  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 140.2k Aufrufe 22 Beobachtet
    @liv-in-sky sagte in Auslesen IP -Adressen:
    im script einstellen
    einen datenpunkt für die vis (wenn man eine hat - ansonsten das file)
    den domänennamen und
    das zu scannende netzwerk
    Ich habe die Einstellungen von dem Batteriescript genommen (also nur file - dann auch keinen DP für vis) und bekomme:
    ascript.0	2020-02-01 15:52:48.712	error	(17017) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-02-01 15:52:48.711	error	(17017) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-02-01 15:52:48.710	error	(17017) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-02-01 15:52:48.710	error	(17017) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:581:17)
    javascript.0	2020-02-01 15:52:48.709	error	(17017) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1048:17)
    javascript.0	2020-02-01 15:52:48.709	error	(17017) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1457:17)
    javascript.0	2020-02-01 15:52:48.707	error	(17017) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1404:37)
    javascript.0	2020-02-01 15:52:48.706	error	(17017) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1181:28)
    javascript.0	2020-02-01 15:52:48.706	error	(17017) at Object.createScript (vm.js:277:10)
    javascript.0	2020-02-01 15:52:48.704	error	(17017) at new Script (vm.js:83:7)
    javascript.0	2020-02-01 15:52:48.704	error	(17017) SyntaxError: Invalid regular expression: missing /
    javascript.0	2020-02-01 15:52:48.702	error	(17017) ^
    javascript.0	2020-02-01 15:52:48.701	error	(17017) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
    javascript.0	2020-02-01 15:52:48.700	error	at script.js.nmap-Testing.initial_release:148
    javascript.0	2020-02-01 15:52:48.700	error	(17017) script.js.nmap-Testing.initial_release compile failed:
    liv-in-skyL Offline
    liv-in-skyL Offline
    #163
    @Homoran es kannsein , das sich die settings unterscheiden - dies ist das neuste template version - also bitte settings einzeln ändern und nicht kopieren und ersetzen
    lt fehlermeldung soll ein promise problem sein - nutze ich nicht - bitte dieses file neu kopieren und alle javascript-insanzen neustarten -
    • liv-in-skyL liv-in-sky
      #164
      und nicht kopieren
      nix kopiert - eingegeben ;-)
      DP-Pfad muss doch nur eingegeben werden wenn "brauche ein widget" = true ist
      was ist das ???
      EDIT:
      ich lese da im Error: SyntaxError: Invalid regular expression: missing /
        @Negalein es sollte alle geräte zeigen - die, die wieder offline gehen, verschwinden mit diesem script wieder - aber ich versuche das einzbauen - in einer der nächsten versionen - im moment ist der status-haken nichts-sagend, da er immer grün ist, wenn ein gerät sichtbar ist
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #165
        Super, dann teste ich mal mit :)
        ° Fixer ---> iob fix
          und nicht kopieren
          was ist das ???
          EDIT:
          liv-in-skyL Offline
          liv-in-skyL Offline
          #166
          @Homoran stimmt - da hast du recht
          aus der fehlermeldung werde ich nicht schlau - ist schon beim compalieren ein fehler oder erst nachdem du das script startest ?
            #167
            @liv-in-sky sofort beim start
            muss mal sehen ob da sonst was unterkringelt ist
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              #168
              @liv-in-sky
              Hab das Script von oben übernommen, DP für VIS angelegt und eingetragen.
              Domainname gleich gelassen, da auch eine Fritzbox
              IP-bereich auf 10.0.1.0/24 geändert.
              kommt folgendes auch gleich beim start des Scripts.
              javascript.0	2020-02-01 16:12:50.248	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
              javascript.0	2020-02-01 16:12:50.248	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
              javascript.0	2020-02-01 16:12:50.247	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
              javascript.0	2020-02-01 16:12:50.247	error	(594) at Object.createScript (vm.js:277:10)
              javascript.0	2020-02-01 16:12:50.247	error	(594) at new Script (vm.js:83:7)
              javascript.0	2020-02-01 16:12:50.247	error	(594) SyntaxError: Invalid regular expression: missing /
              javascript.0	2020-02-01 16:12:50.247	error	(594) ^
              javascript.0	2020-02-01 16:12:50.247	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
              javascript.0	2020-02-01 16:12:50.246	error	at script.js.common.Nmap-Test:152
              javascript.0	2020-02-01 16:12:50.246	error	(594) script.js.common.Nmap-Test compile failed:
              • NegaleinN Negalein
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                #169
                @Negalein oje - selber fehler wie bei @homoran - ich kuck nochmal
                  #170
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #171
                    @Homoran
                    bei mir ist das nicht
                    • liv-in-skyL Offline
                      liv-in-skyL Offline
                      #172
                      ich kopier das file nochmal
                      //HIER WIRD PFAD UND FILENAME DEFINIERT
                      const path = "/htmlexample.html";                   //FIlenamen definieren
                      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                      let   braucheEinFile=true;                          // bei true wird ein file geschrieben
                      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                      let dpVIS="controll-own.0.AAATEST.TestHTML"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                      let mySchedule=" * * * * * ";                       //jede minute
                      const domainName="fritz.box";
                      const ipbereich="192.168.178.0/24";
                      //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                      var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                      var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                      var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                      //ÜBERSCHRIFT ÜBER TABELLE
                      let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                      let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                      const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                      const htmlFarbUber="white";                         // Farbe der Überschrift
                      const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                      const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                      //MEHRERE TABELLEN NEBENEINANDER
                      let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                      const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                      const farbetrennungsLinie="white";
                      const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                      const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                      //ÜBERSCHRIFT SPALTEN
                      const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                      const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
                      const farbeLinieUnterUeberschrift="white";
                      const groesseUeberschrift=16;
                      const UeberschriftStyle="normal"                     // möglich "bold"
                      //GANZE TABELLE
                      let abstandZelle="1";
                      let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                      let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                      let weite="auto";                                     //Weite der Tabelle
                      let zentriert=true;                                   //ganze tabelle zentriert
                      const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                      const htmlSchriftart="Helvetica";
                      const htmlSchriftgroesse="14px";
                      //FELDER UND RAHMEN
                      let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                      const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
                      const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
                      const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                      const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                      const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                      let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                      const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                      // HIER NICHTS  ÄNDERN
                      let borderHelpBottum;
                      let borderHelpRight;
                      let htmlcenterHelp;
                      let htmlcenterHelp2;
                      if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                      if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                      if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                      if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                      zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                      zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                      const htmlZentriert='<center>'
                      const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                         "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                         " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                        // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                         " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                         " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                         "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                         " </style></head><body> <div>";
                      //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                      const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                            "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                      const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                      const htmlTabUeber3="</tr>";
                      table td:first-child {}  //1
                      table td:nth-child(2) {} //2
                      table td:nth-child(3) {} //3
                      table td:last-child {}   //4
                      //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                         	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                      var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                         "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                      var htmlTabUeber="";
                      var htmlOut="";
                      var mix;
                      var counter;
                      //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                      var val1; var val0; var val2;
                      function writeHTML(){
                      htmlOut="";
                      counter=-1;
                      htmlTabUeber="";
                      switch (mehrfachTabelle) {
                         case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                         case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                         case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                         case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                      if (!UeberschriftSpalten) {htmlTabUeber=""}
                      //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                      //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                      var myData;
                      //let myData=getState("0_userdata.0.DeviceIP").val
                      exec("nmap -sP "+ipbereich , function (error, result, stderr) {
                         myData=result
                      let timeout = setTimeout(function () {
                       myData=myData.replace(/\n/g,"")
                      //log(myData)
                      myData=myData.replace(/.+?(for .+? \(\d+\.\d+\.\d+\.\d+)\).+?/g,"$1___")
                      myData=myData.replace(/\(/g,"")
                      myData=myData.replace(/(for .+?) (\d+\.\d+\.\d+\.\d+)/g,"[$1,$2]")
                      myData=myData.replace(/,$/g,"")
                      myData=myData.replace(/___ost.+$/g,"")
                      let myArr=myData.split("___")
                      var myObj=[]
                      for(var i=0;i<myArr.length;i++) {
                        let var1=myArr[i].replace(/\[(.+?),.+/,"$1")
                        let var2=myArr[i].replace(/.+?,(.+)\]/,"$1");//log(var2)
                        let help=[var1,var2]
                        myObj.push(help)
                      //log(myObj[0][0])
                      for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                            //  var ida = id.split('.');
                           //   if( !(id.includes("vis") || id.includes("devices")  ||  id.includes("sssss"))){
                                counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                val0=myObj[i][0].replace("for","")
                                val0=val0.replace("."+domainName,"")
                                  if (val0.length>=23)  val0=val0.substring(0,23)+" ..."
                                val1=myObj[i][1]
                                var val2help=true
                             //   val1=Math.floor( ((val1help)/60/60/24) )+"d "+ Math.floor(((val1help)/60/60) % 24) +"h "+ Math.floor( ((val1help)/60) % 60 )+" m" ;
                                if (!val2help) {val2="❌"} else{val2="✅"}
                           tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                      }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                      //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                            tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                      }, 10000);
                      } // function ende
                      //MAIN:
                      //schedule(mySchedule,  function () {
                       writeHTML();
                       if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                      //writeHTML();                                   //     <tdalign
                       function tabelleBind(){
                         //  counter=counter+mehrfachTabelle;
                               case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                               case 2: if(counter%4==0){
                                          if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                     else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                            }else{
                                                      if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                     else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                               case 3:if(counter%2==0)   {
                                          if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                     else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;}else{
                                          if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}
                               case 4:  // counter=counter+8;
                                         if(counter%8==0)   {
                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                                         else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                                         else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                              } //switch ende
                      function tabelleFinish() {
                             case 1:    break;
                             case 2:
                                        if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                        break;
                             case 3:   if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                       if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                       if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                        break;
                             case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                       if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                       if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                       if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                       break; }
                               var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                              if (!htmlSignature) htmlUnter="";
                                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                 var htmlOutVIS="";
                               //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                  if (htmlUberschrift)
                                      { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                    } else {
                                     zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                        // log("bin raus aus tabelleBind");
                                 if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                       var htmlEnd="</table>"+htmlUnter+"</div></body>";
                       //mit oder ohne überschrift - zentriert oder links
                      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                       //log(htmlOut);
                        @Homoran
                        #173
                        @liv-in-sky du hast bei var 1 einen zusätzlichen Backslash vor der Eckigen öffnenden Klammer - der ist bei mir nicht
                        Damit läuft es
                          #174
                          Bei mir kommt keine Tabelle:-(
                          Habe das iframe so konfiguriert:
                          <iframe width="100% "height="100% "frameborder="0" src="/vis.0/htmlexample.html"></iframe>
                          habe noch nicht überprüft ob die Datei da liegt
                          Habe aber noch Kompilierungsfehler - aber nicht im log!
                          EDIT: unter vis.0 liegt die Datei nicht
                            Damit läuft es
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #175
                            @Homoran gut zu hören - das ist normal (new Date) - damit gibt es keine probleme du kannst das file auch einfach so aufrufen - zum test
                            http://192.168.178.59:8082/vis.0/htmlexamplesetting.html
                            mit deinem server und deinem filenamen
                            @Negalein wie sieht es bei dir aus
                            HomoranH sigi234S NegaleinN 3 Antworten Letzte Antwort
                              #176
                              da ist nix:
                              nur die "alten" Tabellen
                                sigi234S Online
                                sigi234S Online
                                #177
                                @liv-in-sky
                                So bin wieder da, wo ist das neueste Skript?
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #178
                                  folgender Fehler kommt
                                  javascript.0	2020-02-01 16:40:37.873	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
                                  javascript.0	2020-02-01 16:40:37.873	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                  javascript.0	2020-02-01 16:40:37.872	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                  javascript.0	2020-02-01 16:40:37.872	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at Object.createScript (vm.js:277:10)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) at new Script (vm.js:83:7)
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) SyntaxError: Invalid regular expression: missing /
                                  javascript.0	2020-02-01 16:40:37.871	error	(594) ^
                                  javascript.0	2020-02-01 16:40:37.870	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
                                  javascript.0	2020-02-01 16:40:37.870	error	at script.js.common.Nmap-Test:151
                                  javascript.0	2020-02-01 16:40:37.870	error	(594) script.js.common.Nmap-Test compile failed:
                                  liv-in-skyL HomoranH 2 Antworten Letzte Antwort
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #179
                                    @Negalein @sigi234
                                    hier - dieses file nutzen
                                    https://forum.iobroker.net/post/369153
                                      #180
                                      @Negalein
                                      oder einen Backslash hier setzen
                                      statt:
                                      dann
                                        @Negalein
                                        statt:
                                        dann
                                        #181
                                        @Homoran sagte in Auslesen IP -Adressen:
                                        @Negalein
                                        statt:
                                        dann
                                        let var1=myArr[i].replace(/\\[(.+?),.+/,"$1")
                                          @Negalein @sigi234
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #182
                                          hab ich vorhin schon benutzt
                                          let dpVIS="0_userdata.0.Tabellen.nMap-Test"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                          const ipbereich="10.0.1.0/24";
                                          //GANZE TABELLE
                                          //FELDER UND RAHMEN
                                          let htmlcenterHelp;
                                          var htmlOut="";
                                          var mix;
                                          var counter;
                                          htmlOut="";
                                          counter=-1;
                                          htmlTabUeber="";
                                          var myData;
                                             myData=result
                                          //log(myData)
                                          var myObj=[]
                                            let var2=myArr[i].replace(/.+?,(.+)]/,"$1");//log(var2)
                                            myObj.push(help)
                                          //log(myObj[0][0])
                                                    val1=myObj[i][1]
                                                    var val2help=true
                                          }, 10000);
                                          } // function ende
                                          //MAIN:
                                           writeHTML();
        }else{
        } break;}else{
        } break;}
                                                             if(counter%8==0)   {
        } break;}else{
        } break;}
                                                  } //switch ende
                                                 case 1:    break;
                                                 case 2:
                                                            break;
                                                            break;
                                                           break; }
                                                     var htmlOutVIS="";
                                                        } else {
                                           //log(htmlOut);
                                          Fehler bleibt
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
                                          javascript.0	2020-02-01 16:43:54.941	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) at Object.createScript (vm.js:277:10)
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) at new Script (vm.js:83:7)
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) SyntaxError: Invalid regular expression: missing /
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) ^
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
                                          javascript.0	2020-02-01 16:43:54.940	error	(594) script.js.common.Nmap-Test compile failed: at script.js.common.Nmap-Test:151
