  4. Hilfe! IoBroker stürzt wiederholt ab.
iobroker absturz
41 Beiträge 4 Kommentatoren 3.7k Aufrufe 3 Beobachtet
  • sigi234S sigi234
    @Stoni
    Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    Stoni
    schrieb am zuletzt editiert von Stoni
    @sigi234 ok
      Stoni
      Hier noch eine Fehlermeldung, die auch im ioB-Log auftaucht:
      Jan 31 10:05:34 raspberrypi bash[625]: (node:1083) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing i$
      Jan 31 10:06:06 raspberrypi bash[625]: ENOSPC: no space left on device, write
      Jan 31 10:06:06 raspberrypi bash[625]: Error: ENOSPC: no space left on device, write
      Jan 31 10:06:06 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=6/NOTCONFIGURED
      Jan 31 10:06:06 raspberrypi bash[625]: { [Error: ENOSPC: no space left on device, write] errno: -28, code: 'ENOSPC', syscall: 'write' }
      Jan 31 10:06:07 raspberrypi bash[625]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
      Jan 31 10:06:07 raspberrypi bash[625]:       throw ex;
      Jan 31 10:06:07 raspberrypi bash[625]:       ^
      Jan 31 10:06:07 raspberrypi bash[625]: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (_stream_writable.js:411:19)
      Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (_stream_writable.js:399:5)
      Jan 31 10:06:07 raspberrypi bash[625]:     at WriteStream.Writable.write (_stream_writable.js:299:11)
      Jan 31 10:06:07 raspberrypi bash[625]:     at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:602:26)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.log (/opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js:138:20)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile._write (/opt/iobroker/node_modules/winston-transport/index.js:102:17)
      Jan 31 10:06:07 raspberrypi bash[625]:     at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:428:64)
      Jan 31 10:06:07 raspberrypi bash[625]:     at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:417:5)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DailyRotateFile.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:334:11)
      Jan 31 10:06:07 raspberrypi bash[625]:     at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:$
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
      Jan 31 10:06:07 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
      Jan 31 10:06:07 raspberrypi systemd[1]: Stopped ioBroker Server.
      Jan 31 10:06:07 raspberrypi systemd[1]: Started ioBroker Server.
      Jan 31 10:06:09 raspberrypi bash[20201]: /opt/iobroker/node_modules/winston/lib/winston/logger.js:307
      Jan 31 10:06:09 raspberrypi bash[20201]:       throw ex;
      Jan 31 10:06:09 raspberrypi bash[20201]:       ^
      • S Stoni
        @sigi234 ok
        @Stoni sagte in Hilfe! IoBroker stürzt wiederholt ab.:
        @sigi234 wie meinst du das? werde aus der Hilfe nicht schlau.
        du sollst Code in Code-Tags setzen
          Stoni
            Stoni
            @Einstein67
            @Homoran
            Der Log von 10:06 Uhr war der Letzte, danach kam der Neustart um 11:43 Uhr.
            Hat das was mit dem history-Adapter zu tun? Der schreibt Werte meiner PV-Anlage in ein Diagramm. Das mache ich aber schon lange so. Und in dem Pi sitzt ne neue 32GB SD.
            • S Stoni
              Aber du liest was du postest?
                Stoni
                @Homoran Ja das habe ich gelesen, aber ich kann damit nichts anfangen. Wo soll ich keinen Speicherplatz haben? Wie gesagt, ist ne 32GB SD drin.
                • S Stoni
                  und wie hast du Raspbian vor dem ioBroker installiert?
                    Stoni
                    @Homoran Mit dem fertigen Image inkl. ioBroker etc.
                    Habe gerade was gelesen, dass irgendwas mit resize noch durchgeführt werden muss(te). sudo raspi-config. Was muss man da machen? Weiß nicht, ob ich das getan habe.
                    • S Stoni
                      dann wohl nicht das readme gelesen ;-)
                      ja!
                      wohl eher nicht.
                      Was sagt denn df -h
                        ja!
                        wohl eher nicht.
                        Was sagt denn df -h
                        Stoni
                        @Homoran
                        Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                        /dev/root       3,4G    3,2G  8,4M  100% /
                        devtmpfs        1,8G       0  1,8G    0% /dev
                        tmpfs           2,0G       0  2,0G    0% /dev/shm
                        tmpfs           2,0G    8,5M  1,9G    1% /run
                        tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                        tmpfs           2,0G       0  2,0G    0% /sys/fs/cgroup
                        /dev/mmcblk0p1  253M     52M  201M   21% /boot
                        tmpfs           391M       0  391M    0% /run/user/1000
                        • S Stoni
                          @Homoran
                          /dev/root 3,4G 3,2G
                          also kein resize gemacht.
                          Steht im Readme wie du richtig sagst über raspi-config resize filesystem
                          S 2 Antworten Letzte Antwort
                            /dev/root 3,4G 3,2G
                            Stoni
                            @Homoran
                            also sudo raspi-config
                            dann advanced Options und dann
                            Expand filesystem?
                            geht das jetzt noch nachträglich?
                              /dev/root 3,4G 3,2G
                              Stoni
                              @Homoran
                              /dev/root        29G    3,2G   25G   12% /
                              Und jetzt alles gut?
                              • S Stoni
                                @Homoran
                                Expand filesystem?
                                Expand filesystem?
                                so müsste es im ReadMe stehen - die Menüs ändern sich immer mal wieder - in jedem zugehörigen ReadMe sollte die richtige Vorgehensweise stehen,
                                Das resize benötigt auch etwas Speicherplatz. Wenn der nicht mehr da ist geht es nicht.
                                Ob die gescheiterten Versuche etwas zu schreiben unvollständige Daten erzeugt haben, die später zu Problemen führen kann man auch nicht ausschließen
                                  Expand filesystem?
                                  Stoni
                                  @Homoran Habs gemacht. Siehe oben. Dann sollte das Problem jetzt nicht mehr auftreten oder? Kann ich den History dann wieder laufen lassen?
                                    Expand filesystem?
                                    Stoni
                                    @Homoran Kann es sein, dass bei ioB ein täglicher Neustart um 05:00 Uhr eingestellt ist? Ist das gut oder kann man das löschen? Wenn ja wo?
                                    Vielen Dank schon mal soweit...
                                    • S Stoni
                                      @Homoran
                                      Zu 'alles' siehe den Kommentar eben
                                      Immerhin wieder 25GByte freier Platz
                                      ich denke schon
                                      • S Stoni
                                        Wo sollte das sein?
                                        Der Ganze ioB oder nur ein Adapter/Instanz?
                                          Wo sollte das sein?
                                          Stoni
                                          @Homoran Kriege jeden morgen um 05:00 Uhr eine Telegram Nachricht, dass der Bot gestartet wurde...
                                          Ups, aktuell sind alle Instanzen rot...
