  2. English
  3. ioBroker general
  4. How to lower disk writes (for extending life of an sd card)
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
states.jsonwrite interval
16 Beiträge 5 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • Tomasz NowakT
    Tomasz NowakT
    Tomasz Nowak
    I'm new to ioBroker but I have been using FHEM, deCONZ, Node-RED, etc. before.
    I have successfully installed ioBroker in Docker (using Portainer) on yet another Raspberry Pi 3B+ in my house.
    It runs on Sandisk Industrial microsd card and and I'd like to to stay that way.
    I checked system disk writes with iotop and found out that iobroker.js-controller is writing relatively much to a files:
    /opt/iobroker/iobroker-data/states.json
    /opt/iobroker/iobroker-data/states.json.bak
    I understand, that this is a permanent json storage of in-memory states database and is written probably every 30 seconds.
    Is this (frequent interval) required for anything?
    My RPi3 won't be powered off so keeping all in memory is fine and if reboot happens I don't care about states or its history - they would be just read from devices(es) again.
    So my question is - how do I extend write interval to states.json to 8 or 24 hours?
    I didn't find such setting in iobroker.json
    paul53P apollon77A 2 Antworten Letzte Antwort
    • Tomasz NowakT Tomasz Nowak
      paul53P
      paul53P
      @Tomasz-Nowak sagte:
      In file node_modules/iobroker.js-controller/lib/states/statesInMemFileDB.js search for 30000 and change it to a higher value (7 times). Then iobroker restart.
      • Tomasz NowakT
        Tomasz NowakT
        Tomasz Nowak
        schrieb am zuletzt editiert von Tomasz Nowak
        Thanks, works like a charm. I've put 28800000 for 8-hour save interval and instantly sd card writes dropped to almost zero on that PRI. Would be great if that interval could be configurable somewhere in the future
          paul53P
          paul53P
          @Tomasz-Nowak sagt:
          Please create an issue on Github.
            apollon77A
            apollon77A
            @Tomasz-Nowak sagte in How to lower disk writes (for extending life of an sd card):
            I don't know if it is really that easy as soon as you have more complex scripts with "Non device states". If you choose that way then you need to make sure that all your scripts can work with "missing" "outdated" state values ... this will be likely hard when you do not only use device values, but also logical values.
            So when you increase it that much - know what you are doing and which effects it has!!
            • apollon77A apollon77
              paul53P
              paul53P
              @apollon77 sagte:
              A reboot / killing of ioBroker immediately writes the states from RAM to the file. Only in case of a system crash (power failure) such a long time is problematic.
                @apollon77 sagte:
                apollon77A
                apollon77A
                @paul53 ... or a process crash (yes there is come code that tries to write it also when crashing) ... but :-) (e.g. a SIGTERM because of OOM might also not write values).
                It is all about "knowing what one is doing"
                • Tomasz NowakT
                  Tomasz NowakT
                  Tomasz Nowak
                  @paul53 , @apollon77
                  Thanks for your hints, guys. For now I'm just handling Ecovacs Deebot vacuuming robot (and Daikin aircon soon, probably) over MQTT with no logic within ioBroker. So I hope I don't risk any house disaster with that setting
                  @paul53, I've created an issue, thanks.
                  • DutchmanD
                    DutchmanD
                    Dutchman
                    just as suggestion, to avoid load read/write loads on storage and move the to Memory isn't Redis providing more efficient state handling here ?
                    • Tomasz NowakT
                      Tomasz NowakT
                      Tomasz Nowak
                      I thought about it but AFAIK Redis also needs to write to disk / sd card. I have relatively small number of states so I believe creating yet another docker instance for Redis would be kind of overkill in my case.
                      MicM 1 Antwort Letzte Antwort
                        MicM
                        MicM
                        Mic
                        schrieb am zuletzt editiert von Mic
                        @Tomasz-Nowak
                        I am using Redis successfully for several months. I have installed it on the same system (Debian) on which ioBroker is installed - but no Raspberry experience (I am using a Zotac barebone with Proxmox), though.
                        See: https://github.com/ioBroker/ioBroker.js-controller#state-and-objects-databases-and-files
                        Also, see: https://redis.io/topics/persistence
                        You may want to look into it again, but not sure how the performance is gonna be on a Raspberry.
                        Tomasz NowakT 1 Antwort Letzte Antwort
                        • MicM Mic
                          @Tomasz-Nowak
                          Tomasz NowakT
                          Tomasz NowakT
                          Tomasz Nowak
                          @Mic
                          I've read that before. They say good for many objects such has 10000 for performance reasons. I have like 50 objects :)
                          And I don't want make it more complex (you don't install another services in docker instance, you need another docker)
                          • DutchmanD
                            DutchmanD
                            Dutchman
                            schrieb am zuletzt editiert von Dutchman
                            guys wait ...., don't ix performance and io topics please :)
                            we are discussing write access to storage, Redis works in memory so less write on disk/card was my hypothese :)
                            • DutchmanD Dutchman
                              paul53P
                              paul53P
                              @Dutchman sagte:
                              Per default Redis writes every 5 minutes to disk/card.
                                @Dutchman sagte:
                                DutchmanD
                                DutchmanD
                                Dutchman
                                @paul53 sagte in How to lower disk writes (for extending life of an sd card):
                                @Dutchman sagte:
                                Better than every 30 seconds 🤷‍♂️
                                  @Dutchman sagte:
                                  MicM
                                  MicM
                                  Mic
                                  @Dutchman sagte in How to lower disk writes (for extending life of an sd card):
                                  Exactly, and the default value can certainly be increased to whatever is needed. I would give Redis a try.
                                  Also,
                                  I would assume this statement in the documentation was just made for the ease of use of ioBroker in general: Without like Redis, typically ioBroker's performance is good if you have way less than 10000+ objects. You are having a different use case (limited disc r/w per period). Not sure how the performance (like CPU and memory usage) of Redis is on a Raspberry, but I guess pretty low.
                                  84.0k
