  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 140.1k Aufrufe 22 Beobachtet
  • sigi234S sigi234
    @liv-in-sky sagte in Auslesen IP -Adressen:
    @sigi234 also kannst du ihn auf win installieren ?
    Ja,
    Adapter aber immer Rot.
    #397
    @sigi234 was steht im log?
      sigi234S Online
      sigi234S Online
      #398
      @Homoran sagte in Auslesen IP -Adressen:
      radar2.0	2020-02-08 12:51:51.945	info	(12800) Terminated (NO_ERROR): Without reason
      radar2.0	2020-02-08 12:51:51.944	info	(12800) terminating
      radar2.0	2020-02-08 12:51:51.939	warn	(12800) Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then.then (C:\Program Files\iobroker\Test\nod
      radar2.0	2020-02-08 12:51:51.937	warn	(12800) Adapter will exit in latest 1 sec with code false!
      radar2.0	2020-02-08 12:51:51.936	info	(12800) Connected with '0.0.0.0' for DHCP Scan
      radar2.0	2020-02-08 12:51:51.933	info	(12800) Adapter disconnected and stopped with dostop(false) and callback(true)
      radar2.0	2020-02-08 12:51:51.933	error	(12800) Error: No compatible USB Bluetooth 4.0 device found! at BluetoothHciSocket.bindUser (C:\Program Files\iobroker\Test\node_modules\iobroker.radar2\node_modules\@abandonware\bluetooth-hci-soc
      radar2.0	2020-02-08 12:51:51.932	error	(12800) uncaught exception: No compatible USB Bluetooth 4.0 device found!
      radar2.0	2020-02-08 12:51:51.929	info	(12800) radar2 set to scan every 30 seconds and printers every 100 minutes.
      radar2.0	2020-02-08 12:51:51.929	info	(12800) arp-scan will use the following interfaces: [ 'Ethernet', 'Npcap Loopback Adapter' ]
      radar2.0	2020-02-08 12:51:51.928	warn	(12800) arp-scan cmd line not configured in config! Will use '-lgq --retry=4 --timeout=400'
      radar2.0	2020-02-08 12:51:51.928	info	(12800) use known IP list: []
      radar2.0	2020-02-08 12:51:51.928	info	(12800) use known BT list: []
      radar2.0	2020-02-08 12:51:51.927	info	(12800) radar2 set to flag items away if they are not seen for 2 minutes
      radar2.0	2020-02-08 12:51:51.912	info	(12800) found and will use '@abandonware/noble'
      radar2.0	2020-02-08 12:51:51.724	info	(12800) found and will use 'node-bluetooth scan'
      radar2.0	2020-02-08 12:51:51.692	info	(12800) radar2 initialization started...
      radar2.0	2020-02-08 12:51:51.624	info	(12800) starting. Version 1.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.radar2, node: v10.16.3
      HomoranH liv-in-skyL 2 Antworten Letzte Antwort
      • sigi234S sigi234
        #399
        @sigi234 sagte in Auslesen IP -Adressen:
        • sigi234S sigi234
          liv-in-skyL Offline
          liv-in-skyL Offline
          #400
          @sigi234 hast du bluetooth aktiviert und keinen richtige bluetooth anschluss im pc
          • liv-in-skyL liv-in-sky
            sigi234S Online
            sigi234S Online
            #401
            Realtek Bluetooth 4.0 Adapter on Board
            liv-in-skyL 3 Antworten Letzte Antwort
            • sigi234S sigi234
              liv-in-skyL Offline
              liv-in-skyL Offline
              #402
              @sigi234 kann man bluetooth im adapter erstmal deaktivieren ?
              • sigi234S sigi234
                liv-in-skyL Offline
                liv-in-skyL Offline
                #403
                @sigi234
                ...edRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is ...
                da steht was von linux app - da muss der adapter-mann gefragt werden - vielleicht musst du noch was anderes in windowes machen
                • sigi234S sigi234
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #404
                  @sigi234 wenn ich die sche.... sortierung endlich drin habe, teste ich mal radar2 auf windows
                  sigi234S HomoranH 2 Antworten Letzte Antwort
                    sigi234S Online
                    sigi234S Online
                    #405
                    https://forum.iobroker.net/topic/26721/test-adapter-radar2-v1-2-x-github
                      #406
                      @liv-in-sky ich habe den Eindruck, dass da einiges bei der Konvertierung von radar zu radar2 durcheinandergekommen ist.
                      Ich finde jetzt nur noch Hinweise zu OSX, nicht zu Windows. Und OSX ist ja auch in gewisser Weise Linux.
                      Trotzdem taucht immer wieder Windows in den ReadMes auf.
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #407
                        @Homoran ist @Jey-Cee unser mann ? der etwas über radar2 und windows weiß ?
                        HomoranH sigi234S 2 Antworten Letzte Antwort
                          #408
                          @liv-in-sky sieht so aus, wenn man den Tester-Thread ansieht
                            sigi234S Online
                            sigi234S Online
                            #409
                            Ja und ev. @Stabilostick
                            • sigi234S sigi234
                              #410
                              @sigi234
                              @liv-in-sky
                              Der Entwickler ist aber Frank Joke
                              liv-in-skyL sigi234S Jey CeeJ 3 Antworten Letzte Antwort
                                @sigi234
                                @liv-in-sky
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #411
                                @Homoran vielleicht meldet sich einer der beiden - Frank Joke - der name sagt mir nix - wie auch immer, allein durch dieses script muss ich feststellen, um den adapter zu entwickeln oder zu pflegen - respekt - da muss man ahnung haben
                                  @sigi234
                                  @liv-in-sky
                                  sigi234S Online
                                  sigi234S Online
                                  #412
                                  Aber er macht ja nix mehr. Oder?
                                  Habe @frankjoke mal eine PN gesendet.
                                  • Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #413
                                    Muss euch enttäuschen weder Radar noch Windows ist mein Ding.
                                    Persönlicher Support
                                    Spenden -> paypal.me/J3YC33
                                    • Jey CeeJ Jey Cee
                                      sigi234S Online
                                      sigi234S Online
                                      #414
                                      @Jey-Cee sagte in Auslesen IP -Adressen:
                                      Aha, jetzt sehe ich es du hattest es als Admin verschoben.
                                      • Jey CeeJ Jey Cee
                                        #415
                                        @Jey-Cee
                                        wer ist denn der maintainer für den radar2?
                                          @sigi234
                                          @liv-in-sky
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #416
                                          Soweit mir bekannt ist nur er maintainer.
