  4. Auslesen IP -Adressen
vis
541 Beiträge 17 Kommentatoren 140.2k Aufrufe 22 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #168
    @liv-in-sky
    Hab das Script von oben übernommen, DP für VIS angelegt und eingetragen.
    Domainname gleich gelassen, da auch eine Fritzbox
    IP-bereich auf 10.0.1.0/24 geändert.
    kommt folgendes auch gleich beim start des Scripts.
    javascript.0	2020-02-01 16:12:50.248	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
    javascript.0	2020-02-01 16:12:50.248	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
    javascript.0	2020-02-01 16:12:50.247	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
    javascript.0	2020-02-01 16:12:50.247	error	(594) at Object.createScript (vm.js:277:10)
    javascript.0	2020-02-01 16:12:50.247	error	(594) at new Script (vm.js:83:7)
    javascript.0	2020-02-01 16:12:50.247	error	(594) SyntaxError: Invalid regular expression: missing /
    javascript.0	2020-02-01 16:12:50.247	error	(594) ^
    javascript.0	2020-02-01 16:12:50.247	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
    javascript.0	2020-02-01 16:12:50.246	error	at script.js.common.Nmap-Test:152
    javascript.0	2020-02-01 16:12:50.246	error	(594) script.js.common.Nmap-Test compile failed:
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      #169
      @Negalein oje - selber fehler wie bei @homoran - ich kuck nochmal
      • liv-in-skyL liv-in-sky
        #170
          @liv-in-sky sofort beim start
          muss mal sehen ob da sonst was unterkringelt ist
          liv-in-skyL Offline
          liv-in-skyL Offline
          #171
          @Homoran
          bei mir ist das nicht
          • liv-in-skyL Offline
            liv-in-skyL Offline
            #172
            ich kopier das file nochmal
            //HIER WIRD PFAD UND FILENAME DEFINIERT
            const path = "/htmlexample.html";                   //FIlenamen definieren
            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
            let   braucheEinFile=true;                          // bei true wird ein file geschrieben
            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
            let dpVIS="controll-own.0.AAATEST.TestHTML"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
            let mySchedule=" * * * * * ";                       //jede minute
            const domainName="fritz.box";
            const ipbereich="192.168.178.0/24";
            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
            var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
            var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
            var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
            //ÜBERSCHRIFT ÜBER TABELLE
            let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
            let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
            const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
            const htmlFarbUber="white";                         // Farbe der Überschrift
            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
            //MEHRERE TABELLEN NEBENEINANDER
            let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
            const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
            const farbetrennungsLinie="white";
            const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
            //ÜBERSCHRIFT SPALTEN
            const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
            const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
            const farbeLinieUnterUeberschrift="white";
            const groesseUeberschrift=16;
            const UeberschriftStyle="normal"                     // möglich "bold"
            //GANZE TABELLE
            let abstandZelle="1";
            let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let weite="auto";                                     //Weite der Tabelle
            let zentriert=true;                                   //ganze tabelle zentriert
            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
            const htmlSchriftart="Helvetica";
            const htmlSchriftgroesse="14px";
            //FELDER UND RAHMEN
            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
            const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
            const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
            const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
            let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
            // HIER NICHTS  ÄNDERN
            let borderHelpBottum;
            let borderHelpRight;
            let htmlcenterHelp;
            let htmlcenterHelp2;
            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
            const htmlZentriert='<center>'
            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                               " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                               " </style></head><body> <div>";
            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
            const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                  "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
            const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
            const htmlTabUeber3="</tr>";
            table td:first-child {}  //1
            table td:nth-child(2) {} //2
            table td:nth-child(3) {} //3
            table td:last-child {}   //4
            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
               	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
            var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                               "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
            var htmlTabUeber="";
            var htmlOut="";
            var mix;
            var counter;
            //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
            var val1; var val0; var val2;
            function writeHTML(){
            htmlOut="";
            counter=-1;
            htmlTabUeber="";
            switch (mehrfachTabelle) {
               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
               case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
            if (!UeberschriftSpalten) {htmlTabUeber=""}
            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
            //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
            var myData;
            //let myData=getState("0_userdata.0.DeviceIP").val
            exec("nmap -sP "+ipbereich , function (error, result, stderr) {
               myData=result
            let timeout = setTimeout(function () {
             myData=myData.replace(/\n/g,"")
            //log(myData)
            myData=myData.replace(/.+?(for .+? \(\d+\.\d+\.\d+\.\d+)\).+?/g,"$1___")
            myData=myData.replace(/\(/g,"")
            myData=myData.replace(/(for .+?) (\d+\.\d+\.\d+\.\d+)/g,"[$1,$2]")
            myData=myData.replace(/,$/g,"")
            myData=myData.replace(/___ost.+$/g,"")
            let myArr=myData.split("___")
            var myObj=[]
            for(var i=0;i<myArr.length;i++) {
              let var1=myArr[i].replace(/\[(.+?),.+/,"$1")
              let var2=myArr[i].replace(/.+?,(.+)\]/,"$1");//log(var2)
              let help=[var1,var2]
              myObj.push(help)
            //log(myObj[0][0])
            for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                  //  var ida = id.split('.');
                 //   if( !(id.includes("vis") || id.includes("devices")  ||  id.includes("sssss"))){
                      counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                      val0=myObj[i][0].replace("for","")
                      val0=val0.replace("."+domainName,"")
                        if (val0.length>=23)  val0=val0.substring(0,23)+" ..."
                      val1=myObj[i][1]
                      var val2help=true
                   //   val1=Math.floor( ((val1help)/60/60/24) )+"d "+ Math.floor(((val1help)/60/60) % 24) +"h "+ Math.floor( ((val1help)/60) % 60 )+" m" ;
                      if (!val2help) {val2="❌"} else{val2="✅"}
                 tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
            }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
            //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                  tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
            }, 10000);
            } // function ende
            //MAIN:
            //schedule(mySchedule,  function () {
             writeHTML();
             if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
            //writeHTML();                                   //     <tdalign
             function tabelleBind(){
               //  counter=counter+mehrfachTabelle;
                     case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
                                                      {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                     case 2: if(counter%4==0){
                                if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                  }else{
                                            if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                     case 3:if(counter%2==0)   {
                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                           else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
                                                            else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
                                                      } break;}else{
                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
                                                      } break;}
                     case 4:  // counter=counter+8;
                               if(counter%8==0)   {
                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
                                                            else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                      } break;}else{
                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
                                                            else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                      } break;}
                    } //switch ende
            function tabelleFinish() {
                   case 1:    break;
                   case 2:
                              if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                              break;
                   case 3:   if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                             if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                              break;
                   case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                             if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                             break; }
                     var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                    if (!htmlSignature) htmlUnter="";
                      //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                       var htmlOutVIS="";
                     //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                        if (htmlUberschrift)
                            { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                          } else {
                           zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
              // log("bin raus aus tabelleBind");
                       if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
             var htmlEnd="</table>"+htmlUnter+"</div></body>";
             //mit oder ohne überschrift - zentriert oder links
            htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
             //log(htmlOut);
              @Homoran
              #173
              @liv-in-sky du hast bei var 1 einen zusätzlichen Backslash vor der Eckigen öffnenden Klammer - der ist bei mir nicht
              Damit läuft es
                #174
                Bei mir kommt keine Tabelle:-(
                Habe das iframe so konfiguriert:
                <iframe width="100% "height="100% "frameborder="0" src="/vis.0/htmlexample.html"></iframe>
                habe noch nicht überprüft ob die Datei da liegt
                Habe aber noch Kompilierungsfehler - aber nicht im log!
                EDIT: unter vis.0 liegt die Datei nicht
                  Damit läuft es
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #175
                  @Homoran gut zu hören - das ist normal (new Date) - damit gibt es keine probleme du kannst das file auch einfach so aufrufen - zum test
                  http://192.168.178.59:8082/vis.0/htmlexamplesetting.html
                  mit deinem server und deinem filenamen
                  @Negalein wie sieht es bei dir aus
                  HomoranH sigi234S NegaleinN 3 Antworten Letzte Antwort
                    #176
                    @liv-in-sky sagte in Auslesen IP -Adressen:
                    da ist nix:
                    nur die "alten" Tabellen
                      sigi234S Online
                      sigi234S Online
                      #177
                      @liv-in-sky
                      So bin wieder da, wo ist das neueste Skript?
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #178
                        folgender Fehler kommt
                        javascript.0	2020-02-01 16:40:37.873	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
                        javascript.0	2020-02-01 16:40:37.873	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                        javascript.0	2020-02-01 16:40:37.872	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                        javascript.0	2020-02-01 16:40:37.872	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at Object.createScript (vm.js:277:10)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) at new Script (vm.js:83:7)
                        javascript.0	2020-02-01 16:40:37.871	error	(594) SyntaxError: Invalid regular expression: missing /
                        javascript.0	2020-02-01 16:40:37.871	error	(594) ^
                        javascript.0	2020-02-01 16:40:37.870	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
                        javascript.0	2020-02-01 16:40:37.870	error	at script.js.common.Nmap-Test:151
                        javascript.0	2020-02-01 16:40:37.870	error	(594) script.js.common.Nmap-Test compile failed:
                        liv-in-skyL HomoranH 2 Antworten Letzte Antwort
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #179
                          @Negalein @sigi234
                          hier - dieses file nutzen
                          https://forum.iobroker.net/post/369153
                            #180
                            @Negalein
                            oder einen Backslash hier setzen
                            statt:
                            dann
                              @Negalein
                              statt:
                              dann
                              #181
                              @Homoran sagte in Auslesen IP -Adressen:
                              @Negalein
                              statt:
                              dann
                              let var1=myArr[i].replace(/\\[(.+?),.+/,"$1")
                                @Negalein @sigi234
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #182
                                hab ich vorhin schon benutzt
                                let dpVIS="0_userdata.0.Tabellen.nMap-Test"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                const ipbereich="10.0.1.0/24";
                                //GANZE TABELLE
                                //FELDER UND RAHMEN
                                let htmlcenterHelp;
                                var htmlOut="";
                                var mix;
                                var counter;
                                htmlOut="";
                                counter=-1;
                                htmlTabUeber="";
                                var myData;
                                   myData=result
                                //log(myData)
                                var myObj=[]
                                  let var2=myArr[i].replace(/.+?,(.+)]/,"$1");//log(var2)
                                  myObj.push(help)
                                //log(myObj[0][0])
                                          val1=myObj[i][1]
                                          var val2help=true
                                }, 10000);
                                } // function ende
                                //MAIN:
                                 writeHTML();
                                                      }else{
        } break;}else{
        } break;}
                                                   if(counter%8==0)   {
        } break;}else{
        } break;}
                                        } //switch ende
                                       case 1:    break;
                                       case 2:
                                                  break;
                                                  break;
                                                 break; }
                                           var htmlOutVIS="";
                                              } else {
                                 //log(htmlOut);
                                Fehler bleibt
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at process._tickCallback (internal/process/next_tick.js:68:7)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:491:17)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
                                javascript.0	2020-02-01 16:43:54.941	error	(594) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
                                javascript.0	2020-02-01 16:43:54.940	error	(594) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
                                javascript.0	2020-02-01 16:43:54.940	error	(594) at Object.createScript (vm.js:277:10)
                                javascript.0	2020-02-01 16:43:54.940	error	(594) at new Script (vm.js:83:7)
                                javascript.0	2020-02-01 16:43:54.940	error	(594) SyntaxError: Invalid regular expression: missing /
                                javascript.0	2020-02-01 16:43:54.940	error	(594) ^
                                javascript.0	2020-02-01 16:43:54.940	error	(594) let var1=myArr[i].replace(/[(.+?),.+/,"$1")
                                javascript.0	2020-02-01 16:43:54.940	error	(594) script.js.common.Nmap-Test compile failed: at script.js.common.Nmap-Test:151
                                  da ist nix:
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #183
                                  @Homoran @sigi234 @Negalein
                                  bitte warten ich bin bl...
                                  ich habe da was rausgelöscht, weil ich am anfang noch mit blockly was machen wollte - kommt gleich das neuste
                                  es wird kein file geschrieben, und auch keine updates gemacht
                                  kommt gleich
                                    liv-in-skyL Offline
                                    #184
                                    nur zur info - das dauert noch eine weile - muss noch ein paar sachen ausarbeiten
                                    HomoranH NegaleinN sigi234S 3 Antworten Letzte Antwort
                                      #185
                                      @liv-in-sky
                                      nur die Ruhe - keine Panik!
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #186
                                        keine Eile
                                        ich soll mich eh gerade etwas schonen
                                          sigi234S Online
                                          sigi234S Online
                                          #187
                                          Was neues? Kann ich nMap wieder deinstallieren, oder brauchst du noch was?
                                          Erledigt. 😀
