  4. JavaScript
  5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
1.5k Beiträge 53 Kommentatoren 818.2k Aufrufe 52 Beobachtet
  • sigi234S sigi234
    @ticaki
    Sieht besser aus, aber:
    sayit.0	2020-03-11 13:50:00.941	info	(15524) saying: undefined
    sayit.0	2020-03-11 13:49:51.907	info	(15524) saying: C:\Program Files\iobroker\Test\node_modules\iobroker.sayit/gong.mp3
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at processImmediate (timers.js:658:5)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at runCallback (timers.js:705:18)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4851:37)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:450:25)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1123:38)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at Object.<anonymous> (script.js.Alexa.Ansage_UWZ4:669:5)
    javascript.0	2020-03-11 13:49:37.115	warn	(9532) at checkWarningsMain (script.js.Alexa.Ansage_UWZ4:1160:13)
    javascript.0	2020-03-11 13:49:37.114	warn	(9532) at sendMessage (script.js.Alexa.Ansage_UWZ4:1240:13)
    javascript.0	2020-03-11 13:49:37.114	warn	(9532) at setState (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1426:20)
    javascript.0	2020-03-11 13:49:37.111	warn	(9532) You are assigning a undefined to the state "alexa2.0.Echo-Devices.G090XXXXXXXXX.Commands.announcement" which expects a string. Please fix your code to use a string or change the state type
    T
    T
    ticaki
    #184
    @sigi234
    Fehler behoben v.x4 ab jetzt ladbar. Klammer am falschen Ort :(
    Großen Dank für das testen.
    @MartyBr
    uGemeinde uLandkreis. ist das was in AGS für deinen Ort/Kreis steht ohne die kryptischen Zeichen. Da die in den Meldungen gelegentlich sonst was schreiben muß ich versuchen das zu finden was am nächsten dran ist. Oder es gibt "für ihre Region" und wenns nur eines zur Auswahl gibt halt das (Bundesland meist)
    z.B.:
    Amtliche WARNUNG vor STURMBÖEN des DWD(ALPHA) für Kreis Bad xxxxxxx:
    Hochwasserinformation Rheinland-Pfalz von Nina(ALPHA) für ihre Region:
    Das (Alpha) bedeutet das DEBUG auf true steht.
    Spenden
    M sigi234S 2 Antworten Letzte Antwort
    • T ticaki
      @sigi234
      @MartyBr
      z.B.:
      M
      M
      MartyBr
      #185
      @ticaki Das ist diese Liste beim Bund:
      https://warnung.bund.de/assets/json/suche_channel.json
      Das muss im NINA-Adapter eingetragen werden.
      Martin
      Homematic und Homematic IP
      • T ticaki
        @sigi234
        @MartyBr
        z.B.:
        sigi234S
        sigi234S
        #186
        @ticaki sagte in [Script] DWD/UWZ Warnungen als Pushnachrichten:
        Welche Zeile, dann brauch ich sonst nix ändern.
        • M MartyBr
          T
          T
          ticaki
          #187
          @MartyBr sagte in [Script] DWD/UWZ Warnungen als Pushnachrichten:
          Der Adapter braucht die AGS Nummer
          Ich brauche den ausgeschriebenen Kreis und Ort in möglichst kurzer aber eindeutiger Schreibweise
          Spenden
          • T ticaki
            M
            M
            MartyBr
            #188
            @ticaki Okay. Mein Ortsnamen besteht aus zwei mit Leerschritt verbundenen Namen. Ist das Okay?
            Martin
            • sigi234S sigi234
              T
              T
              ticaki
              #189
              @sigi234
              1160           sendMessage(getPushModeFlag(collectMode)&SPEAK, pushMsg);
              Spenden
              • M MartyBr
                T
                T
                ticaki
                #190
                Ja das ist kein Problem.
                Spenden
                • T ticaki
                  M
                  M
                  MartyBr
                  #191
                  @ticaki Ich habe mal die neueste TestVersion eingespielt und warte nun auf Katastrophen und Unwetterwarnungen.
                  Martin
                  • M MartyBr
                    T
                    T
                    ticaki
                    #192
                    @MartyBr
                    @sigi234
                    vx.5
                    766ff   if (mode&DWD) mode = switchFlags(mode, DWD,!!(uPushdienst&dwdManpushdienst));
                            if (mode&UWZ) mode = switchFlags(mode, UWZ,!!(uPushdienst&uwzManpushdienst));
                            if (mode&NINA) mode = switchFlags(mode, NINA,!!(uPushdienst&ninaManpushdienst));
                    Falls noch was kommt guck ich heute abend... Hab auch noch was, will das aber erst testen.
                    Spenden
                    • T ticaki
                      @MartyBr
                      @sigi234
                      vx.5
                      sigi234S
                      sigi234S
                      #193
                      @ticaki
                      javascript.0	2020-03-11 14:33:04.191	warn	(9532) at processImmediate (timers.js:658:5)
                      javascript.0	2020-03-11 14:33:04.191	warn	(9532) at tryOnImmediate (timers.js:676:5)
                      javascript.0	2020-03-11 14:33:04.191	warn	(9532) at runCallback (timers.js:705:18)
                      javascript.0	2020-03-11 14:33:04.191	warn	(9532) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4851:37)
                      javascript.0	2020-03-11 14:33:04.191	warn	(9532) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:450:25)
                      javascript.0	2020-03-11 14:33:04.190	warn	(9532) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1123:38)
                      javascript.0	2020-03-11 14:33:04.190	warn	(9532) at Object.<anonymous> (script.js.Alexa.Ansage_UWZ5:669:5)
                      javascript.0	2020-03-11 14:33:04.190	warn	(9532) at checkWarningsMain (script.js.Alexa.Ansage_UWZ5:1160:13)
                      javascript.0	2020-03-11 14:33:04.190	warn	(9532) at sendMessage (script.js.Alexa.Ansage_UWZ5:1240:13)
                      javascript.0	2020-03-11 14:33:04.190	warn	(9532) at setState (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1426:20)
                      javascript.0	2020-03-11 14:33:04.189	warn	(9532) You are assigning a undefined to the state "alexa2.0.Echo-Devices.Gxxxxxxxxxxxxxxxx.Commands.announcement" which expects a string. Please fix your code to use a string or change the state type t
                      sayit.0	2020-03-11 14:32:48.786	info	(15524) saying: undefined
                      • sigi234S sigi234
                        @ticaki
                        T
                        T
                        ticaki
                        #194
                        @sigi234
                        Den Fehler kannst du so beheben. Aber in dem Teil ist noch der Wurm drin, ich muß das heute Abend mal genauer anschauen.
                        1160           sendMessage(getPushModeFlag(collectMode)&SPEAK, '', pushMsg);
                        Spenden
                        • T ticaki
                          @sigi234
                          sigi234S
                          sigi234S
                          #195
                          @sigi234
                          Jupp:
                          sayit.0	2020-03-11 15:14:55.844	info	(19356) saying: Alle Warnmeldungen wurden aufgehoben.
                          sayit.0	2020-03-11 15:14:46.823	info	(19356) saying: C:\Program Files\iobroker\Test\node_modules\iobroker.sayit/gong.mp3
                          • T
                            T
                            ticaki
                            #196
                            v0.95.7.6
                            • Sprachausgabe geht wieder
                            Sorry dafür und Danke fürs testen.
                            Spenden
                            • T ticaki
                              v0.95.7.6
                              sigi234S
                              sigi234S
                              #197
                              Sorry dafür
                              Brauchst dich nicht dafür zu entschuldigen, ist ja eine Beta und zum testen.
                              • T
                                T
                                ticaki
                                #198
                                Weitere Fehlerbehebungen und Verbesserungen für Nina diesmal.
                                v0.95.8
                                • Nina geht wieder
                                • Nina: Regionsname verbessert
                                • mehr Debugausgaben für (DEBUG = true)
                                Ist jemand so nett und prüft mal die Funktionen unter .config. durch?
                                Spenden
                                • T
                                  T
                                  ticaki
                                  #199
                                  v0.95.8.1
                                  • Nina versendet kurz hintereinander "aufgehoben" und "Warnung vor" Nachrichten (behoben) aber noch nicht ausreichend getestet
                                  • Nina, DWD, UWZ: 1 Logausgabe hinzugefügt, die anzeigt das eine neue Warnung hinzugefügt wurde.
                                  v0.95.8.2
                                  • kleiner Fehler: "Insgesamt 1/3" gibt es jetzt beim manuellen Auslösen der Nachrichten, nicht beim automatischen.
                                  Der Ninateil löscht jetzt keine Warnungen mehr wegen irgendwas das vom Adapter kommt. Die werden ca. 90 Minuten nach dem kein aktiver Datenpunkt oder wenn sie abgelaufen sind entfernt. Hatte heute morgen 2 x 2 Meldungen zu der selben Warnung von Nina. Jedesmal hat der Adapter ins Log eingetragen, dass er eine Datenquelle nicht laden konnte.
                                  Spenden
                                  • T ticaki
                                    v0.95.8.1
                                    v0.95.8.2
                                    sigi234S
                                    sigi234S
                                    #200
                                    @ticaki
                                    Ok, Fragen:
                                    Kann ich bei einen neuen Skript Update immer nur den Code austauschen um nicht jedesmal die Konfig anzupassen?
                                    Dann was/ist macht der DP javascript.0.wetterwarnung.alive
                                    Müssten nicht bei deaktivieren des Automatik Modus die DP auf false sein?
                                    • T
                                      T
                                      ticaki
                                      #201
                                      1. Du kannst immer nur den Code austauschen, wenn im Begleittext nichts von neuen/geänderten Einstellungen steht. Das kommt sehr selten vor, dass ich da was ändere.
                                      2. javascript.0.wetterwarnung.alive ist ein "Hilfsdatenpunkt" für das Skript der hat folgende Funktion:
                                      • er zeigt DIR an ob das Script läuft (wobei ich nicht weiß ob der auch bei einem Fehler zurück gesetzt wird)
                                      • er bietet dem Script einen Datenpunkt über den es sich neustarten kann.
                                      wenn dieser auf false ist und das Script wird beendet, startet das Script neu. Ist er true, setzt die restart funktion den Punkt auf false und endet.
                                      1. 👍
                                      Spenden
                                      • sigi234S sigi234
                                        @ticaki
                                        Ok, Fragen:
                                        T
                                        T
                                        ticaki
                                        #202
                                        @sigi234 sagte in [Script] DWD/UWZ Warnungen als Pushnachrichten:
                                        erledigt.
                                        Das Script speichert aber nicht die alten Werte. Wenn etwas ausgeschaltet wird, geht alles auf unwahr. Wenn etwas eingeschaltet wird alles auf wahr.
                                        EDIT:
                                        Das Betrifft .on .dwd .uwz .nina z.B. umschalten auf .dwd true auto false -> schaltet die manuellen DWD Möglichkeiten auf true und die automatischen auf false
                                        v0.95.8.2
                                        • s.o
                                        • KK
                                        KK = keine Konfigurationsänderung nur Code kopieren
                                        EDIT2:
                                        19:00 Bisher läuft es bei mir ohne Auffälligkeiten. Hab aber keine UWZ Meldungen.
                                        Spenden
                                        • T
                                          T
                                          ticaki
                                          #203
                                          v0.95.9
                                          • Alexa Sprachfehler behoben "...bla bla Frost -2.2 weitere neue Warnungen" (Frost minus zwei Punkt Zwei weitere neue Warnungen)
                                          • Pushover:
                                            Überschrift ist eingefügt
                                            Schlagzeile ist farbig
                                            Links werden hinterlegt
                                            Priorität = 1 wenn Warnung >= attentionWarningLevel (4)
                                            Soundoption
                                            Deviceoption
                                          • iogo:
                                            mehrere Nutzer sollten möglich sein, mehr geht damit leider soweit ich sehe nicht.
                                            Fehler: hatte Nachricht und Überschrift vertauscht.
                                          • Farben-Bedeutung:
                                            0 - Grün
                                            1 - Dunkelgrün
                                            2 - Gelb Wetterwarnungen (Stufe 2)
                                            3 - Orange Warnungen vor markantem Wetter (Stufe 3)
                                            4 - Rot Unwetterwarnungen (Stufe 4) // im Grunde höchste Stufe in diesem Skript.
                                            5 - Violett Warnungen vor extremem Unwetter (nur DWD/ Weltuntergang nach aktueller Erfahrung)
                                          -KK bis auf den Codeschnipsel unten
                                          // das hier einfügen ab 177
                                          177      /* Konfiguration Pushover */
                                          178      var uPushoverDeviceName     = '';
                                          179      var uPushoverSound          = '';
                                          Spenden
                                          84.2k
