  4. Grafana Tagesverbrauch
    6.8k
how-to
55 Beiträge 8 Kommentatoren 22.3k Aufrufe 10 Beobachtet
  • NegaleinN Negalein
    @crunchip sagte in Grafana Tagesverbrauch:
    bist du sicher das die Bezeichnung richtig geschrieben ist? kommt mir irgendwie etwas komisch vor mit dem...hs100__0__10....(die doppelten unterstriche)
    Ja, gerade nochmal geschaut.
    So siehts in Source aus:
    Und so die DP:
    zB der sourceanalytix.0.hs100__0__10_0_1_80__power.Meter_Readings.Current_Reading
    crunchipC Offline
    crunchipC Offline
    @Negalein mach mal ein neues dasboard füge die json ein...und natürlich deinen Datenpunkt anpassen
     "__inputs": [
         "name": "DS_INFLUXDB",
         "label": "InfluxDB",
         "description": "",
         "type": "datasource",
         "pluginId": "influxdb",
         "pluginName": "InfluxDB"
     "__requires": [
         "type": "panel",
         "id": "gauge",
         "name": "Gauge",
         "version": ""
         "type": "grafana",
         "id": "grafana",
         "name": "Grafana",
         "version": "6.5.2"
         "type": "panel",
         "id": "grafana-piechart-panel",
         "name": "Pie Chart",
         "version": "1.4.0"
         "type": "panel",
         "id": "graph",
         "name": "Graph",
         "version": ""
         "id": "influxdb",
         "name": "InfluxDB",
         "version": "1.0.0"
         "type": "panel",
         "id": "yesoreyeram-boomtheme-panel",
         "name": "Boom Theme",
         "version": "0.1.0"
     "annotations": {
       "list": [
           "builtIn": 1,
           "datasource": "-- Grafana --",
           "enable": true,
           "hide": true,
           "iconColor": "rgba(0, 211, 255, 1)",
           "name": "Annotations & Alerts",
           "type": "dashboard"
     "editable": true,
     "gnetId": null,
     "graphTooltip": 0,
     "id": null,
     "links": [
         "asDropdown": false,
         "icon": "dashboard",
         "tags": [
           "Strom"
         "title": "Strom",
         "tooltip": "",
         "type": "dashboards"
     "panels": [
         "activeThemeId": 0,
         "datasource": "${DS_INFLUXDB}",
         "disableThemePicker": true,
         "gridPos": {
           "h": 3,
           "w": 24,
           "x": 0,
           "y": 0
         "id": 12,
         "options": {},
         "targets": [
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "orderByTime": "ASC",
             "policy": "default",
             "refId": "A",
             "resultFormat": "time_series",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
         "themes": [
             "name": "Night Theme",
             "styles": [
                 "props": {
                   "theme": "default"
                 "type": "basetheme"
                 "props": {
                   "url": "https://images.unsplash.com/photo-1524334228333-0f6db392f8a1"
                 "type": "bgimage"
                 "props": {
                   "text": ".panel-container {\n    background-color: rgba(0,0,0,0.3);\n}"
                 "type": "style"
             "name": "Theme 2",
             "styles": [
                 "props": {
                   "theme": "light"
                 "type": "basetheme"
                 "props": {
                   "url": "/public/img/hintergrund/energie.jpg"
                 "type": "bgimage"
                 "props": {
                   "text": ""
                 "type": "style"
         "timeFrom": null,
         "timeShift": null,
         "title": "",
         "transparent": true,
         "type": "yesoreyeram-boomtheme-panel"
         "aliasColors": {
           "Stromverbrauch": "semi-dark-green"
         "bars": true,
         "dashLength": 10,
         "dashes": false,
         "fill": 1,
         "fillGradient": 0,
         "gridPos": {
           "h": 5,
           "w": 21,
           "x": 0,
           "y": 3
         "hiddenSeries": false,
         "id": 2,
         "interval": "10s",
         "legend": {
           "avg": true,
           "current": false,
           "max": true,
           "min": false,
           "show": true,
           "total": false,
           "values": true
         "lines": false,
         "linewidth": 1,
         "links": [],
         "nullPointMode": "null",
         "options": {
           "dataLinks": []
         "percentage": false,
         "pointradius": 2,
         "points": false,
         "renderer": "flot",
         "seriesOverrides": [],
         "spaceLength": 10,
         "stack": true,
         "steppedLine": false,
         "targets": [
             "alias": "Stromverbrauch",
             "groupBy": [
                 "params": [
                   "24h"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "wiffi-wz.0.root.192_168_178_33.w_counter_1",
             "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"wiffi-wz.0.root.10_1_30_10.w_counter_1\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
             "rawQuery": true,
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
         "thresholds": [],
         "timeFrom": null,
         "timeRegions": [],
         "timeShift": null,
         "title": "Strom",
         "tooltip": {
           "shared": true,
           "sort": 0,
           "value_type": "cumulative"
         "type": "graph",
         "xaxis": {
           "buckets": null,
           "mode": "time",
           "name": null,
           "show": true,
           "values": []
         "yaxes": [
             "format": "kwatth",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
             "format": "short",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
         "yaxis": {
           "align": false,
           "alignLevel": null
         "cacheTimeout": null,
         "gridPos": {
           "h": 5,
           "w": 3,
           "x": 21,
           "y": 3
         "id": 6,
         "links": [],
         "options": {
           "fieldOptions": {
             "calcs": [
               "last"
             "defaults": {
               "decimals": 2,
               "mappings": [
                   "id": 0,
                   "op": "=",
                   "text": "N/A",
                   "type": 1,
                   "value": "null"
               "max": 150,
               "min": 0,
               "nullValueMode": "connected",
               "thresholds": [
                   "color": "dark-green",
                   "value": null
                   "color": "dark-yellow",
                   "value": 80
                   "color": "dark-red",
                   "value": 120
               "unit": "currencyEUR"
             "override": {},
             "values": false
           "orientation": "horizontal",
           "showThresholdLabels": false,
           "showThresholdMarkers": true
         "pluginVersion": "6.5.2",
         "targets": [
             "alias": "",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "sourceanalytix.0.wiffi-wz__0__root__10_1_30_10__w_counter_1.cost.03_current_month",
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "distinct"
             "tags": []
         "timeFrom": null,
         "timeShift": null,
         "title": "Monatskosten",
         "type": "gauge"
         "aliasColors": {
           "Gasverbrauch": "semi-dark-red"
         "bars": true,
         "dashLength": 10,
         "dashes": false,
         "fill": 1,
         "fillGradient": 0,
         "gridPos": {
           "h": 5,
           "w": 21,
           "x": 0,
           "y": 8
         "id": 3,
         "interval": "10s",
         "legend": {
           "avg": true,
           "current": false,
           "max": true,
           "min": false,
           "show": true,
           "total": false,
           "values": true
         "lines": false,
         "linewidth": 1,
         "links": [],
         "options": {
           "dataLinks": []
         "pointradius": 2,
         "points": false,
         "renderer": "flot",
         "spaceLength": 10,
         "stack": true,
         "targets": [
             "alias": "Gasverbrauch",
             "groupBy": [
                 "params": [
                   "24h"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "wiffi-wz.0.root.10_1_30_10.w_counter_2",
             "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"wiffi-wz.0.root.10_1_30_10.w_counter_2\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
             "rawQuery": true,
             "refId": "B",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
         "thresholds": [],
         "timeFrom": null,
         "timeRegions": [],
         "timeShift": null,
         "title": "Heizung",
         "tooltip": {
           "shared": true,
           "sort": 0,
         "type": "graph",
         "xaxis": {
           "buckets": null,
           "mode": "time",
           "name": null,
           "show": true,
           "values": []
         "yaxes": [
             "format": "m3",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
             "format": "short",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
         "yaxis": {
           "align": false,
           "alignLevel": null
         "gridPos": {
           "h": 5,
           "w": 3,
           "x": 21,
           "y": 8
         "id": 7,
         "links": [],
         "options": {
           "fieldOptions": {
             "calcs": [
               "last"
             "defaults": {
               "decimals": 2,
               "mappings": [
                   "id": 0,
                   "op": "=",
                   "text": "N/A",
                   "type": 1,
                   "value": "null"
               "max": 200,
               "min": 0,
               "thresholds": [
                   "value": null
                   "value": 130
                   "value": 170
             "override": {},
             "values": false
         "targets": [
             "alias": "",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "sourceanalytix.0.wiffi-wz__0__root__10_1_30_10__w_counter_2.cost.03_current_month",
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "distinct"
             "tags": []
         "timeFrom": null,
         "timeShift": null,
         "type": "gauge"
         "aliasColors": {
           "Wasserverbrauch": "semi-dark-blue"
         "bars": true,
         "dashLength": 10,
         "dashes": false,
         "fill": 1,
         "fillGradient": 0,
         "gridPos": {
           "h": 5,
           "w": 21,
           "x": 0,
           "y": 13
         "hideTimeOverride": false,
         "id": 4,
         "interval": "10s",
         "legend": {
           "avg": true,
           "current": false,
           "hideEmpty": false,
           "hideZero": false,
           "max": true,
           "min": false,
           "show": true,
           "total": false,
           "values": true
         "lines": false,
         "linewidth": 1,
         "links": [],
         "options": {
           "dataLinks": []
         "pointradius": 2,
         "points": false,
         "renderer": "flot",
         "spaceLength": 10,
         "stack": true,
         "targets": [
             "alias": "Wasserverbrauch",
             "groupBy": [
                 "params": [
                   "24h"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "wiffi-wz.0.root.10_1_30_10.w_counter_3",
             "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"wiffi-wz.0.root.10_1_30_10.w_counter_3\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
             "rawQuery": true,
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
         "thresholds": [],
         "timeFrom": null,
         "timeRegions": [],
         "timeShift": null,
         "title": "Wasser",
         "tooltip": {
           "shared": true,
           "sort": 0,
         "type": "graph",
         "xaxis": {
           "buckets": null,
           "mode": "time",
           "name": null,
           "show": true,
           "values": []
         "yaxes": [
             "format": "m3",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
             "format": "short",
             "label": null,
             "logBase": 1,
             "max": null,
             "min": null,
             "show": true
         "yaxis": {
           "align": false,
           "alignLevel": null
         "gridPos": {
           "h": 5,
           "w": 3,
           "x": 21,
           "y": 13
         "id": 8,
         "links": [],
         "options": {
           "fieldOptions": {
             "calcs": [
               "last"
             "defaults": {
               "decimals": 2,
               "mappings": [
                   "id": 0,
                   "op": "=",
                   "text": "N/A",
                   "type": 1,
                   "value": "null"
               "max": 7,
               "min": 0,
               "thresholds": [
                   "value": null
                   "value": 4.5
                   "value": 6
             "override": {},
             "values": false
         "targets": [
             "alias": "",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "sourceanalytix.0.wiffi-wz__0__root__10_1_30_10__w_counter_3.cost.03_current_month",
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "distinct"
             "tags": []
         "timeFrom": null,
         "timeShift": null,
         "type": "gauge"
         "aliasColors": {
           "Heizung": "#E02F44",
           "Strom": "#56A64B",
           "Wasser": "#3274D9"
         "breakPoint": "50%",
         "combine": {
           "label": "Others",
           "threshold": "0"
         "fontSize": "100%",
         "format": "currencyEUR",
         "gridPos": {
           "h": 8,
           "w": 5,
           "x": 0,
           "y": 18
         "id": 10,
         "interval": null,
         "legend": {
           "percentage": true,
           "show": true,
           "values": true
         "legendType": "On graph",
         "links": [],
         "maxDataPoints": 3,
         "nullPointMode": "connected",
         "options": {},
         "pieType": "pie",
         "strokeWidth": 1,
         "targets": [
             "alias": "Strom",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "refId": "A",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
             "alias": "Heizung",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "refId": "B",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
             "alias": "Wasser",
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "refId": "C",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "mean"
             "tags": []
         "timeFrom": null,
         "timeShift": null,
         "title": "Pie Chart",
         "type": "grafana-piechart-panel",
         "valueName": "current"
     "schemaVersion": 21,
     "style": "dark",
     "tags": [
       "Monatsverbrauch"
     "templating": {
       "list": []
     "time": {
       "from": "now/M",
       "to": "now"
     "timepicker": {
       "refresh_intervals": [
         "5s",
         "10s",
         "30s",
         "1m",
         "5m",
         "15m",
         "30m",
         "1h",
         "2h",
         "1d"
       "time_options": [
         "5m",
         "15m",
         "1h",
         "6h",
         "12h",
         "24h",
         "2d",
         "7d",
         "30d"
     "timezone": "",
     "title": "Monatsverbrauch",
     "uid": "_tteA1VZz",
     "version": 73
       "__inputs": [
           "description": "",
       "__requires": [
           "type": "panel",
           "id": "gauge",
           "name": "Gauge",
           "version": ""
           "type": "grafana",
           "id": "grafana",
           "name": "Grafana",
           "version": "6.5.2"
           "type": "panel",
           "version": "1.4.0"
           "type": "panel",
           "id": "graph",
           "name": "Graph",
           "version": ""
           "id": "influxdb",
           "name": "InfluxDB",
           "version": "1.0.0"
           "type": "panel",
           "version": "0.1.0"
       "annotations": {
         "list": [
             "builtIn": 1,
             "enable": true,
             "hide": true,
             "type": "dashboard"
       "editable": true,
       "gnetId": null,
       "graphTooltip": 0,
       "id": null,
       "links": [
           "tags": [
             "Strom"
           "title": "Strom",
           "tooltip": "",
       "panels": [
           "activeThemeId": 0,
           "gridPos": {
             "h": 3,
             "w": 24,
             "x": 0,
             "y": 0
           "id": 12,
           "options": {},
           "targets": [
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
           "themes": [
               "styles": [
                   "props": {
                     "theme": "default"
                   "type": "basetheme"
                   "props": {
                   "type": "bgimage"
                   "props": {
                   "type": "style"
               "name": "Theme 2",
               "styles": [
                   "props": {
                     "theme": "light"
                   "type": "basetheme"
                   "props": {
                   "type": "bgimage"
                   "props": {
                     "text": ""
                   "type": "style"
           "timeFrom": null,
           "timeShift": null,
           "title": "",
           "aliasColors": {
           "bars": true,
           "dashLength": 10,
           "dashes": false,
           "fill": 1,
           "fillGradient": 0,
           "gridPos": {
             "h": 5,
             "w": 21,
             "x": 0,
             "y": 3
           "id": 2,
           "interval": "10s",
           "legend": {
             "avg": true,
             "current": false,
             "max": true,
             "min": false,
             "show": true,
             "total": false,
             "values": true
           "lines": false,
           "linewidth": 1,
           "links": [],
           "options": {
             "dataLinks": []
           "pointradius": 2,
           "points": false,
           "renderer": "flot",
           "spaceLength": 10,
           "stack": true,
           "targets": [
               "groupBy": [
                   "params": [
                     "24h"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "rawQuery": true,
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
           "thresholds": [],
           "timeFrom": null,
           "timeRegions": [],
           "timeShift": null,
           "title": "Strom",
           "tooltip": {
             "shared": true,
             "sort": 0,
           "type": "graph",
           "xaxis": {
             "buckets": null,
             "mode": "time",
             "name": null,
             "show": true,
             "values": []
           "yaxes": [
               "format": "kwatth",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
               "format": "short",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
           "yaxis": {
             "align": false,
             "alignLevel": null
           "gridPos": {
             "h": 5,
             "w": 3,
             "x": 21,
             "y": 3
           "id": 6,
           "links": [],
           "options": {
             "fieldOptions": {
               "calcs": [
                 "last"
               "defaults": {
                 "decimals": 2,
                 "mappings": [
                     "id": 0,
                     "op": "=",
                     "text": "N/A",
                     "type": 1,
                     "value": "null"
                 "max": 150,
                 "min": 0,
                 "thresholds": [
                     "value": null
                     "value": 80
                     "value": 120
               "override": {},
               "values": false
           "targets": [
               "alias": "",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "distinct"
               "tags": []
           "timeFrom": null,
           "timeShift": null,
           "type": "gauge"
           "aliasColors": {
           "bars": true,
           "dashLength": 10,
           "dashes": false,
           "fill": 1,
           "fillGradient": 0,
           "gridPos": {
             "h": 5,
             "w": 21,
             "x": 0,
             "y": 8
           "id": 3,
           "interval": "10s",
           "legend": {
             "avg": true,
             "current": false,
             "max": true,
             "min": false,
             "show": true,
             "total": false,
             "values": true
           "lines": false,
           "linewidth": 1,
           "links": [],
           "options": {
             "dataLinks": []
           "pointradius": 2,
           "points": false,
           "renderer": "flot",
           "spaceLength": 10,
           "stack": true,
           "targets": [
               "groupBy": [
                   "params": [
                     "24h"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "rawQuery": true,
               "refId": "B",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
           "thresholds": [],
           "timeFrom": null,
           "timeRegions": [],
           "timeShift": null,
           "title": "Heizung",
           "tooltip": {
             "shared": true,
             "sort": 0,
           "type": "graph",
           "xaxis": {
             "buckets": null,
             "mode": "time",
             "name": null,
             "show": true,
             "values": []
           "yaxes": [
               "format": "m3",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
               "format": "short",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
           "yaxis": {
             "align": false,
             "alignLevel": null
           "gridPos": {
             "h": 5,
             "w": 3,
             "x": 21,
             "y": 8
           "id": 7,
           "links": [],
           "options": {
             "fieldOptions": {
               "calcs": [
                 "last"
               "defaults": {
                 "decimals": 2,
                 "mappings": [
                     "id": 0,
                     "op": "=",
                     "text": "N/A",
                     "type": 1,
                     "value": "null"
                 "max": 200,
                 "min": 0,
                 "thresholds": [
                     "value": null
                     "value": 130
                     "value": 170
               "override": {},
               "values": false
           "targets": [
               "alias": "",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "distinct"
               "tags": []
           "timeFrom": null,
           "timeShift": null,
           "type": "gauge"
           "aliasColors": {
           "bars": true,
           "dashLength": 10,
           "dashes": false,
           "fill": 1,
           "fillGradient": 0,
           "gridPos": {
             "h": 5,
             "w": 21,
             "x": 0,
             "y": 13
           "id": 4,
           "interval": "10s",
           "legend": {
             "avg": true,
             "current": false,
             "hideEmpty": false,
             "hideZero": false,
             "max": true,
             "min": false,
             "show": true,
             "total": false,
             "values": true
           "lines": false,
           "linewidth": 1,
           "links": [],
           "options": {
             "dataLinks": []
           "pointradius": 2,
           "points": false,
           "renderer": "flot",
           "spaceLength": 10,
           "stack": true,
           "targets": [
               "groupBy": [
                   "params": [
                     "24h"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "rawQuery": true,
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
           "thresholds": [],
           "timeFrom": null,
           "timeRegions": [],
           "timeShift": null,
           "title": "Wasser",
           "tooltip": {
             "shared": true,
             "sort": 0,
           "type": "graph",
           "xaxis": {
             "buckets": null,
             "mode": "time",
             "name": null,
             "show": true,
             "values": []
           "yaxes": [
               "format": "m3",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
               "format": "short",
               "label": null,
               "logBase": 1,
               "max": null,
               "min": null,
               "show": true
           "yaxis": {
             "align": false,
             "alignLevel": null
           "gridPos": {
             "h": 5,
             "w": 3,
             "x": 21,
             "y": 13
           "id": 8,
           "links": [],
           "options": {
             "fieldOptions": {
               "calcs": [
                 "last"
               "defaults": {
                 "decimals": 2,
                 "mappings": [
                     "id": 0,
                     "op": "=",
                     "text": "N/A",
                     "type": 1,
                     "value": "null"
                 "max": 7,
                 "min": 0,
                 "thresholds": [
                     "value": null
                     "value": 4.5
                     "value": 6
               "override": {},
               "values": false
           "targets": [
               "alias": "",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "distinct"
               "tags": []
           "timeFrom": null,
           "timeShift": null,
           "type": "gauge"
           "aliasColors": {
             "Strom": "#56A64B",
             "Wasser": "#3274D9"
           "combine": {
             "label": "Others",
             "threshold": "0"
           "fontSize": "100%",
           "gridPos": {
             "h": 8,
             "w": 5,
             "x": 0,
             "y": 18
           "id": 10,
           "interval": null,
           "legend": {
             "percentage": true,
             "show": true,
             "values": true
           "links": [],
           "maxDataPoints": 3,
           "options": {},
           "pieType": "pie",
           "strokeWidth": 1,
           "targets": [
               "alias": "Strom",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "A",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
               "alias": "Heizung",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "B",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
               "alias": "Wasser",
               "groupBy": [
                   "params": [
                     "$__interval"
                   "type": "time"
                   "params": [
                     "null"
                   "type": "fill"
               "refId": "C",
               "select": [
                     "params": [
                       "value"
                     "type": "field"
                     "params": [],
                     "type": "mean"
               "tags": []
           "timeFrom": null,
           "timeShift": null,
       "style": "dark",
       "tags": [
         "Monatsverbrauch"
       "templating": {
         "list": []
       "time": {
         "from": "now/M",
         "to": "now"
       "timepicker": {
           "5s",
           "10s",
           "30s",
           "1m",
           "5m",
           "15m",
           "30m",
           "1h",
           "2h",
           "1d"
         "time_options": [
           "5m",
           "15m",
           "1h",
           "6h",
           "12h",
           "24h",
           "2d",
           "7d",
           "30d"
       "timezone": "",
       "uid": "_tteA1VZz",
       "version": 73
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      kommt auch "no Data"
      ° Fixer ---> iob fix
        crunchipC Offline
        crunchipC Offline
        @Negalein auch die richtige Datenbank ausgewählt? oder hast du nur eine
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Ja, hab nur eine
          • NegaleinN Offline
            NegaleinN Offline
            Negalein
            wähle ich "nur" den DP als Query aus, kommen Daten.
            Verwende ich aber
            SELECT non_negative_difference(last(cumulative_sum))FROM ( SELECT cumulative_sum(non_negative_difference(last("value"))) FROM "sourceanalytix.0.hs100__0__10_0_1_80__power.Meter_Readings.Current_Reading" WHERE $timeFilter GROUP BY time(1d) ) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')
            kommt "no Data".
              Verwende ich aber
              kommt "no Data".
              crunchipC Offline
              crunchipC Offline
              @Negalein klick mal rechts auf Query Inspector >>Expand All
              vllt kann man da etwas erkennen
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Object
                xhrStatus:"complete"
                request:Object
                method:"GET"
                url:"api/datasources/proxy/1/query"
                params:Object
                db:"iobroker"
                q:"SELECT non_negative_difference(last(cumulative_sum))FROM ( SELECT cumulative_sum(non_negative_difference(last("value"))) FROM "sourceanalytix.0.hs100__0__10_0_1_80__power.Meter_Readings.Current_Reading" WHERE time >= 1583017200000ms GROUP BY time(1d) ) WHERE time >= 1583017200000ms GROUP BY time(1d) tz('Europe/Berlin')"
                epoch:"ms"
                data:null
                precision:"ms"
                response:Object
                results:Array[1]
                0:Object
                statement_id:0
                  Object
                  request:Object
                  method:"GET"
                  params:Object
                  db:"iobroker"
                  epoch:"ms"
                  data:null
                  precision:"ms"
                  response:Object
                  results:Array[1]
                  0:Object
                  statement_id:0
                  crunchipC Offline
                  crunchipC Offline
                  @Negalein mehr kommt da nicht?
                  NegaleinN 2 Antworten Letzte Antwort
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    Nein, ist alles
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      verwende ich nur den DP im Query kommt viel mehr.
                      new 11.txt
                        Nein, ist alles
                        crunchipC Offline
                        crunchipC Offline
                        @Negalein ich würde mal sagen du musst noch nen Tag warten :woman-facepalming:
                        was soll denn auch berechnet werden, wenn erst ein 1 Wert vorhanden ist...wenn ma es logisch betrachtet
                        dieser Part kann ja erst am folgeTag errechnet werden GROUP BY time(1d)
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Ah, ok. Also warte ich mal bis morgen.
                          Dachte, da ich es schon vor Mitternacht aktiviert habe, funktioniert es schon nach Mitternacht .
                            crunchipC Offline
                            crunchipC Offline
                            @Negalein na da hatte ich jetzt auch nicht dran gedacht...warte mal noch nen Tag ab, dann sollte da auch was erscheinen
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              kein Problem
                              Ich melde mich wieder :)
                              • NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @crunchip
                                neuer Tag, leider kein neues Glück.
                                Steht noch immer "no Data".
                                Ich versuch es jetzt mal mit diesen DP aus Source (für jeden Tag ein Query).
                                Mal schaun, ob die Balken dann nebeneinander liegen.
                                  @crunchip
                                  crunchipC Offline
                                  crunchipC Offline
                                  @Negalein seltsam, sollte normalerweise funktionieren
                                  ja wenn du die einzelnen, pro Tag loggst, geht es auf jeden Fall....aber sollte ja auch anders funktionieren
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    Ja, ist komisch.
                                    Die Beispiele, die ich im Netz gefunden habe, zielten auch alle auf deinen Weg hin.
                                    So schauts jetzt mal aus.
                                      Ja, ist komisch.
                                      crunchipC Offline
                                      crunchipC Offline
                                      @Negalein ist doch schon mal was
                                      hast du es nochmal mit dem json vom ganzen dashboard getestet, das ich gestern reingestellt hatte
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        Stimmt, das teste ich gleich
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          bleibt bei "no Data"
