  4. Test Adapter tr-064 v3.0.x
tr-064
158 Beiträge 46 Kommentatoren 28.2k Aufrufe 44 Beobachtet
  • opossumO opossum
    Hallo, @apollon77
    @apollon77 sagte in Test Adapter tr-064 v3.0.x:
    @opossum da wäre log interessant gewesen. Aber wenn’s jetzt tut ist ja super
    Ist das gleiche Problem, welches @Jan1 beschreibt. Anrufweiterleitung aktiviert, Fehler im Log und rot grün im Wechsel.
    2020-01-26 08:25:01.495 - info: tr-064.0 (20514) terminating
    2020-01-26 08:25:01.496 - info: tr-064.0 (20514) Terminated (NO_ERROR): Without reason
    2020-01-26 08:25:02.148 - error: host.iobrokerprod Caught by controller[0]: ReferenceError: fndest is not defined
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at Array.forEach ()
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
    2020-01-26 08:25:02.149 - error: host.iobrokerprod Caught by controller[0]: at Parser.emit (events.js:198:13)
    Wobei ich dort 3 Einträge in der Fritte habe, davon sind zwei aktive Rufsperren und eine inaktive Rufweiterleitung. Ich rufe mich etwas später mal selbst an. Ist noch zu früh, Heimvorstand schläft noch, das gibt sonst Ärger :-) Erst nach einem Anruf sind ja alle Daten erst richtig da.
    EDIT: Hat nix gebracht, bei Aktivierung Anrufweiterschaltung geht der Adapter abwechselnd auf grün, dann gleich wieder auf rot. Sieht so aus, als ob der DP tr-064.0.callForwarding.0 nicht angelegt wird. Aber auch bei eingeschalteter Rufumleitung in der FritzBox keine Besserung.
    knopers1
    #72
    bei mir lässt sich die letzte Version 3.1.1 nicht einmal starten.....!
    host.raspberrypi	2020-01-26 08:29:53.926	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.raspberrypi	2020-01-26 08:29:53.925	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2020-01-26 08:29:53.925	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
    host.raspberrypi	2020-01-26 08:29:53.925	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
    host.raspberrypi	2020-01-26 08:29:53.924	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    host.raspberrypi	2020-01-26 08:29:53.924	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    host.raspberrypi	2020-01-26 08:29:53.924	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    host.raspberrypi	2020-01-26 08:29:53.923	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    host.raspberrypi	2020-01-26 08:29:53.923	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    host.raspberrypi	2020-01-26 08:29:53.923	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    host.raspberrypi	2020-01-26 08:29:53.922	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2020-01-26 08:29:53.922	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    host.raspberrypi	2020-01-26 08:29:53.921	error	Caught by controller[0]: ReferenceError: fndest is not defined
    tr-064.0	2020-01-26 08:29:53.372	info	(6252) Terminated (NO_ERROR): Without reason
    tr-064.0	2020-01-26 08:29:53.370	info	(6252) terminating
    tr-064.0	2020-01-26 08:29:52.861	error	at Parser.emit (events.js:198:13)
    tr-064.0	2020-01-26 08:29:52.861	error	at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
    tr-064.0	2020-01-26 08:29:52.861	error	at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
    tr-064.0	2020-01-26 08:29:52.861	error	at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
    tr-064.0	2020-01-26 08:29:52.861	error	at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
    tr-064.0	2020-01-26 08:29:52.861	error	at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
    tr-064.0	2020-01-26 08:29:52.861	error	at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
    tr-064.0	2020-01-26 08:29:52.861	error	at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
    tr-064.0	2020-01-26 08:29:52.861	error	at Array.forEach (<anonymous>)
    tr-064.0	2020-01-26 08:29:52.861	error	at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
    tr-064.0	2020-01-26 08:29:52.861	error	(6252) ReferenceError: fndest is not defined
    tr-064.0	2020-01-26 08:29:52.860	error	(6252) uncaught exception: fndest is not defined
    tr-064.0	2020-01-26 08:29:51.876	info	(6252) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
    host.raspberrypi	2020-01-26 08:29:49.753	info	instance system.adapter.tr-064.0 started with pid 6252
    host.raspberrypi	2020-01-26 08:29:49.718	info	"system.adapter.tr-064.0" enabled
    tankerkoenig.0	2020-01-26 08:29:43.429	info	(9321) Reading data from tankerkoenig ...
    host.raspberrypi	2020-01-26 08:29:34.906	info	iobroker exit 0
    host.raspberrypi	2020-01-26 08:29:33.882	info	iobroker Adapter "tr-064" updated
      stenmic
      #73
      mit der 3.1.1 funktioniert die Anwesenheitserkennung nun wieder.
      Auch sonst keine Fehler.
      • apollon77A apollon77
        e-s
        schrieb am zuletzt editiert von e-s
        #74
        @apollon77
        Nach Update von 3.1.0 auf 3.1.1
        host.ubuntuserver	2020-01-26 09:39:24.504	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.ubuntuserver	2020-01-26 09:39:24.504	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
        host.ubuntuserver	2020-01-26 09:39:24.504	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
        host.ubuntuserver	2020-01-26 09:39:24.504	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
        host.ubuntuserver	2020-01-26 09:39:24.504	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
        host.ubuntuserver	2020-01-26 09:39:24.503	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
        host.ubuntuserver	2020-01-26 09:39:24.503	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
        host.ubuntuserver	2020-01-26 09:39:24.503	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
        host.ubuntuserver	2020-01-26 09:39:24.503	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
        host.ubuntuserver	2020-01-26 09:39:24.503	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
        host.ubuntuserver	2020-01-26 09:39:24.502	error	Caught by controller[0]: at Array.forEach (<anonymous>)
        host.ubuntuserver	2020-01-26 09:39:24.502	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
        host.ubuntuserver	2020-01-26 09:39:24.502	error	Caught by controller[0]: ReferenceError: fndest is not defined
        tr-064.0	2020-01-26 09:39:23.983	info	(12369) Terminated (NO_ERROR): Without reason
        tr-064.0	2020-01-26 09:39:23.982	info	(12369) terminating
        tr-064.0	2020-01-26 09:39:23.472	error	(12369) ReferenceError: fndest is not defined at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37) at Array.forEach (<anonymous>) at getFunctions (/opt/i
        tr-064.0	2020-01-26 09:39:23.471	error	(12369) uncaught exception: fndest is not defined
        tr-064.0	2020-01-26 09:39:22.200	info	(12369) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
        host.ubuntuserver	2020-01-26 09:39:20.287	info	instance system.adapter.tr-064.0 started with pid 12369
        host.ubuntuserver	2020-01-26 09:38:50.268	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.ubuntuserver	2020-01-26 09:38:50.268	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
        host.ubuntuserver	2020-01-26 09:38:50.268	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
        host.ubuntuserver	2020-01-26 09:38:50.267	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
        host.ubuntuserver	2020-01-26 09:38:50.267	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
        host.ubuntuserver	2020-01-26 09:38:50.267	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
        host.ubuntuserver	2020-01-26 09:38:50.267	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
        host.ubuntuserver	2020-01-26 09:38:50.266	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
        host.ubuntuserver	2020-01-26 09:38:50.266	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
        host.ubuntuserver	2020-01-26 09:38:50.266	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
        host.ubuntuserver	2020-01-26 09:38:50.265	error	Caught by controller[0]: at Array.forEach (<anonymous>)
        host.ubuntuserver	2020-01-26 09:38:50.265	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
        host.ubuntuserver	2020-01-26 09:38:50.264	error	Caught by controller[0]: ReferenceError: fndest is not defined
        tr-064.0	2020-01-26 09:38:49.738	info	(11290) Terminated (NO_ERROR): Without reason
        tr-064.0	2020-01-26 09:38:49.736	info	(11290) terminating
        tr-064.0	2020-01-26 09:38:49.229	error	(11290) ReferenceError: fndest is not defined at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37) at Array.forEach (<anonymous>) at getFunctions (/opt/i
        tr-064.0	2020-01-26 09:38:49.228	error	(11290) uncaught exception: fndest is not defined
        tr-064.0	2020-01-26 09:38:48.144	info	(11290) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
        host.ubuntuserver	2020-01-26 09:38:46.152	info	instance system.adapter.tr-064.0 started with pid 11290
        host.ubuntuserver	2020-01-26 09:38:16.131	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.ubuntuserver	2020-01-26 09:38:16.131	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
        host.ubuntuserver	2020-01-26 09:38:16.131	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
        host.ubuntuserver	2020-01-26 09:38:16.131	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
        host.ubuntuserver	2020-01-26 09:38:16.131	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
        host.ubuntuserver	2020-01-26 09:38:16.131	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at Array.forEach (<anonymous>)
        host.ubuntuserver	2020-01-26 09:38:16.130	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
        host.ubuntuserver	2020-01-26 09:38:16.129	error	Caught by controller[0]: ReferenceError: fndest is not defined
        tr-064.0	2020-01-26 09:38:15.602	info	(10196) Terminated (NO_ERROR): Without reason
        tr-064.0	2020-01-26 09:38:15.600	info	(10196) terminating
        Sehe gerade, bei allen das selbe Problem. Wäre mein log ja nicht notwendig gewesen.
          dwm
          #75
          3.1.1 grade eingespielt:
          020-01-26 09:45:14.045 - info: tr-064.0 (9787) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.16.1
          2020-01-26 09:45:14.721 - error: tr-064.0 (9787) uncaught exception: fndest is not defined
          2020-01-26 09:45:14.721 - error: tr-064.0 (9787) ReferenceError: fndest is not defined
          at Array.forEach ()
          at emitOne (events.js:116:13)
          2020-01-26 09:45:15.581 - info: tr-064.0 (9787) terminating
          2020-01-26 09:45:15.582 - info: tr-064.0 (9787) Terminated (NO_ERROR): Without reason
          2020-01-26 09:45:16.102 - error: host.dragon Caught by controller[0]: ReferenceError: fndest is not defined
          2020-01-26 09:45:16.102 - error: host.dragon Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at Array.forEach ()
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
          2020-01-26 09:45:16.103 - error: host.dragon Caught by controller[0]: at emitOne (events.js:116:13)
          2020-01-26 09:45:16.103 - info: host.dragon instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
          • crunchipC Abwesend
            crunchipC Abwesend
            #76
            nachdem ich den tr-64 wieder installiert habe und zugleich der community gelöscht wurde, taucht dieser noch
            --siehe screen unten--
            vom Typ meta auf. Ist das Korrekt?
            Desweiteren auch gleich mal die Frage, da auch der web.0 seit Ewigkeiten steht.
              Aktuelle Test Version 3.0.0
              Veröffentlichungsdatum 24.01.2020
              Github Link https://github.com/iobroker-community-adapters/ioBroker.tr-064
              der Adapter ist zurück unter seinem "alten" Namen und tr-064-community ist damit leider wieder "tod". Die hohe Anzahl an bestehenden Usern die immer noch die alte Version nutzen (600 User auf Community Version, ca. 11k auf originaler Version) haben diesen Schritt gerechtfertigt!
              Nun zum Release:
              3.0.0 (2020-01-24)
              • (Apollon77) Switch Name back to tr064 becaus ewe got it from npmjs
              • (maeb3) Enhance call handling and fix wrong data for currently active calls
              • (Apollon77) Remove unused state phonebook.ringing
              Happy Testing.
              #77
              @apollon77 auch hier:
              host.iobroker	2020-01-26 10:22:45.625	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
              host.iobroker	2020-01-26 10:22:45.625	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
              host.iobroker	2020-01-26 10:22:45.625	error	Caught by controller[0]: at Array.forEach (<anonymous>)
              host.iobroker	2020-01-26 10:22:45.625	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
              host.iobroker	2020-01-26 10:22:45.625	error	Caught by controller[0]: ReferenceError: fndest is not defined
                @Feuersturm korrekt. States werden erst angelegt wenn sie erstmalig relevant sind.
                ChaotC Offline
                ChaotC Offline
                Chaot
                #78
                @apollon77 Auch bei mir der gleiche Fehler:
                host.ioBroker	2020-01-26 10:34:25.536	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                host.ioBroker	2020-01-26 10:34:25.534	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                host.ioBroker	2020-01-26 10:34:25.532	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                host.ioBroker	2020-01-26 10:34:25.532	error	Caught by controller[0]: ReferenceError: fndest is not defined
                tr-064.0	2020-01-26 10:34:24.489	error	at Parser.emit (events.js:198:13)
                tr-064.0	2020-01-26 10:34:24.489	error	at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                tr-064.0	2020-01-26 10:34:24.489	error	at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                tr-064.0	2020-01-26 10:34:24.489	error	at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                tr-064.0	2020-01-26 10:34:24.489	error	at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                tr-064.0	2020-01-26 10:34:24.489	error	at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                tr-064.0	2020-01-26 10:34:24.489	error	at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                tr-064.0	2020-01-26 10:34:24.489	error	at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                tr-064.0	2020-01-26 10:34:24.489	error	at Array.forEach (<anonymous>)
                tr-064.0	2020-01-26 10:34:24.489	error	at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                tr-064.0	2020-01-26 10:34:24.489	error	(2897) ReferenceError: fndest is not defined
                tr-064.0	2020-01-26 10:34:24.487	error	(2897) uncaught exception: fndest is not defined
                wenn ich die Rufweiterleitungsoptionen aktiv habe.
                  Nun zum Release:
                  3.0.0 (2020-01-24)
                  Happy Testing.
                  vauvau07V Online
                  vauvau07V Online
                  vauvau07
                  #79
                  @apollon77
                  Mit Rufweiterleitungsoptionen gleicher Fehler
                  Gruß Volkmar
                  • apollon77A Offline
                    #80
                    Prüfen und fixen wir. Danke
                      Tom63
                      #81
                      Update auf 3.1.1.
                      Zunächst erst einmal vielen Dank, dass Ihr Euch diesem Adapter gewidmet habt.
                      Ich habe meinen IOBroker auf einem Raspi 4 mit 4GB laufen. Bisher fiel der alter TR-064 sporadisch aus und somit war er mir nicht zuverlässig. Immer musste ich den npm SOEF im entsprechenden Ordner manuell nachinstallieren. Aber dann funktionierte er, vor allem die WLAN Erkennung.
                      Nun kamen mehrere Adapterversionen hinter einander. Ich habe aus dem latest Stand diese als normale Updates installiert, schien auch alles super zu laufen, Geräte Erkennung usw. ohne Probleme.
                      Gestern Abend dann stellte ich fest, dass mein Scribt zur Lichtsteuerung in Abhängigkeit zum WLAN des Fernsehers nicht mehr reagierte.
                      Ich stellte fest, alle Geräte im Device bleiben Active true egale ob im WLAN angemeldet oder nicht.
                      Auch den Adapter 3.1.0 deinstallieren funktionierte gestern nicht, es blieb im Scribt hängen.
                      Heute stellte ich in diesem aktuellen Forum fest, hier bin ich nicht alleine.
                      Habe zunächst die Instanz gelöscht, dann den ganzen Adapter und anschließend den IOBroker offline per Update aktualisiert. Jetzt war der aktuelle Adapter 3.1.1 als letzte Version unter latest auch gelistet.
                      Ich habe ihn installiert, die Geräte erneut eingelesen.
                      Die WLAN-Abschaltung reagiert sehr langsam - dachte erst gar nicht. Hatte mein Handy mal abgemeldet - keine Reaktion.
                      Nun mal meine Feststellung als Hinweis für die Entwicklung...
                      In meiner Fritzbox 7490 kann man ja alle Geräte unter Heimnetz anzeigen lassen. Hier wird unter
                      aktive Verbindungen und ungenutzte Verbindungen unterschieden.
                      Die Fritzbox schmeißt mein Handy erst nach ca. 10 Minuten aus der aktiven Verbindung in die ungenutzte Verbindung.
                      Genau diesen Vorgang habt ihr in State active des Devices hinterlegt.
                      Ist es möglich aus dem TR-064 zu dem Device auch die Eigenschaften des aktuellen Zustandes auszuwerten?
                      Hier sind die Angaben zum aktuellen WLAN eingetragen, also welches Netz und wie hoch die Übertragungsrate ist.
                      Bei LAN- Anschlüssen steht dort aber auch nichts weiter drin.
                      Nur dieser Wert ist für die aktuelle Anbindung im WLAN der einzige schnelle Trigger beim Abmelden.
                      Insgesamt bin ich jetzt aber erst mal sehr dankbar und hoffe der weiteren Entwicklung geholfen zu haben.
                      Vielen Dank und macht weiter - es macht mir sogar Spaß beim ausprobieren !!!
                      Technik kann auch Funktionieren ohne Cloud ;)
                      • F Offline
                        frankyboy73
                        #82
                        Hi, 3.1.1 läuft bei mir, Zustände Callmonitor und Devices werden passend aktualisiert. Zu Rufweiterleitung kann ich nichts sagen, da ich die nicht verwende.
                        Allerdings wurde mir die 3.1.1, auch mit Latest, nicht angezeigt, als verfügbare Version stand bei mir nur die 0.4.18.
                        Ich habe die Instanz und den Adapter dann gelöscht und per GitHub Link die aktuelle Version eingespielt. Installierte Version ist jetzt 3.1.1, Verfügbare Version steht aber immer noch auf 0.4.18
                        Schöne Grüße Frank
                          @FredF Bitte nochmal retesten!
                          FredFF Online
                          FredFF Online
                          FredF
                          Most Active Forum Testing
                          schrieb am zuletzt editiert von FredF
                          #83
                          Update gemacht. Die device active states ändern sich nun.
                          Die Instanz wird allerdings nicht grün.
                          2020-01-26 12:09:19.022 - info: tr-064.0 (26474) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
                          2020-01-26 12:09:19.494 - error: tr-064.0 (26474) uncaught exception: fndest is not defined
                          2020-01-26 12:09:19.494 - error: tr-064.0 (26474) ReferenceError: fndest is not defined
                          at Array.forEach ()
                          at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                          2020-01-26 12:09:19.998 - info: tr-064.0 (26474) terminating
                          2020-01-26 12:09:19.999 - info: tr-064.0 (26474) Terminated (NO_ERROR): Without reason
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                          2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
                          2020-01-26 12:09:21.108 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                          2020-01-26 12:09:21.108 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
                          2020-01-26 12:09:51.128 - info: host.ioBrokerLife instance system.adapter.tr-064.0 started with pid 26845
                          2020-01-26 12:09:52.417 - info: tr-064.0 (26845) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
                          2020-01-26 12:09:52.928 - error: tr-064.0 (26845) uncaught exception: fndest is not defined
                          2020-01-26 12:09:52.929 - error: tr-064.0 (26845) ReferenceError: fndest is not defined
                          at Array.forEach ()
                          2020-01-26 12:09:53.432 - info: tr-064.0 (26845) terminating
                          2020-01-26 12:09:53.433 - info: tr-064.0 (26845) Terminated (NO_ERROR): Without reason
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                          2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
                          2020-01-26 12:09:53.955 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                          2020-01-26 12:09:53.955 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
                          Edit: komplett deinstalliert und neu installiert. Instanz grün 👍
                          Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird
                          • SBorgS Offline
                            SBorgS Offline
                            SBorg
                            #84
                            @apollon77 Da hat sich wohl ein Fipptehler eingeschlichen. Lt. Log:
                            Sollte wohl" tr-064" heißen, nicht "tr-O64" ;)
                            LG SBorg ( SBorg auf GitHub)
                            • X Offline
                              X Offline
                              Xyolyp
                              #85
                              Version 3.1.1 startet bei mir leider nicht.
                              JS Controller 2.2.8
                                Nun zum Release:
                                3.0.0 (2020-01-24)
                                Happy Testing.
                                sigi234S Online
                                sigi234S Online
                                #86
                                @apollon77
                                3.1.1 läuft. Adapter Grün, kein Fehler im Log, DP tr-064.0.callmonitor.ringing funktioniert. Rufumleitung nicht aktiviert.
                                • SBorgS SBorg
                                  #87
                                  @SBorg ne kein Schreibfehler. Eine lib heißt so
                                  • T Tom63
                                    Update auf 3.1.1.
                                    #88
                                    @Tom63 bitte GitHub issue als Feature request anlegen. War schon so mehr so mit dem verzögerten. Was steht denn bei der verbindungsqualität wenn das Handy weg ist?
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      schrieb am zuletzt editiert von SBorg
                                      #89
                                      Habe ich eben auch gemerkt ^^
                                      Er läuft aber nicht:
                                      host.Ubuntu	2020-01-26 13:04:02.512	error	Caught by controller[0]: Error: Cannot find module './tr-064'
                                      Dort liegt kein tr-O64. Ein Verzeichnis höher schon.
                                      EDIT Der Code-Tag macht doch tatsächlich aus O64 ein 064 :(
                                      • smarteuleS Offline
                                        smarteuleS Offline
                                        smarteule
                                        #90
                                        ich bin zwar Anfänger, aber ich möchte Euch mitteilen, dass ich mit dem tr064 ebenfalls Probleme bei der Einstellung bzw. Hakensetzung "Rufweiterleitung verwenden" habe. Wenn der Haken raus ist, bleibt die Inatnz grün. Ist er drin, bleibt die Instanz rot und im Log erscheint folgende Meldung:
                                        tr064 v 3.1.1
                                        js.controller v 2.2.8
                                        node js v 10.18.1
                                        npm v 6.13.4
                                        • smarteuleS smarteule
                                          tr064 v 3.1.1
                                          node js v 10.18.1
                                          npm v 6.13.4
                                          sigi234S Online
                                          sigi234S Online
                                          #91
                                          @smarteule sagte in Test Adapter tr-064 v3.0.x:
