  4. ioBroker startet nicht
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
funktioniertnicht
50 Beiträge 4 Kommentatoren 6.8k Aufrufe 1 Beobachtet
  • N Nier
    @haselchen
    root@NiermannSmartHome:/opt/iobroker# npm -v
    6.13.4
    root@NiermannSmartHome:/opt/iobroker# nodejs -v
    v10.19.0
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    haselchenH Offline
    haselchenH Offline
    haselchen
    @Nier
    dann jetzt
    npm i iobroker.js-controller
    N 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @Nier
      dann jetzt
      N Offline
      N Offline
      Nier
      @haselchen said in ioBroker startet nicht:
      Leider gehts immer noch nicht
      root@NiermannSmartHome:/opt/iobroker# npm i iobroker.js-controller
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.13.4
      > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN winston-daily-rotate-file@4.4.2 requires a peer of winston@^3 but none is installed. You must install peer dependencies yourself.
      npm WARN winston-syslog@2.4.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      + iobroker.js-controller@2.2.9
      updated 1 package and audited 4642 packages in 50.317s
      2 packages are looking for funding
       run `npm fund` for details
      found 50 vulnerabilities (32 low, 18 high)
       run `npm audit fix` to fix them, or `npm audit` for details
      haselchenH AlCalzoneA HomoranH 3 Antworten Letzte Antwort
      • N Nier
        NPM version: 6.13.4
        haselchenH Offline
        haselchenH Offline
        haselchen
        @Nier
        Hilft wohl nur noch der Fixer
        curl -sL https://iobroker.net/fix.sh | bash -
          @Nier
          N Offline
          N Offline
          Nier
          @haselchen
          was kann ich dagegen tin?
          root@NiermannSmartHome:/opt/iobroker# iobroker stop
          root@NiermannSmartHome:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
          library: loaded
          Library version=2020-01-30
          ioBroker or some processes are still running:
           io.cloud.0
           io.yahka.0
           io.ring.0
           io.broadlink2.0
           io.alexa2.0
           io.mihome.0
           io.text2command.0
           io.email.0
           io.web.0
           io.tado.0
           io.meross.0
          Please stop them first and try again!
          • N Nier
            @haselchen
            library: loaded
             io.cloud.0
             io.yahka.0
             io.ring.0
             io.broadlink2.0
             io.alexa2.0
             io.mihome.0
             io.text2command.0
             io.email.0
             io.web.0
             io.tado.0
             io.meross.0
            haselchenH Offline
            haselchenH Offline
            haselchen
            @Nier
            Versuch mal
            pkill iobroker
              @Nier
              Versuch mal
              pkill iobroker
              N Offline
              N Offline
              Nier
              @haselchen Leider nein :( Danke dir aber für diene Zeit
              root@NiermannSmartHome:/opt/iobroker# pkill iobroker
              library: loaded
               io.cloud.0
               io.yahka.0
               io.ring.0
               io.broadlink2.0
               io.alexa2.0
               io.mihome.0
               io.text2command.0
               io.email.0
               io.web.0
               io.tado.0
               io.meross.0
              • N Nier
                library: loaded
                 io.cloud.0
                 io.yahka.0
                 io.ring.0
                 io.broadlink2.0
                 io.alexa2.0
                 io.mihome.0
                 io.text2command.0
                 io.email.0
                 io.web.0
                 io.tado.0
                 io.meross.0
                haselchenH Offline
                haselchenH Offline
                haselchen
                @Nier
                Und ein iobroker stop
                Eventuell mit sudo davor
                  @Nier
                  N Offline
                  N Offline
                  Nier
                  • N Nier
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @Nier
                    Kannst natürlich jeden Adapter einzeln stoppen
                    iobroker stop adapterName
                      @Nier
                      N Offline
                      N Offline
                      Nier
                      @haselchen Wenigstens etwas was geklappt hat :P Aber leider kommt immer noch die gleiche meldung wie vorher
                      This adapter cannot be installed directly from github.
                      You must install it from npm.
                      Write for that "npm install iobroker.admin" in according directory.
                      root@NiermannSmartHome:~# curl -sL https://iobroker.net/fix.sh | bash -#
                      bash: -#: Ungültige Option
                      Aufruf: bash [Lange GNU Option] [Option] ...
                                      bash [Lange GNU Option] [Option] Script-Datei ...
                      Lange GNU Optionen:
                              --debug
                              --debugger
                              --dump-po-strings
                              --dump-strings
                              --help
                              --init-file
                              --login
                              --noediting
                              --noprofile
                              --norc
                              --posix
                              --rcfile
                              --restricted
                              --verbose
                              --version
                      Shell-Optionen:
                              -ilrsD oder -c Kommando oder -O shopt_option            (Nur Aufruf)
                              -abefhkmnptuvxBCHP oder Option -o
                      library: loaded
                          Welcome to the ioBroker installation fixer!
                          Script version: 2020-01-25
                          Installing prerequisites (1/3)
                      OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                      Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                      OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                      OK:4 http://ftp.de.debian.org/debian stretch Release
                      OK:5 https://deb.nodesource.com/node_10.x stretch InRelease
                      Installed gcc-c++
                      Installed python-dev
                          Checking ioBroker user and directory permissions (2/3)
                          Checking autostart (3/3)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      • N Offline
                        N Offline
                        Nier
                        root@NiermannSmartHome:~# install iobroker.admin
                        install: Fehlender Zieldatei‐Operand hinter 'iobroker.admin'
                        „install --help“ liefert weitere Informationen.
                        root@NiermannSmartHome:~# npm install iobroker.admin
                        npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                        npm WARN root No description
                        npm WARN root No repository field.
                        npm WARN root No README data
                        npm WARN root No license field.
                        + iobroker.admin@4.0.5
                        updated 1 package and audited 1050 packages in 5.777s
                        found 0 vulnerabilities
                        • N Nier
                          Lange GNU Optionen:
                                  --debug
                                  --debugger
                                  --dump-po-strings
                                  --dump-strings
                                  --help
                                  --init-file
                                  --login
                                  --noediting
                                  --noprofile
                                  --norc
                                  --posix
                                  --rcfile
                                  --restricted
                                  --verbose
                                  --version
                          Shell-Optionen:
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @Nier
                          Da steht erfolgreich?
                          Reboot gemacht ?
                            @Nier
                            Reboot gemacht ?
                            N Offline
                            N Offline
                            Nier
                            @haselchen Ja habe ich , aber leider immer noch die gleiche meldung :(
                            • N Nier
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @Nier
                              Was ergibt
                              Iobroker -v
                              Und
                              ./iobroker update
                                @Nier
                                Was ergibt
                                Iobroker -v
                                Und
                                ./iobroker update
                                N Offline
                                N Offline
                                Nier
                                ./iobroker update
                                root@NiermannSmartHome:/opt/iobroker# Iobroker -v
                                -bash: Iobroker: Kommando nicht gefunden.
                                root@NiermannSmartHome:/opt/iobroker# ./iobroker update
                                Used repository: default
                                hash unchanged, use cached sources
                                update done
                                Adapter    "admin"         : 3.7.8    , installed 4.0.5
                                Adapter    "alexa2"        : 3.0.5    , installed 3.0.7
                                Adapter    "alpha2"        : 1.0.0
                                Adapter    "amazon-dash"   : 0.3.1
                                Adapter    "artnet"        : 1.0.0
                                Adapter    "asterisk"      : 1.0.6
                                Adapter    "asuswrt"       : 1.0.1
                                Adapter    "b-control-em"  : 0.2.1
                                Adapter    "backitup"      : 1.3.6
                                Adapter    "beckhoff"      : 1.2.0
                                Adapter    "benq"          : 0.2.0
                                Adapter    "ble"           : 0.10.1
                                Adapter    "bmw"           : 1.3.3
                                Adapter    "bosesoundtouch": 0.2.4
                                Adapter    "botvac"        : 1.0.0
                                Adapter    "bring"         : 1.7.1
                                Adapter    "broadlink2"    : 2.0.2    , installed 2.0.2
                                Adapter    "bsblan"        : 0.0.6
                                Adapter    "bshb"          : 0.1.4
                                Adapter    "chromecast"    : 2.3.1
                                Adapter    "cloud"         : 2.6.2    , installed 2.7.1
                                Adapter    "comfoair"      : 0.3.2
                                Adapter    "contactid"     : 1.0.0
                                Adapter    "countdown"     : 1.0.4
                                Adapter    "cul"           : 0.4.0
                                Adapter    "daikin"        : 1.0.5
                                Adapter    "daswetter"     : 2.8.1
                                Adapter    "deconz"        : 1.1.2
                                Adapter    "denon"         : 1.7.2
                                Adapter    "digitalstrom"  : 0.5.5
                                Adapter    "discovergy"    : 0.5.0
                                Adapter    "discovery"     : 1.3.0
                                Adapter    "ds18b20"       : 1.1.4
                                Adapter    "dwd"           : 2.4.3
                                Adapter    "ebus"          : 1.0.0
                                Adapter    "egigeozone"    : 0.1.2
                                Adapter    "ekey"          : 1.1.0
                                Adapter    "email"         : 1.0.5    , installed 1.0.5
                                Adapter    "emby"          : 1.0.2
                                Adapter    "energymanager" : 1.2.2
                                Adapter    "enet"          : 1.0.1
                                Adapter    "epson_stylus_px830": 0.2.1
                                Adapter    "fakeroku"      : 0.2.1
                                Adapter    "feiertage"     : 1.0.17
                                Adapter    "fhem"          : 1.3.0
                                Adapter    "find-my-iphone": 0.2.15
                                Adapter    "firetv"        : 0.0.27
                                Adapter    "flot"          : 1.9.2
                                Adapter    "foobar2000"    : 1.0.0
                                Adapter    "fritzbox"      : 0.2.1
                                Adapter    "fritzdect"     : 0.1.4
                                Adapter    "fronius"       : 1.0.5
                                Adapter    "fullcalendar"  : 0.2.4
                                Adapter    "fullybrowser"  : 1.0.0
                                Adapter    "g-homa"        : 0.5.1
                                Adapter    "geofency"      : 0.3.2
                                Adapter    "gruenbeck"     : 0.0.18
                                Adapter    "habpanel"      : 0.3.4
                                Adapter    "haier"         : 1.0.2
                                Adapter    "ham"           : 1.1.2
                                Adapter    "ham-wemo"      : 1.0.1
                                Adapter    "harmony"       : 1.2.2
                                Adapter    "heytech"       : 0.2.0
                                Adapter    "hid"           : 0.1.17
                                Adapter    "history"       : 1.8.6
                                Adapter    "hm-rega"       : 2.5.4
                                Adapter    "hm-rpc"        : 1.12.6
                                Adapter    "hmip"          : 0.0.11
                                Adapter    "homeconnect"   : 0.0.26
                                Adapter    "homee"         : 0.3.1
                                Adapter    "homepilot"     : 1.0.3
                                Adapter    "hp-ilo"        : 1.0.5
                                Adapter    "hs100"         : 1.0.10
                                Adapter    "hue"           : 3.2.3    , installed 3.2.1 [Updateable]
                                Adapter    "hue-extended"  : 1.2.1    , installed 1.2.2
                                Adapter    "ical"          : 1.7.0    , installed 1.7.1
                                Adapter    "icons-addictive-flavour-png": 0.1.0
                                Adapter    "icons-fatcow-hosting": 0.1.0
                                Adapter    "icons-icons8"  : 0.0.1
                                Adapter    "icons-material-png": 0.1.0
                                Adapter    "icons-material-svg": 0.1.0
                                Adapter    "icons-mfd-png" : 1.0.2
                                Adapter    "icons-mfd-svg" : 1.0.2
                                Adapter    "icons-open-icon-library-png": 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1
                                Adapter    "influxdb"      : 1.6.3
                                Adapter    "info"          : 1.5.6
                                Adapter    "innogy-smarthome": 0.3.3
                                Adapter    "iogo"          : 0.4.17
                                Adapter    "iot"           : 1.1.8
                                Adapter    "iqontrol"      : 0.2.16
                                Adapter    "javascript"    : 4.3.4    , installed 4.4.2
                                Adapter    "jeelink"       : 0.1.0
                                Controller "js-controller" : 2.2.9    , installed 2.2.9
                                Adapter    "kecontact"     : 0.1.0
                                Adapter    "klf200"        : 0.9.5
                                Adapter    "km200"         : 1.1.6
                                Adapter    "knx"           : 0.8.6
                                Adapter    "kodi"          : 1.0.0
                                Adapter    "kress"         : 2.5.5
                                Adapter    "lametric"      : 0.0.7
                                Adapter    "landroid"      : 1.0.3
                                Adapter    "lcn"           : 0.3.2
                                Adapter    "lgtv"          : 1.1.5
                                Adapter    "lgtv-rs"       : 0.0.4
                                Adapter    "lgtv11"        : 1.0.5
                                Adapter    "lifx"          : 0.0.5
                                Adapter    "lightify"      : 0.2.16
                                Adapter    "link"          : 0.4.4
                                Adapter    "linkeddevices" : 1.1.1
                                Adapter    "lovelace"      : 0.2.3
                                Adapter    "loxone"        : 1.0.0
                                Adapter    "luftdaten"     : 0.0.11
                                Adapter    "lupusec"       : 1.2.3
                                Adapter    "luxtronik1"    : 0.1.0
                                Adapter    "material"      : 0.12.1
                                Adapter    "maxcube"       : 0.1.2
                                Adapter    "maxcul"        : 1.1.1
                                Adapter    "mbus"          : 2.1.3
                                Adapter    "megad"         : 1.2.1
                                Adapter    "megadd"        : 0.2.0
                                Adapter    "megaesp"       : 0.1.0
                                Adapter    "mercedesme"    : 0.0.20
                                Adapter    "meross"        : 1.3.11   , installed 1.3.11
                                Adapter    "meteoalarm"    : 1.0.9
                                Adapter    "miele"         : 0.1.5
                                Adapter    "mihome"        : 1.2.5    , installed 1.2.8
                                Adapter    "mihome-lamp"   : 1.1.0
                                Adapter    "mihome-plug"   : 0.2.0
                                Adapter    "mihome-vacuum" : 1.1.5
                                Adapter    "mikrotik"      : 1.0.4
                                Adapter    "milight"       : 0.3.6
                                Adapter    "milight-smart-light": 0.2.7
                                Adapter    "mobile"        : 0.5.0
                                Adapter    "modbus"        : 2.0.9
                                Adapter    "moma"          : 1.2.3
                                Adapter    "mpd"           : 1.0.0
                                Adapter    "mqtt"          : 2.0.4
                                Adapter    "mqtt-client"   : 1.1.1
                                Adapter    "musiccast"     : 0.0.8
                                Adapter    "mysensors"     : 1.2.2
                                Adapter    "nanoleaf-lightpanels": 0.8.1
                                Adapter    "nello"         : 2.0.6
                                Adapter    "netatmo"       : 1.3.1
                                Adapter    "nibeuplink"    : 0.3.0
                                Adapter    "nina"          : 0.0.15
                                Adapter    "node-red"      : 1.13.0
                                Adapter    "nuki"          : 1.1.2
                                Adapter    "nuki-extended" : 2.2.0    , installed 2.2.0
                                Adapter    "nut"           : 1.1.3
                                Adapter    "odl"           : 1.0.5
                                Adapter    "oilfox"        : 0.0.5
                                Adapter    "onkyo"         : 2.0.2
                                Adapter    "onvif"         : 0.0.2
                                Adapter    "openhab"       : 1.1.0
                                Adapter    "openweathermap": 0.1.0
                                Adapter    "opi"           : 0.1.1
                                Adapter    "oppoplayer"    : 0.2.1
                                Adapter    "owfs"          : 0.6.1
                                Adapter    "owntracks"     : 0.6.2
                                Adapter    "panasonic-viera": 1.0.2
                                Adapter    "parser"        : 1.0.7
                                Adapter    "paw"           : 0.0.7
                                Adapter    "phantomjs"     : 1.0.1
                                Adapter    "pi-hole"       : 1.2.3
                                Adapter    "piface"        : 1.0.0
                                Adapter    "pimatic"       : 0.1.5
                                Adapter    "ping"          : 1.3.2
                                Adapter    "places"        : 0.7.0
                                Adapter    "plex"          : 0.8.9
                                Adapter    "plexconnect"   : 0.0.7
                                Adapter    "pollenflug"    : 1.0.4
                                Adapter    "proxmox"       : 0.3.2
                                Adapter    "proxy"         : 1.1.1
                                Adapter    "pushbullet"    : 0.0.11
                                Adapter    "pushover"      : 1.1.1
                                Adapter    "pushsafer"     : 0.1.8
                                Adapter    "radar2"        : 1.0.9
                                Adapter    "radiohead"     : 1.0.4
                                Adapter    "rflink"        : 1.2.0
                                Adapter    "rickshaw"      : 1.0.0
                                Adapter    "ring"          : 1.0.5    , installed 1.0.5
                                Adapter    "roomba"        : 1.1.1
                                Adapter    "rpi2"          : 1.1.1
                                Adapter    "s7"            : 1.1.4
                                Adapter    "samsung"       : 0.2.9
                                Adapter    "sayit"         : 1.7.0
                                Adapter    "sbfspot"       : 2.4.0
                                Adapter    "scenes"        : 1.1.0
                                Adapter    "schoolfree"    : 0.3.1
                                Adapter    "shelly"        : 3.1.6
                                Adapter    "shuttercontrol": 0.4.3
                                Adapter    "sia"           : 1.0.3
                                Adapter    "siegenia"      : 1.0.0
                                Adapter    "simple-api"    : 2.3.2    , installed 2.3.2
                                Adapter    "smappee"       : 0.2.2
                                Adapter    "smartmeter"    : 3.0.10
                                Adapter    "snips"         : 1.5.0
                                Adapter    "snmp"          : 0.5.0
                                Adapter    "socketio"      : 2.1.2    , installed 2.1.2
                                Adapter    "solarlog"      : 1.2.1
                                Adapter    "solarwetter"   : 1.0.0
                                Adapter    "sonnen"        : 1.3.0
                                Adapter    "sonoff"        : 2.2.2
                                Adapter    "sonos"         : 2.0.1
                                Adapter    "sony-bravia"   : 1.0.1
                                Adapter    "spotify-premium": 1.0.0
                                Adapter    "sql"           : 1.9.4
                                Adapter    "squeezebox"    : 1.0.0
                                Adapter    "starline"      : 1.0.0
                                Adapter    "statistics"    : 0.2.0
                                Adapter    "stiebel-isg"   : 1.4.11
                                Adapter    "swiss-weather-api": 0.1.6
                                Adapter    "systeminfo"    : 0.3.1
                                Adapter    "tahoma"        : 0.3.2
                                Adapter    "tankerkoenig"  : 2.0.5
                                Adapter    "telegram"      : 1.4.3
                                Adapter    "terminal"      : 0.1.2
                                Adapter    "text2command"  : 1.2.5    , installed 1.2.5
                                Adapter    "tr-064"        : 0.4.14   , installed 0.4.18
                                Adapter    "tradfri"       : 2.5.2
                                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                Adapter    "tuya"          : 3.2.0
                                Adapter    "tvspielfilm"   : 1.0.4
                                Adapter    "unifi"         : 0.3.1
                                Adapter    "upnp"          : 1.0.11
                                Adapter    "valloxmv"      : 1.0.3
                                Adapter    "vcard"         : 0.0.9
                                Adapter    "velux"         : 0.0.2
                                Adapter    "viessmann"     : 1.2.4
                                Adapter    "virtualpowermeter": 1.0.0
                                Adapter    "vis"           : 1.2.3
                                Adapter    "vis-bars"      : 0.1.4
                                Adapter    "vis-canvas-gauges": 0.1.5
                                Adapter    "vis-colorpicker": 1.1.1
                                Adapter    "vis-fancyswitch": 1.1.0
                                Adapter    "vis-google-fonts": 0.1.0
                                Adapter    "vis-history"   : 1.0.0
                                Adapter    "vis-hqwidgets" : 1.1.3
                                Adapter    "vis-jqui-mfd"  : 1.0.12
                                Adapter    "vis-justgage"  : 1.0.2
                                Adapter    "vis-keyboard"  : 0.0.2
                                Adapter    "vis-lcars"     : 1.0.4
                                Adapter    "vis-map"       : 1.0.2
                                Adapter    "vis-metro"     : 1.1.2
                                Adapter    "vis-players"   : 0.1.5
                                Adapter    "vis-plumb"     : 1.0.1
                                Adapter    "vis-rgraph"    : 0.0.2
                                Adapter    "vis-timeandweather": 1.1.7
                                Adapter    "vis-weather"   : 2.5.2
                                Adapter    "vr200"         : 1.0.0
                                Adapter    "weatherunderground": 3.1.6
                                Adapter    "web"           : 2.4.10   , installed 2.4.10
                                Adapter    "weishaupt-wem" : 0.0.8
                                Adapter    "wetty"         : 0.1.1
                                Adapter    "wiffi-wz"      : 2.1.4
                                Adapter    "wifilight"     : 0.2.0
                                Adapter    "wm-bus"        : 0.1.12
                                Adapter    "wolf"          : 0.9.2
                                Adapter    "worx"          : 1.0.0
                                Adapter    "xbox"          : 0.5.8
                                Adapter    "xs1"           : 1.0.2
                                Adapter    "yahka"         : 0.9.2    , installed 0.9.2
                                Adapter    "yamaha"        : 0.3.19
                                Adapter    "yeelight-2"    : 1.0.3
                                Adapter    "youtube"       : 0.0.6
                                Adapter    "yr"            : 2.0.3
                                Adapter    "zigbee"        : 1.0.2
                                Adapter    "zont"          : 0.5.3
                                Adapter    "zwave"         : 1.6.3
                                • N Nier
                                  ./iobroker update
                                  update done
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @Nier
                                  Ist doch alles tutti.
                                  iobroker restart
                                  Oder
                                  iobroker start admin.0 oder ohne .0 probieren
                                    @Nier
                                    iobroker restart
                                    Oder
                                    N Offline
                                    N Offline
                                    Nier
                                    iobroker restart
                                    alles drei eingegeben und es kommt immer noch:
                                    • N Nier
                                      iobroker restart
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @Nier
                                      Was passiert denn wenn du diesen Befehl in
                                      opt/iobroker eingibst?
                                        @Nier
                                        N Offline
                                        N Offline
                                        Nier
                                        @haselchen dauert wein wenig und dann nichts
                                        root@NiermannSmartHome:/opt/iobroker# iobroker restart
                                        root@NiermannSmartHome:/opt/iobroker# iobroker start admin.0
                                        • N Nier
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @Nier
                                          Ich meinte wenn du den Befehl dort eingibst:
                                          npm install iobroker.admin - update
