  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 140.2k Aufrufe 22 Beobachtet
  • liv-in-skyL liv-in-sky
    @Homoran gut zu hören - das ist normal (new Date) - damit gibt es keine probleme du kannst das file auch einfach so aufrufen - zum test
    http://192.168.178.59:8082/vis.0/htmlexamplesetting.html
    mit deinem server und deinem filenamen
    @Negalein wie sieht es bei dir aus
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #178
    @liv-in-sky sagte in Auslesen IP -Adressen:
    folgender Fehler kommt
    javascript.0	2020-02-01 16:40:37.873	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-02-01 16:40:37.873	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-02-01 16:40:37.872	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-02-01 16:40:37.872	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at Object.createScript (vm.js:277:10)
    javascript.0	2020-02-01 16:40:37.871	error	(594) at new Script (vm.js:83:7)
    javascript.0	2020-02-01 16:40:37.871	error	(594) SyntaxError: Invalid regular expression: missing /
    javascript.0	2020-02-01 16:40:37.871	error	(594) ^
    javascript.0	2020-02-01 16:40:37.870	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
    javascript.0	2020-02-01 16:40:37.870	error	at script.js.common.Nmap-Test:151
    javascript.0	2020-02-01 16:40:37.870	error	(594) script.js.common.Nmap-Test compile failed:
    ° Fixer ---> iob fix
    liv-in-skyL HomoranH 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      liv-in-skyL Offline
      liv-in-skyL Offline
      #179
      @Negalein @sigi234
      hier - dieses file nutzen
      https://forum.iobroker.net/post/369153
        #180
        @Negalein
        oder einen Backslash hier setzen
        statt:
        dann
        let var1=myArr[i].replace(/\[(.+?),.+/,"$1")
          @Negalein
          statt:
          dann
          #181
          @Homoran sagte in Auslesen IP -Adressen:
          @Negalein
          statt:
          dann
          let var1=myArr[i].replace(/\\[(.+?),.+/,"$1")
            @Negalein @sigi234
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #182
            hab ich vorhin schon benutzt
            //HIER WIRD PFAD UND FILENAME DEFINIERT
            const path = "/htmlexample.html";                   //FIlenamen definieren
            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
            let   braucheEinFile=true;                          // bei true wird ein file geschrieben
            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
            let dpVIS="0_userdata.0.Tabellen.nMap-Test"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
            let mySchedule=" * * * * * ";                       //jede minute
            const domainName="fritz.box";
            const ipbereich="10.0.1.0/24";
            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
            var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
            var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
            var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
            //ÜBERSCHRIFT ÜBER TABELLE
            let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
            let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
            const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
            const htmlFarbUber="white";                         // Farbe der Überschrift
            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
            //MEHRERE TABELLEN NEBENEINANDER
            let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
            const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
            const farbetrennungsLinie="white";
            const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
            //ÜBERSCHRIFT SPALTEN
            const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
            const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
            const farbeLinieUnterUeberschrift="white";
            const groesseUeberschrift=16;
            const UeberschriftStyle="normal"                     // möglich "bold"
            //GANZE TABELLE
            let abstandZelle="1";
            let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let weite="auto";                                     //Weite der Tabelle
            let zentriert=true;                                   //ganze tabelle zentriert
            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
            const htmlSchriftart="Helvetica";
            const htmlSchriftgroesse="14px";
            //FELDER UND RAHMEN
            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
            const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
            const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
            const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
            let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
            // HIER NICHTS  ÄNDERN
            let borderHelpBottum;
            let borderHelpRight;
            let htmlcenterHelp;
            let htmlcenterHelp2;
            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
            const htmlZentriert='<center>'
            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                               " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                               " </style></head><body> <div>";
            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
            const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                  "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
            const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
            const htmlTabUeber3="</tr>";
            table td:first-child {}  //1
            table td:nth-child(2) {} //2
            table td:nth-child(3) {} //3
            table td:last-child {}   //4
            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
               	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
            var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                               "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
            var htmlTabUeber="";
            var htmlOut="";
            var mix;
            var counter;
            //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
            var val1; var val0; var val2;
            function writeHTML(){
            htmlOut="";
            counter=-1;
            htmlTabUeber="";
            switch (mehrfachTabelle) {
               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
               case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
            if (!UeberschriftSpalten) {htmlTabUeber=""}
            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
            //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
            var myData;
            //let myData=getState("0_userdata.0.DeviceIP").val
            exec("nmap -sP "+ipbereich , function (error, result, stderr) {
               myData=result
            let timeout = setTimeout(function () {
             myData=myData.replace(/\n/g,"")
            //log(myData)
            myData=myData.replace(/.+?(for .+? \(\d+\.\d+\.\d+\.\d+)\).+?/g,"$1___")
            myData=myData.replace(/\(/g,"")
            myData=myData.replace(/(for .+?) (\d+\.\d+\.\d+\.\d+)/g,"[$1,$2]")
            myData=myData.replace(/,$/g,"")
            myData=myData.replace(/___ost.+$/g,"")
            let myArr=myData.split("___")
            var myObj=[]
            for(var i=0;i<myArr.length;i++) {
              let var2=myArr[i].replace(/.+?,(.+)]/,"$1");//log(var2)
              let help=[var1,var2]
              myObj.push(help)
            //log(myObj[0][0])
            for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                  //  var ida = id.split('.');
                 //   if( !(id.includes("vis") || id.includes("devices")  ||  id.includes("sssss"))){
                      counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                      val0=myObj[i][0].replace("for","")
                      val0=val0.replace("."+domainName,"")
                        if (val0.length>=23)  val0=val0.substring(0,23)+" ..."
                      val1=myObj[i][1]
                      var val2help=true
                   //   val1=Math.floor( ((val1help)/60/60/24) )+"d "+ Math.floor(((val1help)/60/60) % 24) +"h "+ Math.floor( ((val1help)/60) % 60 )+" m" ;
                      if (!val2help) {val2="❌"} else{val2="✅"}
                 tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
            }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
            //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                  tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
            }, 10000);
            } // function ende
            //MAIN:
            //schedule(mySchedule,  function () {
             writeHTML();
             if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
            //writeHTML();                                   //     <tdalign
             function tabelleBind(){
               //  counter=counter+mehrfachTabelle;
                     case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
                                                      {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                     case 2: if(counter%4==0){
                                if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                  }else{
                                            if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                     case 3:if(counter%2==0)   {
                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                           else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
                                                            else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
                                                      } break;}else{
                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
                                                      } break;}
                     case 4:  // counter=counter+8;
                               if(counter%8==0)   {
                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
                                                            else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                      } break;}else{
                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
                                                            else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                      } break;}
                    } //switch ende
            function tabelleFinish() {
                   case 1:    break;
                   case 2:
                              if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                              break;
                   case 3:   if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                             if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                              break;
                   case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                             if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             break; }
                     var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                    if (!htmlSignature) htmlUnter="";
                      //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                       var htmlOutVIS="";
                     //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                        if (htmlUberschrift)
                            { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                          } else {
                           zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
              // log("bin raus aus tabelleBind");
                       if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
             var htmlEnd="</table>"+htmlUnter+"</div></body>";
             //mit oder ohne überschrift - zentriert oder links
            htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
             //log(htmlOut);
            Fehler bleibt
            javascript.0	2020-02-01 16:43:54.941	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
            javascript.0	2020-02-01 16:43:54.941	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
            javascript.0	2020-02-01 16:43:54.940	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
            javascript.0	2020-02-01 16:43:54.940	error	(594) at Object.createScript (vm.js:277:10)
            javascript.0	2020-02-01 16:43:54.940	error	(594) at new Script (vm.js:83:7)
            javascript.0	2020-02-01 16:43:54.940	error	(594) SyntaxError: Invalid regular expression: missing /
            javascript.0	2020-02-01 16:43:54.940	error	(594) ^
            javascript.0	2020-02-01 16:43:54.940	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
            javascript.0	2020-02-01 16:43:54.940	error	(594) script.js.common.Nmap-Test compile failed: at script.js.common.Nmap-Test:151
              da ist nix:
              nur die "alten" Tabellen
              liv-in-skyL Offline
              liv-in-skyL Offline
              #183
              @Homoran @sigi234 @Negalein
              bitte warten ich bin bl...
              ich habe da was rausgelöscht, weil ich am anfang noch mit blockly was machen wollte - kommt gleich das neuste
              es wird kein file geschrieben, und auch keine updates gemacht
              kommt gleich
              • liv-in-skyL Offline
                liv-in-skyL Offline
                #184
                nur zur info - das dauert noch eine weile - muss noch ein paar sachen ausarbeiten
                HomoranH NegaleinN sigi234S 3 Antworten Letzte Antwort
                  #185
                  @liv-in-sky
                  nur die Ruhe - keine Panik!
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #186
                    keine Eile
                    ich soll mich eh gerade etwas schonen
                      sigi234S Online
                      sigi234S Online
                      #187
                      Was neues? Kann ich nMap wieder deinstallieren, oder brauchst du noch was?
                      Erledigt. 😀
                        keine Eile
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #188
                        @Negalein @Homoran @sigi234
                        hätte wieder was zum testen
                        wichtig
                        • neue settiings oben, euer dns server, domain name und wie immer der dpVIS datenpunkt (wenn benötigt)
                        • zum test ist eine update zeit von 30 sekunden eingestellt - damit ihr nicht solange warten müßt, wenn ihr einen client vom netz nehmt (z.b wifi beim handy ausschalten)
                        • beim ersten test, schaltet das wifi vom handy aus bevor das script statet- wartet bis eine anzeige kommt und dann erst das handy wieder auf connect - das simuliert : wenn ein neues gerät dazukommt, soll das beim abmelden vom netz wieder auf falsch gehen - dazu muss ein object beschrieben werden
                        • am besten wäre es, zuerst den nmap befehl auf der console von hand aufzurufen und zu kontrollieren, ob alle gezeigten geräte einen namen haben -also über dns aufgelöst werden können - sonst könnte das script ein problem haben
                        nmap -sPR --dns-servers 192.168.178.1 192.168.178.0/24
                        //@liv-in-sky Januar 2020 2.2-14:39
                        const path = "/htmlip.html";                   //FIlenamen definieren
                        let dpVIS="0_userdata.0.Tabellen.IPDevices"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                        let mySchedule="  */30 * * * * * ";                       //jede minute
                        const ipbereich="192.168.178.0/24";
                        const dnsServer="192.168.178.1"
                        const waitTime=15000;
                        const lastZellColorSetting="lightgreen"
                        var symbolOK="🟢";     // auch möglich: ="✅"
                        var symbolKO="💀";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz  oder : ="❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀
                        var symbolWARN="ℹ️";    // ="⚠️" oder info: "ℹ️"
                        var externalOhneInfo=false;  //noch nicht integriert
                        let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                        const htmlFeldUeber='IP Devices List';              // Überschrift und Signature
                        //GANZE TABELLE
                        let weite="1200";                                     //Weite der Tabelle
                        //FELDER UND RAHMEN
                        let htmlcenterHelp;
                                           " </style></head><body>"; // <div>";
                        var htmlTabUeber2=  "<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                        var rootcount=true;
                        var myObjOld=[];
                        var htmlOut="";
                        var mix;
                        var counter;
                        htmlOut="";
                        counter=-1;
                        htmlTabUeber="";
                        var myData="xxxxx";
                        exec("nmap -sPR --dns-servers "+dnsServer+" "+ipbereich  , function (error, result, stderr) {
                           myData=result
                         if (!myData.includes("xxxx")) {
                        // log(myData)
                        var myTimeScan=myData.replace(/.+(scanned in) (\d+\.\d+ seconds)/,"$1 - $2"); //log(myTimeScan)
                        let var1; let var2; let var3;
                        var myObj=[]
                           var2=myArr[i].replace(/.+?,(.+)\]/,"$1");//log(var2)
                           var3="true"
                          let help=[var1,var2,var3]
                          myObj.push(help)
                          if (rootcount) myObjOld.push(help)
                        //setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())
                           let varhelp1; let varhelp2; let varhelp3="true";    //neue erkannt geräte zu datenbank hinzufügen
                          for (var i=0;i<myObj.length;i++){
                               //  log(myObj[i][0]+"-----"+myObjOld[i][0])
                                   if (!myObjOld.toString().includes(myObj[i][0]))  {  varhelp1=myObj[i][0] ; varhelp2=myObj[i][1]; varhelp3="true";
        let help=[varhelp1,varhelp2,varhelp3]
        myObjOld.push(help)
                                                             } //else{varhelp3="true"; log("bin in break") ;break  }//log(myObj[i][0],"warn") }
                          for (var i=0;i<myObjOld.length;i++){                // ist gerät noch da ???
                                   if (!myObj.toString().includes(myObjOld[i][0]))  {  varhelp1=myObjOld[i][0] ; varhelp2=myObjOld[i][1]; varhelp3="false";
        myObj.push(help)
                           // log("------------------------------------------------"+myObjOld[1].toString())
                           var1=myTimeScan.replace(/(^.+) -.+/," $1")  //nur scanned seconds
                           var3="true"
                           var2=myTimeScan.replace(/.+- (.+$)/,"$1");//log(var2)
                          myObj.push(help)
                        //log(myObj[0][0])
                                //  log(myObj[i][0].toString())
                                  val1=myObj[i][1]
                                  var val2help=myObj[i][2]
                                  if (val2help=="false") {val2=symbolKO;val0=(" <font color=\"red\"> ")+val0 ;val1=(" <font color=\"red\"> ")+val1}  else{val2=symbolOK}           //<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+"
                                  if(val0==" scanned in") {val2=symbolWARN;val0="<font color=\""+lastZellColorSetting+"\"><i>"+"Anzahl "+counter+"</i>"; val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+"</i>"}
                        //myArrOld=myArr.slice(0);
                        //log(myArr.toString()+" und alt : "+myArrOld.toString())
                                   tabelleFinish();
                               }, 1000);
                               } else {log("no Data","warn")}
                               rootcount=false;
                        }, waitTime);
                        } // function ende
                        //MAIN:
                         writeHTML();
                        // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                              }else{
                                                       else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}else{
        } break;}
                                           if(counter%8==0)   {
        else    {htmlOut =htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                } //switch ende
                               case 1:    break;
                               case 2:
                                          break;
                               case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                         if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                          break;
                                         break; }
                              //  log(" ist htmlUnter - signature "+htmlUnter)
                                   var htmlOutVIS="";
                                      } else {
                         //log(htmlOut);
                        nachtrag - das forum verändert das script !?! bitte zeile 160 von hand ändern - es fehlt ein backslash vor der eckigen klammer
                        siehe https://forum.iobroker.net/post/369181
                        sigi234S crunchipC NegaleinN HomoranH 4 Antworten Letzte Antwort
                        • sigi234S sigi234
                          Erledigt. 😀
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #189
                          @sigi234 selbst wenn du es nicht nutzt, das programm benötigt nicht viel platz - musst du eigentlich nicht deinstallieren
                            wichtig
                            //GANZE TABELLE
                            //FELDER UND RAHMEN
                            let htmlcenterHelp;
                            var rootcount=true;
                            var myObjOld=[];
                            var htmlOut="";
                            var mix;
                            var counter;
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                            var myData="xxxxx";
                               myData=result
                            // log(myData)
                            var myObj=[]
                               var3="true"
                              myObj.push(help)
        myObjOld.push(help)
        myObj.push(help)
                               var3="true"
                              myObj.push(help)
                            //log(myObj[0][0])
                                      val1=myObj[i][1]
                                       tabelleFinish();
                                   }, 1000);
                                   rootcount=false;
                            }, waitTime);
                            } // function ende
                            //MAIN:
                             writeHTML();
                                                  }else{
        } break;}else{
        } break;}
                                               if(counter%8==0)   {
        } break;}else{
        } break;}
                                    } //switch ende
                                   case 1:    break;
                                   case 2:
                                              break;
                                              break;
                                             break; }
                                       var htmlOutVIS="";
                                          } else {
                             //log(htmlOut);
                            sigi234S Online
                            sigi234S Online
                            #190
                            @liv-in-sky
                            14:39:32.624	info	javascript.0 (3284) Stop script script.js.Listen.Fritz_IP
                            14:39:32.628	info	javascript.0 (3284) Start javascript script.js.Listen.Fritz_IP
                            14:39:32.629	error	javascript.0 (3284) script.js.Listen.Fritz_IP compile failed: at script.js.Listen.Fritz_IP:157
                              wichtig
                              //GANZE TABELLE
                              //FELDER UND RAHMEN
                              let htmlcenterHelp;
                              var rootcount=true;
                              var myObjOld=[];
                              var htmlOut="";
                              var mix;
                              var counter;
                              htmlOut="";
                              counter=-1;
                              htmlTabUeber="";
                              var myData="xxxxx";
                                 myData=result
                              // log(myData)
                              var myObj=[]
                                 var3="true"
                                myObj.push(help)
        myObjOld.push(help)
        myObj.push(help)
                                 var3="true"
                                myObj.push(help)
                              //log(myObj[0][0])
                                        val1=myObj[i][1]
                                         tabelleFinish();
                                     }, 1000);
                                     rootcount=false;
                              }, waitTime);
                              } // function ende
                              //MAIN:
                               writeHTML();
                                                    }else{
        } break;}else{
        } break;}
                                                 if(counter%8==0)   {
        } break;}else{
        } break;}
                                      } //switch ende
                                     case 1:    break;
                                     case 2:
                                                break;
                                                break;
                                               break; }
                                         var htmlOutVIS="";
                                            } else {
                               //log(htmlOut);
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #191
                              @liv-in-sky und wenn man mehrere Netzwerke laufen hat? 😁
                              z.b normales Netz, eins für Iot, eins für NoT
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #192
                                @crunchip dann hat man unifi, wenn man schlau ist - so wie du - dann braucht man das nicht :-)
                                • sigi234S sigi234
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #193
                                  @sigi234 ich habe das script nochmal kopiert - zeile 157 - bitte ersetze es nochmal und gehe anschliessend durch das script und schaue, ob da was gekringelt wird - aßer das mit new Date - das ist ok
                                    sigi234S Online
                                    sigi234S Online
                                    #194
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at process._tickCallback (internal/process/next_tick.js:68:7)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at promise.then (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at tryCatcher (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at client.get (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:580:17)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at adapter.getForeignState (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:855:17)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at createProblemObject (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1264:17)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at prepareScript (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:1211:37)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at compile (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:988:28)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at Object.createScript (vm.js:277:10)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) at new Script (vm.js:83:7)
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) SyntaxError: Invalid regular expression: missing /
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) ^
                                    javascript.0	2020-02-02 14:47:29.247	error	(3284) var1=myArr[i].replace(/[(.+?),.+/,"$1")
                                    javascript.0	2020-02-02 14:47:29.246	error	at script.js.Listen.Fritz_IP1:161
                                    javascript.0	2020-02-02 14:47:29.246	error	(3284) script.js.Listen.Fritz_IP1 compile failed:
                                    javascript.0	2020-02-02 14:47:29.245	info	(3284) Start javascript script.js.Listen.Fritz_IP1
                                    liv-in-skyL 3 Antworten Letzte Antwort
                                    • sigi234S sigi234
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #195
                                      @sigi234
                                      dies ist der selbe fehler wie gestern - den habe ich im script ausgebessert https://forum.iobroker.net/post/369181
                                      lösche das alte script - und starte mal deine javascript instanzen neu - evtl läuft da was doppelt
                                      • sigi234S sigi234
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #196
                                        @sigi234 im moment weiß ich nicht was da los ist - ich kopiere mein script mit der ausgebesserten zeile 161 ins forum - wenn ich dann aber im forum anschliessend nachsehe, ist wieder die alte version drin - ich wechsle mal den browser
                                          sigi234S Online
                                          sigi234S Online
                                          #197
