  4. tr-064 v3.1.x (Latest Repo) Diskussion
tr-064
295 Beiträge 50 Kommentatoren 70.8k Aufrufe 50 Beobachtet
    @apollon77 Im heutigen log taucht gar nichts auf, weder tr-64 noch fritzbox.
    Das ist das log, vom letzten Test/Anruf gestern
    2020-02-19 13:13:47.784 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:13:47;RING;0;xxxxxxxx;xxxx;SIP0;
    2020-02-19 13:13:48.827 - info: sayit.0 (3070) saying: xxxxxxx ruft gerade an.
    2020-02-19 13:13:49.073 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
    2020-02-19 13:14:03.757 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:14:03;DISCONNECT;0;0;
    2020-02-19 13:16:00.022 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 11203
    2020-02-19 13:16:05.236 - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2020-02-19 13:18:56.478 - info: info.0 (1703) Popup news was read...
    2020-02-19 13:20:00.083 - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 12442
    2020-02-19 13:20:08.684 - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2020-02-19 13:23:17.103 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:17;RING;0;xxxxxxx;981400;SIP0;
    2020-02-19 13:23:18.173 - info: sayit.0 (3070) saying: xxxxxxxxx ruft gerade an.
    2020-02-19 13:23:18.378 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
    2020-02-19 13:23:25.692 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:25;DISCONNECT;0;0;
    2020-02-19 13:24:07.593 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:07;CALL;0;0;xxxxx;xxxxxxxx;SIP0;
    2020-02-19 13:24:38.693 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:38;DISCONNECT;0;0;
    2020-02-19 13:27:59.752 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:27:59;CALL;0;0;xxxxx;xxxxxxxxx;SIP0;
    2020-02-19 13:28:18.208 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:18;CONNECT;0;0;xxxxxxxxx;
    2020-02-19 13:28:26.370 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:26;DISCONNECT;0;6;
    hier nach dem cronjob
    2020-02-20 00:01:00.016 - info: tr-064.0 (3240) Scheduled restart.
    2020-02-20 00:01:00.041 - info: tr-064.0 (3240) terminating
    2020-02-20 00:01:00.045 - info: tr-064.0 (3240) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-02-20 00:01:00.620 - error: host.IoBroker instance system.adapter.tr-064.0 terminated with code 156 (156)
    2020-02-20 00:01:00.620 - info: host.IoBroker Restart adapter system.adapter.tr-064.0 because enabled
    2020-02-20 00:01:01.678 - info: host.IoBroker instance system.adapter.tr-064.0 started with pid 21837
    2020-02-20 00:01:04.336 - info: tr-064.0 (21837) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
    #209
    @crunchip heißt das vllt das nach einem scheduled restart das Problem da war und keine Daten mehr ankamen ? Dann wäre wieder debug log interessant ...
    • apollon77A apollon77
      @crunchip das links in dem GitHub Link auf der Seite sind die Zeilennummern. Rote sind gelöschte und grüne sind neue. Und es wird immer bissl mehr oben und unten drunter angezeigt. Das sollte reichen um die Stellen im Code zu finden. Alternativ Klick im GitHub oben rechts auf file anzeigen oder so und dort ggf raw. Dann kopierst du halt alles
      crunchipC Offline
      crunchipC Offline
      #210
      @apollon77 ok, werd ich testen
        crunchipC Offline
        crunchipC Offline
        #211
        @apollon77 der nächtliche Neustart wäre zumindest eine mögliche Fehlerquelle, dachte ja zuerst, das Fritzbox/Telekom aktualisiert hat und das der Grund wäre, aber ja nicht der Fall war.
        jetzt könnt ich testen
        • a) gucken, das ich ihn aktuell zum laufen bekomm und nehm den Neustart raus
        • b) ich lass wie es ist und änder die Datei
        @apollon77 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
        könnte ich machen, falls ich so lange wach bin heute
        • crunchipC Offline
          crunchipC Offline
          #212
          @apollon77 v3.2.0 gerade probiert
          host.IoBroker	2020-02-21 08:26:54.076	info	Restart adapter system.adapter.tr-064.0 because enabled
          host.IoBroker	2020-02-21 08:26:54.076	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
          host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
          host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
          host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: ReferenceError: secret is not defined
          tr-064.0	2020-02-21 08:26:53.526	info	(25256) Terminated (NO_ERROR): Without reason
          tr-064.0	2020-02-21 08:26:53.525	info	(25256) terminating
          tr-064.0	2020-02-21 08:26:53.495	error	(25256) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
          tr-064.0	2020-02-21 08:26:53.494	error	(25256) uncaught exception: secret is not defined
          tr-064.0	2020-02-21 08:26:53.251	info	(25256) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
          host.IoBroker	2020-02-21 08:26:50.119	info	instance system.adapter.tr-064.0 started with pid 25256
          host.IoBroker	2020-02-21 08:26:49.074	info	Restart adapter system.adapter.tr-064.0 because enabled
            #213
            @crunchip hat ja auch keiner gesagt das GitHub gerade nutzbar ist, oder?! ;-)
              crunchipC Offline
              crunchipC Offline
              #214
              @apollon77 stimmt, wollte es nur testen, da ich durch https://forum.iobroker.net/post/381090 darauf gekommen bin
              diesbezüglich wollte ich es nur melden, bzw Bescheid geben😘
              • wendy2702W Online
                wendy2702W Online
                #215
                Gestern eine Ansage komplett neu aufgesetzt.
                TR-064 in Version 3.1.4 installiert, Benutzer auf Fritzbox eingerichtet und Haken gesetzt um TR064 Zugriff zu erlauben.
                Direkt beim ersten Anruf wurden alle Datenpunkte angelegt und aktualisiert.
                @crunchip : habe nicht alle Beiträge gelesen aber der Haken für TR064 Zugriff in der Fritzbox ist noch drin?
                Du könntest mal den Netzwerkverkehr mitschneiden zwischen Fritzbox und iobroker.
                Entweder hier: http://fritz.box/html/capture.html oder mit Wireshark im Netzwerk schnüffeln um zu sehen wer wann nicht antwortet.
                • wendy2702W wendy2702
                  crunchipC Offline
                  crunchipC Offline
                  #216
                  @wendy2702 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                  ja klar, funktioniert ja auch wieder nach einem manuellen Neustart, hab versuchsweise mal den scheduled von 0:01 vorverlegt auf 23:58
                  mit wireshark kenn ich mich leider nicht aus
                  • wendy2702W Online
                    wendy2702W Online
                    #217
                    Mach doch mal den Mitschnitt auf der Fritzbox, also Mitschnitt starten, z.b. einen Anruf empfangen, Mitschnitt stoppen und log hier posten.
                      crunchipC Offline
                      crunchipC Offline
                      #218
                      @wendy2702 ok und was muss ich da anklicken zum mitschneiden?
                      • wendy2702W Online
                        wendy2702W Online
                        #219
                        Starten für den "ethx" Port an denen dein Iobroker hängt.
                        Habe mal versucht dein Historie mit dem Problem zu lesen.
                        Hast du mal versucht alles was mit TR-064 zu tun hat zu löschen und neu zu installieren?
                        Also Instanz löschen, Adapter löschen, alle Objekte löschen, iobroker bzw. iobroker rechner neu starten, dann Adapter installieren, Instanz erzeugen und konfigurieren?
                        Was steht bei dir im Adapter drin, "fritz.box" oder die IP ?
                        Mal zum testen Callmonitor in der Box deaktiviert, Fritzbox neustart, Callmonitor aktiviert ?
                          crunchipC Offline
                          crunchipC Offline
                          #220
                          könnte ich mal versuchen, das artet jedoch dann etwas aus, da ich sämtliche Datenpunkte(Influx/Flot/Grafana)...alles wieder neu anlegen müsste
                          IP-Adresse ist hinterlegt
                          das wäre nochmal ne Option
                            crunchipC Offline
                            crunchipC Offline
                            #221
                            denke, hat damit nichts zu tun, da auch der fritzbox Adapter nicht aktualisiert
                            .....und täglich grüsst das Murmeltier....😁
                            • gestern die Option in der Fritzbox de/aktiviert
                            • Adapter neugestartet, fritzbox.0, sowie tr-64.0.
                            cronjob hatte ich bei beiden eingestellt, tr-64-- 23:58 und fritzbox--23:59, also bewusst mal vor 0:00
                            hatte es laufe des Tages mehrfach gestestet, funktionierte den ganzen Tag, jedoch heute morgen wieder nicht,
                            weder der fritzbox , noch der tr-64 aktualisieren, eingehende und ausgehende Anrufe getestet.
                            beide Adapter manuell neugestartet und funktioniert wieder alles.
                            werde den nächtlichen cronjob jetzt mal weglassen und testen ob es morgen aktualisiert.
                            • wendy2702W Online
                              wendy2702W Online
                              #222
                              Mal ne andere Frage. Vielleicht habe ich es auch überlesen.
                              Welche FB?
                              IOBROKER per LAN oder WLAN ?
                              Läuft nur ioBroker auf der verwendeten Hardware oder noch anderes?
                              Schnittstellen Mitschnitt gemacht ?
                                Welche FB?
                                crunchipC Offline
                                crunchipC Offline
                                #223
                                @wendy2702
                                aktuell
                                FB 7490, mit beta, exposed host an USG
                                alles über LAN, IoBroker in einer VM in Proxmox
                                wie gesagt, es hatte alles funktioniert, bis das Chaos mit den beiden tr-64 Adaptern aufkam, der alte soef hatte wunderbar funktioniert.
                                Mittschnitt hatte ich mal probiert, kenn mich aber wie gesagt, nicht genau aus, wie was man da machen/aufrufen/auslesen muss
                                • wendy2702W Online
                                  wendy2702W Online
                                  #224
                                  @crunchip sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                                  exposed host an USG
                                  Was bedeutet das?
                                    exposed host an USG
                                    Was bedeutet das?
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #225
                                    @wendy2702 das bedeutet, er hat ein unifi security gateway zwischen fritzbox und netzwerk geschaltet
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #226
                                      Aha...
                                      Und das kann nicht für das Problem verantwortlich sein!?
                                        Aha...
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #227
                                        Aha...
                                        könnte eventuell, möglicher Weise, unter Umständen, vielleicht ein Problem sein, könnte aber auch nicht so sein. Sicher ist auch da wieder jede Konfiguration anders.
                                        • F Offline
                                          Frank579
                                          schrieb am zuletzt editiert von Frank579
                                          #228
                                          Hallo zusammen, habe ein problem mit dem adapter Version 3.1.4.
                                          Und zwar würde ich gerne die Rufumleitung auf mein handy bei Abwesenheit aktivieren. Habe den punkt in den Einstellungen aktiviert, habe auch schon einiges getestet, bekomme aber keine datenpunkte in den ordner... umleitung ist in der Frizbox eingerichtet ind aktiv. Hat es schon jemand am laufen und eine idee?
                                          Besten Dank 🤗
                                          Edit: Hat sich erledigt, habe eine 2 umleitung angelegt dann waren beide drin🙈 einfaches deaktivieren/aktivieren der alten hat nicht gereicht....
