is now available, but maybe not ready
                                zwave-0	2016-04-17 19:38:39	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:38:29	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:38:19	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:38:09	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:59	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:49	info	nodeid 4 is now available, but maybe not ready
                                zwave-0	2016-04-17 19:37:45	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:35	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:25	info	node4: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:15	info	node2: nop, currently not implemented
                                zwave-0	2016-04-17 19:37:11	info	node ready nodeid:1 nodeinfo:{"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"ras
                                zwave-0	2016-04-17 19:37:11	info	node3: node sleep, currently not implemented
                                zwave-0	2016-04-17 19:37:11	info	node3: nop, currently not implemented
                                zwave-0	2016-04-17 19:37:07	info	node2: nop, currently not implemented
                                zwave-0	2016-04-17 19:37:03	info	nodeid 3 is now available, but maybe not ready
                                zwave-0	2016-04-17 19:37:03	info	nodeid 1 is now available, but maybe not ready
                                zwave-0	2016-04-17 19:37:02	info	driver ready: homeid = c0c36bea
                                zwave-0	2016-04-17 19:37:02	info	scanning homeid=0xc0c36bea...
                                zwave-0	2016-04-17 19:37:02	info	node255: timeout, currently not implemented
                                zwave-0	2016-04-17 19:37:01	info	connected: homeid = 1.4.0
                                zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE3.GLOBAL_ACTION
                                zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE3.ready
                                zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE1.GLOBAL_ACTION
                                zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE1.ready
                                zwave-0	2016-04-17 19:37:00	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.zwave
                                host-rasp31	2016-04-17 19:36:59	info	instance system.adapter.zwave.0 started with pid 6639
                                host-rasp31	2016-04-17 19:36:59	info	object change system.adapter.zwave.0
                                host-rasp31	2016-04-17 19:36:56	info	object change system.adapter.zwave.0
                                Wenn ich irgendwie unterstützen kann (Daten liefern, usw.) gerne. Muss nur wissen, was benötigt wird.
                                VG,
                                Michael
                                • ruhr70R Offline
                                  ruhr70R Offline
                                  ruhr70
                                  #94
                                  Ergänzend:
                                  Node 4.2.1
                                  npm 2.14.17
                                  zwave-0	2016-04-17 20:32:55	info	node3: node sleep, currently not implemented
                                  zwave-0	2016-04-17 20:32:51	info	node3: timeout, currently not implemented
                                  zwave-0	2016-04-17 20:32:41	info	node3: node awake, currently not implemented
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #95
                                    Ich habe heute versucht, ein Fibaro FGS-222 Relais per ioBroker.zwave zu schalten. Nachdem sich die Installation schwierig gestaltet hat (Neustart notwendig, um das Relais richtig anzuzeigen), scheint jetzt auch die Verknüpfung nicht ordentlich zu sein.
                                    Bei manuellem Schalten am Relais wird der State in ioBroker korrekt aktualisiert. Die andere Richtung will aber nicht. Setzen des States in ioBroker schaltet das Relais weder an noch aus. Es passiert einfach nichts. Ideen woran das liegen könnte?
                                      #96
                                      Was sagt das log?
                                      ggf. z-Waveadapter auf debug schalten.
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #97
                                        Im Log erscheint überhaupt nichts. Beim Filter-Dropdown ist "debug" vorausgewählt oder was meinst du mit "zwave auf debug stellen"?
                                        So siehts im Ereignis-Tab aus:
                                        ~~![](</s><URL url=)http://i.imgur.com/p900Fn5.png" />
                                        Die gelb hinterlegten Einträge tauchen auf, wenn ich das Relais von Hand betätigte, die anderen beiden Einträge waren je 1 Versuch per "Objekte"-tab und per Skript das Teil anzuschalten – ist aber nichts passiert.~~
                                          #98
                                          @AlCalzone:
                                          Beim Filter-Dropdown ist "debug" vorausgewählt oder was meinst du mit "zwave auf debug stellen"? `
                                          Dann würde er debug ausgaben zeigen wenn er denn welche hätte ;-)
                                          Also im Reiter Instanzen links oben den admin mode über das Männchen-Icon aktivieren, dann in der dann rechts erscheinenden Spalte Log Stufe den Loglevel von Info auf debug schalten.
