  4. Hilfe! IoBroker stürzt wiederholt ab.
iobroker absturz
41 Beiträge 4 Kommentatoren 3.7k Aufrufe 3 Beobachtet
  • S Stoni
    Hier könnte es interessant werden, weiß aber nicht, was das heißt:
    Jan 31 08:06:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it i$
    Jan 31 08:06:34 raspberrypi bash[625]:     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    Jan 31 08:06:34 raspberrypi bash[625]:     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Jan 31 08:06:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
    Jan 31 08:06:34 raspberrypi bash[625]: (node:1083) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejecti$
    Jan 31 08:07:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it i$
    Jan 31 08:07:34 raspberrypi bash[625]:     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    Jan 31 08:07:34 raspberrypi bash[625]:     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Jan 31 08:07:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
    Jan 31 08:08:04 raspberrypi dhcpcd[595]: eth0: Router Advertisement from fe80::cece:1eff:fe73:77a4
    Jan 31 08:08:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it i$
    Jan 31 08:08:34 raspberrypi bash[625]:     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    Jan 31 08:08:34 raspberrypi bash[625]:     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Jan 31 08:08:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
    Jan 31 08:09:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it i$
    Jan 31 08:09:34 raspberrypi bash[625]:     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    Jan 31 08:09:34 raspberrypi bash[625]:     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Jan 31 08:09:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
    Jan 31 08:10:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: ReplyError: MISCONF Redis is configured to save RDB snapshots, but it i$
    sigi234S Online
    sigi234S Online
    @Stoni
    Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • sigi234S sigi234
      @Stoni
      Stoni
      schrieb am zuletzt editiert von Stoni
      @sigi234 ok
        Stoni
        Hier noch eine Fehlermeldung, die auch im ioB-Log auftaucht:
        Jan 31 10:05:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
        Jan 31 10:06:06 raspberrypi bash[625]: ENOSPC: no space left on device, write
        Jan 31 10:06:06 raspberrypi bash[625]: Error: ENOSPC: no space left on device, write
        Jan 31 10:06:06 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=6/NOTCONFIGURED
        Jan 31 10:06:06 raspberrypi bash[625]: { [Error: ENOSPC: no space left on device, write] errno: -28, code: 'ENOSPC', syscall: 'write' }
        Jan 31 10:06:07 raspberrypi bash[625]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
        Jan 31 10:06:07 raspberrypi bash[625]:       throw ex;
        Jan 31 10:06:07 raspberrypi bash[625]:       ^
        Jan 31 10:06:07 raspberrypi bash[625]: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (_stream_writable.js:411:19)
        Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (_stream_writable.js:399:5)
        Jan 31 10:06:07 raspberrypi bash[625]:     at WriteStream.Writable.write (_stream_writable.js:299:11)
        Jan 31 10:06:07 raspberrypi bash[625]:     at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:602:26)
        Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.log (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:138:20)
        Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile._write (/opt/iobroker/node_modules/winston-transport/index.js:102:17)
        Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:428:64)
        Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:417:5)
        Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:334:11)
        Jan 31 10:06:07 raspberrypi bash[625]:     at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:$
        Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
        Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
        Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
        Jan 31 10:06:07 raspberrypi systemd[1]: Stopped ioBroker Server.
        Jan 31 10:06:07 raspberrypi systemd[1]: Started ioBroker Server.
        Jan 31 10:06:09 raspberrypi bash[20201]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
        Jan 31 10:06:09 raspberrypi bash[20201]:       throw ex;
        Jan 31 10:06:09 raspberrypi bash[20201]:       ^
        • S Stoni
          @sigi234 ok
          @Stoni sagte in Hilfe! IoBroker stürzt wiederholt ab.:
          @sigi234 wie meinst du das? werde aus der Hilfe nicht schlau.
          du sollst Code in Code-Tags setzen
            Stoni
              Stoni
              @Einstein67
              @Homoran
              Der Log von 10:06 Uhr war der Letzte, danach kam der Neustart um 11:43 Uhr.
              Hat das was mit dem history-Adapter zu tun? Der schreibt Werte meiner PV-Anlage in ein Diagramm. Das mache ich aber schon lange so. Und in dem Pi sitzt ne neue 32GB SD.
              • S Stoni
                Aber du liest was du postest?
                  Stoni
                  @Homoran Ja das habe ich gelesen, aber ich kann damit nichts anfangen. Wo soll ich keinen Speicherplatz haben? Wie gesagt, ist ne 32GB SD drin.
                  • S Stoni
                    und wie hast du Raspbian vor dem ioBroker installiert?
                      Stoni
                      @Homoran Mit dem fertigen Image inkl. ioBroker etc.
                      Habe gerade was gelesen, dass irgendwas mit resize noch durchgeführt werden muss(te). sudo raspi-config. Was muss man da machen? Weiß nicht, ob ich das getan habe.
                      • S Stoni
                        dann wohl nicht das readme gelesen ;-)
                        ja!
                        wohl eher nicht.
                        Was sagt denn df -h
                          ja!
                          wohl eher nicht.
                          Was sagt denn df -h
                          Stoni
                          @Homoran
                          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                          /dev/root       3,4G    3,2G  8,4M  100% /
                          devtmpfs        1,8G       0  1,8G    0% /dev
                          tmpfs           2,0G       0  2,0G    0% /dev/shm
                          tmpfs           2,0G    8,5M  1,9G    1% /run
                          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                          tmpfs           2,0G       0  2,0G    0% /sys/fs/cgroup
                          /dev/mmcblk0p1  253M     52M  201M   21% /boot
                          tmpfs           391M       0  391M    0% /run/user/1000
                          • S Stoni
                            @Homoran
                            /dev/root 3,4G 3,2G
                            also kein resize gemacht.
                            Steht im Readme wie du richtig sagst über raspi-config resize filesystem
                            S 2 Antworten Letzte Antwort
                              /dev/root 3,4G 3,2G
                              Stoni
                              @Homoran
                              also sudo raspi-config
                              dann advanced Options und dann
                              Expand filesystem?
                              geht das jetzt noch nachträglich?
                                /dev/root 3,4G 3,2G
                                Stoni
                                @Homoran
                                /dev/root        29G    3,2G   25G   12% /
                                Und jetzt alles gut?
                                • S Stoni
                                  @Homoran
                                  Expand filesystem?
                                  Expand filesystem?
                                  so müsste es im ReadMe stehen - die Menüs ändern sich immer mal wieder - in jedem zugehörigen ReadMe sollte die richtige Vorgehensweise stehen,
                                  Das resize benötigt auch etwas Speicherplatz. Wenn der nicht mehr da ist geht es nicht.
                                  Ob die gescheiterten Versuche etwas zu schreiben unvollständige Daten erzeugt haben, die später zu Problemen führen kann man auch nicht ausschließen
                                    Expand filesystem?
                                    Stoni
                                    @Homoran Habs gemacht. Siehe oben. Dann sollte das Problem jetzt nicht mehr auftreten oder? Kann ich den History dann wieder laufen lassen?
                                      Expand filesystem?
                                      Stoni
                                      @Homoran Kann es sein, dass bei ioB ein täglicher Neustart um 05:00 Uhr eingestellt ist? Ist das gut oder kann man das löschen? Wenn ja wo?
                                      Vielen Dank schon mal soweit...
                                      • S Stoni
                                        @Homoran
                                        Zu 'alles' siehe den Kommentar eben
                                        Immerhin wieder 25GByte freier Platz
                                        ich denke schon
                                        • S Stoni
                                          Wo sollte das sein?
                                          Der Ganze ioB oder nur ein Adapter/Instanz?
