  4. Test Adapter tr-064 v3.0.x
tr-064
158 Beiträge 46 Kommentatoren 28.2k Aufrufe 44 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    schrieb am zuletzt editiert von JB_Sullivan
    #92
    Bei mir verbindet sich der Adapter nach dem Updaten von 3.1.0 auf 3.1.1 nicht mehr. Die Instanz flasht zwar kurzeitig grün auf, geht dann aber auf rot. (persönliche Informationen sind ge-X-t)
    host.GLT	2020-01-26 14:26:40.028	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.GLT	2020-01-26 14:26:40.028	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
    host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:304:18)
    host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\tr-O64\lib\Service.js:267:17
    host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:82:28
    host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at tr064Client.init.err (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:1144:27)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at new Deflections (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:21:10)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Deflections.init (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:156:17)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at getFunctions (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:12)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at ar.forEach.fn (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:37)
    host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: ReferenceError: fndest is not defined
    tr-064.0	2020-01-26 14:26:39.822	debug	(3364) Phonebook 0: {"NewPhonebookName":"Telefonbuch","NewPhonebookExtraID":"","NewPhonebookURL":"http://xx.xxx.xxx.xxx:49000/phonebook.lua?sid=xxxxxxxxxxx&pbid=0"} / err=null
    tr-064.0	2020-01-26 14:26:39.799	debug	(3364) Phonebook.read: NewPhonebookList=0
    tr-064.0	2020-01-26 14:26:39.782	debug	(3364) Phonebook.read
    tr-064.0	2020-01-26 14:26:39.781	debug	(3364) getVoIPCommonAreaCode: 0xxxx
    tr-064.0	2020-01-26 14:26:39.766	debug	(3364) getVoIPCommonCountryCode: 0049
    tr-064.0	2020-01-26 14:26:39.750	debug	(3364) forEachConfiguredDevice: i=3 xxxxxx active=0
    tr-064.0	2020-01-26 14:26:39.713	debug	(3364) forEachConfiguredDevice: i=2 xxxxxx active=1
    tr-064.0	2020-01-26 14:26:39.682	debug	(3364) forEachConfiguredDevice: i=1 xxxxxx active=1
    tr-064.0	2020-01-26 14:26:39.594	debug	(3364) forEachConfiguredDevice: i=0 xxxxxx active=1
    Wie @FredF oben geschrieben hat - bei mir das gleiche
    "Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird"
    • apollon77A Offline
      #93
      Mit der 3.1.2 die gerade auf GitHub und npm gelandet ist (und bald im Ltest auftauchen sollte) müsste das Rufumleitungsthema wieder gehen
      vauvau07V 1 Antwort Letzte Antwort
      • apollon77A apollon77
        vauvau07V Online
        vauvau07V Online
        vauvau07
        #94
        @apollon77 sagte in Test Adapter tr-064 v3.0.x:
        3.1.2
        bei mir jetzt alles im grünen Bereich (v3.1.2)
        Gruß Volkmar
          #95
          AM besten gleich auf die 3.1.3 gehen ... hab noch was gefunden und gefixt
          J FredFF 2 Antworten Letzte Antwort
            Jan1
            #96
            @apollon77
            läuft👍
            • H Offline
              Hardy6
              #97
              Mein Ergebnis von: TR-064 -> Update 3.1.3 : noch mit Fehlern
              $ ./iobroker upgrade tr-064
              Update tr-064 from @3.1.1 to @3.1.3
              NPM version: 6.11.3
              npm install iobroker.tr-064@3.1.3 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
              npm
               ERR! code ENOENTnpm ERR! syscall renamenpm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15bnpm ERR! dest C:\Program Files\iobroker\SmartHome\node_modules\yargsnpm ERR! errno -4058
              npm ERR!
               enoent ENOENT: no such file or directory, rename 'C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15b' -> 'C:\Program Files\iobroker\SmartHome\node_modules\yargs'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
              npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-01-26T14_30_53_253Z-debug.log
              ERROR: host.IT-SERVER(SmartHome) Cannot install iobroker.tr-064@3.1.3: 4294963238
              Ich habe alles soweit auf aktuellen Stand (lastest), ioBroker 2.2.8
              bis auf
              Node.js 10.17
              Admin 3.6.12
              weil beim letzten update Versuch nix mehr ging(jedenfalls für mich als Neueinstiger war das nicht mehr ohne Neuinstallation des kompletten ioBroker in Funktion zu bringen.
              Gruß,...
              Hartmut
              • H Hardy6
                NPM version: 6.11.3
                npm
                npm ERR!
                bis auf
                Node.js 10.17
                Admin 3.6.12
                Gruß,...
                Hartmut
                #98
                @Hardy6 Lass mal den Installation Fixer laufen bitte. Der Fehler hat mit dem Adater nix zu tun. Dein npm meckert wegen was ...
                H 1 Antwort Letzte Antwort
                  FredFF Online
                  FredFF Online
                  FredF
                  Most Active Forum Testing
                  #99
                  @apollon77
                  läuft
                    Hardy6
                    #100
                    @apollon77 Wie? iobroker fix ? / vorher stoppen nehme ich an
                      Aktuelle Test Version 3.0.0
                      Veröffentlichungsdatum 24.01.2020
                      Github Link https://github.com/iobroker-community-adapters/ioBroker.tr-064
                      der Adapter ist zurück unter seinem "alten" Namen und tr-064-community ist damit leider wieder "tod". Die hohe Anzahl an bestehenden Usern die immer noch die alte Version nutzen (600 User auf Community Version, ca. 11k auf originaler Version) haben diesen Schritt gerechtfertigt!
                      Nun zum Release:
                      3.0.0 (2020-01-24)
                      • (Apollon77) Switch Name back to tr064 becaus ewe got it from npmjs
                      • (maeb3) Enhance call handling and fix wrong data for currently active calls
                      • (Apollon77) Remove unused state phonebook.ringing
                      Happy Testing.
                      #101
                      @apollon77 3.1.3 benimmt sich unauffällig bis jetzt 😁👍👍
                      Dankeschön 🙂
                      Homer.J.H 1 Antwort Letzte Antwort
                        Dankeschön 🙂
                        Homer.J.H Offline
                        Homer.J.H Offline
                        Homer.J.
                        schrieb am zuletzt editiert von Homer.J.
                        #102
                        Bei mir läuft jetzt die Anwesenheit wieder nicht mehr.
                        Kommando zurück Datenpunkte mal alle gelöscht und funktioniert. 😊
                        • H Hardy6
                          #103
                          @Hardy6 ja stoppen, dann iobroker fix ausführen
                          • maeb3M Offline
                            maeb3M Offline
                            maeb3
                            #104
                            bin jetzt auch auf 3.1.3.
                            bisher keine Auffälligkeiten
                            virtuelle Maschine: linux debian strech
                            js-controller 2.1.1
                            nodejs 8.16.0 (Aktualisierung werde ich nächstes Wochenende mal angehen)
                            npm 6.13.0
                            • MatzebhvM Offline
                              MatzebhvM Offline
                              Matzebhv
                              #105
                              Hier läuft die 3.1.3 jetzt auch ohne Fehler.
                              Matze
                                Hardy6
                                schrieb am zuletzt editiert von Hardy6
                                #106
                                @apollon77 iobroker fix -> erl -> thx 😀
                                process exited with code 0
                                Adapter läuft und sieht "aufgeräumter aus" 👍
                                EIn Wunsch: Die Reihenfolge der Geräte sortiert automatisch nach IP in der Liste wäre deutlich leichter zur Erkennung bei vielen Geräten was schon drin ist.
                                • H Hardy6
                                  #107
                                  @Hardy6 bitte ein GitHub issue als Feature enhancement anlegen.
                                  • X Offline
                                    X Offline
                                    Xyolyp
                                    #108
                                    Die 3.1.3 funktioniert bei mir wie es vor den Updates funktioniert hat. Leider habe ich bei den Anrufweiterleitungen nach wie vor nur einen Datenpunkt tr-064.0.callForwarding und leider keine untergeordneten Datenpunkte, obwohl ich eine Anrufweiterleitung (ohne Zeitplan und deaktiviert) in der Fritzbox konfiguriert habe.
                                    • X Xyolyp
                                      ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      #109
                                      @Xyolyp Hast du mal versucht die Weiterleitung kurz zu aktivieren?
                                      Vielleicht wird dann der DP angelegt.
                                      X 1 Antwort Letzte Antwort
                                      • ChaotC Chaot
                                        X Offline
                                        X Offline
                                        Xyolyp
                                        #110
                                        @Chaot ich habe gerade die Weiterleitung (sofort zum Anrufbeantworter) aktiviert und die Instanz neugestartet: keine Änderung. Also habe ich den Datenpunkt gelöscht und die Instanz erneut neugestartet: es wurde leider wieder nur der eine Datenpunkt angelegt.
                                        • X Xyolyp
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #111
                                          @Xyolyp Hast du Recht. Ich nutze zwar keine Weiterleitung, aber testweise mal versucht verhält sich das bei mir genauso.
                                          Ich habe 3 Datenpunkte 0,1,2 die alle drei auf true stehen und keine weitere Veränderung oder Eintragung.
                                          Box ist eine 6591 (VF-Kabel-Box)
