  4. [Projekt] Material Design CSS für ioBroker.vis
650 Beiträge 111 Kommentatoren 278.4k Aufrufe 68 Beobachtet
  • Dominik F.D Dominik F.
    @Pittini
    mdui-onload: Hierüber kann festgelegt werden, dass die dem Widget zugewiesene Funktion bereits beim Laden der Page ausgeführt werden soll. Wirkt sich nur im Zusammenhang mit mdui-toggle, mdui-expand oder mdui-fullscreen aus.
    in der Demoversion ist eine der Cards eingeklappt dargestellt und wenn ich das richtig verstanden habe ist dieses Widget dafür verantwortlich:
    [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<i class=\"material-icons\">expand_less</i>","class":"mdui-button mdui-center mdui-expand mdui-onload"},"style":{"left":"calc(100% - 56px)","top":"16px","width":"40px","height":"40px"},"widgetSet":"basic"}]
    Das ist das Widget mit dem man die Cards ein und ausklappen kann.
    Pittini
    #609
    @Dominik-F
    mdui-onload klappt, vielen Dank, hatte das zwar gelesen aber anders interpretiert. Das Widget war klar.
    • UhulaU Uhula
      Moin. Vor 10 Tagen habe ich zufällig von einem Freund erfahren, dass ioBroker auch auf der Synology NAS im Docker Container läuft. Also mal kurz installiert, eingerichtet - und schon war ich infiziert. Kompliment an alle, die daran mitgearbeitet haben!
      Aber. Um den FAF (Frauen-Akzeptanz-Faktor) zu erhöhen (Androids Apps wie WhatsApp kommen gut an) und auch ich selbst das Material Design von Google als gelungen ansehe, im ioBroker.vis aber nichts vergleichbares zu finden war, habe ich begonnen meine eigenen CSS Anweisungen über einige basic und jqui Controls zu stülpen. Es ist kein eigener Adapter (kenne mich in JS noch zu wenig aus), sondern es sind nur CSS Anweisungen, die im Projekt auf der CSS-Registerseite eingefügt werden. Anschließend muss den basic- und jqui-Controls noch die entsprechende(n) CSS-Klasse(n) zugewiesen werden. Fertig.
      Bilder sagen mehr, also:
      Look & Feel wie eine Android-App mit App-Bar, Tab-Navigation und Bottom-Navigation; alle Farben sind über CSS-Klassen konfigurierbar.
      <size size="85">Edit 10.10.2017</size>
      Einen Demo-Film gibt es hier: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/docs/MaterialDesign4ioBroker.mp4 (dort downloaden)
      Ein Demo-Projekt für den Import in ioBroker.vis hier: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/ioBroker%20projects/MD_Demo.zip
      Ein Simple-Projekt als Basis für eigene Projekte hier: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/ioBroker%20projects/MD_Simple.zip
      Das Handbuch hier: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/docs/anleitung.pdf
      <size size="85">Edit 17.10.2017</size>
      Wer sich das Demo Projekt direkt, also ohne Download/Import ansehen möchte, kann dieses nun auch über die ioBroker-vis-Demo Site tun: https://iobroker.net:8080/vis/index.htm … o#_landing
      <size size="85">HowTo-Verweise im Forum</size>
      http://forum.iobroker.net/viewtopic.php?f=30&t=8457
      http://forum.iobroker.net/viewtopic.php?f=30&t=8101
      http://forum.iobroker.net/viewtopic.php?f=30&t=8122
      http://forum.iobroker.net/viewtopic.php?f=30&t=8185
      http://forum.iobroker.net/viewtopic.php?f=30&t=8294
      http://forum.iobroker.net/viewtopic.php?f=30&t=10541
      http://forum.iobroker.net/viewtopic.php?f=30&t=10540
      sigi234S Online
      sigi234S Online
      #610
      @Uhula
      Hallo, kann ich bei mdui-flow mdui-fastest mdui-blue-acc auch zB.: Pfeile angezeigt bekommen?
      UhulaU 1 Antwort Letzte Antwort
      • P Offline
        Pittini
        #611
        Noch eine Frage zu mdui-expand. Man kann ja den collapsed Bereich vergrößern, z.B. mit mdui-collapse-100.
        Das funktioniert auch ganz prima, nur bleibt der hellere Bereich in der alten größe. Wie kann ich erreichen das auch der obere Bereich mitwächst?
        • UhulaU Uhula
          @bilberry Glasfaser hat dir im Prinzip die richtige Antwort gegeben. Der glow-Effekt muss dem ganzen Widget zugewiesen werden, nicht nur dem Icon. Da du das "schaltbar" haben möchtest, kannst du die vis-Bindingfähigkeit nutzen. Statt "mdui-button-outlined mdui-blue-glow" musst du dann "mdui-button-outlined {javascript.0.myGlow}" zuweisen. Über die Wertzuweisung an "javascript.0.myGlow" kannst dann das Glühen einschalten in dem du den Wert "mdui-blue-glow" zuweist. Natürlich auch andere Farben ;-)
          @sigi234 Den Hintergrund des Editors setzt du im Projekt-CSS an der Stelle ".vis_container>div"
             Design
          .vis_container>div {
              background: #f0f0f0 !important;
          Statt #f0f0f0 einfach z.B. #121212 zuweisen.
          sigi234S Online
          sigi234S Online
          #612
          @Uhula sagte in [Projekt] Material Design CSS für ioBroker.vis:
          Ok, habe auf Black umgestellt, jetzt ist die Standard Schrift in Schwarz die vorher Weiß waren, und ebenso die Hilfslinien beim Widget ausrichten.
          Muss ich das auch wo umstellen?
          Beim auswählen einer Farbe steht automatisch #FFFFFF drinnen, ändere ich es auf #ffffff geht es.
            mctom
            #613
            zur Zeit setzte ich mich gerade auch mit dem Material Design auseinander und spiele gerade an verschiedenen Stellen. Aktuell habe ich das Problem mit einem Hintergrund.
            Dazu hab eich eine einfache Seite erstellt.
            Auf dieser Seite habe ich ein view ind widget abgelegt und mit folgenden CSS Daten versehen:
            mdui-content mdui-flex mdui-green-bg
            So sieht es dann aus:
            Wenn ich mir die Seite im Browser anschaue taucht das grün nicht auf und es wird weiß:
            Mach ich hier was falsch oder habe ich was übersehen ?
            Michael
            • P Offline
              Pittini
              #614
              mdui-center-v überschreibt text-align right und macht ein text-align left draus. Soll das so sein? Und wenn ja, wie krieg ich das vertikal zentriert UND rechtsbündig?
                SMARTY.ML
                #615
                wollte gerne auf die neue MD umsteigen.
                Habe den iOBroker komplett neu aufgesetzt, vis installiert und die Demo geladen. Leider sieht es so auf allen Endgeräten bei mir aus:
                Was kann ich tun?
                Mod-Edit: Bilder richtig eingefügt. Bitte keine externen Bildhoster verwenden.
                sigi234S D 2 Antworten Letzte Antwort
                • S SMARTY.ML
                  Was kann ich tun?
                  sigi234S Online
                  sigi234S Online
                  #616
                  @SMARTY-ML sagte in [Projekt] Material Design CSS für ioBroker.vis:
                  Was kann ich tun?
                  Bilder bitte nicht extern, sondern das Icon zum Bilder hochladen benutzen!
                  • S SMARTY.ML
                    Was kann ich tun?
                    der-eine
                    #617
                    @SMARTY-ML oben links das Menü öffnen dann auf Einstellungen und die Farbe ändern.
                      mctom
                      schrieb am zuletzt editiert von mctom
                      #618
                      Diese Material Design kann einem ja echt den Kopf zerbrechen. Man hat so viele Ideen. :-)
                      Gibt es eine Möglichkeit dem Titel Bereich von Cards eine eigene Farbe zuzuweisen ?
                      • D der-eine
                        SMARTY.ML
                        schrieb am zuletzt editiert von SMARTY.ML
                        #619
                        @der-eine Wie auf den Bildern zu sehen, keine Chance -.-
                        Update: Ich konnte die Farben nach ein bissl im weißen tippen einstellen. Aber da stimmt doch noch was nicht? Schriftart/größe?? Wo sind die Button? Siehe Bild:
                        • sigi234S sigi234
                          @Uhula
                          UhulaU Offline
                          UhulaU Offline
                          Uhula
                          #620
                          @sigi234 Ja, demnächst. Ich habe ein paar mdui-Shape Anweisungen mit aufgenommen, damit ist es dann möglich Dreiecke/Kreise/Halbkreise usw. zu erzeugen. Daraus kannst du dann auch Pfeile machen in dem du zwei Widgets verwendest (1x Rechteck, 1xDreieck).
                          Bsp: 60836559-08f6-4fec-aa69-6e07060e597c-image.png
                          Falls du nicht warten willst/kannst:
                          /* Shapes */
                          /* Triangle */
                          .mdui-shape-circle {
                            clip-path: circle(50% at 50% 50%);
                          .mdui-shape-halfcircle {
                            clip-path: circle(50% at 0% 50%);
                          .mdui-shape-quartercircle {
                            clip-path: circle(50% at 0% 0%);
                          .mdui-shape-triangle {
                            clip-path: polygon(0% 0%, 100% 50%, 0% 100%);
                          .mdui-shape-corner {
                            clip-path: polygon(0% 0%, 100% 0%, 100% 100%);
                          .mdui-shape-halfcircle[class*="mdui-rotate-"],
                          .mdui-shape-quartercircle[class*="mdui-rotate-"],
                          .mdui-shape-triangle[class*="mdui-rotate-"],
                          .mdui-shape-corner[class*="mdui-rotate-"] { transform-origin: center center;}
                          black-Background: Ist eigentlich nicht so gedacht, dass man im dark-Style im vis arbeitet, sondern im light-Style - und dann erst zur Laufzeit den dark-Style verwendet. Ich schau mal, ob ich das auch im vis variabel hinbekomme. Bis dahin den HIntergrund auf ein grau setzen (#808080) und zur Laufzeit dann via mdui-config auf black.
                          @Pittini Nein, die title-height ist fix im CSS hinterlegt, sie ist nicht dynamisch.
                          Der Umgang mit mdui-center-v ist nicht unkritisch und wirkt sich durch die flex-Verwendung auch auf das Text-Alignment aus. Bisherige Lösung: Wenn es sich lediglich um eine Textdarstellung handelt (label, value, ...) dann einfach mit height:auto arbeiten, dann benötigt man kein center-v
                          @mctom Im nächsten Release habe ich das Farbverhalten ohne mdui-config Werte überarbeitet, dann sollte es automatisch korrekte Farben wählen. Ansonsten einmal zur Laufzeit den Config-Dialog (im Blindflug) bedienen.
                          Titelbereich bunt: Kannst du machen, musst in der CSS nur die background-Angabe im .mdui-card.mdui-title:after, .mdui-card-raised.mdui-title:after, .mdui-card-outlined.mdui-title:after anpassen ... Habe ich bewusst nicht, da eine EInfärbung mit black/white auf allen Farb-Hintergründen funktioniert.
                          @SMARTY-ML Hast du auch auch die "Material Design Widgets" (2 Jahre alt) als Adapter installiert? Wenn ja, die stören, da dort die MD CSS v1.8 enthalten ist.
                          Dein Projekt lautet sicher nicht MD_Demo, also musst du, auf die Icons zu sehen, in der CSS Datei am Anfang die Pfade zu den WebFont "material-icons" auf deinen Projektnamen anpassen.
                          Demnächst gibt es die v2.05, dann auch mit mdui-list/mdui-listitem.
                          Danach ist dann erst einmal Ruhe - sonst komme ich nie dazu de Doku anzupassen.
                          Uhula - Leise und Weise
                          Ex: ioBroker on Gigabyte NUC Proxmox
                          • UhulaU Uhula
                            /* Shapes */
                            /* Triangle */
                            SMARTY.ML
                            #621
                            @Uhula said in [Projekt] Material Design CSS für ioBroker.vis:
                            i
                            Danke, hat geholfen =)
                            • P Offline
                              Pittini
                              #622
                              Evtl. kleiner Bug, zumindest aber unschön. Legt man ein mdui-input und ein mdui-select in exact gleicher Größe (hier 30px) nebeneinander hat die Linie einen Versatz von 2px. Das macht das Layouten und ausrichten nicht leichter.
                                Knallix
                                #623
                                Habe ein Problem mit den lnav / rnav
                                Kann diese nicht benutzen!
                                In dem Projekt Simpel geht nur der lnav. Bei dem lnav läuft es auch mit dem "flex"
                                Die pageStart verschiebt sich, so wie es sein soll :-)
                                Bei der rnav legt es sich über die Page drüber, obwohl hier auf "flex" eingestellt ist.
                                Habe allerdings auch nichts verändert.....
                                In der Projekt Demo geht es weder bei lnav noch bei rnav.
                                Es lassen sich die "navigation" Button nicht drücken. Das Fenster schließt sich sofort wieder!
                                • UhulaU Offline
                                  UhulaU Offline
                                  Uhula
                                  #624
                                  @Knallix Hast du auch auch die "Material Design Widgets" (2 Jahre alt) als Adapter installiert? Wenn ja, die stören, da dort die MD CSS v1.8 enthalten ist.
                                    der-eine
                                    schrieb am zuletzt editiert von der-eine
                                    #625
                                    habt ihr schon Grafana Dashboards eingebunden? Im Editor sieht das Dashboard im iframe ganz normal aus aber in der Runtime
                                    aktualisert es im Sektundentakt und sagt, dass es das Panel mit der id nicht finden kann...
                                    Wenn ich den link im Browser öffne wird es ganz normal angezeigt.
                                    allow_embedding=true
                                    enable anonymous
                                    sind aktiviert.
                                    Jemand nen Tipp?
                                    [Edit]
                                    Problem behoben. Hatte bei iFrame Allgemein Update bei Aufwachen und Update bei Aktivieren aktiviert.
                                    Jetzt gehts.
                                    • D der-eine
                                      enable anonymous
                                      sind aktiviert.
                                      Jemand nen Tipp?
                                      [Edit]
                                      Jetzt gehts.
                                      UhulaU Offline
                                      UhulaU Offline
                                      Uhula
                                      #626
                                      @der-eine Wenn du deine Grafana iFrames in der Zeitachse direkt steuern möchtest, schau dir mal das Beispiel in MD_Demo (Bedienung>Skalieren) an, dort mache ich das über ein Popupmenu, refresh dito. Allerdings muss die Grafana URL einen besonderen Aufbau haben (from / to).
                                      • UhulaU Uhula
                                        der-eine
                                        #627
                                        @Uhula das wäre der Plan. Wie muss denn die URL aussehen bzw. wie erstelle ich so eine URL?
                                        Habe die View aus dem Demo exportiert und in mein Projekt importiert. Hab leider schon gemerkt, dass die Steuerelemente nicht funktionieren.
                                        P 1 Antwort Letzte Antwort
                                          SMARTY.ML
                                          #628
                                          Ich wollte ein Bild laden, welches durch ein Skript gespeichert wird. Ich kann beim Einbinden über vis leider nur solche Bilder sehen, die ich selber hochgeladen habe. Wie kann ich das umgehen?
                                          jpgorganizerJ 1 Antwort Letzte Antwort
