  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 180.6k Aufrufe 22 Beobachtet
  • sigi234S sigi234
    @Homoran sagte in Auslesen IP -Adressen:
    @sigi234 was steht im log?
    radar2.0	2020-02-08 12:51:51.945	info	(12800) Terminated (NO_ERROR): Without reason
    radar2.0	2020-02-08 12:51:51.944	info	(12800) terminating
    radar2.0	2020-02-08 12:51:51.939	warn	(12800) Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then.then (C:\Program Files\iobroker\Test\nod
    radar2.0	2020-02-08 12:51:51.937	warn	(12800) Adapter will exit in latest 1 sec with code false!
    radar2.0	2020-02-08 12:51:51.936	info	(12800) Connected with '0.0.0.0' for DHCP Scan
    radar2.0	2020-02-08 12:51:51.933	info	(12800) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0	2020-02-08 12:51:51.933	error	(12800) Error: No compatible USB Bluetooth 4.0 device found! at BluetoothHciSocket.bindUser (C:\Program Files\iobroker\Test\node_modules\iobroker.radar2\node_modules\@abandonware\bluetooth-hci-soc
    radar2.0	2020-02-08 12:51:51.932	error	(12800) uncaught exception: No compatible USB Bluetooth 4.0 device found!
    radar2.0	2020-02-08 12:51:51.929	info	(12800) radar2 set to scan every 30 seconds and printers every 100 minutes.
    radar2.0	2020-02-08 12:51:51.929	info	(12800) arp-scan will use the following interfaces: [ 'Ethernet', 'Npcap Loopback Adapter' ]
    radar2.0	2020-02-08 12:51:51.928	warn	(12800) arp-scan cmd line not configured in config! Will use '-lgq --retry=4 --timeout=400'
    radar2.0	2020-02-08 12:51:51.928	info	(12800) use known IP list: []
    radar2.0	2020-02-08 12:51:51.928	info	(12800) use known BT list: []
    radar2.0	2020-02-08 12:51:51.927	info	(12800) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0	2020-02-08 12:51:51.912	info	(12800) found and will use '@abandonware/noble'
    radar2.0	2020-02-08 12:51:51.724	info	(12800) found and will use 'node-bluetooth scan'
    radar2.0	2020-02-08 12:51:51.692	info	(12800) radar2 initialization started...
    radar2.0	2020-02-08 12:51:51.624	info	(12800) starting. Version 1.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.radar2, node: v10.16.3
    #399
    @sigi234 sagte in Auslesen IP -Adressen:
    • sigi234S sigi234
      liv-in-skyL
      liv-in-skyL
      #400
      @sigi234 hast du bluetooth aktiviert und keinen richtige bluetooth anschluss im pc
      • liv-in-skyL liv-in-sky
        sigi234S
        sigi234S
        #401
        @liv-in-sky sagte in Auslesen IP -Adressen:
        Realtek Bluetooth 4.0 Adapter on Board
        liv-in-skyL 3 Antworten Letzte Antwort
        • sigi234S sigi234
          liv-in-skyL
          liv-in-skyL
          #402
          @sigi234 kann man bluetooth im adapter erstmal deaktivieren ?
          • sigi234S sigi234
            liv-in-skyL
            liv-in-skyL
            #403
            @sigi234
            ...edRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is ...
            da steht was von linux app - da muss der adapter-mann gefragt werden - vielleicht musst du noch was anderes in windowes machen
            • sigi234S sigi234
              liv-in-skyL
              liv-in-skyL
              #404
              @sigi234 wenn ich die sche.... sortierung endlich drin habe, teste ich mal radar2 auf windows
              sigi234S HomoranH 2 Antworten Letzte Antwort
                sigi234S
                sigi234S
                #405
                https://forum.iobroker.net/topic/26721/test-adapter-radar2-v1-2-x-github
                  #406
                  @liv-in-sky ich habe den Eindruck, dass da einiges bei der Konvertierung von radar zu radar2 durcheinandergekommen ist.
                  Ich finde jetzt nur noch Hinweise zu OSX, nicht zu Windows. Und OSX ist ja auch in gewisser Weise Linux.
                  Trotzdem taucht immer wieder Windows in den ReadMes auf.
                    liv-in-skyL
                    liv-in-skyL
                    #407
                    @Homoran ist @Jey-Cee unser mann ? der etwas über radar2 und windows weiß ?
                    HomoranH sigi234S 2 Antworten Letzte Antwort
                      #408
                      @liv-in-sky sieht so aus, wenn man den Tester-Thread ansieht
                        sigi234S
                        sigi234S
                        #409
                        Ja und ev. @Stabilostick
                        • sigi234S sigi234
                          #410
                          @sigi234
                          @liv-in-sky
                          Der Entwickler ist aber Frank Joke
                          liv-in-skyL sigi234S Jey CeeJ 3 Antworten Letzte Antwort
                            @sigi234
                            @liv-in-sky
                            liv-in-skyL
                            liv-in-skyL
                            #411
                            @Homoran vielleicht meldet sich einer der beiden - Frank Joke - der name sagt mir nix - wie auch immer, allein durch dieses script muss ich feststellen, um den adapter zu entwickeln oder zu pflegen - respekt - da muss man ahnung haben
                              @sigi234
                              @liv-in-sky
                              sigi234S
                              sigi234S
                              #412
                              Aber er macht ja nix mehr. Oder?
                              Habe @frankjoke mal eine PN gesendet.
                              • Jey CeeJ
                                Jey CeeJ
                                Jey Cee
                                #413
                                Muss euch enttäuschen weder Radar noch Windows ist mein Ding.
                                Persönlicher Support
                                Spenden -> paypal.me/J3YC33
                                • Jey CeeJ Jey Cee
                                  sigi234S
                                  sigi234S
                                  #414
                                  @Jey-Cee sagte in Auslesen IP -Adressen:
                                  Aha, jetzt sehe ich es du hattest es als Admin verschoben.
                                  • Jey CeeJ Jey Cee
                                    #415
                                    @Jey-Cee
                                    wer ist denn der maintainer für den radar2?
                                      @sigi234
                                      @liv-in-sky
                                      Jey CeeJ
                                      Jey CeeJ
                                      Jey Cee
                                      #416
                                      Soweit mir bekannt ist nur er maintainer.
                                      • Jey CeeJ Jey Cee
                                        #417
                                        @Jey-Cee Danke!
                                        • liv-in-skyL
                                          liv-in-skyL
                                          #418
                                          wieder mal etwas zum testen
                                          wenn ihr das letzte update schon hattet: kommt es zu anzeige-problemen , den datenpunkt unter javascript.x.Tabellen löschen - dort wären die schon registrierten geräte gespeichert
                                          bitte testen
                                          • sortierung nach client oder ip
                                          • werden die abgeschalteten geräte rot angezeigt und vorallem richtig sortiert
                                          • ob alle geräte außer die echos oder best. androiden angezeigt werden
                                          • ob die aliase funktionieren (const myDeviceNames) - ihr könnt meine löschen - die settings kann man ja wieder kopieren, wenn ein neues script kommt
                                          • kommen diese tabellen verschiebungen noch vor, wo unter der tabelle geräte erscheinen - dieser fehler sollte behoben sein
                                          falls ihr das setting vom letzten mal kopieren wollt - in der ersten zeile war beim letzten update eine zeile ganz oben drin - diese habe ich nach unten ins script gesetzt - also nach dem kopieren der settings die erste zeile (const dpPrefix = "javascript."+ instance +".";) einfach löschen - sonst kringel! das setting ende ist im neuen script markiert
                                          //@liv-in-sky Januar 2020 8.2-14:25
                                          //HIER WIRD PFAD UND FILENAME DEFINIERT
                                          const path = "/htmlip.html";                   //FIlenamen definieren
                                          const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                          let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                                          let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                          let dpVIS="0_userdata.0.Tabellen.IPDevices"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                          let mySchedule="  * * * * * ";                       //jede minute
                                          const domainName="fritz.box";
                                          const ipbereich="192.168.178.0/24";  //  gilt nicht für windows
                                          const dnsServer="192.168.178.1"      // gilt nicht für windows
                                          let sortiereClient=false;             //true nach client false nach ip
                                          const waitTime=15000;
                                          const lastZellColorSetting="lightgreen"
                                          const operationSystem="linux";              // oder windows - hier muss der ipbereich und der dns server direkt ins script eingetragen werden - im exec. befehl
                                          //hier eintragen für die übersetzung der standardnamen - aliase - rechte seite wird statt linker  angezeigt - die beispiele kann man raus löschen
                                          // BITTE AUF DIE KOMMAs ACHTEN
                                          const myDeviceNames={ "192.168.178.24"  :"HF Küche Licht",
                                                               "192.168.178.29"  :"TrekStor13",
                                                               "192.168.178.156" :"EchoShow5",
                                                               "192.168.178.73"  :"MediaPadT5",
                                                               "192.168.178.151" :"FireTab7",
                                                               "192.168.178.126" :"Matrix Büro",
                                                               "192.168.178.20"  :"Matrix Küche",
                                                               "192.168.178.21"  :"GoSund 2 Matrix",
                                                               "192.168.178.155" :"GoSund 3 Freezer",
                                                               "192.168.178.150" :"Gosund 1",
                                                               "192.168.178.33"  :"SonoffS26",
                                                               "192.168.178.77"  :"WerBinIch",
                                                               "192.168.178.81"  :"GalaxyTabA16",
                                                               "192.168.178.56"  :"FireHDStick",
                                                               "192.168.178.68"  :"HF Desk Haupt"
                                          var symbolOK="🟢";     // auch möglich: ="✅"
                                          var symbolKO="💀";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz  oder : ="❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀
                                          var symbolWARN="ℹ️";    // ="⚠️" oder info: "ℹ️"
                                          var externalOhneInfo=false;  //noch nicht integriert
                                          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                                          var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                                          var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                          var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                          //ÜBERSCHRIFT ÜBER TABELLE
                                          let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                                          let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                          const htmlFeldUeber='IP Devices List';              // Überschrift und Signature
                                          const htmlFarbUber="white";                         // Farbe der Überschrift
                                          const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                                          const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                                          //MEHRERE TABELLEN NEBENEINANDER
                                          let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                          const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                          const farbetrennungsLinie="white";
                                          const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                          const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                          //ÜBERSCHRIFT SPALTEN
                                          const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                          const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
                                          const farbeLinieUnterUeberschrift="white";
                                          const groesseUeberschrift=16;
                                          const UeberschriftStyle="normal"                     // möglich "bold"
                                          //GANZE TABELLE
                                          let abstandZelle="1";
                                          let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                          let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                          let weite="1200";                                     //Weite der Tabelle
                                          let zentriert=true;                                   //ganze tabelle zentriert
                                          const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                          const htmlSchriftart="Helvetica";
                                          const htmlSchriftgroesse="14px";
                                          //FELDER UND RAHMEN
                                          let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                                          const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
                                          const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                          const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                          const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                          const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                          let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                          const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                          // HIER NICHTS  ÄNDERN ---------------------SETTING ENDE ----------------------------------------
                                          let borderHelpBottum;
                                          let borderHelpRight;
                                          let htmlcenterHelp;
                                          let htmlcenterHelp2;
                                          if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                          if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                          if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                          if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                          zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                          zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                          const htmlZentriert='<center>'
                                          const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                             "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                             " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                            // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                             " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                             " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                             "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                             " </style></head><body>"; // <div>";
                                          //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
        "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                          const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                          const htmlTabUeber3="</tr>";
                                          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                          var htmlTabUeber2=  "<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                          var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                             "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                                          var rootcount=true;
                                          var myObjOld=[];
                                          var htmlTabUeber="";
                                          var htmlOut="";
                                          var mix;
                                          var counter;
                                          //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                                          var val1; var val0; var val2;
                                          function writeHTML(){
                                          htmlOut="";
                                          counter=-1;
                                          htmlTabUeber="";
                                          switch (mehrfachTabelle) {
                                             case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                             case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                             case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                          if (!UeberschriftSpalten) {htmlTabUeber=""}
                                          //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                          //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                                          var myData="xxxxx";
                                          let myArr=[];
                                          let myObjExtra=[];
                                          if(operationSystem=="linux"){
                                          exec("nmap -sPR --dns-servers "+dnsServer+" "+ipbereich  , function (error, result, stderr) {
                                             myData=result
                                            // setState("0_userdata.0.Tabellen.IPDeviceERROR", result)
                                          });} else {
                                          exec(' "C:\\Program Files (x86)\\Nmap\\nmap" -sP 192.168.178.0/24 --dns-servers 192.168.178.1', function (error, result, stderr) {
                                            // console.log(result);
                                            myData=result;
                                          let timeout = setTimeout(function () {
                                          // myData=getState("0_userdata.0.Tabellen.DeviceIPFake").val       //   FÜR TEST
                                          ////////////////////////////////log(myData)
                                           if (!myData.includes("xxxx")) {
                                          var myTimeScanArr=myData.match(/(scanned in) (\d+\.\d+ seconds)/g); //log(myTimeScan)
                                          // myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+\((\d+.\d+.\d+.\d+)\)|(fritz.\w+)\s+\((\d+.\d+.\d+.\d+)\)|(\d+.\d+.\d+.\d+)$/g)
                                          myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+\((\d+\.\d+\.\d+\.\d+)\)|(fritz\.\w+)\s+\((\d+\.\d+\.\d+\.\d+)\)|(\d+\.\d+\.\d+\.\d+)$/gm)
                                          // log(myArr.toString())
                                          //myArr.push("10.0.1.200")
                                          //myArr.push("for iobroker (10.0.1.200)")
                                          //myArr.push("10.0.1.201")
                                          //myArr.push("fritz.repeater (10.0.1.200)")
                                          /////////////////////////////////////log(myArr.toString())
                                          if(myArr.length>2) {
                                          let var1; let var2; let var3; let varOhneName=[];
                                          var myObj=[]
                                          for(var i=0;i<myArr.length;i++) {
                                              var1="na"; var2="na";
                                              var1=myArr[i].replace(/(for .+) \(\d+\.\d+\.\d+\.\d+\)/,"$1")
                                              var1=var1.replace(/(.+)\(.+\)/," $1")
                                              var2=myArr[i].replace(/for .+ \((\d+\.\d+\.\d+\.\d+)\)/,"$1");//log(var2)
                                              var2=var2.replace(/.+\((.+)\)/,"$1")
                                              varOhneName=myArr[i].match(/^(\d+\.\d+\.\d+\.\d+)$/)
                                              if (varOhneName!=null) {var1=varOhneName[0];var2=varOhneName[0]}
                                              var3="true";
                                             /* var2=var2.replace(/[(,)]/g,"")
                                              for (var index in myDeviceNames) {                   //ersetze mit aliasnamen
        //log(index)
        if ((var2.trim()).match(index)) {var1="for "+myDeviceNames[index];
        // log(val0+" - "+index)
                                            let help=[var1.trim(),var2.trim(),var3]
                                            if (!(var1=="na" || var2=="na")) myObj.push(help)
                                            if (rootcount) {/* myObjOld= getState("0_userdata.0.Tabellen.IPDeviceERROR").val */
                                                            myObjOld.push(help);
                                                           // myObjOld.push(help);
                                                            createState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld,  { name: 'Device_Collection', desc: 'Device_Collection', type: 'array',read: true, write: true });
                                                            else{
                                                            myObjOld=getState(dpPrefix+"Tabellen.IPDevices.Device_Collection").val;
                                          //log("++++++++++++++++++ "+myObj.toString())
                                          //setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())
                                             let varhelp1; let varhelp2; let varhelp3="true";    //neue erkannt geräte zu datenbank hinzufügen
                                            for (var i=0;i<myObj.length;i++){
                                                 //  log(myObj[i][0]+"-----"+myObjOld[i][0])
                                                     if (!myObjOld.toString().includes(myObj[i][1]))  {  varhelp1=myObj[i][0].trim() ; varhelp2=myObj[i][1]; varhelp3="true";
        let help=[varhelp1,varhelp2,varhelp3]
        if (!(varhelp1.indexOf("scanned")>-1)) myObjOld.push(help)
                                            for (var i=0;i<myObjOld.length;i++){                // ist gerät noch da ???
                                                     if (!myObj.toString().includes(myObjOld[i][1]))  {  varhelp1=myObjOld[i][0].trim() ; varhelp2=myObjOld[i][1]; varhelp3="false";
        myObj.push(help)
                                             // log("------------------------------------------------"+myObjOld[1].toString())
                                           /*    if (sortiereClient){
                                                  myObj.sort(function (alpha, beta) {
                                                      if (alpha[0].toUpperCase().trim() > beta[0].toUpperCase().trim())
                                                         return 1;
                                                      if (beta[0].toUpperCase().trim() > alpha[0].toUpperCase().trim())
                                                         return -1;
                                                      return 0;
                                                     });} else {  */
                                          if (!sortiereClient){
                                                         if (parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")) > parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")))
                                                             return -1;
                                                         if (parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")) > parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")))
                                                             return 1;
                                                      return 0;
                                              var1="scanned in" //nur scanned seconds
                                             var3="true"
                                             var2=myTimeScanArr[0].replace(/.+ (\d+\.\d+.+$)/,"$1");//log(var2)
                                             let help=[var1,var2,var3]
                                            if (sortiereClient) help=["xxxx"+var1,var2,var3]
                                            myObj.push(help)
                                          if (!rootcount)  setState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld)
                                          ///////////////////////////log("myObject ------- "+myObj.length.toString()+"---- ")
                                           // setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())   // zur fehlersuche
                                          for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                    counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                                  //  log(myObj[i][0].toString())
                                                    val0=myObj[i][0].replace("for","").trim()
                                                    val0=val0.replace("."+domainName,"")
                                                    val0=val0.replace(/[(,)]/g,"")
                                                    val1=myObj[i][1]
                                                    val1=val1.replace(/[(,)]/g,"")
        //log(index)
        if ((val1.trim()).match(index)) {val0=myDeviceNames[index];
                                                      if (val0.length>=23)  val0=val0.substring(0,23)+" ..."
                                                    var val2help=myObj[i][2]
                                                    if (val2help=="false") {val2=symbolKO;
        val0=(" <font color=\"red\"> ")+val0 ;
        val1=(" <font color=\"red\"> ")+val1}  else{val2=symbolOK}
                                               if(val0=="scanned in") {val2=symbolWARN;val0="<font color=\""+lastZellColorSetting+"\"><i>"+" Anzahl "+counter+"</i>"; val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+"</i>"}
                                               tabelleBind(); }//HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                               else {let help=[val0.trim(),val1,val2help];myObjExtra.push(help);}
                                          }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                                 counter=-1;
                                                  myObjExtra.sort(function (alpha, beta) {
                                                      if ((alpha[0].toUpperCase()).trim() > (beta[0].toUpperCase()).trim())
                                                         return 1;
                                                      if ((beta[0].toUpperCase()).trim() > (alpha[0].toUpperCase()).trim())
                                                         return -1;
                                                      return 0;
                                                     for(var i=0;i<myObjExtra.length;i++) {
                                                         counter++
                                                         val0=myObjExtra[i][0] ;
                                                         val1=myObjExtra[i][1] ;
                                                         val2help=myObjExtra[i][2] ;
                                                         if(val0=="xxxxscanned in") {val2=symbolWARN;
                                                         tabelleBind();
                                          //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                                // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
        tabelleFinish();
        if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
        }, 2000);
                                                 }  else {log("no Array","warn")} //Ende Array falsch
                                                 } else {log("no Data","warn")} // ende daten falsch
                                                 rootcount=false;
                                          }, waitTime);
                                          } // function ende
                                          //MAIN:
                                          schedule(mySchedule,  function () {
                                           if (!rootcount) writeHTML();
                                          // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                          writeHTML();
                                           function tabelleBind(){
                                             //  counter=counter+mehrfachTabelle;
                                                   case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                                   case 2: if(counter%4==0){
                                                              if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
        }else{
        if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                                   case 3:if(counter%2==0)   {
                                                              if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;}else{
                                                              if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        } break;}
                                                   case 4:  // counter=counter+8;
                                                             if(counter%8==0)   {
                                                             if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut =htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                                             if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                                  } //switch ende
                                          function tabelleFinish() {
                                                 case 1:    break;
                                                 case 2:
                                                            if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                            break;
                                                 case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                           if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                            break;
                                                 case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                           if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                           if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                           if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                           break; }
                                                   var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                                 var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                                  if (!htmlSignature) htmlUnter="";
                                                //  log(" ist htmlUnter - signature "+htmlUnter)
                                                    //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                                     var htmlOutVIS="";
                                                   //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                                      if (htmlUberschrift)
                                                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                                        } else {
                                                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                            // log("bin raus aus tabelleBind");
                                                     if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                           var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                           //mit oder ohne überschrift - zentriert oder links
                                          htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                           //log(htmlOut);
                                          sigi234S NegaleinN HomoranH 3 Antworten Letzte Antwort
                                          84.1k
