  4. Gelöst: [Help] Kein Status im hm-rpc DP
keymatic homematic state daten
22 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • R Offline
    robudus
    Tippfehler. Geändert auf 2001 und Callback Adresse auf IP des Iobroker geändert aber jetzt wird der Adapter nicht grün :-(
    • R robudus
      @robudus Was steht im log?
      • R Offline
        robudus
        hm-rpc.0	2020-01-31 21:51:57.551	debug	(19905) xmlrpc -> 192.168.7.195:2001/ init ["http://192.168.7.194:2001","hm-rpc.0"]
        hm-rpc.0	2020-01-31 21:51:35.866	debug	(19905) system.adapter.admin.2: logging true
        hm-rpc.0	2020-01-31 21:51:27.550	debug	(19905) start connecting interval
        hm-rpc.0	2020-01-31 21:51:27.549	debug	(19905) Connect...
        hm-rpc.0	2020-01-31 21:51:27.547	info	(19905) xmlrpc client is trying to connect to 192.168.7.195:2001/ with ["http://192.168.7.194:2001","hm-rpc.0"]
        hm-rpc.0	2020-01-31 21:51:27.547	info	(19905) xmlrpc server is trying to listen on 192.168.7.194:2001
        hm-rpc.0	2020-01-31 21:51:26.130	debug	(19905) [META] Meta data updated
        hm-rpc.0	2020-01-31 21:51:26.024	info	(19905) starting. Version 1.12.6 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.17.0
        hm-rpc.0	2020-01-31 21:51:25.235	debug	(19905) States connected to redis: 127.0.0.1:6379
        hm-rpc.0	2020-01-31 21:51:25.219	debug	(19905) statesDB connected
        hm-rpc.0	2020-01-31 21:51:25.213	debug	(19905) Objects connected to redis: 127.0.0.1:9001
        hm-rpc.0	2020-01-31 21:51:25.211	debug	(19905) Redis States: Use Redis connection: 127.0.0.1:6379
        hm-rpc.0	2020-01-31 21:51:25.208	debug	(19905) objectDB connected
        hm-rpc.0	2020-01-31 21:51:25.145	debug	(19905) Redis Objects: Use Redis connection: 127.0.0.1:9001
        hm-rpc.0	2020-01-31 21:51:20.573	debug	(19851) [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.iobroker","callback":{"message":null,"id":28,"ack":false,"time":1580503880571},"_id":45980070}
        hm-rpc.0	2020-01-31 21:51:20.442	info	(19851) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        hm-rpc.0	2020-01-31 21:51:19.903	info	(19851) xmlrpc -> 192.168.7.195:2001/ init ["http://192.168.7.194:2001",""]
        hm-rpc.0	2020-01-31 21:51:18.902	debug	(19851) [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.iobroker","callback":{"message":null,"id":27,"ack":false,"time":1580503878900},"_id":45980069}
        MOD-EDIT: Code in Code-Tags gesetzt
        • R Offline
          robudus
          Hmm sieht so aus als könnte er sich nicht verbinden... mit 42001 geht es. Jetzt weiss ich auch woher ich den Port habe. Aus der Doku. Da ich https nutze. Oder ist es nicht korrekt?
          Bin zwar Admin beruflich aber manche Dinge verwirren auch mich :-)
          2001 for wireless devices (https: 42001),
            @robudus sagte in [Help] Kein Status im hm-rpc DP:
            Ok. Haken herausgenommen.
            Nein! - der muss von selber rausgehen.
            Wenn das nicht passiert stimmt etwas mit der Kommunikation zur CCU nicht!
            Homematic Port 42001
            Ist das HmIP??
            (oder https???)
            Als Callback die IP der piCCU
            da muss die IP des ioBrokers rein
            Geräte nicht löschen - Haken raus
            nochmals - ist das HmIP?
            Fazit
            • mangels Screenshot nehme ich an, dass du HmIP konfiguriert hast - die keymatic ist aber HM-rf
            • Callback ist falsch
            dslraserD Offline
            dslraserD Offline
            dslraser
            @Homoran sagte in [Help] Kein Status im hm-rpc DP:
            Ist das HmIP??
            (oder https???)
            @robudus
            das hatte @Homoran vorhin gefragt
            • R Offline
              robudus
              Ich habe keine HMIp Komponenten. Also https. Sorry aber verstehe die Frage nicht ganz. Homematic ist noch sehr neu für mich. Bisher habe ich mich nur mit Iobroker beschäftigt.
              • R robudus
                Das hatte ich ja gefragt
                der Port ohne https ist eben 2001 + das war der Sinn der Frage
                und läuft es jetzt nach Änderung der Callback-Adresse?
                • R Offline
                  robudus
                  Achso ich dachte die Keymatic wäre wireless weil Funk aber damit ist nur WLAN gemeint richtig?
                  • R robudus
                    @robudus
                    Gaaaanz ruhig
                    es ist alles gut - hoffentlich
                    • R Offline
                      robudus
                      Grossartig. Jetzt ist der STATE da. Du glaubst nicht wie glücklich du mich gemacht hast :-)
                      Schönes Wochenden... Grossartiges Forum. Mega Thx...
                      G ROBudus
                        @robudus
                        Gaaaanz ruhig
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        @Homoran
                        Diese Missverständnisse entstehen oft wenn man Beiträge editiert. Ich weiß nicht ob hier alle auch immer "rückwärts" nochmal lesen...🤗
                        Aber ich editiere auch oft, um nicht noch einen neuen Beitrag zu schreiben.
