  2. English
  3. ioBroker general
  4. How to lower disk writes (for extending life of an sd card)
Geplant Angeheftet Gesperrt Verschoben ioBroker general
states.jsonwrite interval
16 Beiträge 5 Kommentatoren 2.6k Aufrufe 3 Beobachtet
    @apollon77 sagte:
    this will be likely hard when you do not only use device values, but also logical values.
    A reboot / killing of ioBroker immediately writes the states from RAM to the file. Only in case of a system crash (power failure) such a long time is problematic.
    apollon77A
    apollon77A
    @paul53 ... or a process crash (yes there is come code that tries to write it also when crashing) ... but :-) (e.g. a SIGTERM because of OOM might also not write values).
    It is all about "knowing what one is doing"
    • Tomasz NowakT
      Tomasz NowakT
      Tomasz Nowak
      schrieb am zuletzt editiert von Tomasz Nowak
      @paul53 , @apollon77
      Thanks for your hints, guys. For now I'm just handling Ecovacs Deebot vacuuming robot (and Daikin aircon soon, probably) over MQTT with no logic within ioBroker. So I hope I don't risk any house disaster with that setting
      @paul53, I've created an issue, thanks.
      • DutchmanD
        DutchmanD
        Dutchman
        just as suggestion, to avoid load read/write loads on storage and move the to Memory isn't Redis providing more efficient state handling here ?
        • Tomasz NowakT
          Tomasz NowakT
          Tomasz Nowak
          I thought about it but AFAIK Redis also needs to write to disk / sd card. I have relatively small number of states so I believe creating yet another docker instance for Redis would be kind of overkill in my case.
          MicM 1 Antwort Letzte Antwort
          • Tomasz NowakT Tomasz Nowak
            MicM
            MicM
            Mic
            schrieb am zuletzt editiert von Mic
            @Tomasz-Nowak
            I am using Redis successfully for several months. I have installed it on the same system (Debian) on which ioBroker is installed - but no Raspberry experience (I am using a Zotac barebone with Proxmox), though.
            See: https://github.com/ioBroker/ioBroker.js-controller#state-and-objects-databases-and-files
            Also, see: https://redis.io/topics/persistence
            You may want to look into it again, but not sure how the performance is gonna be on a Raspberry.
            Tomasz NowakT 1 Antwort Letzte Antwort
            • MicM Mic
              @Tomasz-Nowak
              Tomasz NowakT
              Tomasz NowakT
              Tomasz Nowak
              @Mic
              I've read that before. They say good for many objects such has 10000 for performance reasons. I have like 50 objects :)
              And I don't want make it more complex (you don't install another services in docker instance, you need another docker)
              • DutchmanD
                DutchmanD
                Dutchman
                schrieb am zuletzt editiert von Dutchman
                guys wait ...., don't ix performance and io topics please :)
                we are discussing write access to storage, Redis works in memory so less write on disk/card was my hypothese :)
                • DutchmanD Dutchman
                  paul53P
                  paul53P
                  @Dutchman sagte:
                  Per default Redis writes every 5 minutes to disk/card.
                  Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                    @Dutchman sagte:
                    DutchmanD
                    DutchmanD
                    Dutchman
                    @paul53 sagte in How to lower disk writes (for extending life of an sd card):
                    @Dutchman sagte:
                    Better than every 30 seconds 🤷‍♂️
                      @Dutchman sagte:
                      MicM
                      MicM
                      Mic
                      @Dutchman sagte in How to lower disk writes (for extending life of an sd card):
                      Exactly, and the default value can certainly be increased to whatever is needed. I would give Redis a try.
                      Also,
                      @Tomasz-Nowak sagte in How to lower disk writes (for extending life of an sd card):
                      I would assume this statement in the documentation was just made for the ease of use of ioBroker in general: Without like Redis, typically ioBroker's performance is good if you have way less than 10000+ objects. You are having a different use case (limited disc r/w per period). Not sure how the performance (like CPU and memory usage) of Redis is on a Raspberry, but I guess pretty low.
                      84.1k
