  4. Test Adapter tr-064 v3.0.x
tr-064
158 Beiträge 46 Kommentatoren 28.2k Aufrufe 44 Beobachtet
  • apollon77A apollon77
    @FredF Bitte nochmal retesten!
    FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    schrieb am zuletzt editiert von FredF
    #83
    @apollon77 sagte in Test Adapter tr-064 v3.0.x:
    Update gemacht. Die device active states ändern sich nun.
    Die Instanz wird allerdings nicht grün.
    2020-01-26 12:09:19.022 - info: tr-064.0 (26474) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
    2020-01-26 12:09:19.494 - error: tr-064.0 (26474) uncaught exception: fndest is not defined
    2020-01-26 12:09:19.494 - error: tr-064.0 (26474) ReferenceError: fndest is not defined
    at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    at Array.forEach ()
    at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
    at Parser.emit (events.js:198:13)
    2020-01-26 12:09:19.998 - info: tr-064.0 (26474) terminating
    2020-01-26 12:09:19.999 - info: tr-064.0 (26474) Terminated (NO_ERROR): Without reason
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
    2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
    2020-01-26 12:09:21.108 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    2020-01-26 12:09:21.108 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
    2020-01-26 12:09:51.128 - info: host.ioBrokerLife instance system.adapter.tr-064.0 started with pid 26845
    2020-01-26 12:09:52.417 - info: tr-064.0 (26845) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
    2020-01-26 12:09:52.928 - error: tr-064.0 (26845) uncaught exception: fndest is not defined
    2020-01-26 12:09:52.929 - error: tr-064.0 (26845) ReferenceError: fndest is not defined
    at Array.forEach ()
    2020-01-26 12:09:53.432 - info: tr-064.0 (26845) terminating
    2020-01-26 12:09:53.433 - info: tr-064.0 (26845) Terminated (NO_ERROR): Without reason
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
    2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
    2020-01-26 12:09:53.955 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    2020-01-26 12:09:53.955 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
    Edit: komplett deinstalliert und neu installiert. Instanz grün 👍
    Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird
    • SBorgS Offline
      SBorgS Offline
      SBorg
      #84
      @apollon77 Da hat sich wohl ein Fipptehler eingeschlichen. Lt. Log:
      Sollte wohl" tr-064" heißen, nicht "tr-O64" ;)
      LG SBorg ( SBorg auf GitHub)
      • X Offline
        X Offline
        Xyolyp
        #85
        Version 3.1.1 startet bei mir leider nicht.
        JS Controller 2.2.8
          Aktuelle Test Version 3.0.0
          Veröffentlichungsdatum 24.01.2020
          Github Link https://github.com/iobroker-community-adapters/ioBroker.tr-064
          der Adapter ist zurück unter seinem "alten" Namen und tr-064-community ist damit leider wieder "tod". Die hohe Anzahl an bestehenden Usern die immer noch die alte Version nutzen (600 User auf Community Version, ca. 11k auf originaler Version) haben diesen Schritt gerechtfertigt!
          Nun zum Release:
          3.0.0 (2020-01-24)
          • (Apollon77) Switch Name back to tr064 becaus ewe got it from npmjs
          • (maeb3) Enhance call handling and fix wrong data for currently active calls
          • (Apollon77) Remove unused state phonebook.ringing
          Happy Testing.
          sigi234S Online
          sigi234S Online
          #86
          @apollon77
          3.1.1 läuft. Adapter Grün, kein Fehler im Log, DP tr-064.0.callmonitor.ringing funktioniert. Rufumleitung nicht aktiviert.
          • SBorgS SBorg
            #87
            @SBorg ne kein Schreibfehler. Eine lib heißt so
            • T Tom63
              Update auf 3.1.1.
              Zunächst erst einmal vielen Dank, dass Ihr Euch diesem Adapter gewidmet habt.
              Ich habe meinen IOBroker auf einem Raspi 4 mit 4GB laufen. Bisher fiel der alter TR-064 sporadisch aus und somit war er mir nicht zuverlässig. Immer musste ich den npm SOEF im entsprechenden Ordner manuell nachinstallieren. Aber dann funktionierte er, vor allem die WLAN Erkennung.
              Nun kamen mehrere Adapterversionen hinter einander. Ich habe aus dem latest Stand diese als normale Updates installiert, schien auch alles super zu laufen, Geräte Erkennung usw. ohne Probleme.
              Gestern Abend dann stellte ich fest, dass mein Scribt zur Lichtsteuerung in Abhängigkeit zum WLAN des Fernsehers nicht mehr reagierte.
              Ich stellte fest, alle Geräte im Device bleiben Active true egale ob im WLAN angemeldet oder nicht.
              Auch den Adapter 3.1.0 deinstallieren funktionierte gestern nicht, es blieb im Scribt hängen.
              Heute stellte ich in diesem aktuellen Forum fest, hier bin ich nicht alleine.
              Habe zunächst die Instanz gelöscht, dann den ganzen Adapter und anschließend den IOBroker offline per Update aktualisiert. Jetzt war der aktuelle Adapter 3.1.1 als letzte Version unter latest auch gelistet.
              Ich habe ihn installiert, die Geräte erneut eingelesen.
              Die WLAN-Abschaltung reagiert sehr langsam - dachte erst gar nicht. Hatte mein Handy mal abgemeldet - keine Reaktion.
              Nun mal meine Feststellung als Hinweis für die Entwicklung...
              In meiner Fritzbox 7490 kann man ja alle Geräte unter Heimnetz anzeigen lassen. Hier wird unter
              aktive Verbindungen und ungenutzte Verbindungen unterschieden.
              Die Fritzbox schmeißt mein Handy erst nach ca. 10 Minuten aus der aktiven Verbindung in die ungenutzte Verbindung.
              Genau diesen Vorgang habt ihr in State active des Devices hinterlegt.
              Ist es möglich aus dem TR-064 zu dem Device auch die Eigenschaften des aktuellen Zustandes auszuwerten?
              Hier sind die Angaben zum aktuellen WLAN eingetragen, also welches Netz und wie hoch die Übertragungsrate ist.
              Bei LAN- Anschlüssen steht dort aber auch nichts weiter drin.
              Nur dieser Wert ist für die aktuelle Anbindung im WLAN der einzige schnelle Trigger beim Abmelden.
              Insgesamt bin ich jetzt aber erst mal sehr dankbar und hoffe der weiteren Entwicklung geholfen zu haben.
              Vielen Dank und macht weiter - es macht mir sogar Spaß beim ausprobieren !!!
              #88
              @Tom63 bitte GitHub issue als Feature request anlegen. War schon so mehr so mit dem verzögerten. Was steht denn bei der verbindungsqualität wenn das Handy weg ist?
                SBorgS Offline
                SBorgS Offline
                SBorg
                schrieb am zuletzt editiert von SBorg
                #89
                Habe ich eben auch gemerkt ^^
                Er läuft aber nicht:
                host.Ubuntu	2020-01-26 13:04:02.512	error	Caught by controller[0]: Error: Cannot find module './tr-064'
                Dort liegt kein tr-O64. Ein Verzeichnis höher schon.
                EDIT Der Code-Tag macht doch tatsächlich aus O64 ein 064 :(
                • smarteuleS Offline
                  smarteuleS Offline
                  smarteule
                  #90
                  ich bin zwar Anfänger, aber ich möchte Euch mitteilen, dass ich mit dem tr064 ebenfalls Probleme bei der Einstellung bzw. Hakensetzung "Rufweiterleitung verwenden" habe. Wenn der Haken raus ist, bleibt die Inatnz grün. Ist er drin, bleibt die Instanz rot und im Log erscheint folgende Meldung:
                  tr064 v 3.1.1
                  js.controller v 2.2.8
                  node js v 10.18.1
                  npm v 6.13.4
                  • smarteuleS smarteule
                    tr064 v 3.1.1
                    node js v 10.18.1
                    npm v 6.13.4
                    sigi234S Online
                    sigi234S Online
                    #91
                    @smarteule sagte in Test Adapter tr-064 v3.0.x:
                    Prüfen und fixen wir. Danke
                    • JB_SullivanJ Offline
                      JB_Sullivan
                      schrieb am zuletzt editiert von JB_Sullivan
                      #92
                      Bei mir verbindet sich der Adapter nach dem Updaten von 3.1.0 auf 3.1.1 nicht mehr. Die Instanz flasht zwar kurzeitig grün auf, geht dann aber auf rot. (persönliche Informationen sind ge-X-t)
                      host.GLT	2020-01-26 14:26:40.028	info	Restart adapter system.adapter.tr-064.0 because enabled
                      host.GLT	2020-01-26 14:26:40.028	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                      host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
                      host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:304:18)
                      host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\tr-O64\lib\Service.js:267:17
                      host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:82:28
                      host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at tr064Client.init.err (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:1144:27)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at new Deflections (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:21:10)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Deflections.init (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:156:17)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at getFunctions (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:12)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at ar.forEach.fn (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:37)
                      host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: ReferenceError: fndest is not defined
                      tr-064.0	2020-01-26 14:26:39.822	debug	(3364) Phonebook 0: {"NewPhonebookName":"Telefonbuch","NewPhonebookExtraID":"","NewPhonebookURL":"http://xx.xxx.xxx.xxx:49000/phonebook.lua?sid=xxxxxxxxxxx&pbid=0"} / err=null
                      tr-064.0	2020-01-26 14:26:39.799	debug	(3364) Phonebook.read: NewPhonebookList=0
                      tr-064.0	2020-01-26 14:26:39.782	debug	(3364) Phonebook.read
                      tr-064.0	2020-01-26 14:26:39.781	debug	(3364) getVoIPCommonAreaCode: 0xxxx
                      tr-064.0	2020-01-26 14:26:39.766	debug	(3364) getVoIPCommonCountryCode: 0049
                      tr-064.0	2020-01-26 14:26:39.750	debug	(3364) forEachConfiguredDevice: i=3 xxxxxx active=0
                      tr-064.0	2020-01-26 14:26:39.713	debug	(3364) forEachConfiguredDevice: i=2 xxxxxx active=1
                      tr-064.0	2020-01-26 14:26:39.682	debug	(3364) forEachConfiguredDevice: i=1 xxxxxx active=1
                      tr-064.0	2020-01-26 14:26:39.594	debug	(3364) forEachConfiguredDevice: i=0 xxxxxx active=1
                      Wie @FredF oben geschrieben hat - bei mir das gleiche
                      "Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird"
                      • apollon77A Offline
                        #93
                        Mit der 3.1.2 die gerade auf GitHub und npm gelandet ist (und bald im Ltest auftauchen sollte) müsste das Rufumleitungsthema wieder gehen
                        vauvau07V 1 Antwort Letzte Antwort
                          vauvau07V Online
                          vauvau07V Online
                          vauvau07
                          #94
                          3.1.2
                          bei mir jetzt alles im grünen Bereich (v3.1.2)
                          Gruß Volkmar
                            #95
                            AM besten gleich auf die 3.1.3 gehen ... hab noch was gefunden und gefixt
                            J FredFF 2 Antworten Letzte Antwort
                              Jan1
                              #96
                              @apollon77
                              läuft👍
                              • H Offline
                                Hardy6
                                #97
                                Mein Ergebnis von: TR-064 -> Update 3.1.3 : noch mit Fehlern
                                $ ./iobroker upgrade tr-064
                                Update tr-064 from @3.1.1 to @3.1.3
                                NPM version: 6.11.3
                                npm install iobroker.tr-064@3.1.3 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                                npm
                                 ERR! code ENOENTnpm ERR! syscall renamenpm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15bnpm ERR! dest C:\Program Files\iobroker\SmartHome\node_modules\yargsnpm ERR! errno -4058
                                npm ERR!
                                 enoent ENOENT: no such file or directory, rename 'C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15b' -> 'C:\Program Files\iobroker\SmartHome\node_modules\yargs'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                                npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-01-26T14_30_53_253Z-debug.log
                                ERROR: host.IT-SERVER(SmartHome) Cannot install iobroker.tr-064@3.1.3: 4294963238
                                Ich habe alles soweit auf aktuellen Stand (lastest), ioBroker 2.2.8
                                bis auf
                                Node.js 10.17
                                Admin 3.6.12
                                weil beim letzten update Versuch nix mehr ging(jedenfalls für mich als Neueinstiger war das nicht mehr ohne Neuinstallation des kompletten ioBroker in Funktion zu bringen.
                                Gruß,...
                                Hartmut
                                • H Hardy6
                                  NPM version: 6.11.3
                                  npm
                                  npm ERR!
                                  bis auf
                                  Node.js 10.17
                                  Admin 3.6.12
                                  Gruß,...
                                  Hartmut
                                  #98
                                  @Hardy6 Lass mal den Installation Fixer laufen bitte. Der Fehler hat mit dem Adater nix zu tun. Dein npm meckert wegen was ...
                                  H 1 Antwort Letzte Antwort
                                    FredFF Online
                                    FredFF Online
                                    FredF
                                    #99
                                    @apollon77
                                    läuft
                                      Hardy6
                                      #100
                                      @apollon77 Wie? iobroker fix ? / vorher stoppen nehme ich an
                                        Nun zum Release:
                                        3.0.0 (2020-01-24)
                                        Happy Testing.
                                        #101
                                        @apollon77 3.1.3 benimmt sich unauffällig bis jetzt 😁👍👍
                                        Dankeschön 🙂
                                        Homer.J.H 1 Antwort Letzte Antwort
                                          Dankeschön 🙂
                                          Homer.J.H Offline
                                          Homer.J.H Offline
                                          Homer.J.
                                          schrieb am zuletzt editiert von Homer.J.
                                          #102
                                          Bei mir läuft jetzt die Anwesenheit wieder nicht mehr.
                                          Kommando zurück Datenpunkte mal alle gelöscht und funktioniert. 😊
