  4. Test Adapter doorio v2.1.2
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 209.8k Aufrufe 39 Beobachtet
  • WalW Wal
    Meine Konfigs:
    config.yml
    mqtt:
      host: 192.168.123.12
      port: 1883
      user: "user"
      password: "password"
      topic_prefix: piface
      client_id: piface
    gpio_modules:
      - name: raspberrypi
        module: piface2
    digital_inputs:
      - name: DoorBell_1
        module: raspberrypi
        pin: 0
        on_payload: "true"
        off_payload: "false"
      - name: DoorBell_2
        module: raspberrypi
        pin: 1
        on_payload: "true"
    digital_outputs:
      - name: Door_1
        module: raspberrypi
        pin: 1
        on_payload: "true"
      - name: Door_2
        module: raspberrypi
        pin: 0
        on_payload: "true"
    Barsip config:
    # baresip configuration
    # Core
    poll_method		epoll		# poll, select, epoll ..
    # SIP
    sip_listen		0.0.0.0:5060
    #sip_certificate	cert.pem
    # Call
    call_local_timeout	120
    call_max_calls		4
    # Audio
    #audio_path		/usr/local/share/baresip
    audio_player            pulse,noecho.sound_out
    audio_source            pulse,noecho.mic_in
    audio_alert             pulse,null
    #ausrc_srate		48000
    #auplay_srate		48000
    #ausrc_channels		0
    #auplay_channels	0
    #audio_txmode		poll		# poll, thread
    audio_level		no
    ausrc_format		s16		# s16, float, ..
    auplay_format		s16		# s16, float, ..
    auenc_format		s16		# s16, float, ..
    audec_format		s16		# s16, float, ..
    # Video
    #video_source		v4l2,/dev/video0
    #video_display		x11,nil
    video_size		352x288
    video_bitrate		500000
    video_fps		25.00
    video_fullscreen	yes
    videnc_format		yuv420p
    # AVT - Audio/Video Transport
    rtp_tos			184
    #rtp_ports		10000-20000
    #rtp_bandwidth		512-1024 # [kbit/s]
    rtcp_mux		no
    jitter_buffer_delay	5-10		# frames
    rtp_stats		no
    #rtp_timeout		60
    # Network
    #dns_server		10.0.0.1:53
    #net_interface		eth0
    # BFCP
    #bfcp_proto		udp
    # Modules
    module_path		/usr/local/lib/baresip/modules
    # UI Modules
    module			stdio.so
    #module			cons.so
    #module			evdev.so
    #module			httpd.so
    # Audio codec Modules (in order)
    #module			opus.so
    #module			amr.so
    #module			g7221.so
    module			g722.so
    #module			g726.so
    #module			g711.so
    #module			gsm.so
    #module			l16.so
    #module			bv32.so
    #module			mpa.so
    #module			codec2.so
    #module			ilbc.so
    #module			isac.so
    # Audio filter Modules (in encoding order)
    #module			vumeter.so
    #module			sndfile.so
    #module			speex_aec.so
    #module			speex_pp.so
    #module			plc.so
    # Audio driver Modules
    #module			alsa.so
    module			pulse.so
    #module			jack.so
    #module			portaudio.so
    #module			aubridge.so
    #module			aufile.so
    # Video codec Modules (in order)
    #module			avcodec.so
    #module			vp8.so
    #module			vp9.so
    #module			h265.so
    # Video filter Modules (in encoding order)
    #module			selfview.so
    #module			snapshot.so
    #module			swscale.so
    #module			vidinfo.so
    # Video source modules
    #module			v4l2.so
    #module			v4l2_codec.so
    #module			avformat.so
    #module			x11grab.so
    #module			cairo.so
    #module			vidbridge.so
    # Video display modules
    #module			directfb.so
    #module			x11.so
    #module			sdl2.so
    #module			fakevideo.so
    # Audio/Video source modules
    #module			rst.so
    #module			gst1.so
    #module			gst_video1.so
    # Media NAT modules
    #module			stun.so
    #module			turn.so
    #module			ice.so
    #module			natpmp.so
    #module			pcp.so
    # Media encryption modules
    #module			srtp.so
    #module			dtls_srtp.so
    #module			zrtp.so
    # Temporary Modules (loaded then unloaded)
    #module_tmp		uuid.so
    module_tmp		account.so
    # Application Modules
    #module_app		auloop.so
    #module_app		b2bua.so
    #module_app		contact.so
    module_app		debug_cmd.so
    #module_app		dtmfio.so
    #module_app		echo.so
    #module_app		gtk.so
    module_app		menu.so
    #module_app		mwi.so
    #module_app		presence.so
    module_app		syslog.so
    #module_app		mqtt.so
    module_app		ctrl_tcp.so
    #module_app		vidloop.so
    # Module parameters
    # UI Modules parameters
    cons_listen		0.0.0.0:5555 # cons
    http_listen		0.0.0.0:8000 # httpd - server
    ctrl_tcp_listen		0.0.0.0:4444 # ctrl_tcp
    evdev_device		/dev/input/event0
    # Opus codec parameters
    opus_bitrate		28000 # 6000-510000
    #opus_stereo		yes
    #opus_sprop_stereo	yes
    #opus_cbr		no
    #opus_inband_fec	no
    #opus_dtx		no
    #opus_mirror		no
    #opus_complexity		10
    #opus_application		audio	# {voip,audio}
    # Opus Multistream codec parameters
    #opus_ms_channels	2	#total channels (2 or 4)
    #opus_ms_streams		2	#number of streams
    #opus_ms_c_streams	2	#number of coupled streams
    vumeter_stderr		yes
    # Selfview
    video_selfview		window # {window,pip}
    #selfview_size		64x64
    # ICE
    ice_turn		no
    ice_debug		no
    ice_nomination		regular	# {regular,aggressive}
    ice_mode		full	# {full,lite}
    Barsip accounts(Autoannahme):
    <sip:door2sip@fritz.box>;auth_pass=password;answermode=auto
    Lasse Barsip auf der Konsole laufen um Fehlermeldungen zu sehen.
    WoduwolleW Offline
    WoduwolleW Offline
    Woduwolle
    #100
    @Wal
    Hier mal ein Screenshot vom IOBroker .... ick kann außer das rot markierte nichts rauslesen
    • WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      #101
      Du wirst im ioBroker nicht feststellen können, warum ein Besetztzeichen kommt.
      Wie gesagt, lasse Baresip mit "baresip -v" in der Console laufen, da bekommst du Fehler angezeigt.Bildschirmfoto vom 2019-12-02 12-29-27.png
      Ich denke das was mit dem Audioplugin nicht stimmt, da pulseaudio mit einem RPI1 evtl. nicht funzt. Du wirst alsa einstellen müssen.
      Walter
      DoorIO-Adapter
      WoduwolleW 1 Antwort Letzte Antwort
      • WalW Wal
        WoduwolleW Offline
        WoduwolleW Offline
        Woduwolle
        #102
        Okay da sieht man mehr aber welche adresse muss ich jetzt abändern ???
        Ich wollte sowieso mit alsa starten von dem her habe ich es auch mal so eingestellt
        WalW 1 Antwort Letzte Antwort
        • WoduwolleW Woduwolle
          WalW Offline
          WalW Offline
          Wal
          #103
          @Woduwolle
          evtl. hast du baresip im Hintergrund schon laufen ?
          Bevor du barsip aufrufst, ein "sudo systemctl stop baresip".
          Walter
          DoorIO-Adapter
            siscop
            #104
            Guten Morgen,
            leider finde ich keine Doku wie was angeschlossen werden soll.
            Zuerst muss Baresip laufen.
            Meine Gegenstelle ist ein Telefon an der Fritzbox.
            Baresip erreicht ihn und die Kommunikation ist i.O.
            Ich hätte trotzdem einige Fragen diesbezüglich
            1. An der Türstation soll KEIN Freizeichen im Lautsprecher ertönen wenn er den Taster drückt. Wie schaltete ich das Stumm?
            2. Wenn keiner da ist bzw. an dem TelefonGegenstelle keiner abnimmt soll der Verbindungsversuch nach 10 sek. abgebrochen werden. Ich finde kein TimeoutParameter diesbezüglich.
              Anscheinend habt ihr es in doorio implementiert. Dann verstehe ich nicht wie ihr das Signal – drücken des Schalters – an doorio bringt. Ich nutze kein Piface. Wenn als Antwort jetzt kommt MQTT von GPIO – das habe ich versucht jedoch findet er die yml-Datei nicht bei der Installation. Es gibt doch bestimmt einen anderen Weg ausser MQTT
            3. Muss Baresip immer laufen oder wird er gestartet wenn jemand die Taste drückt?
            3.1 Wenn es immer läuft dann finde ich keinen weg „d sip:**612@fritzbox“ bzw. „d **612“ einzugeben. Wie habt ihr es gemacht? Bei mir läuft es nur im selben Terminal wo ich baresip gestartet habe jedoch ist dieses Terminal beim Systemstart schwer zu finden ;)
            3.2 Wenn starten soll sobald jemand den Taster drückt – Wie lautet der Terminalbefehl?
            „Baresip -e sip:**612@fritzbox“ funktioniert nicht.
            1. Wenn ich Hausintern die Türsprechanlage anrufe funktioniert das Autoabheben der Türsprechanlage genau nur 1x. Sobald ich auflege und wieder anrufe klingelt es nur noch. Wie habt ihr das realisiert? Funktioniert bei euch das anrufen zu Türsprechanlage?
              Der Befehlt im account
            <sip:**620@fritz.box>;auth_pass=meinpassword;answermode=auto
            sollte doch noch valid sein.
            1. Verbindung zu doorio ist zwar erfolgreich und hätte da noch einige Fragen zu den Parameter jedoch soll ich ja erstmal baresip fertig zum laufen bringen :)
              siscop
              #105
              Ich habe mittlerweile das MQTT hinbekommen und kann die GPIO übertragen nach iobroker. Ich weiss trotzdem nicht wie ich die unterbrechung nach 10 sekunden hinbekomme.
              Ich bräuchte immernoch Hilfe zu den oben genannten Punkte...😵
              • WalW Wal
                @Woduwolle
                WoduwolleW Offline
                WoduwolleW Offline
                Woduwolle
                #106
                @Wal Ersteinmal viel dank für deine Hilfe das mit dem "sudo systemctl stop baresip" funktioniert danach kann ich ein gespräch aufbauen, allerdings muss ich es nach einem neustart wiederholt eingeben ???
                dann würde ich gerne das mit dem MQTT angehen das ich dort eine verbindung aufgebaut bekomme, ich versuche mich da vielleicht über die Weihnachtstage mal daran, vielleicht bekomme ich es auch selbst heraus
                Wünsche allen hier im Forum schöne Weihnachten und einen Guten Rutsch
                  WalW Offline
                  WalW Offline
                  Wal
                  #107
                  @Woduwolle sagte in Test Adapter doorio v0.0.x:
                  Nach dem Systemstart scheint ja dann Baresip schon zu laufen, du brauchst es also nicht mehr zu starten.
                  Walter
                  DoorIO-Adapter
                  • MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    schrieb am zuletzt editiert von MathiasJ
                    #108
                    Hi @Wal
                    Du hast mich auf dem doorpi-Forum heute auf doorio aufmerksam gemacht.
                    Die fertige Image habe ich heute herunter geladen.
                    Nun folgt die Installation des Adapters.... Ähm und Doorbird wird deinstalliert :)
                    Kannst mir mal sagen, welches Hardware-Setup Du benutzt?
                    ist Baresip auf dem Image schon installiert?
                    Gruß,
                    Mathias
                    IObroker auf dem NUC als VM.
                    • MathiasJM MathiasJ
                      Hi @Wal
                      Gruß,
                      Mathias
                      WalW Offline
                      WalW Offline
                      Wal
                      #109
                      @MathiasJ sagte in Test Adapter doorio v0.0.x:
                      Hi @Wal
                      Gruß,
                      Mathias
                      Wusste gar nicht das der Download noch funktioniert. ;-)
                      Das Hardwaresetup ist noch hier Link Text
                      Walter
                      DoorIO-Adapter
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        #110
                        @Wal
                        Hat sich eh erledigt.
                        Ich werde ein neues Image aufsetzen und es da noch mal versuchen.
                        Irgendwie funktioniert das mit dem Netzwerk nicht so recht.
                          @Wal
                          WalW Offline
                          WalW Offline
                          Wal
                          #111
                          @Wal
                          Ist eh besser, wegen dem Lerneffekt.
                          Walter
                          DoorIO-Adapter
                          MathiasJM 1 Antwort Letzte Antwort
                          • WalW Wal
                            @Wal
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            #112
                            @Wal
                            bin gerade dabei, mqtt zu installieren nach https://github.com/flyte/pi-mqtt-gpio
                            aber:
                            root@doorio:~# pip install pi-mqtt-gpio
                            -bash: pip: Kommando nicht gefunden.
                            Gruß,
                            Mathias
                              @Wal
                              aber:
                              Gruß,
                              Mathias
                              WalW Offline
                              WalW Offline
                              Wal
                              #113
                              @MathiasJ
                              sudo apt install python3-pip
                              sudo pip3 install pifacecommon
                              sudo pip3 install pifacedigitalio
                              sudo adduser pi spi
                              git clone https://github.com/flyte/pi-mqtt-gpio
                              cd pi-mqtt-gpio
                              sudo pip3 install pi-mqtt-gpio
                              Walter
                              DoorIO-Adapter
                              wandW 1 Antwort Letzte Antwort
                              • MathiasJM Offline
                                MathiasJM Offline
                                MathiasJ
                                #114
                                @Wal
                                Super, danke!
                                ich glaube, ich muß mich da noch mal einlesen und von vorne beginnen....
                                ich habe da den einen oder anderen Hund reingehauen.
                                WalW 2 Antworten Letzte Antwort
                                  @Wal
                                  Super, danke!
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #115
                                  @Wal
                                  Super, danke!
                                  Ich bin Zuhause und habe Zeit.
                                  Walter
                                  DoorIO-Adapter
                                    @Wal
                                    Super, danke!
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #116
                                    @Wal
                                    Super, danke!
                                    Habe gerade das Image mit ioBroker,Pulseaudio,doorio runtergeladen. Das funktioniert noch, falls du arbeit sparen möchtest.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @Wal
                                      Super, danke!
                                      MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      #117
                                      @Wal
                                      Du meinst das Image auf der ersten Seite?
                                      ja mache ich, den Fehler habe ich auch gefunden.
                                      Sag mal, geht der auch mit dem PI4?
                                      Mein anderer Raspberry ist im Rasperry-Himmel, da geht nichts mehr.
                                        @Wal
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        #118
                                        @Wal
                                        Nein, Seite 5
                                        Walter
                                        DoorIO-Adapter
                                          @Wal
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #119
                                          @MathiasJ
                                          Ja geht, aber nicht das Image, das ist für RPI3
                                          Ich nutze ein RPI4, mit Pulseaudio installieren hatte ich unter Buster meine Probleme.
                                          Walter
                                          DoorIO-Adapter
