  4. JavaScript
  5. [Vorlage] JS: Log-Datei aufbereiten für VIS
617 Beiträge 60 Kommentatoren 211.2k Aufrufe 49 Beobachtet
  • GlasfaserG Glasfaser
    @sigi234 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
    [{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"0_userdata.0.Log-Script.all.visView1.whichFilter","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/miclog/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/miclog/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/miclog/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"all","buttontext":" All ({v:0_userdata.0.Log-Script.logall.logJSONcount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:0_userdata.0.Log-Script.all.visView1.whichFilter;b==\"all\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnAll"},"style":{"left":"25px","top":"304px","z-index":"50","width":"180px","height":"32px","background-color":"{b:0_userdata.0.Log-Script.All.visView1.whichFilter;b==\"Info\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"}]
    sigi234S Online
    sigi234S Online
    #524
    @Glasfaser
    @Negalein
    Danke, hatte ich auch schon fast. Habe aber All eingefügt.
    • sigi234S sigi234
      @Glasfaser
      @Negalein
      GlasfaserG Offline
      GlasfaserG Offline
      #525
      @sigi234
      Habe mich auch schon gewundert ;)
        @sigi234
        sigi234S Online
        sigi234S Online
        #526
        @Glasfaser sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
        @sigi234
        javascript.0	2020-02-27 23:34:22.047	error	(12272) script.js.LOG.MIC_Log1: Log-Script-Fehler: Gewählter Filter all, aber Datenpunkt [0_userdata.0.Log-Script.logall.logJSON] ist nicht vorhanden.
        Erledigt, Fehler weg.
        • MicM Mic
          @Negalein
          Teste mal frisch:
          1. Altes Script deaktivieren
          2. Alle Datenpunkte löschen, es sei denn sie sind nicht unterhalb 0_userdata.0.Log-Script, sondern wo anders
          3. Frisches aktuelles Script in JavaScript-Adapter rein. Du brauchst daran erst mal gar nichts im Code ändern. Aktivieren
          4. Projekt installieren (nichts daran ändern)
          So geht es auf jeden Fall, zumindest bei mir so getestet.
          O Online
          O Online
          Oli
          #527
          @Mic
          nochmals danke für das tolle Script.
          Kann ich mir in deinem Script auch den Status aller Javascripte (aktiviert, nicht aktiviert, Pause) anzeigen lassen?
          Oliver
          MicM 1 Antwort Letzte Antwort
          • MicM Offline
            MicM Offline
            Mic
            #528
            @Negalein
            Hi. Das Log-Script behandelt wirklich nur Logs, und keine Datenpunkte.
            Aber ich nutze schon seit längerem ein von mir geschriebenes Script, um die Alexa-History zu loggen und in VIS auszugeben. Also so:
            Falls gewünscht, kann ich das Script gerne veröffentlichen. Gibt einen Datenpunkt, dessen Inhalt dann in VIS als Tabelle ausgegeben wird.
            • O Oli
              @Mic
              MicM Offline
              MicM Offline
              Mic
              schrieb am zuletzt editiert von Mic
              #529
              @Oli sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
              das geht so leider nicht, da das Log-Script ausschließlich die Logs als Quelle nimmt. Für deine Anforderung am besten einen neuen Thread öffnen ☺
              • P ple
                @Mic said in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                @Mic
                Du Schlingel ( Künstler ) ,dachte auch wie @Negalein es wäre das Top App Bar Menue .
                Ist dir sehr gut gelungen 👍
                Haha.
                Danke 😊
                @ Alle
                Denkt auch daran, bestimmte Log-Ereignisse in anderen Views damit darstellen zu können. Also z.B. An-/Abwesenheiten, Zustandsänderungen von Geräten, usw.
                Mit den Filtern ist fast alles möglich, bin da gerne behilflich.
                Beispiel Garagentor (ein Javascript liefert hier z.B. die Logs):
                Mein Gott, was eine Arbeit.
                Ich gucke mir dein Script bereits einige Zeit an, aber verstehe leider nicht viel davon.
                Vielleicht hast du eine Idee, wie ich dein Script nutzen kann als Meldearchiv.
                Eigentlich will ich mir in einer Table nur anzeigen lassen, wenn ein Aktor auf true geht, oder sonst was.
                Ähnlich Fensterzähler oder dein Garagentor. Nur soll die Meldung auch wieder weggehen, wenn z.B. dein Garagentor nicht mehr klemmt.
                Hast du da vielleicht eine Idee, wie man sowas umsetzen könnte?
                Mein rudimentärer Anfang ist hier mal dokumentiert.
                https://forum.iobroker.net/topic/30324/array-erstellen-mit-prüfung-für-json-tabelle/9
                MicM Offline
                MicM Offline
                Mic
                #530
                @ple sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                das Log-Script ist nicht für deinen Anwendungsfall gedacht, es nimmt ausschließlich die Logs als Quelle. Ebenso ist es ein "Log", daher werden ältere Werte nicht nachträglich angepasst.
                P 1 Antwort Letzte Antwort
                • MicM Mic
                  @Negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #531
                  @Mic sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                  Cool
                  Ja bitte
                  PS: kannst du mir dann einen Export von obigem Screenshot auch mitgeben?
                  ° Fixer ---> iob fix
                  • NegaleinN Negalein
                    Cool
                    Ja bitte
                    MicM Offline
                    MicM Offline
                    Mic
                    #532
                    @Negalein sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                    Cool
                    Ja bitte
                    Gerne. Siehe hier: https://forum.iobroker.net/topic/30657/vorlage-alexa-history-befehle-in-vis-anzeigen
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #533
                      @Mic
                      Ich schaffe es nicht das Design der Tabelle in mein Projekt zu übernehmen.
                      Das komplette Widget hab ich von deinem Projekt exportiert und bei mir wieder eingefügt.
                      Dann in deinem Projekt das Widget markiert und unter CSS/Global den Code 1:1 in meinem Projekt beim Widget unter CSS/Global eingefügt.
                      Trotzdem sind bei mir die Zeilen anders.
                      EDIT:
                      Kommando retour.
                      Ich hab das falsche CSS kopiert.
                        mguenther
                        #534
                        Ich weiß nicht, ob ich alles richtig verstehe. Wenn ich einen Log-File zu einem Adapter auswerten möchte, dann lege ich im Skript z.B. das an:
                            filter_all:     [/modbus.0/],
                            filter_any:     [' - error: ', ' - warn: ',  ' - info: '],  // entweder error oder warn
                            blacklist:      ['', '', ''],
                            clean:          ['', '', ''],
                            merge:          true,
                            sortDescending: true,
                            jsonDateFormat: '#DD.MM.# hh:mm',
                            jsonColumns:    ['date','level','source','msg'],
                            jsonLogLength:  100,
                            jsonMaxLines:   100,
                            jsonCssToLevel: false,
                        und schreibe das z.B. unter das Beispiel im Skript für homematic. Es werden auch die folgenden Datenpunkte angelegt.
                        Jetzt werte ich das in der VIS separat aus, allerdings scheine ich beim Layout anpassen an meine VIS etwas geändert zu haben - ich habe keine farbigen Einträge mehr. Was muss ich denn wo entsprechend ändern?
                        danke
                        Marcus
                        • M mguenther
                              merge:          true,
                              jsonLogLength:  100,
                              jsonMaxLines:   100,
                          danke
                          Marcus
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #535
                          @mguenther
                          Wenn du von Ihm das View in dein Projekt kopierst , dann mußt du auch die CCS kopieren .
                          CSS:
                                         — LINKS —
                          .noteProject a:link { color: #b8b8b8; } /* unvisited link */
                          .noteProject a:visited { color: #b8b8b8; } /* visited link */
                          .noteProject a:hover { color: #ffffff; } /* mouse over link */
                          .pnoteProjecte a:active { color: #ffffff; } /* selected link */
                          hr { border:0; height: 1px; background-color:#b8b8b8 }
                                         — TABLE —
                          .tableLog .log-warn { color: orange;}
                          .tableLog .log-error { color: red;}
                          .tableLog .log-info { color: yellow;}
                          /* Word-Break anwenden */
                          .tableLog {
                             word-break: break-word;
                          /* Jede zweite Tabellenzeile formatieren */
                          .tableLog tr:nth-child(even) {
                             background:rgba(56,46,67,0.1);
                          /* Rand unterhalb Tabellenüberschrift */
                          .tableLog .mdc-data-table__header-row {
                             border-bottom: 1px solid #434343;
                          /* Zeilenhöhe und Abstände */
                          .tableLog .mdc-data-table__cell  {
                             line-height:1.3em;
                             padding-top: 6px;
                             padding-bottom: 6px;
                          /* Scrollbar */
                          .tableLog::-webkit-scrollbar { width: 15px; }
                          .tableLog::-webkit-scrollbar-track { background: transparent; }
                          .tableLog::-webkit-scrollbar-thumb { background-color: rgba(63,64,71,1); border-radius: 7px; border-color: rgba(63,64,71,1); }
                          .tableLog::-webkit-scrollbar-thumb:hover { background: #8f8f8f; }
                                         — BUTTONS —
                          .leftBarBtn .materialdesign-button-body {
                             justify-content: left !important;
                             margin-left: 0.9em;
                            @mguenther
                            CSS:
                                           — LINKS —
                                           — TABLE —
                            .tableLog {
                               line-height:1.3em;
                               padding-top: 6px;
                            /* Scrollbar */
                                           — BUTTONS —
                               margin-left: 0.9em;
                            mguenther
                            #536
                            @Glasfaser
                            das hatte ich gesucht... ich bin blöd, bei mir stand die ganze Zeit CSS auf global und deswegen hatte ich es nicht gesehen
                            danke
                            • MicM Offline
                              MicM Offline
                              Mic
                              #537
                              Update: Script-Version 4.10
                              Die neue Log-Script Version 4.10 erlaubt es nun, über Logs, die abgegeben werden (z.B. über Funktion log() in JavaScript oder Blockly) die Inhalte zu manipulieren. Da das Log-Script umfangreiche Filter bietet, von denen beliebig viele angelegt werden können und dann in Datenpunkten verfügbar sind, können mit dieser Funktion einfach per log() entsprechend Tabellen gefüllt werden.
                              Hier im Link weitere Infos zur Verwendung.
                              Beispiel:
                              Folgendes Script erzeugt eine Log-Zeile, sobald ein Befehl an ein Alexa-Gerät gesprochen wird.
                              Github: alexa-log-script.js
                              So sieht dann das Log dieses Scripts in etwa aus:
                              javascript.0 (12345) script.js.Alexa: [Alexa-Log-Script] ##{"msg":"Licht An", "source":"Sonos Küche"}##
                              Anzeige im VIS durch diese neue Funktion des Log-Scripts:
                              Wie zu sehen wird damit "Quelle" (wäre hier normalerweise "javascript.0") durch das Alexa-Gerät (hier: Sonos Küche) ersetzt. Außerdem wird die Message durch den gesprochenen Befehl (hier: "Licht An") ersetzt.
                              Genauso können auch noch das Datum ("date") und das Log-Level ("level") ersetzt werden.
                              Für dieses Script-Beispiel einfach folgenden Filter setzen:
                                  filter_all:     ['[Alexa-Log-Script]', ''],
                                  filter_any:     [' - info: '],
                                  clean:          [/script\.js\.[^:]*: \[Alexa-Log-Script]/, '', ''],
                                  merge:          false,
                                  jsonLogLength:  100,
                                  jsonMaxLines:   50,
                                  jsonCssToLevel: true,
                              Genau so können auch mehrere Filter für verschiedene Alexa-Geräte angelegt werden.
                              Dazu einfach unter filter_all ein bestimmtes Alexa-Gerät, z.B. "Show 5 Küche" hinzufügen.
                              Update von Vorversion
                              Einfach alles unterhalb von hier ersetzen:
                               * Ab hier nichts mehr ändern / Stop editing here!
                              GlasfaserG NegaleinN 2 Antworten Letzte Antwort
                              • MicM Mic
                                Beispiel:
                                    merge:          false,
                                    jsonLogLength:  100,
                                    jsonMaxLines:   50,
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #538
                                Beispiel:
                                Ich würde das Skript noch auf Github legen , sonst geht es hier unter !?
                                EDIT: und das Filterbeispiel ...
                                @Negalein .... da hat Mic was tolles für Dich gemacht ;)
                                NegaleinN MicM 2 Antworten Letzte Antwort
                                  Beispiel:
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #539
                                  Ja, definitiv!
                                  Schon geil, was @Mic da für Zauberhände hat.
                                  • NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #540
                                    @Mic
                                    Ich bekomm folgenden Error und das Log-Script geht auf Pause (Gelb).
                                    javascript.0	2020-03-01 20:31:44.477	error	(591) at Script.runInContext (vm.js:133:20)
                                    javascript.0	2020-03-01 20:31:44.477	error	(591) at script.js.System.IOBroker_Log:285:21
                                    javascript.0	2020-03-01 20:31:44.476	error	(591) SyntaxError: Invalid regular expression: /script\.js\.[^:]*: [Alexa-Log-Script]/: Range out of order in character class
                                    javascript.0	2020-03-01 20:31:44.476	error	(591) ^
                                    javascript.0	2020-03-01 20:31:44.476	error	(591) clean: [/script\.js\.[^:]*: [Alexa-Log-Script]/, '', ''],
                                    javascript.0	2020-03-01 20:31:44.475	error	(591) script.js.System.IOBroker_Log: script.js.System.IOBroker_Log:285
                                     * History der Alexa-Sprachbefehle in VIS darstellen.
                                     * Erfordert das Log-Script: https://github.com/Mic-M/iobroker.logfile-script
                                    // Normalerweise wird die "summary", also der Befehl an Alexa, in Kleinbuchstaben zurückgegeben, also
                                    // z.B. "flurlicht einschalten". Wenn diese Option auf "true" ist, wird die Ausgabe zu
                                    // "Flurlicht Einschalten", also jeweils erster Buchstabe groß.
                                    // Falls nicht gewünscht, auf "false" setzen.
                                    const CAPITALIZE_FIRSTS = true;
                                    main();
                                    function main() {
                                        // All instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
                                        on({id: /^alexa2\.\d\.History\.json$/, change:'any'}, function(obj) {
                                            // obj.state.val: JSON string of oject.
                                            // Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
                                            let objHistory = JSON.parse(obj.state.val);
                                            // ignore alexa keywords or empty value.
                                            if(! (['', 'alexa','echo','computer'].includes(objHistory['summary']) )) {
                                                // ignore "sprich mir nach"
                                                if (!(objHistory['summary'].includes('sprich mir nach '))) {
                                                    log('[Alexa-Log-Script] ##{"msg":"' + formatAlexaSummary(objHistory['summary']) + '", "source":"' + objHistory['name'] + '"}##');
                                     * Formats the Alexa summary text accordingly.
                                     * @param {string} summaryText   The summary text
                                     * @return {string} the formatted summary
                                    function formatAlexaSummary(summaryText) {
                                        if (CAPITALIZE_FIRSTS) summaryText = summaryText.replace(/(^|\s)\S/g, l => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
                                        return summaryText;
                                    Log-Script.txt
                                      Beispiel:
                                      MicM Offline
                                      MicM Offline
                                      Mic
                                      #541
                                      @Glasfaser
                                      @Negalein
                                      Vielen Dank für euer Feedback 😊
                                      Guter Hinweis, erledigt (da ist auch das Filterbeispiel drin): https://github.com/Mic-M/iobroker.logfile-script/blob/master/alexa/alexa-log-script.js
                                      sigi234S GlasfaserG 2 Antworten Letzte Antwort
                                      • MicM Mic
                                        @Glasfaser
                                        @Negalein
                                        sigi234S Online
                                        sigi234S Online
                                        #542
                                        @Mic
                                        Hm, ist das jetzt ein eigenes Skript?
                                        • sigi234S sigi234
                                          @Mic
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #543
                                          das kurze Script wird benötigt, um mit den neuen Log-Script die Alexa-History auszulesen.
