  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 140.1k Aufrufe 22 Beobachtet
  • sigi234S sigi234
    @liv-in-sky
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at ontimeout (timers.js:438:13)
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2016:34)
    javascript.0	2020-02-03 18:50:45.014	error	(18996) at Object.<anonymous> (script.js.Listen.Fritz_IP2:155:21)
    javascript.0	2020-02-03 18:50:45.013	error	(18996) Error in callback: TypeError: Cannot read property 'length' of null
    javascript.0	2020-02-03 18:50:32.222	error	(18996) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-02-03 18:50:32.222	error	(18996) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-02-03 18:50:32.222	error	(18996) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-02-03 18:50:32.222	error	(18996) at ontimeout (timers.js:438:13)
    javascript.0	2020-02-03 18:50:32.222	error	(18996) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2016:34)
    javascript.0	2020-02-03 18:50:32.221	error	(18996) at Object.<anonymous> (script.js.Listen.Fritz_IP2:155:21)
    javascript.0	2020-02-03 18:50:32.221	error	(18996) Error in callback: TypeError: Cannot read property 'length' of null
    #294
    @sigi234 das wäre bei mir die Zeile 155: for(var i=0;i<myArr.length;i++) {
    • sigi234S sigi234
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      #295
      @sigi234 das sind 2 verschiedene scripts oben - fußball unten plötzlich fritzip
      • liv-in-skyL liv-in-sky
        sigi234S Online
        sigi234S Online
        #296
        @liv-in-sky sagte in Auslesen IP -Adressen:
        Mit kopiert
        • sigi234S sigi234
          Mit kopiert
          liv-in-skyL Offline
          liv-in-skyL Offline
          #297
          @sigi234 ist das ein zufall, dass beide nicht funktionieren ?
          ich weiß im moment nicht, ob du überhaupt daten bekommst und wenn ja wie die aussehen
          schreib mal in zeile 146:
          log(myData)
          wird da was im log angezeigt ? bevor der fehler dann kommt
            log(myData)
            sigi234S Online
            sigi234S Online
            #298
            log(myData)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at ontimeout (timers.js:438:13)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2016:34)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) at Object.<anonymous> (script.js.Listen.Fritz_IP2:155:21)
            javascript.0	2020-02-03 19:04:15.307	error	(18996) Error in callback: TypeError: Cannot read property 'length' of null
            javascript.0	2020-02-03 19:04:15.305	info	(18996) script.js.Listen.Fritz_IP2:
            javascript.0	2020-02-03 19:04:00.292	info	(18996) script.js.Listen.Fritz_IP2: registered 0 subscriptions and 1 schedule
            javascript.0	2020-02-03 19:04:00.287	info	(18996) Start javascript script.js.Listen.Fritz_IP2
            javascript.0	2020-02-03 19:04:00.245	info	(18996) Stop script script.js.Listen.Fritz_IP2
            javascript.0	2020-02-03 19:03:51.346	info	(18996) script.js.Listen.Fritz_IP2: registered 0 subscriptions and 1 schedule
            javascript.0	2020-02-03 19:03:51.338	info	(18996) Start javascript script.js.Listen.Fritz_IP2
            javascript.0	2020-02-03 19:03:49.303	info	(18996) Stop script script.js.Listen.Fritz_IP2
            • sigi234S sigi234
              log(myData)
              liv-in-skyL Offline
              liv-in-skyL Offline
              #299
              @sigi234 keine daten - es sollte eigentlich xxxxx drinstehen - aber der exec schreibt wohl was - du kannst das script stoppen, bis wir wissen, wie der exec(...nmap...) richtig in windows läuft - erst dann können wir feststellen, ob mit dem script etwas unter windows nicht stimmt
              sigi234S HomoranH 2 Antworten Letzte Antwort
                sigi234S Online
                sigi234S Online
                #300
                Ok
                  #301
                  @liv-in-sky
                  Habe mich mal eben aucf die schnelle durch die nmap.org windows seiten gewühlt.
                  Welche Version habt ihr? oder @sigi234
                  liv-in-skyL sigi234S 2 Antworten Letzte Antwort
                    @liv-in-sky
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #302
                    @Homoran windows ist bei mir 7.7o
                    linux ist 7.40
                      @liv-in-sky
                      sigi234S Online
                      sigi234S Online
                      #303
                      @Homoran sagte in Auslesen IP -Adressen:
                      oder @sigi234
                      7.80
                        linux ist 7.40
                        #304
                        @liv-in-sky
                        gut,
                        habe gerade 7.80 runtergeladen
                        Frage deshalb weil ich iinzwischen überprüft habe: Debian 7.40 mit MAC; Raspi 7.70 ohne MAC
                        Ich versuche es mal mit der 7.80
                          #305
                          @liv-in-sky
                          @sigi234
                          Hat etwas länger gedauert.
                          Installation ging fix, aber ich bekam nmap in der cmd nicht ans laufen, bis...
                          ich bei nmap-org nach langem Suchen fand:
                          If you execute Nmap frequently, you can add the Nmap directory (c:\Program Files (x86)\Nmap by default on Windows 7) to your command execution path.
                          man muss wenn man das nicht macht, den Befehl immer in dem Verzeichnis c:\Program Files (x86)\Nmap aufrufen.
                          Ist das so gemacht, bei euch?
                            @liv-in-sky
                            @sigi234
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #306
                            @Homoran
                            https://forum.iobroker.net/post/370498
                            bei mir geht es auch ohne pfadangabe
                              @Homoran
                              #307
                              Hast du dann so etwas gemacht?
                              The exact place to set this varies by Windows platform. On my Windows XP box, which installs Nmap in c:\Program Files\Nmap, I do the following:
                              From the desktop, right click on My Computer and then click “properties”.
                              In the System Properties window, click the “Advanced” tab.
                              Click the “Environment Variables” button.
                              Choose Path from the System variables section, then hit edit.
                              Add a semi-colon and then your Nmap directory (e.g. c:\Program Files\Nmap) to the end of the value.
                              Open a new DOS window and you should be able to execute a command such as nmap scanme.nmap.org from any directory.
                              Sorry, der verlinkte Post ist mir am Handy nicht so präsent gewesen
                              • sigi234S sigi234
                                oder @sigi234
                                7.80
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #308
                                @sigi234
                                wieder mal ich - bitte testen - dpVIS einstellen
                                //@liv-in-sky Januar 2020 2.2-20:39
                                //HIER WIRD PFAD UND FILENAME DEFINIERT
                                const path = "/htmlip.html";                   //FIlenamen definieren
                                const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                                let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                let dpVIS="0_userdata.0.Tabellen.IPDevices"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                let mySchedule="  * * * * * ";                       //jede minute
                                const domainName="fritz.box";
                                const ipbereich="192.168.178.0/24";
                                const dnsServer="192.168.178.1"
                                const waitTime=25000;
                                const lastZellColorSetting="lightgreen"
                                var symbolOK="🟢";     // auch möglich: ="✅"
                                var symbolKO="💀";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz  oder : ="❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀
                                var symbolWARN="ℹ️";    // ="⚠️" oder info: "ℹ️"
                                var externalOhneInfo=false;  //noch nicht integriert
                                //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                                var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                                var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                //ÜBERSCHRIFT ÜBER TABELLE
                                let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                                let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                const htmlFeldUeber='IP Devices List';              // Überschrift und Signature
                                const htmlFarbUber="black";                         // Farbe der Überschrift
                                const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                                const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                                //MEHRERE TABELLEN NEBENEINANDER
                                let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                const farbetrennungsLinie="white";
                                const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                //ÜBERSCHRIFT SPALTEN
                                const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
                                const farbeLinieUnterUeberschrift="white";
                                const groesseUeberschrift=16;
                                const UeberschriftStyle="normal"                     // möglich "bold"
                                //GANZE TABELLE
                                let abstandZelle="1";
                                let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                let weite="1200";                                     //Weite der Tabelle
                                let zentriert=true;                                   //ganze tabelle zentriert
                                const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                const htmlSchriftart="Helvetica";
                                const htmlSchriftgroesse="14px";
                                //FELDER UND RAHMEN
                                let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                                const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
                                const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                // HIER NICHTS  ÄNDERN
                                let borderHelpBottum;
                                let borderHelpRight;
                                let htmlcenterHelp;
                                let htmlcenterHelp2;
                                if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                const htmlZentriert='<center>'
                                const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                  "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                  " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                 // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                  " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                  " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                  "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                  " </style></head><body>"; // <div>";
                                //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                     "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                const htmlTabUeber3="</tr>";
                                table td:first-child {}  //1
                                table td:nth-child(2) {} //2
                                table td:nth-child(3) {} //3
                                table td:last-child {}   //4
                                //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                var htmlTabUeber2=  "<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                  "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                                var rootcount=true;
                                var myObjOld=[];
                                var htmlTabUeber="";
                                var htmlOut="";
                                var mix;
                                var counter;
                                //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                                var val1; var val0; var val2;
                                function writeHTML(){
                                htmlOut="";
                                counter=-1;
                                htmlTabUeber="";
                                switch (mehrfachTabelle) {
                                  case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                  case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                  case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                  case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                if (!UeberschriftSpalten) {htmlTabUeber=""}
                                //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                                var myData="xxxxx";
                                //var command="C:\\Program Files (x86)\\Nmap\\nmap.exe -sPR "+--dns-servers+ "+dnsServer+" "+ipbereich"
                                exec(' "C:\\Program Files (x86)\\Nmap\\nmap" -sPR 192.168.178.0/24 --dns-server 192.168.178.1', function (error, result, stderr) {
                                  // console.log(result);
                                  myData=result;
                                //log(myData)
                                let timeout = setTimeout(function () {
                                if (!myData.includes("xxxx")) {
                                var myTimeScanArr=myData.match(/(scanned in) (\d+\.\d+ seconds)/g); //log(myTimeScan)
                                // log(myData)
                                let myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+\((\d+.\d+.\d+.\d+)\)|(fritz.\w+)\s+\((\d+.\d+.\d+.\d+)\)|(\d+.\d+.\d+.\d+)$/g)
                                // log(myArr.toString())
                                let var1; let var2; let var3;
                                var myObj=[]
                                  var1=myArr[i].replace(/(for .+) \(\d+\.\d+\.\d+\.\d+\)/,"$1")
                                  log(var1)
                                   var1=var1.replace(/(.+)\(.+\)/," $1")
                                  var2=myArr[i].replace(/for .+ \((\d+\.\d+\.\d+\.\d+)\)/,"$1");//log(var2)
                                  var2=var2.replace(/.+\((.+)\)/,"$1")
                                  var3="true"
                                 let help=[var1,var2,var3]
                                 myObj.push(help)
                                 if (rootcount) myObjOld.push(help)
                                //setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())
                                  let varhelp1; let varhelp2; let varhelp3="true";    //neue erkannt geräte zu datenbank hinzufügen
                                 for (var i=0;i<myObj.length;i++){
                                      //  log(myObj[i][0]+"-----"+myObjOld[i][0])
                                          if (!myObjOld.toString().includes(myObj[i][0]))  {  varhelp1=myObj[i][0] ; varhelp2=myObj[i][1]; varhelp3="true";
        let help=[varhelp1,varhelp2,varhelp3]
        myObjOld.push(help)
                                 for (var i=0;i<myObjOld.length;i++){                // ist gerät noch da ???
                                          if (!myObj.toString().includes(myObjOld[i][0]))  {  varhelp1=myObjOld[i][0] ; varhelp2=myObjOld[i][1]; varhelp3="false";
        myObj.push(help)
                                  // log("------------------------------------------------"+myObjOld[1].toString())
                                  var1="scanned in" //nur scanned seconds
                                  var3="true"
                                  var2=myTimeScanArr[0].replace(/.+ (\d+\.\d+.+$)/,"$1");//log(var2)
                                 myObj.push(help)
                                //log(myObj[0][0])
                                for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                     //  var ida = id.split('.');
                                    //   if( !(id.includes("vis") || id.includes("devices")  ||  id.includes("sssss"))){
                                         counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                       //  log(myObj[i][0].toString())
                                         val0=myObj[i][0].replace("for","")
                                         val0=val0.replace("."+domainName,"")
                                           if (val0.length>=23)  val0=val0.substring(0,23)+" ..."
                                         val1=myObj[i][1]
                                         var val2help=myObj[i][2]
                                         if (val2help=="false") {val2=symbolKO;val0=(" <font color=\"red\"> ")+val0 ;val1=(" <font color=\"red\"> ")+val1}  else{val2=symbolOK}           //<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+"
                                         if(val0=="scanned in") {val2=symbolWARN;val0="<font color=\""+lastZellColorSetting+"\"><i>"+" Anzahl "+counter+"</i>"; val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+"</i>"}
                                    tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                     // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                          tabelleFinish();
                                      if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                      }, 2000);
                                      } else {log("no Data","warn")}
                                      rootcount=false;
                                }, waitTime);
                                } // function ende
                                //MAIN:
                                schedule(mySchedule,  function () {
                                writeHTML();
                                // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                writeHTML();                                   //     <tdalign
                                function tabelleBind(){
                                  //  counter=counter+mehrfachTabelle;
                                        case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                        case 2: if(counter%4==0){
                                                   if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                              else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                                     }else{
                                                               if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                              else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                        case 3:if(counter%2==0)   {
                                                   if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                              else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;}else{
                                                   if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        } break;}
                                        case 4:  // counter=counter+8;
                                                  if(counter%8==0)   {
                                                  if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut =htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                                  if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                       } //switch ende
                                function tabelleFinish() {
                                      case 1:    break;
                                      case 2:
                                                 if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                 break;
                                      case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                 break;
                                      case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                break; }
                                        var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                      var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                       if (!htmlSignature) htmlUnter="";
                                     //  log(" ist htmlUnter - signature "+htmlUnter)
                                         //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                          var htmlOutVIS="";
                                        //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                           if (htmlUberschrift)
                                               { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                             } else {
                                              zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                 // log("bin raus aus tabelleBind");
                                          if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                //mit oder ohne überschrift - zentriert oder links
                                htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                //log(htmlOut);
                                  @sigi234
                                  //GANZE TABELLE
                                  //FELDER UND RAHMEN
                                  let htmlcenterHelp;
                                  var rootcount=true;
                                  var myObjOld=[];
                                  var htmlOut="";
                                  var mix;
                                  var counter;
                                  htmlOut="";
                                  counter=-1;
                                  htmlTabUeber="";
                                  var myData="xxxxx";
                                    myData=result;
                                  //log(myData)
                                  // log(myData)
                                  var myObj=[]
                                    log(var1)
                                    var3="true"
                                   myObj.push(help)
        myObjOld.push(help)
        myObj.push(help)
                                    var3="true"
                                   myObj.push(help)
                                  //log(myObj[0][0])
                                           val1=myObj[i][1]
                                            tabelleFinish();
                                        }, 2000);
                                        rootcount=false;
                                  }, waitTime);
                                  } // function ende
                                  //MAIN:
                                  writeHTML();
                                                       }else{
        } break;}else{
        } break;}
                                                    if(counter%8==0)   {
        } break;}else{
        } break;}
                                         } //switch ende
                                        case 1:    break;
                                        case 2:
                                                   break;
                                                   break;
                                                  break; }
                                            var htmlOutVIS="";
                                               } else {
                                  //log(htmlOut);
                                  sigi234S Online
                                  sigi234S Online
                                  #309
                                  @sigi234
                                  Du Zauberer. 😁
                                  Das kommt noch und das Skript geht auf Pause
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at Timer.processTimers (timers.js:223:10)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at listOnTimeout (timers.js:263:5)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at tryOnTimeout (timers.js:300:5)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at ontimeout (timers.js:438:13)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2016:34)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) at Object.<anonymous> (script.js.Listen.Fritz_IP3:156:21)
                                  javascript.0	2020-02-04 16:28:25.030	error	(7244) Error in callback: TypeError: Cannot read property 'length' of null
                                  • sigi234S sigi234
                                    @sigi234
                                    Du Zauberer. 😁
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #310
                                    @sigi234 ok - habe gar keine nachricht bekommen über diesen post
                                    also immerhin haben wir das exc() schon mal am laufen - jetzt muss ich mir noch was einfallen lassen, um diesen fehler wegzubekommen - im moment weiß ich nicht, wann genau er auftritt - finden wir schon noch - der nmap befehl bekommt leider nicht immer eine gleiche antwort - und ab und zu kommt da was, was diesen fehler erzeugt -
                                    eine idee habe ich schon - scheinbar wird kein array erzeugt und bei der abfrage der arraylänge kommt der fehler
                                    • sigi234S sigi234
                                      @sigi234
                                      Du Zauberer. 😁
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #311
                                      @sigi234 @Homoran und alle die noch dabei sind
                                      hier ein script , welches die fehler besser abfangen ( zeile 156) sollte und nur noch warn in das log scheibt, das schedule ist hier eine minute
                                      @sigi234 ich habe hier auch windows integriert, dass bitte oben einstellen in den settings
                                       const operationSystem="windows";
                                      der exec befehl ist moment auf dein netzwerk eingestellt ipBereich: 192.168.178.0/24 und dns server - andere windows nutzer müssen das von hand im exec befehl ändern
                                      • wenn die namen komisch sind, liegt ds an der fritzbox- kann ich leider nicht ändern
                                      @sigi234 - die überschrift ist in diesem script wieder eingeschaltet
                                      let   braucheEinFile=true;                          // bei true wird ein file geschrieben
                                      const ipbereich="192.168.178.0/24";  //  gilt nicht für windows
                                      const dnsServer="192.168.178.1"      // gilt nicht für windows
                                      const waitTime=15000;
                                      const operationSystem="linux";              // oder windows - hier muss der ipbereich und der dns server direkt ins script eingetragen werden - im exec. befehl
                                      let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                      const htmlFarbUber="white";                         // Farbe der Überschrift
                                      //GANZE TABELLE
                                      //FELDER UND RAHMEN
                                      let htmlcenterHelp;
                                      var rootcount=true;
                                      var myObjOld=[];
                                      var htmlOut="";
                                      var mix;
                                      var counter;
                                      htmlOut="";
                                      counter=-1;
                                      htmlTabUeber="";
                                      var myData="xxxxx";
                                      let myArr=[];
                                      //let myData=getState("0_userdata.0.DeviceIP").val
                                      if(operationSystem=="linux"){
                                      exec("nmap -sPR --dns-servers "+dnsServer+" "+ipbereich  , function (error, result, stderr) {
                                         myData=result
                                       //  setState("0_userdata.0.Tabellen.IPDeviceERROR", result)
                                      });} else {
                                      exec(' "C:\\Program Files (x86)\\Nmap\\nmap" -sP 192.168.178.0/24 --dns-servers 192.168.178.1', function (error, result, stderr) {
                                        myData=result;
                                      //log(myData)
                                      if(myArr.length>2) {
                                      var myObj=[]
                                        // log(var1)
                                         var3="true"
                                        myObj.push(help)
        myObjOld.push(help)
        myObj.push(help)
                                         var3="true"
                                        myObj.push(help)
                                      //log(myObj[0][0])
                                                val1=myObj[i][1]
                                                 tabelleFinish();
                                             }, 2000);
                                             }  else {log("no Array","warn")} //Ende Array falsch
                                             } else {log("no Data","warn")} // ende daten falsch
                                             rootcount=false;
                                      }, waitTime);
                                      } // function ende
                                      //MAIN:
                                       writeHTML();
                                                            }else{
        } break;}else{
        } break;}
                                                         if(counter%8==0)   {
        } break;}else{
        } break;}
                                              } //switch ende
                                             case 1:    break;
                                             case 2:
                                                        break;
                                                        break;
                                                       break; }
                                                 var htmlOutVIS="";
                                                    } else {
                                       //log(htmlOut);
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #312
                                        du hattest recht - ich habe das mit dem pfad schon vor einem jahr gemacht und vergessen - im script nutze ich den standard installationspfad zu nmap - damit geht es
                                          //GANZE TABELLE
                                          //FELDER UND RAHMEN
                                          let htmlcenterHelp;
                                          var rootcount=true;
                                          var myObjOld=[];
                                          var htmlOut="";
                                          var mix;
                                          var counter;
                                          htmlOut="";
                                          counter=-1;
                                          htmlTabUeber="";
                                          var myData="xxxxx";
                                          let myArr=[];
                                             myData=result
                                          });} else {
                                            myData=result;
                                          //log(myData)
                                          var myObj=[]
                                            // log(var1)
                                             var3="true"
                                            myObj.push(help)
        myObjOld.push(help)
        myObj.push(help)
                                             var3="true"
                                            myObj.push(help)
                                          //log(myObj[0][0])
                                                    val1=myObj[i][1]
                                                     tabelleFinish();
                                                 }, 2000);
                                                 rootcount=false;
                                          }, waitTime);
                                          } // function ende
                                          //MAIN:
                                           writeHTML();
        }else{
        } break;}else{
        } break;}
                                                             if(counter%8==0)   {
        } break;}else{
        } break;}
                                                  } //switch ende
                                                 case 1:    break;
                                                 case 2:
                                                            break;
                                                            break;
                                                           break; }
                                                     var htmlOutVIS="";
                                                        } else {
                                           //log(htmlOut);
                                          #313
                                          erster Lauf
