  4. tr-064 v3.1.x (Latest Repo) Diskussion
tr-064
295 Beiträge 50 Kommentatoren 70.8k Aufrufe 50 Beobachtet
    @apollon77 du bist witzig😁
    wo und wie pack ich das rein?
    das ist die aktuelle callmonitor.js
    /* jshint -W097 */
    /* jshint strict: false */
    /* jslint node: true */
    'use strict';
    const CALLMONITOR_NAME = 'callmonitor';
    const enableConnect1012 = '--- To use the callmonitor, enable connects to port 1012 on FritzBox by dialing #96*5* with a directly connected phone (line/dect) and restart this adapter';
    function checkPatchForECONNREFUSED(adapter) {
       if (process || process.version) {
           const ar = process.version.split('.');
           if (ar[0].indexOf('v') === 0) {
               ar[0] = ar[0].substr(1);
           let version = 0;
           for (let i = 0; i < ar.length; i++) {
               version *= 1000;
               version += ~~ar[i];
           if (version >= 6000000) return;
       const util = require('util');
       const old_errnoException = util._errnoException;
       util._errnoException = function (err, syscall, original) {
           if (typeof original === 'string' && original.indexOf(':1012') >= 0) {
               adapter.log.error('--- ECONNREFUSED ' + original);
               adapter.log.error(enableConnect1012);
           return old_errnoException(err, syscall, original);
    const pauseStates = {
       inbound:  'ring',
       lastCall: 'end',
       connect:  'connect'
    function CallMonitor(adapter, devices, phonebook) {
       if (!adapter.config.useCallMonitor) {
           return;
       adapter.log.debug('starting callmonitor');
       checkPatchForECONNREFUSED(adapter);
       const net = require('net');
       const connections = {};
       let timeout;
       let lastCaller;
       let lastCallee;
       let client;
       devices.root.createNew(CALLMONITOR_NAME + '.toPauseState', {val: '', common: {name: 'On call states', desc: 'State to pause players. values are: ring, connect, end'}});
       function init() {
           client = new net.Socket();
           client.on('connect', () =>
               adapter.log.debug('callmonitor connected'));
           client.on('error', err => {
               if (err.errno === 'ECONNREFUSED') {
                   this.close();
           client.on('close', _hadError => {
               timeout && clearTimeout(timeout);
               timeout = setTimeout(() => {
                   timeout = null;
                   init();
               }, adapter.config.reconnectInterval || 5000);
           client.on('data', data => {
               const raw = data.toString();
               adapter.log.debug('Callmonitor Raw: ' + raw);
               const array = raw.split(';');
               const type = array[1];
               const id = array[2];
               const timestamp = array[0];
               let message;
               //var dev = new devices.CDevice(0, '');
               //dev.setDevice(CALLMONITOR_NAME, {common: {name: CALLMONITOR_NAME, role: 'channel'}, native: {} });
               const dev = new devices.CDevice(CALLMONITOR_NAME, '');
               dev.force = true;
               let timer = null;
               function set(name) {
                   //const dev = new devices.CDevice(CALLMONITOR_NAME, '');
                   //dev.force = true;
                   timer && clearTimeout(timer);
                   timer = null;
                   adapter.log.debug('New Call data ' + name + ': ' + JSON.stringify(message));
                   dev.setChannel('', '');
                   dev.set('ringing', name === 'inbound');
                   // var pause = pauseStates[name];
                   // if (pause !== undefined) {
                   //     dev.set('toPauseState', pause);
                   dev.setChannel(name, name);
                   for (const i in message) {
                       if (i[0] !== '_') {
                           dev.set(i, message[i]);
                   dev.set('timestamp', timestamp);
                   message._type = name;
                   if (adapter.config.usePhonebook && phonebook) {
                       if (lastCaller !== message.caller) {
                           lastCaller = message.caller;
                       if (!message.callerName && message.caller) {
                           const pbe = phonebook.byNumber(message.caller);
                           if (pbe) {
                               message.callerName = pbe.name;
                               if (pbe.imageurl) {
                                   message.imageurlcaller = pbe.imageurl;
                           } else {
                               message.callerName = '';
                       dev.set('callerName', message.callerName || '');
                       if (lastCallee !== message.callee) {
                           lastCallee = message.callee;
                       if (!message.calleeName && message.callee) {
                           const pbee = phonebook.byNumber(message.callee);
                           if (pbee) {
                               message.calleeName = pbee.name;
                               if (pbee.imageurl) message.imageurlcallee = pbee.imageurl;
                           } else {
                               message.calleeName = '';
                       dev.set('calleeName', message.calleeName || '');
                   dev.set('json', JSON.stringify(message));
                   const pause = pauseStates[name];
                       message.extension && dev.set('toPauseState-' + message.extension, pause);
                   // soef.getHttpData(message.imageurlcaller, function (err, body, res) {
                   //     res = res;
                   adapter.log.debug('callMonitor.set: type=' + name + ' caller=' + message.caller + ' callee=' + message.callee + (message.callerName ? ' callerName=' + message.callerName : '') + (message.calleeName ? ' calleeName=' + message.calleeName : ''));
                   timer = setTimeout(() => {
                       dev.update();
                       devices.update();
                   }, 500);
               switch (type) {
                   case 'CALL':
                       message = {caller: array[4], callee: array[5], extension: array[3], timestamp, id};
                       connections[id] = message;
                       set('outbound');
                       break;
                   case 'RING':
                       message = {caller: array[3], callee: array[4], timestamp, id};
                       set('inbound');
                       break;
                   case 'CONNECT':
                       message = connections[id];
                       if (!message) {
                           break;
                       message.extension = array[3];
                       set('connect');
                       break;
                   case 'DISCONNECT':
                       if (!message) {
                           break;
                       switch (message._type) {
                           case 'inbound':
                               message.type = 'missed';
                               break;
                           case 'connect':
                               message.type = 'disconnect';
                               break;
                           case 'outbound':
                               message.type = 'unreached';
                               break;
                       message.duration = array[3] >> 0;
                       //set('disconnect');
                       set('lastCall');
                       delete connections[id];
                       break;
           client.connect({
               host: adapter.config.ip,
               port: 1012
               .on('error', error =>
                   adapter.log.error('Cannot start ' + CALLMONITOR_NAME + ': ' + error));
       this.close = function () {
           if (client) {
               try {
                   client.removeAllListeners();
                   client.destroy();
               } catch (e) {
               client = null;
           timeout = null;
       init();
       return this;
    module.exports = CallMonitor;
    #208
    @crunchip das links in dem GitHub Link auf der Seite sind die Zeilennummern. Rote sind gelöschte und grüne sind neue. Und es wird immer bissl mehr oben und unten drunter angezeigt. Das sollte reichen um die Stellen im Code zu finden. Alternativ Klick im GitHub oben rechts auf file anzeigen oder so und dort ggf raw. Dann kopierst du halt alles
      @apollon77 Im heutigen log taucht gar nichts auf, weder tr-64 noch fritzbox.
      Das ist das log, vom letzten Test/Anruf gestern
      2020-02-19 13:13:47.784 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:13:47;RING;0;xxxxxxxx;xxxx;SIP0;
      2020-02-19 13:13:48.827 - info: sayit.0 (3070) saying: xxxxxxx ruft gerade an.
      2020-02-19 13:13:49.073 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
      2020-02-19 13:14:03.757 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:14:03;DISCONNECT;0;0;
      2020-02-19 13:16:00.022 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 11203
      2020-02-19 13:16:05.236 - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      2020-02-19 13:18:56.478 - info: info.0 (1703) Popup news was read...
      2020-02-19 13:20:00.083 - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 12442
      2020-02-19 13:20:08.684 - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2020-02-19 13:23:17.103 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:17;RING;0;xxxxxxx;981400;SIP0;
      2020-02-19 13:23:18.173 - info: sayit.0 (3070) saying: xxxxxxxxx ruft gerade an.
      2020-02-19 13:23:18.378 - info: sayit.0 (3070) Set "chromecast.0.Google_Home_mini.player.announcement to {"url":"http://10.1.1.10:8082/state/sayit.0.tts.mp3","volume":60}
      2020-02-19 13:23:25.692 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:23:25;DISCONNECT;0;0;
      2020-02-19 13:24:07.593 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:07;CALL;0;0;xxxxx;xxxxxxxx;SIP0;
      2020-02-19 13:24:38.693 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:24:38;DISCONNECT;0;0;
      2020-02-19 13:27:59.752 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:27:59;CALL;0;0;xxxxx;xxxxxxxxx;SIP0;
      2020-02-19 13:28:18.208 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:18;CONNECT;0;0;xxxxxxxxx;
      2020-02-19 13:28:26.370 - info: fritzbox.0 (3268) data from 192.168.178.1: 19.02.20 13:28:26;DISCONNECT;0;6;
      hier nach dem cronjob
      2020-02-20 00:01:00.016 - info: tr-064.0 (3240) Scheduled restart.
      2020-02-20 00:01:00.041 - info: tr-064.0 (3240) terminating
      2020-02-20 00:01:00.045 - info: tr-064.0 (3240) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-02-20 00:01:00.620 - error: host.IoBroker instance system.adapter.tr-064.0 terminated with code 156 (156)
      2020-02-20 00:01:00.620 - info: host.IoBroker Restart adapter system.adapter.tr-064.0 because enabled
      2020-02-20 00:01:01.678 - info: host.IoBroker instance system.adapter.tr-064.0 started with pid 21837
      2020-02-20 00:01:04.336 - info: tr-064.0 (21837) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
      #209
      @crunchip heißt das vllt das nach einem scheduled restart das Problem da war und keine Daten mehr ankamen ? Dann wäre wieder debug log interessant ...
      • apollon77A apollon77
        crunchipC Offline
        crunchipC Offline
        #210
        @apollon77 ok, werd ich testen
          crunchipC Offline
          crunchipC Offline
          #211
          @apollon77 der nächtliche Neustart wäre zumindest eine mögliche Fehlerquelle, dachte ja zuerst, das Fritzbox/Telekom aktualisiert hat und das der Grund wäre, aber ja nicht der Fall war.
          jetzt könnt ich testen
          • a) gucken, das ich ihn aktuell zum laufen bekomm und nehm den Neustart raus
          • b) ich lass wie es ist und änder die Datei
          @apollon77 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
          könnte ich machen, falls ich so lange wach bin heute
          • crunchipC Offline
            crunchipC Offline
            #212
            @apollon77 v3.2.0 gerade probiert
            host.IoBroker	2020-02-21 08:26:54.076	info	Restart adapter system.adapter.tr-064.0 because enabled
            host.IoBroker	2020-02-21 08:26:54.076	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
            host.IoBroker	2020-02-21 08:26:54.075	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
            host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
            host.IoBroker	2020-02-21 08:26:54.074	error	Caught by controller[0]: ReferenceError: secret is not defined
            tr-064.0	2020-02-21 08:26:53.526	info	(25256) Terminated (NO_ERROR): Without reason
            tr-064.0	2020-02-21 08:26:53.525	info	(25256) terminating
            tr-064.0	2020-02-21 08:26:53.495	error	(25256) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
            tr-064.0	2020-02-21 08:26:53.494	error	(25256) uncaught exception: secret is not defined
            tr-064.0	2020-02-21 08:26:53.251	info	(25256) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
            host.IoBroker	2020-02-21 08:26:50.119	info	instance system.adapter.tr-064.0 started with pid 25256
            host.IoBroker	2020-02-21 08:26:49.074	info	Restart adapter system.adapter.tr-064.0 because enabled
              #213
              @crunchip hat ja auch keiner gesagt das GitHub gerade nutzbar ist, oder?! ;-)
                crunchipC Offline
                crunchipC Offline
                #214
                @apollon77 stimmt, wollte es nur testen, da ich durch https://forum.iobroker.net/post/381090 darauf gekommen bin
                diesbezüglich wollte ich es nur melden, bzw Bescheid geben😘
                • wendy2702W Online
                  wendy2702W Online
                  #215
                  Gestern eine Ansage komplett neu aufgesetzt.
                  TR-064 in Version 3.1.4 installiert, Benutzer auf Fritzbox eingerichtet und Haken gesetzt um TR064 Zugriff zu erlauben.
                  Direkt beim ersten Anruf wurden alle Datenpunkte angelegt und aktualisiert.
                  @crunchip : habe nicht alle Beiträge gelesen aber der Haken für TR064 Zugriff in der Fritzbox ist noch drin?
                  Du könntest mal den Netzwerkverkehr mitschneiden zwischen Fritzbox und iobroker.
                  Entweder hier: http://fritz.box/html/capture.html oder mit Wireshark im Netzwerk schnüffeln um zu sehen wer wann nicht antwortet.
                  • wendy2702W wendy2702
                    crunchipC Offline
                    crunchipC Offline
                    #216
                    @wendy2702 sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                    ja klar, funktioniert ja auch wieder nach einem manuellen Neustart, hab versuchsweise mal den scheduled von 0:01 vorverlegt auf 23:58
                    mit wireshark kenn ich mich leider nicht aus
                    • wendy2702W Online
                      wendy2702W Online
                      #217
                      Mach doch mal den Mitschnitt auf der Fritzbox, also Mitschnitt starten, z.b. einen Anruf empfangen, Mitschnitt stoppen und log hier posten.
                        crunchipC Offline
                        crunchipC Offline
                        #218
                        @wendy2702 ok und was muss ich da anklicken zum mitschneiden?
                        • wendy2702W Online
                          wendy2702W Online
                          #219
                          Starten für den "ethx" Port an denen dein Iobroker hängt.
                          Habe mal versucht dein Historie mit dem Problem zu lesen.
                          Hast du mal versucht alles was mit TR-064 zu tun hat zu löschen und neu zu installieren?
                          Also Instanz löschen, Adapter löschen, alle Objekte löschen, iobroker bzw. iobroker rechner neu starten, dann Adapter installieren, Instanz erzeugen und konfigurieren?
                          Was steht bei dir im Adapter drin, "fritz.box" oder die IP ?
                          Mal zum testen Callmonitor in der Box deaktiviert, Fritzbox neustart, Callmonitor aktiviert ?
                            crunchipC Offline
                            crunchipC Offline
                            #220
                            könnte ich mal versuchen, das artet jedoch dann etwas aus, da ich sämtliche Datenpunkte(Influx/Flot/Grafana)...alles wieder neu anlegen müsste
                            IP-Adresse ist hinterlegt
                            das wäre nochmal ne Option
                              crunchipC Offline
                              crunchipC Offline
                              #221
                              denke, hat damit nichts zu tun, da auch der fritzbox Adapter nicht aktualisiert
                              .....und täglich grüsst das Murmeltier....😁
                              • gestern die Option in der Fritzbox de/aktiviert
                              • Adapter neugestartet, fritzbox.0, sowie tr-64.0.
                              cronjob hatte ich bei beiden eingestellt, tr-64-- 23:58 und fritzbox--23:59, also bewusst mal vor 0:00
                              hatte es laufe des Tages mehrfach gestestet, funktionierte den ganzen Tag, jedoch heute morgen wieder nicht,
                              weder der fritzbox , noch der tr-64 aktualisieren, eingehende und ausgehende Anrufe getestet.
                              beide Adapter manuell neugestartet und funktioniert wieder alles.
                              werde den nächtlichen cronjob jetzt mal weglassen und testen ob es morgen aktualisiert.
                              • wendy2702W Online
                                wendy2702W Online
                                #222
                                Mal ne andere Frage. Vielleicht habe ich es auch überlesen.
                                Welche FB?
                                IOBROKER per LAN oder WLAN ?
                                Läuft nur ioBroker auf der verwendeten Hardware oder noch anderes?
                                Schnittstellen Mitschnitt gemacht ?
                                  Welche FB?
                                  crunchipC Offline
                                  crunchipC Offline
                                  #223
                                  @wendy2702
                                  aktuell
                                  FB 7490, mit beta, exposed host an USG
                                  alles über LAN, IoBroker in einer VM in Proxmox
                                  wie gesagt, es hatte alles funktioniert, bis das Chaos mit den beiden tr-64 Adaptern aufkam, der alte soef hatte wunderbar funktioniert.
                                  Mittschnitt hatte ich mal probiert, kenn mich aber wie gesagt, nicht genau aus, wie was man da machen/aufrufen/auslesen muss
                                  • wendy2702W Online
                                    wendy2702W Online
                                    #224
                                    @crunchip sagte in tr-064 v3.1.x (Latest Repo) Diskussion:
                                    exposed host an USG
                                    Was bedeutet das?
                                      exposed host an USG
                                      Was bedeutet das?
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #225
                                      @wendy2702 das bedeutet, er hat ein unifi security gateway zwischen fritzbox und netzwerk geschaltet
                                      • wendy2702W Online
                                        wendy2702W Online
                                        #226
                                        Aha...
                                        Und das kann nicht für das Problem verantwortlich sein!?
                                          Aha...
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #227
                                          Aha...
                                          könnte eventuell, möglicher Weise, unter Umständen, vielleicht ein Problem sein, könnte aber auch nicht so sein. Sicher ist auch da wieder jede Konfiguration anders.
