  4. [Projekt] MDCSS v2: Material Design CSS Version 2
material uivismaterial css
717 Beiträge 74 Kommentatoren 294.5k Aufrufe 77 Beobachtet
  • sigi234S sigi234
    @Stephan-Schleich sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
    @sigi234 magst es mir mal kurz exportieren?
    [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"","class":"mdui-flow mdui-fastest mdui-blue-acc","name":"Animation iobroker backup","visibility-oid":"backitup.0.oneClick.iobroker"},"style":{"left":"31px","top":"518px","width":"200px","height":"15px","z-index":"2","color":"","background-color":"rgba(39, 39, 39, 50)"},"widgetSet":"basic"}]
    Stephan SchleichS
    Stephan SchleichS
    Stephan Schleich
    #215
    @sigi234 danke, geht auch nicht, dann scheint ein fehler im CSS zu sein oder?
    Hab die v2.2 10.03.2020
    UhulaU 1 Antwort Letzte Antwort
    • Stephan SchleichS Stephan Schleich
      UhulaU
      UhulaU
      Uhula
      #216
      @Stephan-Schleich Ich habe mir eben aus Github die project.css (2.2) herunter geladen und in mein Demo-Projekt gesetzt. Auch damit funktioniert "flow" bei mir (Chrome-Browser). Hast du evtl. Änderungen am CSS vorgenommen, dann lade es dir erneut herunter.
      Uhula - Leise und Weise
      Ex: ioBroker on Gigabyte NUC Proxmox
      Stephan SchleichS 1 Antwort Letzte Antwort
      • UhulaU Uhula
        Stephan SchleichS
        Stephan SchleichS
        Stephan Schleich
        schrieb am zuletzt editiert von Stephan Schleich
        #217
        @Uhula An der Änderung lags, danke
        /* (2) Umschalten vis-Edit light/dark Theme */
        :root {
          /* Design-time light-Theme */
          --content-background: #000000;
          --design-font-color: #000000;
          --design-hint-background: lightgreen;
          --design-hint-color: #000000;
          --design-grid: #000000;
          --design-black33-background:rgba(0,0,0,.33;
        • D
          D
          der-eine
          #218
          Gibt es jetzt schon einen neuen Thread wo nur mdui-Vis-Views drinnen sind? Könnte noch Anregungen brauchen. 😁
          • D der-eine
            Dominik F.D
            Dominik F.D
            Dominik F.
            #219
            @der-eine
            das wäre eine feine Sache....besonders bei der Vis für Heizungssteuerung bräuchte ich Anregungen :D
            P 1 Antwort Letzte Antwort
            • D
              D
              der-eine
              #220
              Habe einen neuen Post erstellt und hoffe das ist ok? Wäre nett wenn sich ein paar beteiligen :-)
              https://forum.iobroker.net/topic/31335/material-design-style-vis-views-zur-inspiration
              • mickymM
                mickymM
                mickym
                #221
                So ich habe mal wieder ein Problem - ich steh noch am Anfang - aber ich versuche doch wenigstens die Dinge nun soweit auszutesten, um ein Fehlverhalten bzw. eine Fehlkonfiguration möglichst einzugrenzen. Ich hab mir nun erst mal eingebildet - als Übersichtsseite mit so einem Grundriss - zumindest bei großen Bildschirmen - zu beginnen - vielleicht ändert sich das auch wieder.
                Mir ist dabei ein Problem bei der Navigation aufgefallen - und ich dachte erst es liegt an meinen Seiten oder das ich das widget-in 8 view nicht als content Seite nutzen kann - aber das kann ich nun ausschließen.
                Aufgrund des Grundrisses nutze ich die vis-Funktionalität als Startseiten nun je Auflösung verschiedene Startseiten (defaults) zu nutzen - die Folgeseiten kann ich dann ja mit dem responsive Design machen - so die Idee. Eine Layer-Struktur über das man die Widgets mit skalieren kann - habe ich irgenwie nicht gefunden - insofern scheidet das Flex damit erst mal aus.
                Da in dem Demo-Projekt alles funktioniert - gehe ich davon aus, dass ich irgendwo einen Fehler mache - aber ich weiß nicht wo.
                Rufe ich meine Defaultseiten beim 1. Mal aus dem Browser auf - wird der Seiteninhalt mit Hintergrundfarbe gefüllt - klickt man dann aus dem Menü heraus - ohne auf eine andere Seite navigiert zu haben, dann bleibt das Browserfenster leer.
                Resultat ist eine leere Seite, wenn man kein Menüpunkt auswählt
                Wenn man dann allerdings einmal intern wieder auf die gleiche Seite navigiert hat - dann funktioniert die Anzeige einwandfrei!!!
                Ich hoffe Ihr Profis könnt helfen - sorry will auch nicht den Thread vollmüllen, können auch gerne einen anderen Thread aufmachen - aber vielleicht habt ihr ja ein paar Tipps!
                Danke schon Mal!
                • D der-eine
                  UhulaU
                  UhulaU
                  Uhula
                  #222
                  @der-eine Generell eine gute Idee, wobei es gut wäre, wenn du statt "[Material Design Style]" besser "[Material Design CSS]" verwendest, weil auch die Widgets von @Scrounger als "Material Design Style" zu verstehen sind. Wenn du in der Themen-Überschrift noch "MDCSS v2" unterbringst, wird dein Thema auch aus meinen 1.Beitrag heraus gefunden.
                  Ein Link auf den 1.Beitrags dieses Themas hier wäre auch gut, damit das MDCSS v2 von Interessierten gleich gefunden wird - und die von mir erstellten Views auch. Danke.
                  Freut mich, wenn es genutzt wird.
                  • mickymM mickym
                    Danke schon Mal!
                    UhulaU
                    UhulaU
                    Uhula
                    #223
                    @mickym Wenn du nur ein Widget skalieren möchtest, dann geht das über die "transform" Eigenschaft des Widgets in dem du dort "scale(f)" eingibst. f ist der Faktor 1=100% 0.5=50% 2=200% usw. Alternativ kannst du auch "mdui-scale-nnn" Klassen zuweisen. Schau mal in die CSS, dort stehen die drin.
                    /* Skalierungen */
                    .mdui-scale-010 { transform: scale(0.1); transform-origin: 0% 0%; }
                    .mdui-scale-020 { transform: scale(0.2); transform-origin: 0% 0%; }
                    .mdui-scale-025 { transform: scale(0.25); transform-origin: 0% 0%; }
                    .mdui-scale-030 { transform: scale(0.30); transform-origin: 0% 0%; }
                    .mdui-scale-033 { transform: scale(0.33); transform-origin: 0% 0%; }
                    .mdui-scale-040 { transform: scale(0.40); transform-origin: 0% 0%; }
                    .mdui-scale-050 { transform: scale(0.5); transform-origin: 0% 0%; }
                    .mdui-scale-060 { transform: scale(0.6); transform-origin: 0% 0%; }
                    .mdui-scale-066 { transform: scale(0.66); transform-origin: 0% 0%; }
                    .mdui-scale-070 { transform: scale(0.7); transform-origin: 0% 0%; }
                    .mdui-scale-075 { transform: scale(0.75); transform-origin: 0% 0%; }
                    .mdui-scale-080 { transform: scale(0.8); transform-origin: 0% 0%; }
                    .mdui-scale-090 { transform: scale(0.9); transform-origin: 0% 0%; }
                    • UhulaU Uhula
                      D
                      D
                      der-eine
                      #224
                      @Uhula danke für die Hinweise hab ich angepasst. Würde mich freuen, wenn Du Dich auch an diesem Beitrag beteiligst. 😀
                      • foxriver76F
                        foxriver76F
                        foxriver76
                        #225
                        Hi @Uhula,
                        mal wieder eine mehr oder minder blöde Frage. Ich habe einen Kamera Stream, der wird auf einem Webserver auf meinem Host in 1280x720px als mjpeg ausgegeben. Diesen versuche ich aktuell in die klassische MDCSS Logik einzubauen, sprich habe ganz normal Page->Content und auf der Card dann die Seite als iFrame eingebunden. In den meisten Browsern insbesondere Mobil, ist die Anzeige leider nicht responsiv und das iFrame bekommt Scrollbalken. Wenn ich die Seite hinter dem iFrame aufrufe, skaliert der Stream allerdings durchaus mit der Fenstergröße. Hast du hierzu eine Idee, wo das Problem liegen könnte? Einziger Browser wo es einigermaßen läuft ist Firefox auf dem Desktop (mobil auch nicht). Anbei mal zwei Bilder.
                        Mobil vis:
                        Mobil direkter Aufruf:
                        Videotutorials & mehr
                        • foxriver76F foxriver76
                          Hi @Uhula,
                          Mobil vis:
                          UhulaU
                          UhulaU
                          Uhula
                          #226
                          @foxriver76 Warum nutzt du ein iFrame dafür, wenn du einen mpeg Stream hast? Ich nutze das basic-Image Widget und gebe bei "Quelle" dann die URL an
                          Quelle: "http://192.168.2.133/video2.mjpg?user=Viewer&pw=XXXX"
                          darin skaliert das Bild. Alternativ für dich möglich?
                          • UhulaU Uhula
                            foxriver76F
                            foxriver76F
                            foxriver76
                            schrieb am zuletzt editiert von foxriver76
                            #227
                            @Uhula Ah, ja.. vielen Dank - das schaut schon mal mit am Besten aus. Das hatte ich schon mal kurz und hat am Desktop net gepasst, deshalb wieder außer Betracht gezogen. Habe dann nur das Problem, dass es am Desktop etwas unschick ausschaut. Vermutlich muss ich hart die Anzahl cols rows vergeben? Aktuell hat die card im cont die folgenden CSS Klassen: mdui-card-raised mdui-cols-4-toc-20 mdui-rows-4-tor-16 mdui-order-1 jetzt passiert auf dem Desktop folgendes Verhalten:
                            Er nimmt sich die Cols, die er hat, jedoch nicht die Rows um das Image komplett zu zeigen. Weite und Höhe des Basic Image Widgets sind jeweils calc(100% - paar Pixel) Wenn ich das Fenster auf Smartphone Größe klein ziehe, passt es auch echt gut. Sprich das Problem ist nur noch die Höhe der Card.
                              UhulaU
                              UhulaU
                              Uhula
                              #228
                              @foxriver76 In der page-View, dort im content-Widget hast du sicher "mdui-flex" gesetzt - damit werden die Breitenanpassungen (MM-toc-NN) aktiviert. Wenn auch die Höhen (MM-tor-NN) angepasst werden sollen, musst du im content-Widget zusätzlich "mdui-flex-stretch" setzen.
                              • UhulaU Uhula
                                foxriver76F
                                foxriver76F
                                foxriver76
                                #229
                                @Uhula Hmm.. das ist gesetzt.
                                Edit: Deja-vu .. height war vom kopieren auf der card gesetzt 🤦
                                • D
                                  D
                                  der-eine
                                  #230
                                  @Uhula bin schon den ganzen Nachmittag dran aber bekomme es einfach nicht hin...
                                  Ich hätte gerne einen türkisen Ring der animiert einen Farbverlauf anzeigt. Er soll
                                  die LED eines Alexa Smartspeakers imitieren. Hättest Du eine Idee wie ich das machen könnte?
                                  AlexaLed.mov
                                  Würde gut zur Alexatimer-View passen...
                                  • D der-eine
                                    AlexaLed.mov
                                    UhulaU
                                    UhulaU
                                    Uhula
                                    #231
                                    @der-eine Wenn es ohne Verlauf geht, dann sollte dir dieses helfen. Einfach in die Projekt CSS kopieren, ein basic-html in die View einfügen und "mdui-loader" als CSS-Class zuweisen.
                                    .mdui-loader {
                                      border:8px solid;
                                      border-radius:50%;
                                      border-color:blue aqua aqua aqua;
                                      animation:mdui-loader-spin 2s linear infinite;
                                    @keyframes mdui-loader-spin{
                                      100%{transform:rotate(360deg)}
                                    • UhulaU
                                      UhulaU
                                      Uhula
                                      #232
                                      Neu:
                                      • [Vorlage] MDCSS v2: Homatic-Log in vis anzeigen
                                      Bisher:
                                      • [Vorlage] MDCSS v2: ioBroker Log in vis anzeigen
                                      • [Vorlage] MDCSS v2: ping-Adapter in vis anzeigen
                                      • [Vorlage] MDCSS v2: tr-064/devices-Adapter in vis anzeigen
                                      • Dominik F.D Dominik F.
                                        @der-eine
                                        P
                                        P
                                        Pittini
                                        #233
                                        @Dominik-F sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                                        Falls noch nicht bekannt: Hier ein Vis für Heizungssteuerung mit "Unterbau" durch MD2 von @Uhula. Vorraussetzung Du verwendest den HeatingControl Adapter.
                                        • liv-in-skyL
                                          liv-in-skyL
                                          #234
                                          ich versuche gerade meinen vis-editor zu verschönern - hat das schon jmd gemacht und hätte eine vorlage ?
                                          das sind meine ersten schritte mit diesen css einstellungen (respekt - tolle und vor allem viel arbeit ) und evtl könnt mir jmd sagen, ob ich die farben ändern kann
                                          roter pfeil -die schriftfarbe in schwarz
                                          lila - das icon sichtbarer - evt. dunkelgrün
                                          blau - den hintergrund leicht gräulich
                                          84.2k
