  4. Telegram voice calls, thanks to CallMeBot.com
telegramvoice calls
54 Beiträge 10 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • BluefoxB Offline
    BluefoxB Offline
    Telegram Phone Calls from ioBroker (with Voice Messages)
    At least the ioBroker can make a Telegram phone calls (with Voice) too thanks to the CallMeBot API.
    You need ioBroker.telegram adapter with version >= 1.5.0 for that.
    Everything is you need is to create a blockly or script as following:
    Blockly
    Just place the block "call via Telegram" as on the picture:
    <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="pcI%RNejJ#^wD#ZBKcPV" x="62.800048828125" y="37.399993896484375">
      <field name="OID">javascript.0.trigger</field>
      <field name="ACK_CONDITION">false</field>
      <statement name="STATEMENT">
        <block type="telegram_call" id="D==]%~cRa3pHO99!P4Qs">
          <field name="LANGUAGE"></field>
          <field name="LOG"></field>
          <value name="MESSAGE">
            <shadow type="text" id="o$5h,J65nfBdfVO.3|fd">
              <field name="TEXT">ioBroker is calling you!</field>
            </shadow>
          </value>
          <value name="USERNAME">
            <shadow type="text" id="V/Gwj;1y%D@`xq9*#niO">
              <field name="TEXT">@Username!</field>
            </shadow>
          </value>
        </block>
      </statement>
    </block>
    and set the valid text and user name.
    Now by change of the state trigger the call via telegram will be done.
    Script
    To use calls via Telegram in script write following:
    sendTo('telegram.0', 'call', 'Some text');
    or
    sendTo('telegram.0', 'call', {
        text: 'Some text',
        user: '@Username',
        language: 'de-DE-Standard-A' // optional
    Read more here
    Mod-Edit: Thema von "Englisch - ioBroker Generel" nach "Deutsch - ioBroker Allgemein" verschoben!
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      Habs gerade probiert.
      Funktioniert jedoch nicht.
      Im log kommt:
      host.Asus-Buero	2020-02-04 17:27:42.424	error	Caught by controller[1]: at processImmediate (timers.js:658:5)
      host.Asus-Buero	2020-02-04 17:27:42.424	error	Caught by controller[1]: at tryOnImmediate (timers.js:676:5)
      host.Asus-Buero	2020-02-04 17:27:42.424	error	Caught by controller[1]: at runCallback (timers.js:706:11)
      host.Asus-Buero	2020-02-04 17:27:42.424	error	Caught by controller[1]: at Immediate.callUsers (C:\ioBroker\node_modules\iobroker.telegram\main.js:881:28)
      host.Asus-Buero	2020-02-04 17:27:42.424	error	Caught by controller[1]: TypeError: users.shift is not a function
      telegram.0	2020-02-04 17:27:41.695	info	(5964) Terminated (NO_ERROR): Without reason
      telegram.0	2020-02-04 17:27:41.694	info	(5964) terminating
      telegram.0	2020-02-04 17:27:41.188	error	(5964) TypeError: users.shift is not a function at Immediate.callUsers (C:\ioBroker\node_modules\iobroker.telegram\main.js:881:28) at runCallback (timers.js:706:11) at tryOnImmediate (time
      telegram.0	2020-02-04 17:27:41.187	error	(5964) uncaught exception: users.shift is not a function
      Danke.
      BluefoxB 1 Antwort Letzte Antwort
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        Bei 1.4.3 wird der Name noch angezeigt:
        Bei 1.5.0 wird der Name nicht angezeigt.
        Und deshalb hat es wohl nicht funktioniert.
        Danke.
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          So, nochmal probiert.
          1.5.0 speichert den Namen nicht !
          Bitte prüfen !
          Danke.
          • bahnuhrB bahnuhr
            Im log kommt:
            BluefoxB Offline
            BluefoxB Offline
            @bahnuhr Hast du von npm installiert oder von github?
            • BluefoxB Bluefox
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @Bluefox sagte in Telegram voice calls, thanks to CallMeBot.com:
              So:
              Nachtrag:
              dann upload (Pfeil nach oben).
              und nachricht vom Handy gesendet. Nr. wird gespeichert; Namen nicht.
              Dann wieder 1.4.3: Namen ist dort in der config ersichtlich.
              Danke.
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @Bluefox
                Habe nun mal die Instanz sowie den Adapter gelöscht.
                Dann neu wie oben installiert.
                Name kommt jetzt:
                früher stand bei Name nur: Dieter
                jetzt steht da: bahnuhr / Dieter
                Folgende Script (Schnipsel aus meinem telegram Script) klappt weiterhin:
                var vUser = "Dieter";
                var vText = "/Standort\n" + "/Zusammenfassung";
                sendTo('telegram', { user: vUser, text: vText, parse_mode: 'HTML' });
                User Dieter scheint wohl zu funktionieren.
                Folgendes neue Script mit call klappt nicht:
                    text: 'Dies is ein Test',
                    user: 'Dieter'
                Hab auch schon "bahnuhr" oder "bahnuhr / Dieter" probiert.
                Klappt nicht.
                Lass ich User weg; dann klappt der call.
                Allerdings wird der Text in einer Endlosschleife wiederholt !
                Soll dies so sein ?
                mfg
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  So, ich bin mit dem Test durch.
                  call mit User funktioniert nicht.
                  call ohne User -> dann wird der 1. User genommen.
                  Danke.
                  • bahnuhrB bahnuhr
                    @bahnuhr hast du in den Einstellungen von Telegram einen Username angegeben am Handy? Und das @ Zeichen gehört dazu zum Username wenn man ihn vergeben hat dann geht es auch.
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @Brainbug sagte in Telegram voice calls, thanks to CallMeBot.com:
                      Bei solch einem Befehl:
                      brauch ich kein @
                      Und bei dem call Befehl brauch ich @
                      Finde ich jetzt komisch aber ich probiers gleich aus.
                      Und sag mir bitte auch wo ein Username eingegeben wird. In der config von telegram find ich nichts; und vom Handy wird nur Dieter übermittelt, das greif ich mit einem anderen script ab wenn ich z.B. etwas per Handy schreibe.
                      Danke.
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        Habe eben folgenden Befehl probiert:
                        sendTo('telegram.0', 'call', { user: '@Dieter', text: 'Dies ist ein Test' });
                        Klappt nicht (zumindest bei mir so).
                        Danke.
                        • ? Offline
                          Geht wunderbar, für die Instanz.2 musste ich einen Username angeben dann ging die auch. Ansonsten kam es immer bei .0 an.
                          Bei der Einstellung: Username anstatt Vorname.. hatte ich einmal aktiv und dann wieder deaktiviert. Das der Username auch erkannt wird von Telegram.
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            Wo gibts du bitte in der Instanz den Usernamen an.
                            Habe diesen gerade in der app auf dem Handy gefunden.
                            Mit dem Usernamen funktioniert der call jetzt bei mir auch.
                            Trotzdem komisch bei mir:
                            Text senden mit user = Vorname
                            call senden mit user = Username die auf dem handy eingegeben wurde.
                            Ich finde dies zumindest komisch.
                            Aber wenn es bei dir läuft, dann is gut.
                            Bei mir geht es nicht wie gewünscht.
                            Danke.
                            • bahnuhrB bahnuhr
                              @bahnuhr said in Telegram voice calls, thanks to CallMeBot.com:
                              Zuerst am Handy definiert und dann einmal die Einstellung im Adapter aktiviert und deaktiviert.
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Das hab ich alles schon gemacht.
                                Aber wie schon geschrieben. Bei mir steht in der 2. Seite der config nun beides
                                Username und Vorname
                                Früher stand da nur der Vorname
                                Und das Häkchen auf der 1. Seite der config ist raus.
                                Danke.
                                • bahnuhrB bahnuhr
                                  @bahnuhr ja so hab ich das auch und erst ab da ging bei mir der Call mit dem .2 Adapter.
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Na gut, dann ist es halt so.
                                    Also:
                                    Text mit Vorname als user
                                    und call mit Benutzername als user
                                    (wenn mans weiß geht es ja).
                                    Aber sag mal:
                                    Werden bei dir die Texte dann bei dem call auch ständig wiederholt.
                                    Kann man dies abstellen ?
                                    Danke.
                                    • ? Offline
                                      Ja anrufen mit @ wie in der Anleitung * duckundwech *
                                      Und ja es wiederholt sich, ich frag mal ob es normal ist.
                                      Gerade nach gefragt: eine Option soll kommen mit der man die Wiederholung ausschalten kann. Muss dann nur von @Bluefox eingebaut werden 🙂 Wenn der Bot es dann kann.
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        Gut zu wissen.
                                        Dann warten wir noch.
                                        Danke für deine Hilfe.
                                        Danke.
                                        • L Offline
                                          Leviathan09
                                          schrieb am zuletzt editiert von Leviathan09
                                          Also bei mir hat es nicht direkt funktioniert...ich war aber auch so doof und hatte vergessen das in meinen Privatsphären einstellungen Anrufe blockiert waren...das sollte man also auch beachten.
