  4. Fehler bei Weather Underground
    5.2k
weather forecastundergroundadapterwetter
96 Beiträge 15 Kommentatoren 14.5k Aufrufe 12 Beobachtet
    smarti2015
    Hi Leute, hab mir heute mal wieder den Adapter für Weather Underground installiert, aber leider scheint der mit dem aktuellen JS-Controller oder Node nicht mehr zu laufen. Bekomme diese Meldung, hat einer ne Idee:
    weatherunderground.0	2020-02-20 08:17:39.583	error	(3206) TypeError: Cannot read property 'current_observation' of undefined at parseNewResult (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:902:18) at getNewWuDataHourlyForcast
    weatherunderground.0	2020-02-20 08:17:39.582	error	(3206) uncaught exception: Cannot read property 'current_observation' of undefined
    weatherunderground.0	2020-02-20 08:17:39.555	error	(3206) Wunderground reported an error: --/Error: options.uri is a required argument
    weatherunderground.0	2020-02-20 08:17:39.551	error	(3206) Wunderground reported an error: --/Error: options.uri is a required argument
    weatherunderground.0	2020-02-20 08:17:39.583	error	at getNewWuDataDailyForcast (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:234:96)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at getNewWuDataHourlyForcast (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:1652:9)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at request (/opt/iobroker/node_modules/request/index.js:53:10)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at new Request (/opt/iobroker/node_modules/request/request.js:127:8)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at Request.init (/opt/iobroker/node_modules/request/request.js:231:17)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at Request.emit (events.js:198:13)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:1680:19)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at getNewWuDataHourlyForcast (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:234:138)
    weatherunderground.0	2020-02-20 08:17:39.583	error	at parseNewResult (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:902:18)
    GEEKOM AS 6
    • S smarti2015
      crunchipC Offline
      crunchipC Offline
      @smarti2015 welche Version, ich habe v3.2.0 und die läuft
      Welche settings hast du eingestellt....eigenen Api key?
        smarti2015
        Hab auch die 3.2.0. Nein einen eiegen Api Key hab ich leider nicht bekommen. Hab in den Settings nur die ID der Station hingerlegt.
        GEEKOM AS 6
        • S smarti2015
          crunchipC Offline
          crunchipC Offline
          @smarti2015 trag mal deine Koordinaten unter Ort ein
            smarti2015
            Ah das sieht tatsächlich besser aus, noch keine Daten da, aber auch keine Fehlermeldung mehr. Ich möchte aber genau diese eine Station haben. Wie kann ich das einstellen oder nimmt der die Station automatisch, wenn die in der Näher der Koord sind?
            GEEKOM AS 6
            • S smarti2015
              crunchipC Offline
              crunchipC Offline
              @smarti2015 es wird normalerweise die nächstgelegene genommen, du kannst aber rechts daneben, bei Messstation unten auf Wundermap und dir da deine Station raussuchen
                smarti2015
                Dankeschön es klappt jetzt mit den Koord super. 👍 😊
                GEEKOM AS 6
                • jackblacksonJ Offline
                  jackblackson
                  Hab es mir auch grad installiert, vielleicht kannst du mir auch helfen. Version ist 3.2.0 (hatte erst die aus dem Stable, aber da kamen noch mehr fehler) und dieses Setup:
                  Bekomme dann diese Fehlermeldungen:
                  Wenn ich es ohne die StationsID mache, dann das:
                  • jackblacksonJ jackblackson
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @jackblackson
                    Ich vermute mal das liegt an deiner Node V12 Version , es sind noch nicht alle Adapter freigegeben , ob dieser Adapter darunterliegt kann ich nicht sagen !
                    Versuche mal die 3.2.1 von Git
                    jackblacksonJ 1 Antwort Letzte Antwort
                    • GlasfaserG Glasfaser
                      @jackblackson
                      jackblackson
                      @Glasfaser sagte in Fehler bei Weather Underground:
                      @jackblackson
                      Hm...leider die selbe Fehlermeldung..Dann heißt es wohl warten, bis er auf NodeV12 ist, bzw. vielleicht hat ihn ja sonst wer und kann mir sagen ob es wirklich daran liegt, oder ob es sonst ein Problem ist
                        @jackblackson
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @jackblackson
                        Habe mal eine zweite Instanz installiert .......
                        funktioniert nicht !!
                        Auch bei Node V10 kommt die gleiche Fehlermedung , wie bei dir ...
                          @jackblackson
                          jackblackson
                          @Glasfaser Ich hab mal ein Issue auf Github eröffnet..
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @jackblackson
                            Habe auch alles mögliche versucht ... sehr komisch .
                            Zum Glück habe ich nichts gelöscht 😧
                              @jackblackson
                              sigi234S Online
                              sigi234S Online
                              @Glasfaser
                              @jackblackson
                              Hatte ich auch, entscheidend ist der Ort UND Messstation.
                              • sigi234S sigi234
                                @Glasfaser
                                @jackblackson
                                jackblackson
                                @sigi234 Hab ich beides ausgefüllt, Fehler kommt trotzdem..
                                GlasfaserG crunchipC sigi234S 3 Antworten Letzte Antwort
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @jackblackson sagte in Fehler bei Weather Underground:
                                  Dito ... auch mit einer zweiten Instanz !!!
                                    crunchipC Offline
                                    crunchipC Offline
                                    @jackblackson kann auch zu Fehlern führen, wenn die Station keine Werte liefert, gegebenenfalls mal andere Station auswählen, deine koordinaten sind auch so richtig, wie eingegeben?
                                      sigi234S Online
                                      sigi234S Online
                                      Bist du auf wundermap gewesen und hast eine Station in der Nähe gesucht?
                                      https://www.wunderground.com/wundermap
                                      • sigi234S sigi234
                                        jackblackson
                                        @sigi234 Ja, mit zwei verschiedenen in der Nähe. Hab es grad nochmal mit ganz was anderem, mit "KCAFAIRF254" versucht, aber auch da, selber Fehler.
                                          crunchipC Offline
                                          crunchipC Offline
                                          @jackblackson kann es sein das deine Koordinaten nicht stimmen?
                                          GlasfaserG jackblacksonJ 2 Antworten Letzte Antwort
